RDA5820NS
RDA5820NS
    RDA(锐迪科)
    QFN20_3X3MM_EP
    单片广播调频收发器,1.8~5.5V,QFN20_3X3MM_EP
RDA5820NS 数据手册
RDA5820NS SINGLE-CHIP BROADCAST FM TRANSCEIVER 1 Rev.1.1–Mar.2011 General Description The RDA5820NS is the newest generation single-chip broadcast FM receive/transmit tuner with fully integrated synthesizer, IF selectivity and MPX decoder. The chip uses the CMOS process, support multi-interface and require the least external component. The package size is 3X3mm and is completely adjustment-free. All these make it very suitable for portable devices. The RDA5820NS has a powerful low-IF digital audio processor, this make it have optimum sound quality with varying reception conditions. The RDA5820NS use RDA patented dual synthesizers, all digital transmit structure, this make it have perfectly transmition performance and agility. Figure 1-1. RDA5820NS Top View The RDA5820NS support 50M~115M frequency band FM and RDS/RBDS receive and transmit, support power supply range is 1.8-5.5V, all these make it can be used in simple wireless control appliance such as mobile phone or toys. The RDA5820NS package is pin-to-pin compatible with FM receive tuner RDA5802NS. 1.1 Features  CMOS single-chip fully-integrated FM transceiver  High performance A/D converter  Low power consumption  IF selectivity performed internally     Total current consumption is about 26 mA at  Fully integrated on-chip loop filter 3.0 V power supply (maximum power transmit  All digital transmitter mode)  Autonomous search tuning  Support RDS/RBDS receive and transmit  Support SNR FM searching  Support 32.768KHz crystal oscillator  Digital auto gain control (AGC)  Digital adaptive noise cancellation 50 -115 MHz 100KHz, 200KHz, 50KHz and 25KHz Digital low-IF tuner  Fully integrated digital frequency synthesizer Fully integrated on-chip RF and IF VCO Support flexible channel spacing mode    Support worldwide and campus frequency band   Total current consumption is about 22mA at 3.0 V power supply (receive mode) Image-reject down-converter  Mono/stereo switch Copyright © RDA Microelectronics Inc. 2006. All rights are reserved. The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. RDA Microelectronics, Inc.  Soft mute  High cut  Programmable de-emphasis (50/75 s)  Receive signal strength indicator (RSSI) and SNR  Bass boost  Volume control  Support I2S digital transmitter  Support audio power amplifier ( 32Ω resistance loading)  I2S digital input / output interface  Line-level analog output voltage  32.768 KHz, 12M,24M,13M,26M,19.2M,38.4MHz RDA5820NS FM Transceiver V1.1  1.8 to 5.5 V operation voltage  3X3mm 20 pin QFN package  Pin-to-pin compatible with RDA5802NS 1.2 Applications  Cellular handsets  MP3, MP4 players  Portable radios  PDAs, Notebook PCs  Wireless Toys reference clock  Only support IIC serial control bus interface  Directly support 32Ω resistance loading  Integrated LDO regulator The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 2 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 2 Table of Contents 1  General Description ....................................................................................................................................1  1.1  Features .........................................................................................................................................1  1.2  Applications ..................................................................................................................................2  Table of Contents.........................................................................................................................................2  Functional Description................................................................................................................................3  3.1  FM Transceiver Structure ..................................................................................................................3  3.2  FM Receive ...................................................................................................................................3  3.3  FM Transmit..................................................................................................................................4  3.4  Audio Amplify ..............................................................................................................................4  3.5  I2S Transmit ..................................................................................................................................4  3.6  PA..................................................................................................................................................4  3.7  Synthesizer1 ..................................................................................................................................4  3.8  Synthesizer2 ....................................................................................................................................4  3.9  Power Supply ................................................................................................................................4  3.10  RESET and Control Interface select .............................................................................................4  3.11  Control Interface ...........................................................................................................................4  3.12  I2S Audio Data Interface ...............................................................................................................5  3.13  GPIO Outputs................................................................................................................................5  Electrical Characteristics ...........................................................................................................................6  Receiver Characteristics .............................................................................................................................7  Transmitter Characteristics .......................................................................................................................9  6.1  I2C Interface Timing.................................................................................................................... 11  Register Definition ....................................................................................................................................12  Pins Description.........................................................................................................................................18  Application Diagram.................................................................................................................................21  9.1  RDA5820NS Common Application Diagram:............................................................................21  9.1.1  Bill of Materials: .........................................................................................................................21  Package Physical Dimension ....................................................................................................................22  PCB Land Pattern.....................................................................................................................................23  Change List................................................................................................................................................26  Notes: .......................................................................................................................................................26  Contact Information .................................................................................................................................27  2  3  4  5  6  7  8  9  10  11  12  13  14  The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 2 of 28 RDA Microelectronics, Inc. RIN Functional Description LIN 3 RDA5820NS FM Transceiver V1.1 Figure 3-1. RDA5820NS FM Transceiver Block Diagram 3.1 FM Transceiver Structure The RDA5820NS is a single-chip FM transceiver (Rx/Tx). Based on RDA patented dual synthesizers RF structure, it has perfectly FM receive and transmit performances, also least external components. Except FM receive and transmit, the RDA5820NS also have RDS/RBDS, I2S input/output, audio amplify functions. All these make it very suitable for portable devices. 