SLC05C – Bi-Direction ESD Protection Diode
Description
Design to protect voltage sensitive electronic components
from ESD and other transients. Excellent clamping capability, low
leakage, low capacitance and fast response time provide best in
class protection on designs that are exposed to ESD.
The combination of small size, low capacitance and high
level of ESD protection makes them a flexible solution for
applications such as HDMI, Display Port TM and MDDI interfaces. It
is designed to replace multilayer varistors (MLV) in consumer
equipment applications such as mobile phone, notebook, PAD, STB,
LCD TV etc.
Marking
Features
IEC61000-4-2 (ESD) ±30kV (Air), ±30kV (Contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
IEC61000-4-5 (Surge): 17A (8/20s)
350 Watts Peak Pulse Power per line (tp = 8/20s)
Protects one high speed I/O line
Low clamping voltage
Working voltage: 5.0V
Low leakage current
PDA
Portable electronics
Applications
Computers and peripherals
Digital cameras
Audio and video equipment
Cellular handsets and accessories
Maximum Rating
Parameter
Symbol
IEC61000-4-2 ESD Voltage – Air Mode
VESD(1)
IEC61000-4-2 ESD Voltage – Contact Mode
Limit
±30
±30
Unit
kV
Peak Pulse Power
PPP(2)
350
W
Peak Pulse Current
IPP(2)
17
A
Maximum Lead Solder Temperature (10 seconds duration)
TL
260
°C
Junction Temperature
TJ
-55~150
°C
Storage Temperature Range
Tstg
-55~150
°C
Note:
1. Device stressed with ten non-repetitive ESD pulses.
2. Non-repetitive current pulse 8/20s exponential decay waveform according to IEC61000-4-5.
3. All ratings are measured at environmental temperature of T A = 25°C unless otherwise noted.
新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan.
TEL: +886-3-5643931
FAX: +886-3-5644624
http://www.pttc.com.tw
Page: 1 of 5
2016/12/27
Rev: A
ESD Standards Compliance
IEC61000-4-2 Standard
Contact Discharge
JESD22-A114-B Standard
Air Discharge
ESD Class
Level
Test Voltage (kV)
Level
Test Voltage (kV)
1
2
1
2
2
4
2
4
3
6
3
8
4
8
4
15
Human Body Discharge Voltage (V)
0~249
1A
1B
1C
250~499
500~999
1000~1999
2
2000~3999
3A
3B
4000~7999
8000~15999
Electrical Parameters
Symbol
Parameter
VC
Clamping Voltage @ IPP
IPP
Peak Pulse Current
VBR
Breakdown Voltage @ IT
IT
Test Current
IR
Reverse Leakage Current @ VRWM
VRWM
Reverse Stand-off Voltage
Electrical Characteristics
Parameter
Symbol
Test Conditions
VRWM(1)
IR
VRWM = 5V
VBR
IT = 1mA
Breakdown Voltage
Clamping Voltage
Typical Capacitance
VC(2)
CJ
Min
Typ
Max
Unit
5.0
V
1
A
6.0
V
IPP = 1A
9.8
IPP = 17A
18.3
V
1.35
pF
VR = 0V, f = 1MHz
1.00
V
Note:
1.
2.
3.
Other voltages available upon request.
TEL: +886-3-5643931
FAX: +886-3-5644624
Page: 2 of 5
2016/12/27
Rev: A
Typical Characteristics
TEL: +886-3-5643931
FAX: +886-3-5644624
Page: 3 of 5
2016/12/27
Rev: A
SOD-323 Package Outline Dimensions
Symbol
Dimensions (mm)
Min
Max
A
Dimensions (inch)
Min
Max
1.000
0.039
A1
0.000
0.100
0.000
0.004
A2
0.800
0.900
0.031
0.035
b
0.250
0.350
0.010
0.014
c
0.080
0.150
0.003
0.006
D
1.200
1.400
0.047
0.055
E
1.600
1.800
0.063
0.071
E1
2.550
2.750
0.100
0.108
L
0.475 Ref.
0.019 Ref.
L1
0.250
0.400
0.010
0.016
0°
8°
0°
8°
SOD-323 Recommended Pad Layout
Note:
1. Controlling dimensions in millimeters
2. General tolerance: ±0.05mm
3. The pad layout is for reference purpose only
Notice
PTTC reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to
any product herein. PTTC does not assume any liability arising out of the application or use of any product herein.
TEL: +886-3-5643931
FAX: +886-3-5644624
Page: 4 of 5
2016/12/27
Rev: A
Tape and Reel Specifications
Package Type
A
B
C
d
E
F
P0
P
P1
W
SOD-323
1.48
3.3
1.25
1.50
1.75
3.50
4.00
4.00
2.00
8.00
Reel Option
D
D1
D2
G
H
I
W1
W2
7” Dia.
178.0
54.4
13.0
R78.0
R25.6
R6.5
9.5
12.3
*All Dimensions are in millimeters.
Packaging Information
Reel
Reel Size
BOX
Box Size
Carton
Carton Size
3,000 pcs
7 inch
TEL: +886-3-5643931
FAX: +886-3-5644624
Page: 5 of 5
2016/12/27
Rev: A
很抱歉,暂时无法提供与“SLC05C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.52715
- 100+0.43384
- 300+0.38718
- 3000+0.35057
- 6000+0.32260
- 9000+0.30856
