SM-42TA104
SM-42TA104
    NIDEC(尼得科)
    SMD-3P,4.8x4.6mm
    可调电阻/电位器 100KΩ ±10% 250mW SMD-3P,4.8x4.6mm ±100ppm/℃
SM-42TA104 数据手册
SURFACE MOUNT CERMET TRIMMERS RoHS compliant SM-42/43 INTERNAL STRUCTURE 9 1 2 3 8 4 5 7 6 Part name ■ FEATURES ● RoHS compliant ● Fine adjustment is available ● Automatic mounting is available (Taping) ● Reflow soldering is available ● Sealed construction (Washable: Refer to page 698.) Material Flammability Polyphenylenesulphide UL94V-0 1 Housing 2 Base element 3 Electrode Ag-Pd cermet 4 Resistive element RuO2 cermet 5 Adhesive 6 Wiper 7 Terminal pin 8 Rotor gear 9 Shaft Ceramic — Epoxy Multi metal alloy Copper alloy, Sn-Cu-plated Polyamide UL94V-0 Brass, Nickel-plated — ■ PART NUMBER DESIGNATION S M - 4 □ T W 1 0 0Ω ( 1 0 1 ) Series name Resistance code Electrical turn Resistance value 2:11 turns 3:5 turns Form of packaging Product shape (Shape of terminal) T:Taping (Reel) Blank:Bulk in plastic bag W, X:Top adjustmet A, B:Side adjustmet ※ Please refer to the LIST OF PART NUMBERS when placing orders. SM-42/43 SURFACE MOUNT TRIMMERS ■ LIST OF PART NUMBERS Electrical turn Form of packaging Adjustment Shape of terminal position Top adjustment 11 Side adjustment Top adjustment 5 Side adjustment 〈Nominal resistance values〉 Plastic bag 10 k Ω 20 k Ω 50 k Ω 100 k Ω 200 k Ω 500 k Ω 1 M Ω 2 M Ω W (J-hook) SM-42TW SM-42W The products indicated by A mark are manufactured upon receipt of order basis. X (Gull wing) SM-42TX SM-42X (J リード) A (J-hook) SM-42TA SM-42A B (Gull wing) ※The above part numbers are all available with the respective combination of (Fig. 1). ※ Verify the above part numbers when placing orders. ※ Taping specification is not sold separately and must be purchased in reel units. SM-42TB SM-42B W (J-hook) SM-43TW SM-43W X (Gull wing) SM-43TX SM-43X A (J-hook) SM-43TA SM-43A B (Gull wing) SM-43TB SM-43B TA, TB : 500 pcs./reel TW, TX : 250 pcs./reel 50 pcs./pack Pieces in package ■ ELECTRICAL CHARACTERISTICS Effective electrical turn 11 turns (SM-42), 5 turns (SM-43) End resistance 1 % or 2 Ω , whichever is greater C.R.V. 1 % or 3 Ω , whichever is greater − 65 ~ 150 °C Operating temp. range ± 100 10 /°C maximum -6 100 M Ω minimum (DC500 V) Dielectric strength AC600 V, 60 s Net weight Approx. 0.17 g 〈Reflow profile for soldering heat evaluation〉 Temperature 100 50 200 cycles [ Δ R/R ≦ ± (3 Ω +3 %)] Thrust to shaft 5 N {0.51 kgf} minimum Width 90 mm, bend 3 mm, 5 s, 1 time 100 mA or power rating, whichever is smaller Peak : 250 +5 0 ℃ Over 230 ℃ 150 ℃ Rotational life Substrate bending Maximum wiper current 150 Clutch action 0.25 W (85 °C) 0 W (150 °C) DC300 V or power rating, whichever is smaller 180 ℃ Mechanical stop 5 N {0.51 kgf} 10 s Maximum input voltage 200 17.6 mN·m {180 gf·cm} maximum Shear (Adhesion) Linear law (℃) 250 Operating torque ± 10 % Resistance law Insulation resistance ■ MECHANICAL CHARACTERISTICS 245 ± 3 °C, 2 ~ 3 s Resistance tolerance Temp. coefficient Fig. 1 Solderability 10 Ω ~ 2 M Ω Nominal resistance range Power ratings A10 Ω A20 Ω 50 Ω 100 Ω 200 Ω 500 Ω 1 k Ω 2 k Ω 5 k Ω Taping (reel) Pull-off strength 5 N {0.51 kgf} 10 s { }:Reference only ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions Thermal shock − 65 ~ 150 °C (0.5 h), 5 cycles [ Δ R/R ≦ 2 %] [S.S. ≦ 1 %] Humidity [ Δ R/R ≦ 2 %] Shock − 10 ~ 65 °C (80 ~ 98 %), 10 cycles, 240 h 981 m/s2, 6 ms 6 directions for 3 times each Vibration (Amplitude) 1.52 mm or (Acceleration) 196 m/s2, 10 ~ 2000 Hz, 3 directions, 12 times each Load life 85 °C, 0.25 W, 1000 h Low temp. operation − 65 °C, 2 h High temp. exposure 150 °C, 250 h Immersion seal 85 °C, 60 s Reflow : Peak temperature 255 °C (Please refer to the profile below.) Soldering heat Manual soldering:350 ± 10 °C, 3 ~ 4 s Pre Heating Zone 90 ± 30 s Specifications [ Δ R/R ≦ 1 %] [S.S. ≦ 1 %] [ Δ R/R ≦ 3 % or 3 Ω ] [S.S. ≦ 2 %] [ Δ R/R ≦ 1 %] [S.S. ≦ 1 %] [ Δ R/R ≦ 2 %] [S.S. ≦ 1 %] No leaks (No continuous bubbles) [ Δ R/R ≦ 1 %] 30 ± 10 s Heating time Soldering Zone Reflow : two times maximum Δ R/R:Change in total resistance S.S. :Setting stability SM-42/43 SURFACE MOUNT TRIMMERS ■ MAXIMUM INPUT RATINGS Nominal resistance Resistance code Maximum input values ( Ω ) voltage (V) Maximum wiper current (mA) A 10 A 20 50 100 200 500 100 200 500 101 201 501 1.00 2.00 3.53 5.00 7.07 11.2 100 100 70.7 50.0 35.4 22.4 1 k 2 k 5 k 10 k 20 k 50 k 102 202 502 103 203 503 15.8 22.4 35.4 50.0 70.7 112 15.8 11.2 7.07 5.00 3.54 2.24 100 k 200 k 500 k 1 M 2 M 104 204 504 105 205 158 223 300 300 300 1.58 1.12 0.60 0.30 0.15 The products indicated by A mark are manufactured upon receipt of order basis. ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS ● SM-42/43B ● SM-42/43X 2 2 2.3 5.1 0 2.3 1.3 2.54 1.3 1.9 1.3 1.3 2.9 0 1.6 5.2 0 2 0 4 1.6 2 1.9 2 2 ● SM-42/43W 1.3 ● SM-42/43A (Unit: mm) 2.54 1.3 Note) The zero point is the center of mounting. SM-42/43 SURFACE MOUNT TRIMMERS ■ OUTLINE DIMENSIONS ● SM-42/43W 3.9 1 Resistance code & Production date code 3.5 3 CW rotation 2 ※ Note the terminal position. 3 – 0.9 1.2 4.8 2.54 2 1.3 1 2 – 0.8 Unless otherwise specified, tolerance : ± 0.3(Unit : mm) φ 1.5, Slot 3 0.56W × 0.5D 5.1 2.6 3–1 5.3 ● SM-42/43X 5.7 Resistance code & Production date code 3.5 2 2 – 0.8 1.2 4.8 2.54 1.3 1 φ 1.5, Slot 0.56W × 0.5D 3 5.1 3–1 5.3 ● SM-42/43A 3.7 3 – 0.8 Resistan ce code & Produ ction d ate code ① 2 – 0.9 4.8 1.2 1.3 2.3 3–1 ② φ 1.5, Slot 0.56W × 0.5D 2.6 ③ 4.6 5 ● SM-42/43B 1 1.2 2.3 1.3 4.8 2 2 – 0.9 φ 1.5, Slot 0.56W × 0.5D 2.8 4.6 6 3 3 – 0.6 3.9 Resistance code & Production date code SM-42/43 SURFACE MOUNT TRIMMERS ■ PACKAGING SPECIFICATIONS Maximum number of consecutive missing pieces = 2 Leader length and reel dimension are shown in the diagrams below. ● Taping version (SM-42/43TA, TB) is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. SM-42/43TW, TX is packaged in 250 pcs. per reel. Orders will be accepted for units of 250 pcs., i.e., 500, 750 pcs., etc. ● EMBOSSED TAPE DIMENSIONS ● REEL DIMENSIONS (Conforms to JIS C 0806-3) (TA/TB type : In accordance with EIAJ ET-7200A) Empty Filled (Unit: mm) Empty +1 Head 40 mm min. 21±0.8 20 pitches min. 2±0.5 Direction of feed 60 Leader +1 0 End 13 0 (TA/TB) 17±0.3 (TW, TX) 400 mm min. 13±0.2 0 180 –1.5 (TA/TB) 0 180 –3 (TW, TX) A 1 12 ± 0.1 1.75 ± 0.1 5.5 ± 0.05 1 2 ± 0.1 3 5.75 Cross section A-A ● Unit of bulk in a plastic bag is 50 pcs. per pack. ● Boxing of bulk in a plastic bag is performed with 200 pcs. per box. 2 A 8 ± 0.1 0.4 ± 0.1 Installation example (SM-42A) 12 A .1 +0 0 2 4 ± 0.1 5 1. 7.5 ± 0.1 3 0.5 ± 0.1 Installation example (SM-42W) +0.3 2 ± 0.1 φ .1 +0 0 .5 φ1 A ● SM-42/43TA/TB 16 –0.1 4 ± 0.1 1.75 ± 0.1 ● SM-42/43TW/TX 15.4±1 (TA/TB) 19.5±1 (TW/TX) 4.5 Cross section A-A
SM-42TA104 价格&库存
很抱歉,暂时无法提供与“SM-42TA104”相匹配的价格&库存,您可以联系我们找货
SM-42TA104
  • 1+27.979931+3.61921
  • 10+23.3336810+3.01822
  • 25+21.6711125+2.80316
  • 50+20.4900250+2.65039
  • 100+19.36847100+2.50532
  • 250+17.97285250+2.32479
库存:7177
SM-42TA104
  • 1+8.80601
  • 30+8.50851
  • 100+7.91351
  • 500+7.31850
  • 1000+7.02100
SM-42TA104
  • 500+16.98036500+2.19641
  • 1000+16.040311000+2.07482
  • 1500+15.513811500+2.00671
  • 2500+14.874382500+1.92400
  • 3500+14.467283500+1.87135
  • 5000+14.047705000+1.81707
库存:7177
SM-42TA104
  • 1+38.83415
  • 10+26.75558
  • 100+22.85199
  • 500+16.99068
  • 1000+15.29399
  • 2000+14.99736
SM-42TA104
  • 1+27.789001+3.60250
  • 10+23.2373010+3.01240
  • 25+20.4345025+2.64910
  • 100+19.28460100+2.50000
  • 250+17.88320250+2.31830
  • 500+16.82910500+2.18170
  • 1000+15.343801000+1.98920
  • 2500+14.289802500+1.85250
  • 5000+13.942405000+1.80750