3.2 FM Receive The receiver uses a digital low-IF architecture that avoids the difficulties associated with direct conversion while delivering lower solution cost and reduces complexity, and integrates a low noise amplifier (LNA) supporting the FM broadcast band (50 to 115MHz), a quadrature image-reject mixer, a programmable gain control (PGA), a high resolution analog-to-digital converters (ADCs), an audio DSP and a highfidelity digital-to-analog converters (DACs). The LNA has differential input ports, which have same characters and anyone of them can used as FM signal input port. The two LNA ports can be arbitrary selected by set according registers bits (LNA_PORT_SEL[1:0]). It default input common mode voltage is GND. The quadrature mixer down converts the LNA output differential RF signal to low-IF, it also has image-reject function. The PGA amplifies the mixer output IF signal and then digitized with ADCs. The DSP core finishes the channel selection, FM demodulation, stereo MPX decoder and output audio signal. The MPX decoder can autonomous switch from stereo to mono to limit the output noise. The DACs convert digital audio signal to analog and change the volume at same time. The DACs has low-pass feature and -3dB frequency is about 30 KHz. The PA (Power Amplifier) is power down. Its output impedance is high resistance. The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 3 of 28 RDA Microelectronics, Inc. 3.3 RDA5820NS FM Transceiver V1.1 FM Transmit 3.6 The transmit uses a digital modulate structure. Audio signals (LIN and RIN) are amplified by PGAs firstly, then converted to digital codes by ADCs. The DSP core finishes audio coding and FM modulate, pre-emphasis. The syntersizer2 transmits the digital FM data to VCO2. The PA (Power Amplifier) amplify the FM signal. The PGA gain and PA gain are adjustable by set according registers bits (PGA_GAIN[2:0] 1 and PA_GAIN[5:0]2). Table 3-1 PGA_GAIN and Input Signal Strength PGA_GAIN[2:0] V-LIN(VPP) PGA_GAIN[2:0] V-LIN(VPP) 000 1.20V 100 0.075V 001 0.60V 101 0.037V 010 0.30V 110 0.018V 011 0.15V 111 0.009V PA The PA (Power Amplifier) work frequency band is 50~115MHz, and output power is linearly adjustable. The PA use linear structure for better frequency distortion performance. 3.7 Synthesizer1 The frequency synthesizer 1 (including synthesizer1 and VCO1 ) generates the local oscillator signal which divide to quadrature, then be used to downconvert the RF input to a constant low intermediate frequency (IF). The synthesizer reference clock is 32.768 KHz. The synthesizer1 frequency is defined by bits CHAN[9:0] with the range from 50MHz to 115MHz. The synthesizer1 also generates reference to synthesizer2 under FM TX (transmit) mode. 3.8 Synthesizer2 Table 3-2 PA_GAIN and Fm Transmit Power PA_GAIN[5:0] POUT PA_GAIN[5:0] POUT 111111 3dBm 011001 -3dBm 100111 0dBm 000000 -32dBm 3.4 Audio Amplify Audio signals (LIN and RIN) can also directly send to audio amplifier in DACs and driving the headphone through LOUT and ROUT ports. 3.5 The frequency synthesizer 2 (including synthesizer2 and VCO2 ) generates clock signals for ADC under FM RX (receive) mode. The frequency synthesizer2 is also the FM transmit core. The digital signals (audio and RDS/RBDS) are directly added on it. 3.9 Power Supply The RDA5820NS integrated one LDO which supplies power to the chip. The external supply voltage range is 1.8-5.5 V. I2S Transmit 3.10 The RDA5820NS supports directly digital FM transmit. The digital signals can input through chip’s ports GPIO1/2/3, then transmits directly through synthersizer2 and PA, also transimts to DAC and send out through LOUT and ROUT ports. I2S mode support slave mode. RESET and Control Interface select The RDA5820NS is RESET itself When VIO is Power up. And also support soft reset by trigger 02H BIT1 from 0 to 1. 3.11 Control Interface The RDA5820NS only supports I2C control interface. 