ESD5341N
ESD5341N
    WILLSEMI(韦尔)
    DFN1006-2
    TVS二极管 VRWM=5V VBR(Min)=7V VC=15V IPP=4A Ppp=60W DFN1006-2L
ESD5341N 数据手册
ESD5341N ESD5341N 1-Line, Uni-directional, Low Capacitance http//:www.sh-willsemi.com Transient Voltage Suppressor Descriptions The ESD5341N is a low capacitance TVS (Transient Voltage Suppressor) designed to protect high speed data interfaces. It has been specifically designed to protect sensitive electronic components which are connected to data and transmission lines from over-stress DFN1006-2L (Bottom View) caused by ESD (Electrostatic Discharge). The ESD5341N incorporates one pair of low capacitance steering diodes plus a TVS diode. The ESD5341N may be used to provide ESD protection up to Pin1 Pin2 ±20kV (contact discharge) according to IEC61000-4-2, and withstand peak pulse current up to 4A (8/20μs) according to IEC61000-4-5. Circuit diagram The ESD5341N is available in DFN1006-2L package. Standard products are Pb-free and Halogen-free. Features  Stand-off voltage: 5V max.  Transient protection for each line according to Pin1 * = Month code ( A~Z) IEC61000-4-4 (EFT): 40A (5/50ns) Marking (Top View) IEC61000-4-5 (surge): 4A (8/20μs)  Low capacitance: CJ = 1.0pF typ.  Ultra-low leakage current: IR
ESD5341N
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现四路模拟信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN-16封装,尺寸为4x4mm。
ESD5341N 价格&库存
很抱歉,暂时无法提供与“ESD5341N”相匹配的价格&库存,您可以联系我们找货
