【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】
www.yxc.hk
YSX321SL
Features
. External dimensions: 3.2 x 2.5 x 0.7 mm.
. Frequency range: 8MHz ~ 64MHz.
C
Y X
X
X X
.High precision and high frequency stability.
.Extremely good for reducing EMI effect.
.RoHS Compliant / Pb Free.
The best choice of Bluetooth, wireless communication set, DSC, PDA
and mobile phone.
Electrical Specifications
Item / Type
YSX321SL
8 ~ 64 MHz
Vibration Mode
AT Fundamental
Load Capacitance
12 pF, 20 pF, or specify
Remark : Speci
mark : Speci
Nominal Frequency Range
Frequency Tolerance (at 25 ℃)
± 10 ppm, ± 20 ppm, or specify
Frequency Versus Temperature Characteristics
Operating Temperature
- 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify
Storage Temperature
Shunt Capacitance
7 pF Max.
Level Of Drive
1 ~100 μW Max. (10 uW typical)
Frequency Aging (at 25 ℃)
± 3 ppm / year Max.
Insulation Resistance
More Than 500MΩ at DC 100V
Equivalent Series Resistance(ESR)
Fundamental
8 ~ 11.2892
MHz
150 Ω Max.
12 ~ 16 MHz
80 Ω Max.
17 ~ 64 MHz
50 Ω Max.
Dimensions
YXC
12.0XXX
Units: mm
come visit our site http://www.yxc.hk
1/2
www.yxc.hk
YSX321SL
★ PART NUMBER GUIDE 部件号示例 e.g. X322512MSB4 SC
Quartz Crystal Resonator Dimensions Frequency Load Capacitance
(Hz)
(Pf)
X
12M
3225
Frequency
Stability Pin
Overall
(ppm)
S
★ TAPING SPECIFICATION (Unit: mm)
4.0
YSX321SL =3.2×2..5 SMD SEAM TYPE
4
B
Material
Operating Temp.
Range
S
C
编带规格
φ1.95
1.1
12
0°
φ13
5.1
C
B
D
SMD3225
G
A
F
E
A
B
C
178±2.0
8.03±0.3
D
3.81±0.10
3.04±0.10
E
F
G
3.84±0.1
1.54±0.10
62.0±1.0
3000 pcs per reel
★ REFLOW SOLDERING PROFILE 回流焊特性
Temperature (℃)
260℃ max
220℃
180℃
③
①
②
Times (S)
Pb free reflow
A
①
Preheat
160~180℃
②
Primary heat 220℃
60sec. max
③
Peak
10sec. max.
260℃
2/2
120sec. max
很抱歉,暂时无法提供与“X32258MSB4SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65020
- 50+0.62610
- 150+0.60200
- 500+0.57790
- 1000+0.55390
- 国内价格
- 1+0.61880
- 30+0.59605
- 100+0.57330
- 500+0.52780
- 1000+0.50505
- 2000+0.49140
- 国内价格
- 1+0.84436
- 200+0.58176
- 1500+0.52924
- 3000+0.49490
- 国内价格
- 5+1.12634
- 50+0.85299
- 150+0.71950
- 500+0.60038
- 3000+0.53266
- 6000+0.51300
- 国内价格
- 1+0.53560
- 500+0.51550
- 1000+0.51320
- 国内价格
- 10+2.19320
- 100+1.30820
- 800+0.91570
- 3000+0.65410
- 6000+0.62150
- 30000+0.57560
