VEPD1260-100M-A
VEPD1260-100M-A
    VOLUMESOURCE(千代源)
    IND_12.6X13.8MM_SM
    功率电感 10µH ±20% 20.7mΩ IND_12.6X13.8MM_SM
VEPD1260-100M-A 数据手册
SPECIFIC AT IONS Customer Product Name Wire Wound SMD Power Inductors Volume Part Number VEPD1260 Series Customer Part Number [ New Released, Revised] SPEC No: VEPD1260-100M-A PART NO: FIA01260-05 【This SPEC is total 8 pages.】 【ROHS Compliant Parts】 Approved By Checked By Issued By ShenZhen Volume Source Electronics Co., Ltd. Address: 16th Floor, Building T5-N4, Tian'an Digital City, Fenggang, Dongguan Tel: 0769-89891993 Fax: 0769-89891993-806 【For Customer approval Only】 Qualification Status: Approved By Comments: □Full Date: □Restricted Verified By □Rejected Re-checked By Checked By 【Version change history】 Rev. Effective Date Changed Contents Change Reasons Approved By 01 / New released / Luyong Han Applications: ●Laptops and PCs ●Switchs and servers ●Base stations ●DC/DC converters Features : ●RoHS, Halogen Free and REACH Compliance ●High rated current ●Ultra low buzz noise 1. Product physical map 2. Dimension (mm) 3. Schematic Marking A 12.6±0.3 B 13.8Max C 6.0Max D 3.7 E 2.7±0.7 H 5.5 I 4.0 Characteristics : ●Saturation Current(Isat):The current when the inductance Becomes 30% lower than is initial value.(Ta=20℃). ●Temperature Rise Current(Irms):The current when the temperature of coil increases up to max.ΔT=40℃.(Ta=20℃). ●Operating temperature : -40℃~+125℃. ●Storage temperature range (packaging conditions): -5℃~+30℃ and RH 70% (Max.) Test equipments : ●L&Q: HP 4285A or HP 4284A,VE116/VE7210. ●DCR: Milli-ohm meter,VR131. ●Electrical specifications at 25℃. J 10.5 Electrical Characteristics RDC Isat Irms (mΩ)Max (A)Typ. (A)Typ. 100KHz/0.25V 6.0 26.0 18.0 2R2 3.3±20% 100KHz/0.25V 9.0 23.0 14.0 3R3 VEPD1260-4R7M-A 4.7±20% 100KHz/0.25V 11.0 20.0 12.8 4R7 VEPD1260-6R8M-A 6.8±20% 100KHz/0.25V 13.8 15.0 11.5 6R8 VEPD1260-8R2M-A 8.2±20% 100KHz/0.25V 16.0 13.5 11.0 8R2 VEPD1260-100M-A 10±20% 100KHz/0.25V 20.7 12.5 10.0 100 VEPD1260-120M-A 12±20% 100KHz/0.25V 23.0 10.0 7.0 120 VEPD1260-150M-A 15±20% 100KHz/0.25V 29.0 9.0 6.0 150 VEPD1260-180M-A 18±20% 100KHz/0.25V 35.0 8.0 5.0 180 VEPD1260-220M-A 22±20% 100KHz/0.25V 45.5 7.5 4.8 220 VEPD1260-270M-A 27±20% 100KHz/0.25V 56.0 6.5 4.0 270 VEPD1260-330M-A 33±20% 100KHz/0.25V 75.0 6.0 3.9 330 VEPD1260-470M-A 47±20% 100KHz/0.25V 90.0 5.5 3.5 470 VEPD1260-680M-A 68±20% 100KHz/0.25V 130.0 4.5 3.25 680 VEPD1260-820M-A 82±20% 100KHz/0.25V 140.0 4.0 3.0 820 VEPD1260-101M-A 100±20% 100KHz/0.25V 200.0 3.5 2.5 101 VEPD1260-121M-A 120±20% 100KHz/0.25V 235.0 3.2 2.3 121 VEPD1260-151M-A 150±20% 100KHz/0.25V 350.0 2.7 2.0 151 Inductance ( uH ) Test Frequency VEPD1260-2R2M-A 2.2±20% VEPD1260-3R3M-A Part No. Test Instruments WK3260B Impedance / Material Analyzer Marking Packing method 1. Packing quantity of each reel: 500PCS/R (14-25PCS not packed at the beginning and end), affixed with the correct label, and then placed into a plastic bag (plastic bag size: 360x460mm), with a package of desiccant, sealing, reel and carrying tape dimensions. Fig. 1-1 Fig .1-1 Reel dimensions ,general tolerance (±0.5mm) A B C W D Ф330 Ф100 Ф13.5 24.5 30.5 The general tolerance, of carrier size is ±
VEPD1260-100M-A 价格&库存
很抱歉,暂时无法提供与“VEPD1260-100M-A”相匹配的价格&库存,您可以联系我们找货
VEPD1260-100M-A
  • 5+0.83000
  • 20+0.75500
  • 100+0.68000
  • 500+0.60500
  • 1000+0.57000
  • 2000+0.54500
