ASMD1812-075
ASMD1812-075
    JDTFUSE(集电通)
    PTC Vmax=13.2V Imax=100A Ih=0.75A Pd+800mW FUSE1812
ASMD1812-075 数据手册
PRODUCT DATASHEET ASMD1812 Series Surface Mount PTC Devices ASMD1812 Series Surface Mount PTC Devices Description The ASMD1812 series provides surface mount resettable overcurrent protection with holding current from 0.1A to 3.5A. This series offers complete portfolio in terms of holding current and working voltage, and is suitable for wide range of applications. Features ● RoHS compliant and lead-free ● Low profile ● Halogen-free ● Fast response to fault current ● Compact design saves board space ● Compatible with high temperature solders Agency Approvals Agency Applications File Number pending pending ● USB hubs, ports and peripherals ● Motherboard USB & IEEE 1394 protection ● Set-top-box and HDMI ● Optical disk drives ● Game console port protection General electronics Regulation Standard 2002/95/EC EN14582 JDT FUSE Industrial Corp. www.jdtfuse.com Page 1/7 ASMD1812 Series Surface Mount PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Maximum Time To Trip Pd @25°C (A) @25°C (A) Typ. (W) Resistance Current (A) Time (Sec) R i min R1max (Ω) (Ω) ASMD1812-010 30.0 100 0.10 0.30 0.8 0.5 1.50 0.750 15.000 ASMD1812-014 60.0 100 0.14 0.34 0.8 1.5 0.15 0.650 6.000 ASMD1812-020 30.0 100 0.20 0.40 0.8 8.0 0.02 0.350 5.000 ASMD1812-030 30.0 100 0.30 0.60 0.8 8.0 0.10 0.250 3.000 ASMD1812-050 15.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.000 ASMD1812-050-30 30.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.000 ASMD1812-050-60 60.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.400 ASMD1812-075 13.2 100 0.75 1.50 0.8 8.0 0.20 0.090 0.450 ASMD1812-110 8.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 ASMD1812-110-16 16.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 ASMD1812-125 16.0 100 1.25 2.50 0.8 8.0 0.40 0.050 0.140 ASMD1812-150 8.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 ASMD1812-150-16 16.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 ASMD1812-160 8.0 100 1.60 2.80 0.8 8.0 1.00 0.030 0.130 ASMD1812-200 8.0 100 2.00 4.00 0.8 8.0 2.00 0.020 0.100 ASMD1812-260 8.0 100 2.60 5.00 0.8 8.0 2.50 0.015 0.050 ASMD1812-300 8.0 100 3.00 5.00 0.8 8.0 4.00 0.012 0.040 ASMD1812-350 6.0 100 3.50 6.00 2.0 10.0 4.00 0.008 0.030 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max Test= Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change   Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C JDT FUSE Industrial Corp. www.jdtfuse.com Page 2/7 ASMD1812 Series Surface Mount PTC Devices Thermal Derating Curve Percentage of Derated Current Derating Curves for ASMD1812 Series 160 140 120 100 80 60 40 20 0 -40 -20 0 20 40 60 80 Temperature (°C ) Average Time-Current Curve 100 0.30A TIME IN SECOND 0.50A 0.75A 10 1.00A 1.25A 1.50A 1 1.85A 2.0A 2.50A 0.1 2.60A 3.00A 3.50A 0.01 0.1 1 10 100 CURRENT IN AMPERES JDT FUSE Industrial Corp. www.jdtfuse.com Page 3/7 ASMD1812 