TP1625
TP1625
    ROCPU(台普)
    SEN_2.8X2.35MM_SM
    2.8X2.35X1.6 传感开关 震动开关
TP1625 数据手册
A B D C 1.6mm±0.1 5m 2.3 H 0.1 m± 2 w D w 1.2±0.15 1.0±0.15 1.2±0.15 G 接触电阻 Contact Resistance:30 Mohm MAX 耐温 Temperature Range:-50℃ ̄100℃ 潮湿敏感等级 MSL:1级 额定电流 Rated Current:50nA(0.05uA)-10mA 绝缘电阻 Insulation Resistance:100 Ohm Min 振动寿命 Vibration durability:500 000 cycles .1 ±0 m .8m F 电器性能规格  Electrical Characteristics: 额定电压 Rated Voltage:24Vdc 2.5±0.15 1 E 2 3 4 A4 5 COMMON A3 台普 A2 A1 REV DATE REVISION DESCRIPTION ISSUE TOLERANCE X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR UNIT MM DRAWN BY FUYUAN DATE 2019 PROJCTED PRODUCT NAME: CHECKED BY COCO MODEL NO: APPROVAL B ALEN Https: TP1625 www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission F
TP1625 价格&库存
很抱歉,暂时无法提供与“TP1625”相匹配的价格&库存,您可以联系我们找货
TP1625
  • 1+7.90560
  • 10+6.54480
  • 30+5.78880
  • 100+4.94640
库存:248
