NCA1051
High-speed CAN Transceiver
Datasheet (EN) 1.1
Product Overview
The NCA1051 is a high-speed CAN transceiver that
provides an interface between a Controller Area Network
(CAN) protocol controller and the physical two-wire CAN
bus, which can support at least 110 CAN nodes. The
NCA1051 implements the CAN physical layer as defined in
ISO 11898-2:2016 and SAE J2284-1 to SAE J2284-5. This
implementation enables reliable communication in the
CAN FD fast phase at data rates up to 5 Mbit/s. The
NCA1051 provides thermal protection and transmit data
dominant time out function.
These features make the NCA1051 an excellent choice for
all types of HS-CAN networks, in nodes that do not require
a silent mode with wake-up capability via the bus.
Key Features
Applications
5Mbps operation in highly loaded CAN networks down to
10 kbps networks using TXD DTO
Industrial automation, control, sensors, and drive
systems
Building, security, and climate control automation
CAN bus standards such as CANopen、DeviceNet、
NMEA2000、ARNIC825、ISO11783 and CANaerospace
Device Information
Part Number
NCA1051-DSPR
Package
SOP8
Body Size
4.90mm × 3.90mm
NCA1051N-DSPR
SOP8
4.90mm × 3.90mm
Fully compatible with the ISO11898-2 standard
Ideal passive behavior to the CAN bus when the supply
voltage is off
Functional Block Diagrams
NCA1051 can be interfaced directly to micro controllers
with supply voltage from 3V to 5V
Bus fault protection of -70V to +70V
Transmit data (TXD) dominant time out function
Over current and over temperature protection
Date rate: up to 5Mbps
Low loop delay:
很抱歉,暂时无法提供与“NCA1051N-DSPR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.04700
- 10+3.98860
- 30+3.45940
- 100+2.93020
