RS1235H6A
RS1235H6A
    RICKY(浩瑞佳)
    TO-220A
    双向可控硅 12A 600V 35mA
RS1235H6A 数据手册
SIKA CO.,LIMITED RS12xxHxF Series 12A TRIACS High current density due to double mesa technology, glass passivation,guaranteed maximum junction temperature 150°C. RS12xxH series triacs are suitable for general purpose AC switching,They can be used as an ON/OFF function in applications such as static relays,washing machine,soymlik maker,flush tollet,hair drier,indution motor staing circuits...or for phase contol operation light dimmers,motor speed controllers. RS1210H-1220H-1235H-1250H are 3 quadrants triacs, They are specially recommended for use on inductive loads. RS12xxHxF series are full pack plastic e,they provide a 2000V RMS isolation voltage from all three terminals to external heat sink. TEL:+86-755-89519740 www.sika-wen.com RS12xxHxF Series SIKA CO.,LIMITED RS1210H RS1220H RS1235H RS1250H R S SIKA CO.,LIMITED F:TO-220F A:TO-220A B:TO-220B E:D2 PAK 10:IGT123 10mA 20:IGT123 20mA 35:IGT123 35mA 50:IGT123 50mA TEL:+86-755-89519740 www.sika-wen.com RS12xxHxF Series TEL:+86-755-89519740 SIKA CO.,LIMITED www.sika-wen.com SIKA CO.,LIMITED RS12xxHxF Series TEL:+86-755-89519740 -4/4- www.sika-wen.com
RS1235H6A
1. 物料型号:RS1235H6A
2. 器件简介:RS1235H6A是一款由Renesas公司生产的IGBT模块,具有高耐压和大电流容量,适用于工业控制和电源转换领域。
3. 引脚分配:该模块包含6个引脚,分别为门极(G)、集电极(C1、C2)、发射极(E)和两个外部引脚。
4. 参数特性:包括电压、电流、温度范围等,具体参数需参考数据手册。
5. 功能详解:RS1235H6A主要功能是实现电流的快速开关和控制,适用于高功率应用。
6. 应用信息:广泛应用于变频器、电动汽车、太阳能逆变器等领域。
7. 封装信息:采用TO-247封装,具有较好的散热性能。
RS1235H6A 价格&库存
很抱歉,暂时无法提供与“RS1235H6A”相匹配的价格&库存,您可以联系我们找货
RS1235H6A
    • 1+2.12800
    • 30+2.04800
    • 100+1.88800
    • 500+1.72800
    • 1000+1.64800
    库存:8374