1 2 Register 0x68H_BIT[12:10] Register 0x41H_BIT[5:0] PGA_GAIN_BIT[2:0] PA_GAIN_BIT[2:0] The I2C interface is compliant to I2C Bus Specification 2.1. It includes two pins: SCLK and The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 4 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 SDIO. A I2C interface transfer begins with START 42Kbps. condition, a command byte and data bytes, each byte has a followed ACK (or NACK) bit, and ends with STOP condition. The command byte includes a 7-bit chip address (0010001b) and a R/W bit. The ACK (or NACK) is always sent out by receiver. When in write transfer, data bytes is written out from MCU, and when in read transfer, data bytes is read out from RDA5820NS. 3.12 I2S Audio Data Interface The RDA5820NS supports I2S (Inter_IC Sound Bus) audio interface. The interface is fully compliant with I2S bus specification. When setting I2SEN bit high, RDA5820NS will output SCK, WS, SD signals from GPIO3, GPIO1, GPIO2 as I2S master and transmitter, the sample rate is 3.13 GPIO Outputs The RDA5820NS has three GPIOs. The function of GPIOs could programmed with bits GPIO1[1:0], GPIO2[1:0], GPIO3[1:0] and I2SEN. If I2SEN is set to low, GPIO pins could be programmed to output low or high or high-Z, or be programmed to output interrupt and stereo indicator with bits GPIO1[1:0], GPIO2[1:0], GPIO3[1:0]. GPIO2 could be programmed to output a low interrupt (interrupt will be generated only with interrupt enable bit STCIEN is set to high) when seek/tune process completes. GPIO3 could be programmed to output stereo indicator bit ST. Constant low, high or high-Z functionality is available regardless of the state of VDD supplies or the ENABLE bit. SCK WS LEFT CHANNEL RIGHT CHANNEL 1 SCK SD 1 SCK MSB LSB MSB LSB Figure 3-2. I2S Digital Audio Format The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 5 of 28 RDA Microelectronics, Inc. 4 RDA5820NS FM Transceiver V1.1 Electrical Characteristics Table 4-1 DC Electrical Specification (Recommended Operation Conditions): SYMBOL DESCRIPTION MIN TYP MAX UNIT VDD Supply Voltage 1.8 3.3 5.5 V VIO Interface Supply Voltage 1.5 - 3.6 V Tamb Ambient Temperature -20 27 +70 ℃ VIL CMOS Low Level Input Voltage 0 0.3*VIO V VIH CMOS High Level Input Voltage 0.7*VIO VIO V VTH CMOS Threshold Voltage Table 4-2 0.5*VIO V DC Electrical Specification (Absolute Maximum Ratings): SYMBOL DESCRIPTION MIN TYP MAX UNIT VIO Interface Supply Voltage -0.5 +4 V Tamb Ambient Temperature IIN -40 +90 °C (1) -10 +10 mA (1) -0.3 VIO+0.3 V 0 dBm Input Current VIN Input Voltage Vlna LNA FM Input Level Notes: 1. For Pin: SCLK, SDIO Table 4-3 Power Consumption Specification (VDD = 3 V, VIO=3 V, TA =25℃, unless otherwise specified) SYMBOL DESCRIPTION CONDITION TYP UNIT FM Receive IVDD Supply Power Current ENABLE=1 22 mA IVIO Interface Supply Current SCLK and RCLK inactive 200 A IAPD Analog Powerdown Current ENABLE=0 5 A IDPD Digital Powerdown Current ENABLE=0 10 A IVDD Supply Power Current PA_GAIN[5:0]=[111111];VRF=3dBm 26 mA IVDD Supply Power Current PA_GAIN[5:0]=[100111];VRF=0dBm 25 mA IVDD Supply Power Current PA_GAIN[5:0]=[011001];VRF=3dBm 24.5 mA IVDD Supply Power Current PA_GAIN[5:0]=[000000];VRF=-32dBm 23 mA FM Transmit The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 6 of 28 RDA Microelectronics, Inc. 5 RDA5820NS FM Transceiver V1.1 Receiver Characteristics Table 5-1 Receiver Characteristics (VDD = 3 V, VIO=3 V, TA = 25 °C, unless otherwise specified) SYMBOL PARAMETER CONDITIONS MIN Adjust BAND Register 50 TYP MAX UNIT 115 MHz General Specifications Fin FM Input Frequency Range 1,2,3 Vrf S/N=26dB Sensitivity IFrej Iimage_rej Input IP3 - 1.2 98MHz - 1.2 108MHz - 1.3 AGCD=1 80 m=0.3 60 ±200KHz ±400KHz 1,2 AM Suppression Adjacent Channel Selectivity VAFR (Pins LOUT and ROUT) EMF 6 Ratio Stereo Stereo Channel Separation Audio Output Loading Single-ended Resistance Audio Total Harmonic 1,3,6 Distortion Volume[3:0]=1111 - Db 50 70 - Db 60 85 mV 55 57 - 53 55 35 - - dB 32 - - Ω 0.03 0.05 - - 0.05 dB 60 - - dB Rload=32Ω Imbalance1,6 Audio Response1 - Rload=1KΩ Audio Output L/R Mute Attenuation Ratio1 dBV 420 Mono2 1,2,3,5 BWaudio V - Volume [3 :0] =1111 Maximum Signal to Noise αAOI Rmute 88MHz dB Audio L/R Output Voltage THD 1.2 40 VAFL; RL - Image Rejection 400KHz Selectivity αSCS 65MHz dB S400 S/N 1.5 40 IP3in S200 - IF Rejection 4 αam 50MHz Volume[3:0]=0000 9 1KHz=0dB ± 3dB Low Freq 100 point High Freq 14 dB % Hz Pins FMIN,FMOUT, LOUT, ROUT,LIN,RIN Vcom_fmin Vcom_fmout Vcom_in Vcom Pins FMIN Input Common Mode V 0 Voltage Pin FMOUT Common Mode Voltage V 0 Pins LIN/RIN Input Common Mode Audio Output Common Mode Voltage8 V 1.1 Voltage 0.95 1. 