Pin #
SIGNAL NAME DESCRIPTION
MATING
SEQUENCE
1
VBUS
POWER
SECOND
2
D-
THIRD
3
D+
USB 2.0
DIFFERENTIAL PAIR
4
5
GND
GROUND FOR POWER RETURN
SECOND
StdA_SSRX-
SUPERSPEED RECEIVER
DIFFERENTIAL PAIR
LAST
6
StdA_SSRX+
7
GND_DRAIN
GROUND FOR SIGNAL RETURN
8
StdA_SSTX-
9
SUPERSPEED TRANSMITTER
DIFFERENTIAL PAIR
StdA_SSTX+
Shell
Shield
CONNECTOR METAL SHELL
Material
Housing Material: LCP, UL94V-0, blue
Contact Terminal: Brass
Metallic Shell:Brass
Plating
Underplating: Nickel
Contact Plating: 1µ" Gold
Solder Tail: 100µ" Min. Tin
Metallic Shell: Nickel
Electrical
Voltage Rating: 100 V AC
Current Rating: 1.5A
Contact Resistance: 30mΩ Max.
Insulation resistance: 1000MΩ Min.
Dielectric withstanding voltage: 100V AC/Minute
Mechanical
Durability: 1500 cycles
Mating Force: 35N (3.57Kgf) Max
Unmating Force: 10N (1.02Kgf) Min. initial, 8N min after test
Environmental and Processing
Operating Temperature: -40°C to +85°C
FRIST
6.59 [0.259]
5.60 [0.220]
POS 9
3.89 [0.153]
2.20 [0.087]
1.61 [0.063]
18.30 [0.720]
12.21 [0.481]
12.90 [0.508]
A
14.26 [0.561]
POS 5
2.00 [0.079]
2.71 [0.107]
2.00 [0.079]
4.00 [0.157]
10.30 [0.406]
A
8.45 [0.333]
1.87 [0.074]
14.40 [0.567]±0.3
12.00 [0.472]
12.04 [0.474]
8.50 [0.335]
1.77 [0.070]
2.00 [0.079]
U235-09XN-4BLRC16-2
1.75 [0.069]
Ø0.70 [Ø0.028]
2.00 [0.079]
0.1
5
6
7
8
2
1
3
4
9
A
B
1:Au 1U"
5:Au 15U"
6:Au 30U"
T:TIN
N:NICKEL
Ø0.92 [Ø0.036]
0.1
A
B
Ø2.30 [Ø0.091](2x)
10.30 [0.406]
2.71 [0.107]
0.50 [0.020](5X)
2.50 [0.098]
5.00 [0.197]
8.50 [0.335]
A
2.50 [0.098]
4.77 [0.188]
CONNECTOR FRONT EDGE
RECOMMANDED PCBA LAYOUT
X
X
X
MARK
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
B
REVISED
APPROVED
ANGLAR
L≤4
4
U235-091N-4BLRC16-2 价格&库存
很抱歉,暂时无法提供与“U235-091N-4BLRC16-2”相匹配的价格&库存,您可以联系我们找货
