TMI3281
1MHz, 18V,2A Synchronous Step-Down Converter
FEATURES
GENERAL DESCRIPTION
The TMI3281 is a fully integrated, high–
efficiency 2.0A synchronous rectified
step-down converter. The TMI3281
operates at high efficiency over a wide
output current load range.
The TMI3281 has force PWM operation
mode and low EMI for light load
The TMI3281 requires a minimum number
of readily available standard external
components and is available in a 6-pin
SOT23 ROHS compliant package.
High Efficiency: Up to 95%@5V
1MHz Frequency Operation
2.0A Output Current
No Schottky Diode Required
3.5V to 18V Input Voltage Range
0.6V Reference
Slope Compensated Current Mode Control
for Excellent Line and Load Transient
Response
Integrated internal compensation
Stable with Low ESR Ceramic Output
Capacitors
Over Current Protection with Hiccup-Mode
Input over voltage protection(OVP)
Thermal Shutdown
Inrush Current Limit and Soft Start
Available in SOT23-6 Package
APPLICATIONS
Distributed Power Systems
Digital Set Top Boxes
Flat Panel Television and Monitors
Notebook computer
Wireless and DSL Modems
TYPICAL APPILCATION
C1
1
VIN
5
BS
VIN
LX
6
L1
VOUT
CIN
22μ
F
R1
4
ON /
OFF
EN
FB
3
COUT
GND
R2
2
22μ
F
Figure 1. Basic Application Circuit
TMI and SUNTO are the brands of TOLL microelectronic
TMI3281 V1.0
2017.11
www.toll-semi.com
www.suntosemi.com
1
TMI3281
ABSOLUTE MAXIMUM RATINGS (Note 1)
Parameter
Value
Unit
Input Supply Voltage ,EN
-0.3~23
V
LX Voltages
-0.3~23
V
FB Voltage
-0.3~25
V
BS Voltage
-0.6~25
V
Storage Temperature Range
-65~150
°C
Junction Temperature(Note2)
160
°C
Power Dissipation
600
mW
Lead Temperature(Soldering,10s)
260
°C
Over operating free-air temperature range (unless otherwise noted)
PACKAGE/ORDER INFORMATION
SOT23-6
Top Mark: T36XXX (T36: Device Code, XXX: Inside Code)
www.toll-semi.com
2
Part Number
Package
Top mark
Quantity/ Reel
TMI3281
SOT23-6
T36XXX
3000
www.suntosemi.com
TMI and SUNTO are the brands of TOLL microelectronic.
TMI3281 V1.0
2017.11
TMI3281
PIN FUNCTIONS
Pin
Name
Function
1
BS
2
GND
3
FB
4
EN
5
IN
Power supply Pin
6
LX
Switching Pin
Bootstrap. A capacitor connected between LX and BST pins is required to form a floating
supply across the high-side switch driver.
Ground pin
Adjustable version feedback input. Connect FB to the center point of the external resistor
divider.
Drive this pin to a logic-high to enable the IC. Drive to a logic-low to disable the IC and
enter micro-power shutdown mode.
Don’t floating this pin.
ESD RATING
Items
Description
Value
Unit
VESD
Human Body Model for all pins
±2000
V
JEDEC specification JS-001
RECOMMENDED OPERATING CONDITIONS
Items
Description
Voltage Range
IN
3.5
18
V
TA
Operating Temperature Range
-40
85
°C
TMI3281 V1.0
2017.11
Min
www.toll-semi.com
Max
Unit
www.suntosemi.com
3
TMI3281
ELECTRICAL CHARACTERISTICS (Note 3)
( VIN=12V ,VOUT=5V , TA = 25°C, unless otherwise noted.)
Parameter
Test Conditions
Input Voltage Range
Min
Typ
3.5
OVP Threshold
Max
Unit
18
V
19
UVLO Threshold
V
3.0
Supply Current in Shutdown
VEN =0
Regulated Feedback Voltage
TA = 25°C,3.5V≤VIN ≤18V
V
2
0.588
0.6
uA
0.612
V
High-Side Switch On-Resistance
120
mΩ
Low-Side Switch On-Resistance
80
mΩ
High-Side Switch Leakage Current
VEN=0V, VLX=0V
Upper Switch Current Limit
Minimum Duty Cycle
Oscillation Frequency
2.5
uA
A
1
MHz
92
Minimum On-Time
100
nS
Thermal Shutdown
160
Maximum Duty Cycle
VFB=0.6V
Note 1: Absolute Maximum Ratings are those values beyond which the life of a device may
be impaired.
Note 2: TJ is calculated from the ambient temperature TA and power dissipation PD
according to the following formula: TJ = TA + (PD) x (250°C/W).
Note 3: 100% production test at +25°C. Specifications over the temperature range are
guaranteed by design and characterization.
Note 4: Dynamic supply current is higher due to the gate charge being delivered at the
switching frequency.
www.toll-semi.com
4
www.suntosemi.com
TMI3281 V1.0
2017.11
TMI3281
OPERATION
Internal Regulator
The TMI3281 is a current mode step down DC/DC converter that provides excellent transient
response with no extra external compensation components. This device contains an internal,
low resistance, high voltage power MOSFET, and operates at a high 1MHz operating
frequency to ensure a compact, high efficiency design with excellent AC and DC
performance.
Error Amplifier
The error amplifier compares the FB pin voltage with the internal FB reference (VFB) and
outputs a current proportional to the difference between the two. This output current is
then used to charge or discharge the internal compensation network to form the COMP
voltage, which is used to control the power MOSFET current. The optimized internal
compensation network minimizes the external component counts and simplifies the control
loop design.