1.05 V The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 7 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 Notes: 1. Fin=65 to 115MHz; Fmod=1KHz; de-emphasis=75s; MONO=1; L=R unless noted otherwise; 2. f=22.5KHz; 3. BAF = 300Hz to 15KHz, RBW 1MHz, f0=2xf1-f2, AGC disable, Fin=76 to 108MHz; 5. PRF=60dBUV; 6. f=75KHz. 7. Measured at VEMF = 1 m V, f RF = 76 to 108MHz 8. At LOUT and ROUT pins 9.Adjustable The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 8 of 28 RDA Microelectronics, Inc. 6 RDA5820NS FM Transceiver V1.1 Transmitter Characteristics Table 6-1 Transmitter Characteristics (VDD = 3 V, VIO=3 V, TA = 25 °C, unless otherwise specified) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNIT 115 MHz General specifications Frf △ F Transmit Frequency 50 2,3 Transmit Frequency Accuracy and Stability 2.6 KHz VRF Maximum Transmit Voltage PA_GAIN=[111111] 3 dBm VRF Minimum Transmit Voltage PA_GAIN=[000000] -32 dBm Transmit Voltage Step 3 dBm Transmit Voltage Stability 1 dB Transmit Channel >±100KHz Edge Power Pre-emphasis off Transmit Adjacent >±200KHz Channel Power Pre-emphasis off Transmit Alternate >±400KHz Channel Power Transmit Emissions Pre-emphasis off In band(76 to 108MHz) -85 dBc -85 dBc -85 dBc -50 dBc Pre-emphasis TX_PREMPHASIS=75 us 70 75 80 us Time Constant TX_PREMPHASIS=50 us 45 50 55 us 50 55 dB 51 55 dB f=22.5KHz,Mono △ Audio SNR Mono Limiter off f=22.5KHz, △ fpolit=6.75KHz, △ Audio SNR Stereo Stereo Limiter off f=75KHz,Mono △ Audio THD Mono Limiter off 0.08 0.6 % 0.08 0.6 % f=68.25KHz, △ fpolit=6.75KHz, △ Audio THD Stereo Stereo Limiter off SCR Audio Stereo Separation 40 dB Sub Carrier Rejection Ratio 27 dB Power up Setting Time 30 ms Input Signal Level 1 VPK 15K Hz Mono,±1.5dB, Frequency Flatness f=75KHz, △ 0,50,75us pre-emphasis, 30 limiter off The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 9 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 Mono,-3dB, High-Pass △ Frequency Response 0,50,75us pre-emphasis, f=75KHz, 5 30 Hz 15k 16k Hz -1 1 dB -10 10 % -10 10 % limiter off Mono,-3dB, Low-Pass △ Frequency Response 0,50,75us pre-emphasis, f=75KHz, limiter off Audio Imbalance Mono Pilot Modulation △ Rate Accuracy △ Audio Modulation △ Rate Accuracy △ f=68.25KHz, fpilot=6.75KHz,Stereo f=68.25KHz, fpilot=6.75KHz,Stereo Input Resistance 10 15 20 K Input Capacitance 0.5 0.7 1 pF Notes: 1. Fin=65 to 115MHz; Fmod=1KHz; de-emphasis=75s; MONO=1; L=R unless noted otherwise; 2.Guaranteed by Characterization only ; 3.No measurable △fRF/△VDD at VDD of 500mV pk-pk at 100HZ to 10KHz; △ The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 10 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 Serial Interface 6.1 I2C Interface Timing Table 6-1 I2C Interface Timing Characteristics (VDD = 3 V, VIO=3 V, TA = 25°C, unless otherwise specified) PARAMETER SYMBOL TEST CONDITION MIN TYP MAX UNIT SCLK Frequency fscl 0 - 400 KHz SCLK High Time thigh 0.6 - - s SCLK Low Time tlow 1.3 - - s Setup Time for START Condition tsu:sta 0.6 - - s Hold Time for START Condition thd:sta 0.6 - - s Setup Time for STOP Condition tsu:sto 0.6 - - s SDIO Input to SCLK↑ Setup tsu:dat 100 - - ns SDIO Input to SCLK↓ Hold thd:dat 0 - 900 ns STOP to START Time tbuf 1.3 - - s SDIO Output Fall Time tf:out 20+0.1Cb - 250 ns tr:in / tf:in 20+0.1Cb - 300 ns Input Spike Suppression tsp - - 50 ns SCLK, SDIO Capacitive Loading Cb - - 50 pF 5 pF SDIO Input, SCLK Rise/Fall Time Digital Input Pin Capacitance Figure 6-1. I2C Interface Write Timing Diagram Figure 6-2. I2C Interface Read Timing Diagram The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 11 of 28 RDA Microelectronics, Inc. 7 Register Definition REG 00H 02H RDA5820NS FM Transceiver V1.1 BITS 15:0 15 NAME FUNCTION DEFAULT CHIPID[15:0] Chip ID. 0x5820 DHIZ Audio Output High-Z Disable. 0 0 = High impedance; 1 = Normal operation 14 Mute Disable. DMUTE 0 0 = Mute; 1 = Normal operation 13 Mono Select. MONO 0 0 = Stereo; 1 = Force mono 12 BASS 11 RCLK Bass Boost. 0 0 = Disabled; 1 = Bass boost enabled NON-CALIBRATE 0=RCLK clock is always supply 0 1=RCLK clock is not always supply when FM work ( when MODE 1, RDA5820NS can’t directly support -20℃~70℃ temperature. Only suppory ±20℃ temperature swing from tune point) 10 RCLK DIRECT INPUT 1=RCLK clock use the directly input mode 0 0 MODE 9 SEEKUP Seek Up. 8 SEEK Seek. 0 = Seek down; 1 = Seek up 0 0 = Disable stop seek; 1 = Enable Seek begins in the direction specified by SEEKUP and ends when a channel is found, or the entire band has been searched. The SEEK bit is set low and the STC bit is set high when the seek operation completes. 