NUP2105LT1G
Transient Voltage Suppressor
Features
400 watts peak pulse power (tp = 8/20μs)
Response Time is Typically < 1 ns
Protects one bidirectional line or two unidirectional
lines
Working Voltages: 24V
Low clamping voltages
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 8A (8/20μs)
Mechanical Characteristics
Applications
JEDEC SOT-23 package
Automotive Networks
Molding compound flammability rating:
Control & Monitoring Systems
UL 94V-0
Portable Electronics
Marking : Marking Code
Set-Top Box
Packaging : Tape and Reel per EIA 481
Servers, Notebook, and Desktop PC
RoHS Compliant
Wireless Bus Protection
Circuit Diagram
Schematic & PIN Configuration
1
1
3
3
2
2
SOT-23 (Top View)
1/5
NUP2105LT1G
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power(tp=8/20μs)
PPP
450
Watts
Peak Pulse Current(tp=8/20μs)
IPP
8
A
Operating Temperature
TJ
-55 to + 125
TSTG
-55 to +150
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
Parameter
IPP
Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
I
IPP
IT
IR
VC VBR V RWM
Reverse Stand-Off Voltage
IR
IT
VRWM VBR VC
Reverse Leakage Current @ VRWM
VBR
Breakdown Voltage @ IT
IT
IPP
Test Current
Electrical Characteristics
NUP2105LT1G
Parameter
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
24
V
VBR
IT=1mA
26..7
IR
VRWM=24V, T=25℃
Clamping Voltage
VC
IPP=8A, tp=8/20μs
50
Dynamic Resistance1,2
RDYN
TLP=0.2/100ns
0.4
Ω
ESD Clamping Voltage1
VC
38.0
V
VC
43.0
V
Junction Capacitance
Cj
IPP = 4A,
tp = 0.2/100ns (TLP)
IPP = 16A,
Pin 1 to 3 or Pin 2 to 3
VR = 0V, f = 1MHz
V
25
200
nA
54
V
35
pF
Notes:1、TLP Setting:tp=100ns, tr=0.2ns, ITLP and VTLP sample window:t1=70ns to t2=90ns.
2、Dynamic resistance calculated from IPP=4A to IPP=16A using “Best Fit”
2/5
V
NUP2105LT1G
Typical Characteristics
Figure 2: Power Derating Curve
Figure 1: Peak Pulse Power vs. Pulse Time
Percent of Rated Power for Ipp
Ppp–Peak Pulse Power–Watts
10,000
450W 8/20µs
Waveform
1,000
100
10
110
100
90
80
70
60
50
40
30
1
10
100
1000
10000
td–Pulse Duration–µs
Ambient Temperature - TA (
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
Figure 3: Clamping Voltage vs. Peak Pulse
Current
1.1
1.0
F=1MHz
0.9
Cj(VR)/Cj(VR=0)
Clamping Voltage -Vc(V)
50
40
30
0.7
0.6
0.5
0.4
0.3
0.2
10
0.1
00
2
4
6
8
10
Peak Pulse Current -Ipp(A)
Reverse Voltage -VR(V)
Figure 5: 8/20µs Pulse Waveform
Figure 6: TLP I-V Curve
tr=8µs
110
80
70
60
50
40
Half Value Ipp/2
30
15
TLP Current (A)
Percent Ipp
90
Waveform
Paramters
tr=8µs
td=20µs
100
10
RDYN=0.40 Ohms
5
TLP
Parameters:
tp=100ns
tr=0.2ns
td=20µs
10
-5
Time (µs)
5 10 15 20 25 30 35 40 45 50 55 60
TLP Voltage (V)
3/5
NUP2105LT1G
Soldering Parameters
Reflow Condition
Pre Heat
Temperature Min (Ts(min))
Temperature Max (Ts(max))
Time (min to max) (ts )
Average ramp up rate (Liquidus Temp) (TL) to peak
TS(max) to TL——Ramp-up Rate
Temperature (TL) (Liquidus)
Reflow
Temperature (tL)
Peak Temperature (TP)
Pb – Free assembly
150°C
200°C
60 – 190 secs
5°C/second max
5°C/second max
217°C
60 – 150 seconds
260+0/-5 °C
Time within actual peak Temperature (tp )
20 – 40 seconds
Ramp-down Rate
Time 25°C to peak Temperature (TP)
Do not exceed
5°C/second max
8 minutes Max.
280°C
4/5
NUP2105LT1G
Outline Drawing – SOT-23
3
PACKAGE OUTLINE
1
D
2
SOT-23
3
DIMENSIONS
0.25
E1 E
SYMBOL
θ
1
e
b
e1
A
INCHES
A
MIN
0.90
MAX
1.15
A1
0.00
0.10
0.000
0.004
A2
0.60
0.70
0.0236
0.0275
b
0.30
0.50
0.012
0.020
c
L
2
MILLIMETER
MIN
0.035
MAX
0.045
c
0.08
0.15
0.003
0.006
D
2.80
3.00
0.110
0.118
E
2.25
2.55
0.089
0.100
E1
1.20
1.40
0.047
0.055
A2
e
A1
b
Z
M
C
e
INCHES
0.0374 BSC
e1
1.80
2.00
0.071
L
0.30
0.50
0.012
0.020
θ
0.079
Notes
DIMENSIONS
DIM
0.95 BSC
MILLIMETERS
M
0.0795
2.02
C
0.0315
0.80
Z
0.111
2.82
e
0.037 BSC
0.95 BSC
e1
0.075 BSC
1.9 BSC
b
0.0315
0.80
1. Dimensioning and tolerances per ANSI Y14.5M,
1985.
2. Controlling Dimension: Inches
3. Pin 3 is the cathode (Unidirectional Only).
4. Dimensions are exclusive of mold flash and metal
burrs.
e1
Marking Codes
Part Number
Marking Code
3
NUP2105LT1G
D24
1
2
Package Information
Qty:3k/Reel
5/5
很抱歉,暂时无法提供与“NUP2105LT1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30932
- 100+0.24711
- 300+0.21600
- 3000+0.18360
- 6000+0.16492
- 9000+0.15552
- 国内价格
- 1+0.15510
- 3000+0.13750
- 国内价格
- 1+0.19739
- 100+0.18339
- 300+0.16940
- 500+0.15540
- 2000+0.14840
- 5000+0.14420