Series Surface Mount PTC Devices Thermal Derading Chart Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) Model - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C ASMD1812-010 0.16 0.14 0.12 0.10 0.08 0.07 0.06 0.05 0.03 ASMD1812-014 0.23 0.19 0.17 0.14 0.12 0.10 0.09 0.08 0.06 ASMD1812-020 0.29 0.26 0.23 0.20 0.17 0.15 0.14 0.12 0.10 ASMD1812-030 0.44 0.39 0.35 0.30 0.26 0.23 0.21 0.18 0.15 ASMD1812-050 0.59 0.57 0.55 0.50 0.45 0.43 0.35 0.30 0.23 ASMD1812-075 1.10 0.99 0.87 0.75 0.63 0.57 0.49 0.45 0.35 ASMD1812-110 1.60 1.45 1.28 1.10 0.92 0.83 0.71 0.66 0.52 ASMD1812-110-16V 1.59 1.44 1.27 1.10 0.92 0.82 0.70 0.64 0.50 ASMD1812-125 2.00 1.75 1.52 1.25 1.00 0.95 0.90 0.75 0.53 ASMD1812-150 2.30 2.05 1.77 1.50 1.23 1.09 0.95 0.82 0.61 ASMD1812-150-16V 2.28 2.03 1.75 1.50 1.21 1.07 0.93 0.79 0.58 ASMD1812-160 2.10 1.96 1.88 1.60 1.26 1.12 0.98 0.84 0.63 ASMD1812-200 2.88 2.61 2.25 2.00 1.80 1.66 1.45 1.09 0.80 ASMD1812-260 3.90 3.42 2.96 2.60 2.33 2.07 1.94 1.35 1.00 ASMD1812-300 4.15 3.76 3.46 3.00 2.55 2.28 2.01 1.61 1.33 ASMD1812-350 4.84 4.39 4.04 3.50 2.98 2.66 2.35 1.88 1.55 Soldering Parameters TP 20~40 S TP 260 Ramp-up Profile Feature Critical Zone TL to TP TL 217 tL Tsmax Temperature (°C ) Preheat Tsmin Ramp-down ts Preheat 60~180 s 25 3℃/second mac. (Ts max to T p) 60~150 s 200 150 Average Ramp-Up Rate Pb-Free Assembly t 25°C to peak Time Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT FUSE Industrial Corp. www.jdtfuse.com -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Page 4/7 ASMD1812 Series Surface Mount PTC Devices Physical Dimensions(mm.) A Model B C D E Min. Max. Min. Max. Min. Max. Min. Min. ASMD1812-010 4.37 4.73 3.07 3.41 0.50 1.00 0.30 0.25 ASMD1812-014 4.37 4.73 3.07 3.41 0.50 1.00 0.30 0.25 ASMD1812-020 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 ASMD1812-030 4.37 4.73 3.07 3.41 0.50 1.00 0.30 0.25 ASMD1812-050 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 ASMD1812-050-30V 4.37 4.73 3.07 3.41 0.70 1.30 0.30 0.25 ASMD1812-050-60V 4.37 4.73 3.07 3.41 1.10 1.80 0.30 0.25 ASMD1812-075 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 ASMD1812-110 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 ASMD1812-110-16V 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 ASMD1812-125 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 ASMD1812-150 4.37 4.73 3.07 3.41 0.40 1.20 0.30 0.25 ASMD1812-150-16V 4.37 4.73 3.07 3.41 0.40 1.20 0.30 0.25 ASMD1812-160 4.37 4.73 3.07 3.41 0.40 1.20 0.30 0.25 ASMD1812-200 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 ASMD1812-260 4.37 4.73 3.07 3.41 0.50 1.50 0.30 0.25 ASMD1812-300 4.37 4.73 3.07 3.41 0.50 1.50 0.30 0.25 ASMD1812-350 4.37 4.73 3.07 3.41 0.50 1.50 0.30 0.25 Termination Pad Characteristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. Packaging Quantity and Marking 3.2±0.1 Part Number 3.2±0.1 SMD812 Series Quantity 1,500 pcs/reel Tape & reel packaging per EIA481-1 1.78±0.1 JDT FUSE Industrial