7 SKMODE Seek Mode 0 0 = wrap at the upper or lower band limit and continue seeking 1 = stop seeking at the upper or lower band limit 6:4 CLK_MODE[2:0] 000=32.768kHz 000 001=12Mhz 101=24Mhz 010=13Mhz 110=26Mhz 011=19.2Mhz 111=38.4Mhz 3 RDS_EN RDS/RBDS enable 0 If 1, RDS/RBDS enable 2 RSVD Reserved 0 1 SOFT_RESET Soft reset. 0 If 0, not reset; If 1, reset. The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 12 of 28 RDA Microelectronics, Inc. REG BITS 0 RDA5820NS FM Transceiver V1.1 NAME ENABLE FUNCTION Power Up Enable. DEFAULT 0 0 = Disabled; 1 = Enabled 03H 15:6 CHAN[9:0] Channel Select. 0x00 BAND = 0 Frequency = Channel Spacing (kHz) x CHAN+ 87.0 MHz BAND = 1or 2 Frequency = Channel Spacing (kHz) x CHAN + 76.0 MHz BAND = 3 Frequency = Channel Spacing (kHz) x CHAN + 65.0 MHz CHAN is updated after a seek operation. 5 DIRECT MODE Directly Control Mode, Only used when test. 0 4 TUNE Tune 0 0 = Disable 1 = Enable The tune operation begins when the TUNE bit is set high. The STC bit is set high when the tune operation completes. The tune bit is reset to low automatically when the tune operation completes.. 3:2 BAND[1:0] Band Select. 00 00 = 87–108 MHz (US/Europe) 01 = 76–91 MHz (Japan) 10 = 76–108 MHz (world wide) 3 11 = 65 –76 MHz (East Europe) or 50-65MHz 1:0 SPACE[1:0] Channel Spacing. 00 00 = 100 kHz 01 = 200 kHz 10 = 50kHz 11 = 25KHz 04H 15 RDSIEN RDS ready Interrupt Enable. 0 0 = Disable Interrupt 1 = Enable Interrupt Setting STCIEN = 1 will generate a low pulse on GPIO2 when the interrupt occurs. 14 STCIEN Seek/Tune Complete Interrupt Enable. 0 0 = Disable Interrupt 1 = Enable Interrupt Setting STCIEN = 1 will generate a low pulse on GPIO2 when the interrupt occurs. 13 RBDS 1 = RBDS mode enable 0 0 = RDS mode only 12 3 RDS_FIFO_EN 1 = RDS fifo mode enable. 0 If 0x07h_bit[9] ( band )=1, 65-76MHz; =0, 50-76MHz The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 13 of 28 RDA Microelectronics, Inc. REG BITS 11 RDA5820NS FM Transceiver V1.1 NAME FUNCTION De-emphasis. DE DEFAULT 0 0 = 75 µs; 1 = 50 µs 10 RDS_FIFO_CLR 1 = clear RDS fifo 1 9 SOFTMUTE_EN If 1, softmute enable 1 8 AFCD AFC disable. 0 If 0, afc work; If 1, afc disabled. 7 RSVD Reserved 0 6 I2S_ENABLED I2S bus enable 0 If 0, disabled; If 1, enabled. 5:4 General Purpose I/O 3. GPIO3[1:0] 00 00 = High impedance 01 = Mono/Stereo indicator (ST) 10 = Low 11 = High 3:2 General Purpose I/O 2. GPIO2[1:0] 00 00 = High impedance 01 = Interrupt (INT) 10 = Low 11 = High 1:0 General Purpose I/O 1. GPIO1[1:0] 00 00 = High impedance 01 = Reserved 10 = Low 11 = High 05H 15 INT _MODE If 0, generate 5ms interrupt; 1 If 1, interrupt last until read reg0CH action occurs. 14:13 SEEK_MODE[1:0] 01= adjacent seek process && noise condition 00 10= adjacent seek process || noise condition 12 11:8 RSVD SEEKTH[3:0] 4 (inverse of Reserved 0 Seek SNR threshold value: 1000 Noise_th(dB) = 79 – seek_th noise_h_th) 7:6 LNA_PORT_SEL[1:0] LNA input port selection bit: 10 00: no input 01: LNAN 10: LNAP 11: dual port input 5:4 RSVD Reserved 00 3:0 VOLUME[3:0] DAC Gain Control Bits (Volume). 1111 0000=min; 1111=max Volume scale is logarithmic When 0000, output mute and output impedance is very large 4 The default noise threshold is 71dB. The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 14 of 28 RDA Microelectronics, Inc. REG 06H BITS 15:13 12 RDA5820NS FM Transceiver V1.1 NAME FUNCTION RSVD I2S_MODE 5 DEFAULT reserved 000 If 0, master mode; 0 If 1, slave mode. 11 3 SW_LR Ws relation to l/r channel. 10 If 0, ws=0 ->r, ws=1 ->l; If 1, ws=0 ->l, ws=1 ->r. 10 SCLK_I_EDGE 3 When I2S enable 0 If 0, use normal sclk internally; If 1, inverte sclk internally. 9 DATA_SIGNED 3 If 0, I2S output unsigned 16-bit audio data. 0 If 1, I2S output signed 16-bit audio data. 8 WS_I_EDGE 3 If 0, use normal ws internally; 0 If 1, inverte ws internally. 7:4 3 I2S_SW_CNT[4:0] ( Only valid in master mode ) 3 2 1 07H SW_O_EDGE 3 SCLK_O_EDGE L_DELY 3 4'b1000: WS_STEP_48; 4'b0111: WS_STEP=44.1kbps; 4'b0110: WS_STEP=32kbps; 4'b0101: WS_STEP=24kbps; 4'b0100: WS_STEP=22.05kbps; 4'b0011: WS_STEP=16kbps; 4'b0010: WS_STEP=12kbps; 4'b0001: WS_STEP=11.025kbps; 4'b0000: WS_STEP=8kbps; 0000 If 1, invert ws output when as master. 