SK-13D07-6
SK-13D07-6
    ROCPU(台普)
    弯插,12.8x4.7mm
    滑动开关 弯插,12.8x4.7mm 单刀三掷 1万次 弯插
SK-13D07-6 数据手册
A B D C E F G 12.80 [0.504] 2.00 [0.079] 4.00 [0.157] 3 2 7.50[0.295] 8.00 [0.315] SCHEMATIC PCB LAYOUT 2.00[0.079] 2.00 [0.079] 3 4 2.00 [0.079] 0.40[0.016] 1 1.Limit value: 0.3A 50V DC 1.额度值:0.3A 50V DC 2.Contact resistance: ≤ 100m Ω Max 2.接触电阻:≤100mΩ MAX 3.Insulation resistance: ≥ 100m Ω Max 3.绝缘电阻:≥100mΩ MAX 4.Withstand voltage: AC 500V 1 min 4.耐电压:AC 500V 1 min 5.Action force: 260 ± 100gf 4 Terminal 端子 Brass 黄铜 4 3 Base 基座 Phenolic Resin 酚醛树脂 1 2 Frame 框架 SUS 1 Natural 1 Hand shank 手柄 PA66 1 Black 黑色 NO 序号 Part name 部件名 Material 材料 QTY 数量 Remark 备注 1.20[0.047] 8.00 [0.315] 4 5.动作力:260±100gf 6.Stroke: 2.0mm 6.行程:2.0mm 7.Service life: 10000 times 7.使用寿命:10000次 8.Service temperature: - 16 ℃ ~ + 60 ℃ 8.使用温度:﹣16℃~﹢60℃ 9.Contact type: 1P3T 9.接触型式:1P3T 12.30[0.484] UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV MM ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED DATE 2019 Ag plated 镀银 4 PRODUCT NAME: TOLERANCE A3 5 2 3 0.50[0.020] 4.00 [0.158] 1 12.29 [0.484] 4.70 [0.185] 2 6.00[0.236] 7.80[0.307] 4.40[0.173] 1 CHECKED BY COCO MODEL NO: SK-13D07-6 APPROVAL B ALEN Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E F G 5
SK-13D07-6 价格&库存
很抱歉,暂时无法提供与“SK-13D07-6”相匹配的价格&库存,您可以联系我们找货
SK-13D07-6
    • 5+0.76032
    • 50+0.60480
    • 150+0.52704
    • 1000+0.46872
    • 2000+0.42207
    库存:2667
