AMCW4532B-2-510T
AMCW4532B-2-510T
    SUNLORD(顺络)
    SMD,4.5x3.2mm
    共模滤波器 SMD,4.5x3.2mm 230mA 1Ω
AMCW4532B-2-510T 数据手册
Wire Wound Chip Common Mode Choke Coil –AMCW-B Series Operating Temp. : -40℃~+150℃ FEATURES     Winding type realizes small size and low profile Prevention of common mode noise at high frequency Excellent solderability AEC-Q200 verified APPLICATIONS  Common mode noise filtering for automotive CAN-BUS and signal line. PRODUCT IDENTIFICATION AMCW 3225 B ① ② ③ ① AMCW -2 -110 ④ ⑥ ③ ② Type Winding Type Common Mode Choke Coil T ⑤ Code External Dimensions (L×W) (mm) 3225 [1210] 3.2×2.5 4532 [1812] 4.5×3.2 B for CAN-BUS ⑤ Example 110 220 510 101 ④ Number of Lines 2 Inductance(μH) Nominal Value 11 22 51 100 ⑥ Packing T Tape & Reel SHAPE AND DIMENSIONS AMCW3225B TYPE Recommended Land Pattern Unit: mm Sunlord Part Number A AMCW3225B-2-110T/220T 0.80mm AMCW3225B-2-510T/101T 0.70mm Specifications subject to change without notice. Please check our website for latest information. Revised 2019/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SHAPE AND DIMENSIONS AMCW4532B TYPE Recommended Land Pattern Unit:mm SPECIFICATIONS AMCW3225B TYPE Part Number Inductance Units Symbol AMCW3225B-2-110T AMCW3225B-2-220T AMCW3225B-2-510T AMCW3225B-2-101T +50%/-30% μH L 11(@100KHz/0.1V) 22(@100KHz/0.1V) 51(@100KHz/0.1V) 100(@100KHz/0.1V) DC Resistance Max. Ω DCR 0.3 0.5 1.5 2.2 Rated Current Rated Voltage Max. mA Ir 400 300 200 150 Max. Volts VDC 80 80 80 80 Rated Current Rated Voltage Max. mA Ir 360 310 230 200 Max. Volts VDC 50 50 50 50 Insulation Resistance Min. MΩ IR 10 10 10 10 AMCW4532B TYPE Part Number Inductance Units Symbol AMCW4532B-2-110T AMCW4532B-2-220T AMCW4532B-2-510T AMCW4532B-2-101T +50%/-30% μH L 11(@100KHz/0.1V) 22(@100KHz/0.1V) 51(@1.0MHz/0.1V) 100(@1.0MHz/0.1V) DC Resistance Max. Ω DCR 0.5 0.8 1.0 2.0 Insulation Resistance Min. MΩ IR 10 10 10 10 ※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales. EQUIVALENT CIRCUIT Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2019/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs. Frequency AMCW3225B TYPE Impedance vs. Frequency AMCW4532B TYPE Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2019/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
AMCW4532B-2-510T 价格&库存
很抱歉,暂时无法提供与“AMCW4532B-2-510T”相匹配的价格&库存,您可以联系我们找货