0 If 1, invert sclk output when as master. 0 3 If 1, L channel data delay 1T. 0 3 If 1, R channel data delay 1T. 0 0 R_DELY 15 RSVD Must be 0 0 14:10 TH_SOFRBLEND[5:0] Softblend threshold setting for noise. 10011 If (127-noise_db2)>4*th, turn soft blend off. 9 65M_50M MODE Valid when band[1:0] = 2’b11 (0x03H_bit) 1 1 = 65~76 MHz; 0 = 50~76 MHz. 8 7:2 RSVD SEEK_TH_OLD Reserved 6 Seek threshold 0 for old seek mode, Valid when 000000 Seek_Mode=01 1 SOFTBLEND_EN If 1, Softblend enable 1 0 FREQ_MODE If 1, then freq setting changed. 0 Freq = 76000(or 87000) kHz + freq_direct (08H) kHz. 0AH 15 RDSR RDS ready 0 0 = No RDS/RBDS group ready(default) 1 = New RDS/RBDS group ready 14 STC Seek/Tune Complete. 0 0 = Not complete 1 = Complete 3 This function is open when I2S_Enabled=1. 6 0x05H_bit[14:13], SEEK_MODE register. Default value is 00; When = 01, will add the 5802E seek mode. The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 15 of 28 RDA Microelectronics, Inc. REG BITS RDA5820NS FM Transceiver V1.1 NAME FUNCTION DEFAULT The seek/tune complete flag is set when the seek or tune operation completes. 13 SF 0 Seek Fail. 0 = Seek successful; 1 = Seek failure The seek fail flag is set when the seek operation fails to find a channel with an RSSI level greater than SEEKTH[5:0]. 12 RDSS RDS Synchronization 0 0 = RDS decoder not synchronized(default) 1 = RDS decoder synchronized Available only in RDS Verbose mode 11 BLK_E When RDS enable: 0 1 = Block E has been found 0 = no Block E has been found 10 ST 1 Stereo Indicator. 0 = Mono; 1 = Stereo Stereo indication is available on GPIO3 by setting GPIO3[1:0] =01. 9:0 READCHAN[9:0] Read Channel. 8’h00 BAND = 0 Frequency = Channel Spacing (kHz) x READCHAN[9:0]+ 87.0 MHz BAND = 1 or 2 Frequency = Channel Spacing (kHz) x READCHAN[9:0]+ 76.0 MHz BAND = 3 Frequency = Channel Spacing (kHz) x READCHAN[9:0]+ 65.0 MHz READCHAN[9:0] is updated after a tune or seek operation. 0BH 15:9 RSSI[6:0] RSSI. 0 000000 = min 111111 = max RSSI scale is logarithmic. 8 FM TRUE 1 = the current channel is a station 0 0 = the current channel is not a station 7 FM_READY 1=ready 0 0=not ready 6:5 RSVD Reserved 00 4 ABCD_E 1= the block id of register 0cH,0dH,0eH,0fH is E 0 0= the block id of register 0cH, 0dH, 0eH,0fH is A, B, C, D 3:2 BLERA[1:0] Block Errors Level of RDS_DATA_0, and is always read as 00 Errors Level of RDS BLOCK A (in RDS mode) or BLOCK E (in RBDS mode when ABCD_E flag is 1) 00= 0 errors requiring correction 01= 1~2 errors requiring correction 10= 3~5 errors requiring correction 11= 6+ errors or error in checkword, correction not The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 16 of 28 RDA Microelectronics, Inc. REG BITS RDA5820NS FM Transceiver V1.1 NAME FUNCTION DEFAULT possible. Available only in RDS Verbose mode 1:0 BLERB[1:0] Block Errors Level of RDS_DATA_1, and is always read as 00 Errors Level of RDS BLOCK B (in RDS mode ) or E (in RBDS mode when ABCD_E flag is 1). 00= 0 errors requiring correction 01= 1~2 errors requiring correction 10= 3~5 errors requiring correction 11= 6+ errors or error in checkword, correction not possible. Available only in RDS Verbose mode 0CH 15:0 RDSA[15:0] BLOCK A ( in RDS mode) or BLOCK E (in RBDS mode when 16’h5820 ABCD_E flag is 1) 0DH 15:0 RDSB[15:0] BLOCK B ( in RDS mode) or BLOCK E (in RBDS mode when 16’h5820 ABCD_E flag is 1) 0EH 15:0 RDSC[15:0] BLOCK C ( in RDS mode) or BLOCK E (in RBDS mode when 16’h5805 ABCD_E flag is 1) 0FH 15:0 RDSD[15:0] BLOCK D ( in RDS mode) or BLOCK E (in RBDS mode when 16’h5805 ABCD_E flag is 1) 40H 15:4 RSVD 3:0 WORK MODE Reserved 16’h000 0000 = FM Receive 0000 0001 = FM Transmit 1000 = Audio Amplify 1100 = Codec 1110 = ADC 41H 67H 68H 15:12 RSVD Reserved 0000 11:9 TXPA_VCOM[2:0] TXPA Common Voltage 000 8:6 TXPA_IBIT[2:0] TXPA Bias Current 111 5:0 TXPA_GAIN[5:0] TXPA Gain Bit 000000 15:8 FMTX_PILOT_DEV[7:0] FM Transmit Pilot Tone Modulate Parameter 16’h0E 7:0 FMTX_RDS_ DEV[7:0] FM Transmit RDS Signal Modulate Parameter 16’h10 RSVD Reserved 00 FMTX_PGA_GAIN FM Transmit PGA Gain Bit 001 FMTX_ADC_GAIN FM Transmit ADC Gain Bit 000 FMTX_AUDIO_DEV FM Transmit Audio