90*130
90*130
    SANDUN(叁盾)
    说明书 90*130
90*130 数据手册
快速指南_105g铜版纸_70* 110mm_单黑印刷_左右对折 展开尺寸:140*110mm 折叠尺寸:70*110mm 公差:+/-2mm Technical Specs Items Specification Operating System Android 11 CPU Quad-core@2.0Ghz Memory Camera 2GB RAM + 16GB ROM (LPDDR3) Main: 10.1”, 800*1280 with Touch Panel Second: 4”, 480*800 without Touch Panel 0.3M FF (for QR code scanning) Printer 3 inch Thermal Printer Display Cellular Network Support 2G/3G/4G WIFI IEEE 802.11a/b/g/n/ac(2.4G/5G) Communication Bluetooth 5.0, support Ethernet NFC Interface Battery Warning Support, non-Financial 4*USB-A、1*RJ45、1*RS232、1*RJ12 Optional ATTENTION  Read all instructions and safety information before use to avoid injury.  The limit operating ambient temperature of the device declared by the manufacturer is -10~45°C. Battery safety  Charge battery only at ambient temperatures ranging from 0~40°C.  Dispose of used batteries according to manufacturer’s instructions.  Danger of explosion if battery is incorrectly replaced. Replace only with the same or equivalent type of battery recommended by the manufacturer. Statement  The equipment damage caused by natural disasters, falling, self disassembly and non-compliance with the operation specifications is not covered by the free warranty.  Some details of this document may be inconsistent with the real object due to the update iteration of the product. Please take the real object as the standard, and our company reserves the right to interpret this document. D1 Quick Guide Diagram Reset Button Used for restart device instantly as soon as you press the reset button which locates behind the battery cover when device is crashed. 4” Second Display Scan Window Light Bar Printer Button Interfaces Assemble Interfaces assemble includes USB type-A for connecting standard universal USB peripherals, micro USB for debugging, Ethernet port for data transmission, RJ12 for connecting cash box as well as DC jack for charging. 80mm Autocut Printer 10.1” Main Display Printer Button Card selection instruction 15.00mm Speaker 24.00 mm Product Non-Financial NFC 11.00 mm 9.00 mm micro SD nano SIM Interface Assemble Wire Bcukle micro SD Printer instructions nano SIM Display Main Display is setting for merchants to do commercial settlement. Second Display is setting for show some business information such as the amount of goods you need to pay or some fashionable advert. Scan Window Used for capturing and identifying QR code when equipped with decode algorithm. Light Bar Served as the indicator to show the state of scanning.It will be green when code scanning is successful but turn to red while failed. Non-Financial NFC Card Reader Used for sensing chip and acquire data through contactless way. Power Button Used for change the running states of device, such as pressing 2~3 seconds to power on/off or screen capture and pressing 10 seconds to restart automatically when device is crashed. Printer Button Served as the shortcut button to open the printer cover and feed the new paper roll as you need. 1) Support 3 inch thermal paper roll with specification of 80*60mm (w*φ) 2) Feed the paper correctly into the paper container in the direction as shown, and pull some paper outside the cutter; Note: If the printed paper is blank, please check whether the pap-er roll has been installed in the correct direction. Package List NO. Items list 1 Device Description Default 2 Charger 24V/2.5A European Standard 3 User manual Neutral
90*130 价格&库存
很抱歉,暂时无法提供与“90*130”相匹配的价格&库存,您可以联系我们找货
