VEPD0624-100M-A
VEPD0624-100M-A
    VOLUMESOURCE(千代源)
    SMD,7.3x6.6mm
    功率电感 10µH ±20% 101mΩ IND_6.6X7.3MM_SM
VEPD0624-100M-A 数据手册
SPECIFIC AT IONS Customer Product Name Wire Wound SMD Power Inductors Volume Part Number VEPD0624 Series Customer Part Number [ New Released, Revised] SPEC No: VEPD0624-100M-A PART NO: FIA00624-04 【This SPEC is total 8 pages.】 【ROHS Compliant Parts】 Approved By Checked By Issued By ShenZhen Volume Source Electronics Co., Ltd. Address: 16th Floor, Building T5-N4, Tian'an Digital City, Fenggang, Dongguan Tel: 0769-89891993 Fax: 0769-89891993-806 【For Customer approval Only】 Qualification Status: Approved By Comments: □Full Date: □Restricted Verified By □Rejected Re-checked By Checked By 【Version change history】 Rev. Effective Date Changed Contents Change Reasons Approved By 01 / New released / Luyong Han Applications: ●Laptops and PCs ●Switchs and servers ●Base stations,DC/DC converters Features : ●RoHS, Halogen Free and REACH Compliance ●High rated current ●Ultra low buzz noise 1. Product physical map 2. Dimensions in (mm) 3. Schematic Marking A 6.6±0.3 B 7.3Max C 2.4Max D 2.9 E 1.6±0.5 H 3.5 I 2.35 Characteristics : ●Saturation Current(Isat):The current when the inductance Becomes 30% lower than is initial value.(Ta=20℃). ●Temperature Rise Current(Irms):The current when the temperature of coil increases up to max.ΔT=40℃.(Ta=20℃) ●Operating temperature : -40℃~+125℃. ●Storage temperature range (packaging conditions): -5℃~+30℃ and RH 70% (Max.) Test equipments : ●L&Q: HP 4285A or WK3260B, VR116/VR7210. ●DCR: Milli-ohm meter, VR131. ●Electrical specifications at 25℃. J 6.05 Electrical Characteristics RDC Isat Irms (mΩ)Max (A)Typ. (A)Typ. 100KHz/0.25V 3.2 34 21 R22 0.33±30% 100KHz/0.25V 4.1 24.5 18 R33 VEPD0624-R47N-A 0.47±30% 100KHz/0.25V 5.1 22 15 R47 VEPD0624-1R0M-A 1.0±20% 100KHz/0.25V 13.5 16 9 1R0 VEPD0624-1R5M-A 1.5±20% 100KHz/0.25V 20 15 9 1R5 VEPD0624-2R2M-A 2.2±20% 100KHz/0.25V 28 11 6 2R2 VEPD0624-3R3M-A 3.3±20% 100KHz/0.25V 39 10 5.5 3R3 VEPD0624-4R7M-A 4.7±20% 100KHz/0.25V 50 10 5.0 4R7 VEPD0624-6R8M-A 6.8±20% 100KHz/0.25V 70 6.0 4.0 6R8 VEPD0624-100M-A 10±20% 100KHz/0.25V 101 4.0 3.1 100 VEPD0624-150M-A 15±20% 100KHz/0.25V 160 3.3 2.5 150 Inductance ( uH ) Test Frequency VEPD0624-R22N-A 0.22±30% VEPD0624-R33N-A Part No. Test Instruments WK3260B Impedance / Material Analyzer Marking Packing method 1. Packing quantity of each reel: 1500PCS/R (18-36PCS not packed at the beginning and end), affixed with the correct label, and then placed into a plastic bag (plastic bag size: 360x460mm), with a package of desiccant, sealing, reel and carrying tape dimensions. Fig. 1-1 Fig .1-1 Reel dimensions ,general tolerance (±0.5mm) A B C W D Ф330 Ф100 Ф13.5 16.5 22.5 The general tolerance, of carrier size is ±
VEPD0624-100M-A 价格&库存
很抱歉,暂时无法提供与“VEPD0624-100M-A”相匹配的价格&库存,您可以联系我们找货
VEPD0624-100M-A
  • 5+0.46480
  • 20+0.42280
  • 100+0.38080
  • 500+0.33880
  • 1000+0.31920
  • 2000+0.30520