Signal Modulate Parameter 16’hF0 The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 17 of 28 RDA Microelectronics, Inc. GPIO2 VDD RIN RCLK GPIO1 LIN SDIO VIO GND Pins Description SCLK 8 RDA5820NS FM Transceiver V1.1 Figure 8-1. RDA5820NS Top View Table 8-1 RDA5820NS Pins Description SYMBOL PIN DESCRIPTION GND 2,4,5,11,14,20,21 FMIN 3 FM LNAP input port. FMOUT 1 .FM output port and LNAN input port SCLK SDIO RCLK VIO VDD ROUT,LOUT RIN,LIN GPIO1/2/3 6 7 8 9 10 12,13 18,19 17,16,15 Ground. Connect to ground plane on PCB Clock input for serial control bus Data input/output for serial control bus 32.768KHz crystal oscillator and reference clock input Power supply for I/O Power supply for analog and digital section Right/Left audio output port Right/Left audio input port General purpose input/output The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 18 of 28 RDA Microelectronics, Inc. Table 8-2 Internal Pin Configuration SYMBOL FMIN PIN DESCRIPTION 4 17/18 Rload RIN/LIN RDA5820NS FM Transceiver V1.1 FMs FMOUT 1 FMOUT MN1 35pF Sout RCLK 8 The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 19 of 28 RDA Microelectronics, Inc. SCLK/SDIO RDA5820NS FM Transceiver V1.1 9/10 in GPIO1/GPIO2/GPIO3 17/16/15 GPIO1\2\3 Out The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 20 of 28 RDA Microelectronics, Inc. 9 RDA5820NS FM Transceiver V1.1 Application Diagram 9.1 RDA5820NS Common Application Diagram: F1 1.5K@100MHz C4 125uF J1 F2 Notes: 1. J1: Common 32Ω Resistance 1.5K@100MHz C5 125uF FM_LIN C7 Headphone; 2. U1: RDA5820NS Chip; FM_RIN C8 GPIO1 GPIO2 3.VDD: Power Supply (1.8~5.5V); 4: C7/C8: Audio Input Couple Capacitance; C1 1nF 1 5. FM Choke (L3 and C3) for Audio GPIO3 Common; 6.C1: Fm Antenna Couple Capacitor 7. Place C6 Close to VDD pin. 8.Ferrite F1/F2 should close to J1. 11 SCLK SDIO RCLK VIO C6 24nF V1 Figure 9-1. RDA5820NS FM Transceiver Application Diagram (TCXO Application) 9.1.1 Bill of Materials: COMPONENT U1 VALUE RDA5820NS J1 DESCRIPTION Broadcast FM Transceiver SUPPLIER RDA Common 32Ω Resistance Headphone F1/F2 1.5K@100MHz FM Band Ferrite Murata C1 1nF FM Antenna Couple Capacitor Murata C7/C8 0.22uF Audio Couple Capacitors Murata L3/C3 100nH/24pF LC Chock for LNA Input Murata C4,C5 125µF Audio AC Couple Capacitors Murata C6 24nF Power Supply Bypass Capacitor Murata The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 21 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 10 Package Physical Dimension Figure 10-1 illustrates the package details for the RDA5820NS. The package is lead-free and RoHS-compliant. Figure 10-2. 20-Pin 3x3 Quad Flat No-Lead (QFN) The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 22 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 11 PCB Land Pattern Figure 18.Classification Reflow Profile Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly Average Ramp-Up Rate 3 oC/second max. 3 oC/second max. -Temperature Min (Tsmin) 100 oC 150 oC -Temperature Max (Tsmax) 100 oC 200 oC -Time (tsmin to tsmax) 60-120 seconds 60-180 seconds -Temperature (TL) 183 oC 217oC -Time (tL) 60-150seconds 60-150 seconds Peak /Classification Temperature(Tp) See Table-II See Table-III Time within 5 oC of actual Peak Temperature (tp) 10-30 seconds 20-40 seconds Ramp-Down Rate 6 oC/second max. 6 oC/seconds max. Time 25 oC to Peak Temperature 6 minutes max. 8 minutes max. (TSmax to Tp) Preheat Time maintained above: Table-I Classification Reflow Profiles The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 23 of 28 RDA Microelectronics, Inc. RDA5820NS FM Transceiver V1.1 Volume mm3 Volume mm3
RDA5820NS
物料型号:RDA5820NS
器件简介:RDA5820NS是新一代的单芯片广播FM收发器,具有完全集成的合成器、中频选择性和MPX解码器。使用CMOS工艺,支持多种接口,并且外部组件需求最少。封装尺寸为3x3mm,无需任何调整,非常适合便携设备。
引脚分配:文档提供了RDA5820NS的顶视图和封装图,展示了各个引脚的位置和功能。
参数特性: - 支持50M~115M频率带的FM接收和RDS/RBDS收发。 - 电源供应范围为1.8-5.5V。 - 采用RDA专利的双合成器和全数字发射结构,具有优异的传输性能和敏捷性。 - 具有数字低中频调谐器、高性能A/D转换器和内部执行的中频选择性。 - 全数字发射器,支持自主搜索调谐和SNR FM搜索。
功能详解: - RDA5820NS具有数字自动增益控制(AGC)和数字自适应噪声消除功能。 - 支持I2S数字发射和音频功率放大器。 - 提供I2S数字输入/输出接口和线路级模拟输出电压。 - 支持32.768KHz晶体振荡器。
应用信息: - 适用于手机、MP3/MP4播放器、便携式收音机、PDA、笔记本电脑和无线玩具等设备。
封装信息:RDA5820NS采用3x3mm 20引脚QFN封装,与FM接收器RDA5802NS管脚兼容。
RDA5820NS 价格&库存
很抱歉,暂时无法提供与“RDA5820NS”相匹配的价格&库存,您可以联系我们找货
RDA5820NS
  • 1+7.25000
  • 30+7.00000
  • 100+6.50000
  • 500+6.00000
  • 1000+5.75000
