AC0805FR-7W2KL
AC0805FR-7W2KL
    YAGEO(国巨)
    贴片电阻 0805 2KΩ ±1% 1/4W ±100ppm/℃
AC0805FR-7W2KL 数据手册
DATA SHEET THICK FILM CHIP RESISTORS AUTOMOTIVE GRADE AC series ±5%, ±1%, ±0.5%, ±0.1% (LOW TCR) Sizes 0201/0402/0603/0805/1206/ 1210/1218/2010/2512 Product specification – November 17, 2023 V.11 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount AC 0201 to 2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AC0201 to AC2512 chip resistors with leadfree terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS ⚫ ⚫ All general purpose applications Car electronics, industrial application FEATURES ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ AEC-Q200 qualified Moisture sensitivity level: MSL 1 AC series soldering is compliant with J-STD-020D Halogen free epoxy RoHS compliant - Products with lead-free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS Reduce environmentally hazardous waste High component and equipment reliability The resistors are 100% performed by automatic optical inspection prior to taping. GLOBAL PART NUMBER AC XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201/ 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE B = ± 0.1% for low TCR F = ± 1% D = ± 0.5% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE = Base on spec E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel & Standard power 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE 1Ω to 22 MΩ There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter B is for bulk AOI ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76Ω) 1R = 1Ω 1R5 = 1.5Ω 9R76 = 9.76Ω XXRX (10 to 97.6Ω) 10R = 10Ω 97R6 = 97.6Ω XXXR (100 to 976Ω) 100R = 100Ω 976R = 976Ω XKXX (1 to 9.76 KΩ) 1K = 1,000Ω 9K76 = 9760Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000Ω 9M76= 9,760,000Ω XXMX (10 MΩ) 10M = 10,000,000Ω O RDERING EXAMPLE The ordering code for an AC0402 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel is: AC0402FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process". 2. On customized label, "LFP" or specific symbol can be printed. 3. AC series with 0.5% tolerance is also available. For further information, please contact sales. www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 MARKING AC0201 / AC0402 No marking Fig. 1 AC0603 / AC0805 / AC1206 / AC1210 / AC2010 / AC2512 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 2 Value=10 KΩ AC0603 YNSC037 Fig. 3 E-24 series: 3 digits, ± 1% & ± 0.5% One short bar under marking letter Value = 24 Ω E-96 series: 3 digits, ± 1% & ± 0.5% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AC0805 / AC1206 / AC1210 / AC2010 / AC2512 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ AC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ YNSC103 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 7 Value = 10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AC series is the same as RC series. www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 CONSTRUCTION The resistors are constructed on top of an automotive grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a protective glass. The composition of the glaze is adjusted to give the approximately required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added, as shown in Fig.8. OUTLINES Fig. 8_1 Fig. 8_2 Chip resistor outlines AC2010/ 2512 double power chip resistor outlines DIMENSIONS Table 1 For outlines, please refer to Fig. 9 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AC0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03 0.12 ± 0.05 0.15 ± 0.05 AC0402 1.00 ± 0.05 0.50 ± 0.05 0.32 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AC0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AC0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 AC1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.45 ± 0.20 AC1210 3.10 ± 0.10 2.60 ± 0.15 0.55 ± 0.10 0.45 ± 0.15 0.50 ± 0.20 AC1218 3.10 ± 0.10 4.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 AC2010 5.00 ± 0.10 2.50 ± 0.15 0.55 ± 0.10 0.55 ± 0.15 0.55 ± 0.20 AC2512 6.35 ± 0.10 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 For dimension, please refer to Table 1 AC0201/0402 0603/0805/1206/1210/ 2010/2512 I1 AC1218 Side view for all type I1 I1 W W Fig. 9 Chip resistor dimensions H W I2 L L L YNSC096 www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AC0201 POWER 1/20 W Operating Max. Temperature Working Range Voltage -55°C to 155°C 25V Max. Dielectric Overload Withstanding Voltage Voltage 50V 50V Resistance Range Temperature Coefficient Jumper Criteria 5% (E24) 1Ω ≤ R ≤ 10Ω Rated Current 1Ω ≤ R ≤ 10MΩ -100/+350 ppm°C 0.5A 1% (E24/E96) 10Ω < R ≤ 10M Maximum 1Ω ≤ R ≤ 10MΩ ± 200 ppm°C Current 0.5% (E24/E96) 1.0A 10Ω ≤ R ≤ 1MΩ Jumper
AC0805FR-7W2KL
物料型号:YAGEO Phicomp 芯片电阻,型号从AC0201至AC2512。
器件简介:这些电阻器采用厚膜工艺制造,具有无铅端子,符合汽车级标准。
引脚分配:文档中没有明确提到引脚分配,但提到了电阻器的构造,包括内部金属电极和外部端子(Ni/亚光锡)。
参数特性: - 尺寸范围:0201至2512。 - 公差:±0.5%,±1%,±5%。 - 温度系数:根据规格书。 - 包装类型:纸带卷装或压花带卷装。 - 电阻值范围:1Ω至22MΩ。
功能详解: - 符合AEC-Q200标准。 - 湿度敏感度等级:MSL 1。 - 符合J-STD-020D的焊接标准。 - 无卤素环氧树脂,符合RoHS要求。
应用信息:适用于汽车电子、工业应用等一般用途。
封装信息:提供了不同尺寸的电阻器的详细尺寸信息,包括长度、宽度、高度以及标记层和保护玻璃的厚度。
电气特性:包括工作温度范围、最大电压、耐压、电阻范围、温度系数和额定电流等。
测试和要求:包括高温暴露、湿度抵抗、偏置湿度、操作寿命、耐焊热性、热冲击和静电放电等测试。
法律声明:Yageo对产品规格书的信息准确性不作保证,并且可能随时更改产品信息。Yageo不承担因使用其产品引起的任何责任。
AC0805FR-7W2KL 价格&库存
很抱歉,暂时无法提供与“AC0805FR-7W2KL”相匹配的价格&库存,您可以联系我们找货
AC0805FR-7W2KL
  • 1+0.699011+0.09040
  • 10+0.3145610+0.04068
  • 25+0.2306725+0.02984
  • 100+0.15204100+0.01967
  • 1000+0.109221000+0.01413
  • 5000+0.103025000+0.01333
  • 10000+0.0935810000+0.01211
  • 15000+0.0893915000+0.01156
  • 25000+0.0849325000+0.01099
  • 50000+0.0803950000+0.01040
库存:272
AC0805FR-7W2KL
    • 1+0.37380
    • 100+0.25300
    • 1000+0.17160
    • 2500+0.12220
    • 5000+0.08840
    库存:2920
    AC0805FR-7W2KL
    • 5000+0.109775000+0.01420
    • 10000+0.1003210000+0.01298
    • 15000+0.0957315000+0.01238
    • 25000+0.0907525000+0.01174
    • 35000+0.0879135000+0.01137
    • 50000+0.0852150000+0.01102
    库存:50384
    AC0805FR-7W2KL
    • 50+0.06049
    • 1000+0.04980
    • 2000+0.04905
    • 5000+0.04386
    库存:10650
    AC0805FR-7W2KL
      库存:30000
      AC0805FR-7W2KL
        • 1+0.26620
        • 500+0.08877
        • 2500+0.05918
        • 5000+0.04851
        库存:2837
        AC0805FR-7W2KL
        • 1+0.61088
        • 10+0.29346
        • 25+0.21417
        • 100+0.14122
        • 1000+0.10144
        • 5000+0.09572
        • 10000+0.08695
        • 15000+0.08306
        • 25000+0.07891
        • 50000+0.07465
        库存:272