Internal Soft-Start
The soft-start is implemented to prevent the converter output voltage from overshooting
during startup. When the chip starts, the internal circuitry generates a soft-start voltage (SS)
ramping up from 0V to 0.6V. When it is lower than the internal reference (REF), SS overrides
REF so the error amplifier uses SS as the reference. When SS is higher than REF, REF regains
control.
Over-Current-Protection and Hiccup
The TMI3281 has cycle-by-cycle over current limit when the inductor current peak value
exceeds the set current limit threshold. Meanwhile, output voltage starts to drop until FB is
below the Under-Voltage (UV) threshold, typically 30% below the reference. Once a UV is
triggered, the TMI3281 enters hiccup mode to periodically restart the part. This protection
mode is especially useful when the output is dead-short to ground. The average short circuit
current is greatly reduced to alleviate the thermal issue and to protect the regulator. The
TMI3281 exits the hiccup mode once the over current condition is removed.
Startup and Shutdown
If both VIN and EN are higher than their appropriate thresholds, the chip starts. The
reference block starts first, generating stable reference voltage and currents, and then the
internal regulator is enabled. The regulator provides stable supply for the remaining
circuitries. Three events can shut down the chip: EN low, VIN low and thermal shutdown. In
the shutdown procedure, the signaling path is first blocked to avoid any fault triggering. The
COMP voltage and the internal supply rail are then pulled down. The floating driver is not
subject to this shutdown command.
TMI3281 V1.0
2017.11
www.toll-semi.com
www.suntosemi.com
5
TMI3281
FUNCTIONAL BLOCK DIAGRAM
Figure 2. TMI3281 Block Diagram
APPLICATION INFORMATION
Setting the Output Voltage
The external resistor divider is used to set the output voltage (see Typical Application on
page 1). The feedback resistor R1 also sets the feedback loop bandwidth with the internal
compensation capacitor. Choose R1 to be around 51kΩ for optimal transient response. R2 is
then given by:
R2
R1
Vout / VFB 1
www.toll-semi.com
6
www.suntosemi.com
Vout
R1(KΩ)
R2(KΩ)
5.1V
3.3V
1.8V
1.55V
1.25V
1.20V
1.05V
51
51
51
51
51
51
33
6.8
11.3
25.5
33
47
51
47
TMI3281 V1.0
2017.11
TMI3281
Inductor Selection
A 4.7μH to 22μH inductor with a DC current rating of at least 25% percent higher than the
maximum load current is recommended for most applications. For highest efficiency, the
inductor DC resistance should be less than 15mΩ. For most designs, the inductance value can
be derived from the following equation.
L
Vout (Vin Vout )
Vin I L fOSC
Where ΔIL is the inductor ripple current. Choose inductor ripple current to be approximately
30% if the maximum load current, 2A. The maximum inductor peak current is:
I L ( MAX ) I LOAD
I L
2
Under light load conditions below 100mA, larger inductance is recommended for improved
efficiency.
Output Capacitor Selection
The output capacitor (Cout) is required to maintain the DC output voltage. Ceramic, tantalum,
or low ESR electrolytic capacitors are recommended. Low ESR capacitors are preferred to
keep the output voltage ripple low. The output voltage ripple can be estimated by:
VOUT
VOUT VOUT
1
1
RESR
f S L VIN
8 f S C2
Where L is the inductor value and RESR is the equivalent series resistance (ESR) value of the
output capacitor. In the case of ceramic capacitors, the impedance at the switching
frequency is dominated by the capacitance. The output voltage ripple is mainly caused by the
capacitance. For simplification, the output voltage ripple can be estimated by:
VOUT
VOUT
VOUT
1
2
8 f S L C2 VIN
In the case of tantalum or electrolytic capacitors, the ESR dominates the impedance at the
switching frequency. For simplification, the output ripple can be approximated to:
VOUT
VOUT VOUT
1
RESR
f S L VIN
The characteristics of the output capacitor also affect the stability of the regulation system.
The TMI3281 can be optimized for a wide range of capacitance and ESR values.
Layout Consideration
PCB layout is very important to achieve stable operation. It is highly recommended to
duplicate EVB layout for optimum performance. If change is necessary, please follow these
guidelines for reference.
TMI3281 V1.0
2017.11
www.toll-semi.com
www.suntosemi.com
7
TMI3281
1) Keep the path of switching current short and minimize the loop area formed by Input
capacitor, high-side MOSFET and low-side MOSFET.
2) Bypass ceramic capacitors are suggested to be put close to the IN Pin.
3) Ensure all feedback connections are short and direct. Place the feedback resistors and
compensation components as close to the chip as possible.
4) VOUT, LX away from sensitive analog areas such as FB.
5) Connect IN, LX, and especially GND respectively to a large copper area to cool the chip to
improve thermal performance and long-term reliability.
www.toll-semi.com
8
www.suntosemi.com
TMI3281 V1.0
2017.11
TMI3281
PACKAGE INFORMATION
SOT23-6
Note:
1) All dimensions are in millimeters.
2) Package length does not include mold flash, protrusion or gate burr.
3) Package width does not include interlead flash or protrusion.
4) Lead popularity (bottom of leads after forming) shall be 0.10 millimeters max.
5) Pin 1 is lower left pin when reading top mark from left to right.
TMI3281 V1.0
2017.11
www.toll-semi.com
www.suntosemi.com
9
很抱歉,暂时无法提供与“TMI3281”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.64053
- 50+0.50882
- 600+0.39357
- 1200+0.38767
- 3000+0.35407
- 国内价格
- 5+0.70589
- 50+0.56074
- 150+0.48816
- 500+0.43373
- 3000+0.39021
- 6000+0.36839
- 国内价格
- 1+0.72940
- 200+0.50260
- 1500+0.45780
- 3000+0.42700