Corp. www.jdtfuse.com 1.78±0.1 Page 5/7 ASMD1812 Series Surface Mount PTC Devices Tape And Reel Specifications (mm) Governing Specifications EIA 481-1 W 12 ± 0.3 P0 4.0 ± 0.10 P1 8.0 ± 0.10 P2 2.0 ± 0.05 A0 3.5 ± 0.10 B0 5.1 ± 0.10 B1max. 5.9 D0 1.50 + 0.1, -0 F 5.5 ± 0.05 E1 1.75 ± 0.10 E2min. 10.25 T 0.6 T1max. 0.1 K0 0.9 ± 0.1 Leader min. 390 Trailer min. 160 Reel Dimensions   A max. 178 N min. 60 W1 12.4 ± 0.5 W2 18.4 Storage And Handling ● Storage conditions:40°C max, 70% R.H. ● Devices may not meet specified performance if storage conditions are exceeded.Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com P1 P2 D0 P0 E1 F W T D2 K0 A0 B0 H W4 W3 D C W2 W F W1 H1 Page 6/7 ASMD1812 Series Surface Mount PTC Devices Part Number System ASMD 1812 - Special Voltage Rating(Optional) Holding Current Rating Device Dimensions: Length/width(Unit:1/100 inch) Size 4532 mm / 1812 inch Surface Mount Device Cross Reference Cross Reference Model Tyco / PolySwitch® Littelfuse / POLY-FUSE® Polytronics / EVERFUSE® ASMD1812-010 miniSMDC010F 1812L010 SMD1812P010TF ASMD1812-014 -miniSMDC014F 1812L014 SMD1812P014TF ASMD1812-020 miniSMDC020F 1812L020 SMD1812P020TF ASMD1812-030 - 1812L035 SMD1812P030TF ASMD1812-050 miniSMDC050F 1812L050 SMD1812P050TF ASMD1812-050-30V miniSMDC050F 1812L050/30 SMD1812P050TF/30 ASMD1812-050-60V - - - ASMD1812-075 miniSMDC750F 1812L075 SMD1812P075TF ASMD1812-110 miniSMDC110F 1812L110 SMD1812P110TF ASMD1812-110-16V miniSMDC110F/16 1812L110/16 SMD1812P110TF/16 ASMD1812-125 miniSMDC125F 1812L125 SMD1812P125TF ASMD1812-150 miniSMDC150F 1812L150 SMD1812P150TF ASMD1812-150-16V miniSMDC150F/12 1812L150/12 SMD1812P150TF/12 ASMD1812-160 miniSMDC160F 1812L160 SMD1812P160TF ASMD1812-200 miniSMDC200F 1812L200 SMD1812P200TF ASMD1812-260 miniSMDC260F 1812L260 SMD1812P260TF ASMD1812-300 miniSMDC300F 1812L300 SMD1812P300TF ASMD1812-350 - - - “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com Page 7/7
ASMD1812-075
物料型号:ASMD1812系列
器件简介:提供0.1A至3.5A的保持电流,适用于广泛的应用领域。
引脚分配:文档中没有提供具体的引脚分配图,但提到了表面贴装。
参数特性: - 符合RoHS和无铅标准 - 低高度 - 无卤素 - 对故障电流响应快 - 紧凑设计节省板空间 - 兼容高温焊接
功能详解: - 提供过电流保护,具有自动重置功能 - 工作电压和保持电流有多种选择 - 快速响应故障电流 - 环境规格包括被动老化、湿度老化、热冲击、耐溶剂、振动等测试
应用信息: - 适用于USB集线器、端口和外围设备 - 用于主板USB和IEEE 1394保护 - 机顶盒和HDMI - 光盘驱动器 - 游戏控制台端口保护 - 一般电子产品
封装信息: - 提供了详细的物理尺寸和标记信息 - 端子垫特性包括镀锡镍铜材料,满足EIA规范RS186-9E和ANSI/J-STD-002第3类 - 包装数量和标记,例如SMD812系列每卷1500件
焊接参数: - 提供了推荐的焊接方法和参数,包括预热、时间、峰值温度等
存储和处理: - 存储条件为最高40°C,70%相对湿度 - 如果超出存储条件,设备可能无法满足规定的性能
交叉参考: - 提供了与Tyco/PolySwitch、Littelfuse/POLY-FUSE、Polytronics/EVERFUSE等品牌的交叉参考型号。
ASMD1812-075 价格&库存
很抱歉,暂时无法提供与“ASMD1812-075”相匹配的价格&库存,您可以联系我们找货
ASMD1812-075
  • 10+0.30489
  • 100+0.24103
  • 300+0.20909
  • 1500+0.18514
  • 4500+0.16595
  • 10500+0.15634
库存:1595
ASMD1812-075
  • 10+0.72300
  • 100+0.43120
  • 500+0.30190
  • 1500+0.21560
  • 3000+0.20480
  • 15000+0.18980
库存:31226
ASMD1812-075
  • 10+0.23249
  • 100+0.21749
  • 500+0.20249
  • 2000+0.18000
  • 5000+0.17250
  • 10000+0.16800
库存:192
