HEF4027BT,653
HEF4027BT,653
    NEXPERIA(安世)
    SOIC-16
    双JK触发器
HEF4027BT,653 数据手册
HEF4027B Dual JK flip-flop Rev. 11 — 7 December 2021 Product data sheet 1. General description The HEF4027B is a dual positive-edge triggered JK flip-flop featuring independent set direct (nSD), clear direct (nCD), clock inputs (nCP) and complementary outputs (nQ and nQ). Data is accepted when nCP is LOW, and transferred to the output on the positive-going edge of the clock. The asynchronous clear-direct (nCD) and set-direct (nSD) are independent and override the nJ, nK, and nCP inputs. Schmitt-trigger action in the clock input makes the circuit highly tolerant to slower clock rise and fall times. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VDD. 2. Features and benefits • • • • • • • • • Wide supply voltage range from 3.0 V to 15.0 V CMOS low power dissipation High noise immunity Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Complies with JEDEC standard JESD 13-B ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-B exceeds 200 V Specified from -40 °C to +85 °C 3. Applications • • • Registers Counters Control circuits 4. Ordering information Table 1. Ordering information Type number Package HEF4027BT Temperature range Name Description Version -40 °C to +85 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4027B Nexperia Dual JK flip-flop 5. Functional diagram FF 1 9 1SD 10 1J 13 1CP 11 1K 1Q 15 1Q 14 2Q 1 2Q 2 1CD 12 FF 2 7 2SD 6 2J 3 2CP 5 2K 2CD 4 001aae593 Fig. 1. Functional diagram CP C J Q C C C C C C C Q K C C CD SD Fig. 2. 001aae595 Logic diagram of one flip-flop HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 2 / 11 HEF4027B Nexperia Dual JK flip-flop 6. Pinning information 6.1. Pinning HEF4027B 2Q 1 16 VDD 2Q 2 15 1Q 2CP 3 14 1Q 2CD 4 13 1CP 2K 5 12 1CD 2J 6 11 1K 2SD 7 10 1J VSS 8 9 1SD 001aae594 Fig. 3. Pin configuration SOT109-1 (SO16) 6.2. Pin description Table 2. Pin description Symbol Pin Description VSS 8 ground supply voltage 1SD, 2SD 9, 7 asynchronous set-direct input (active HIGH) 1J, 2J 10, 6 synchronous input 1K, 2K 11, 5 synchronous input 1CD, 2CD 12, 4 asynchronous clear-direct input (active HIGH) 1CP, 2CP 13, 3 clock input (LOW-to-HIGH edge-triggered) 1Q, 2Q 14, 2 complement output 1Q, 2Q 15, 1 true output VDD 16 supply voltage 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care.; ↑ = positive-going transition. Inputs Outputs nSD nCD nCP nJ nK nQ nQ H L X X X H L L H X X X L H H H X X X H H L L ↑ L L no change no change L L ↑ H L H L L L ↑ L H L H L L ↑ H H nQ nQ HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 3 / 11 HEF4027B Nexperia Dual JK flip-flop 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O Conditions Min Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA input/output current - ±10 mA IDD supply current - 50 mA Tstg storage temperature -65 +150 °C Tamb ambient temperature in free air -40 +85 °C Ptot total power dissipation Tamb -40 °C to +85 °C - 500 mW P power dissipation per output - 100 mW VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V V 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Min Max VDD supply voltage Conditions 3 15 Unit V VI input voltage 0 VDD V Tamb ambient temperature in free air -40 +85 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - 3.75 μs/V VDD = 10 V - 0.5 μs/V VDD = 15 V - 0.08 μs/V 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter Conditions VDD Min Max Min Max Min Max VIH HIGH-level input voltage |IO| < 1 μA 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VIL VOH VOL LOW-level input voltage HIGH-level output voltage LOW-level output voltage HEF4027B Product data sheet |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA Tamb = -40 °C Tamb = +25 °C Tamb = +85 °C Unit All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 4 / 11 HEF4027B Nexperia Dual JK flip-flop Symbol IOH IOL Parameter Conditions HIGH-level output current LOW-level output current II input leakage current IDD supply current CI VDD Tamb = -40 °C Tamb = +25 °C Tamb = +85 °C Unit Min Max Min Max Min Max VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - ±0.3 - ±0.3 - ±1.0 μA 5V - 4.0 - 4.0 - 30 μA 10 V - 8.0 - 8.0 - 60 μA 15 V - 16.0 - 16.0 - 120 μA - - - - 7.5 - - pF Min Typ Max Unit IO = 0 A input capacitance mA 11. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 °C unless otherwise specified; for test circuit see Fig. 7. Symbol Parameter Conditions VDD Extrapolation formula [1] tPHL CP → Q, Q; see Fig. 4 5V 78 ns + (0.55 ns/pF)CL - 105 210 ns 10 V 29 ns + (0.23 ns/pF)CL - 40 80 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 60 ns 5V 93 ns + (0.55 ns/pF)CL - 120 240 ns 10 V 33 ns + (0.23 ns/pF)CL - 45 90 ns 15 V 27 ns + (0.16 ns/pF)CL - 35 70 ns 5V 113 ns + (0.55 ns/pF)CL - 140 280 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 58 ns + (0.55 ns/pF)CL - 85 170 ns 10 V 27 ns + (0.23 ns/pF)CL - 35 70 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 60 ns 5V 48 ns + (0.55 ns/pF)CL - 75 150 ns 10 V 24 ns + (0.23 ns/pF)CL - 35 70 ns 15 V 17 ns + (0.16 ns/pF)CL - 25 50 ns 5V 43 ns + (0.55 ns/pF)CL - 70 140 ns 10 V 19 ns + (0.23 ns/pF)CL - 30 60 ns 15 V 17 ns + (0.16 ns/pF)CL - 25 50 ns [2] 10 ns + (1.00 ns/pF)CL - 60 120 ns HIGH to LOW propagation delay CD → Q; see Fig. 4 SD → Q; see Fig. 4 tPLH LOW to HIGH propagation delay CP → Q, Q; see Fig. 4 CD → Q; see Fig. 4 SD → Q; see Fig. 4 tt tsu transition time set-up time HEF4027B Product data sheet see Fig. 4 J, K → CP; see Fig. 5 5V 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V 50 25 - ns 10 V 30 10 - ns 15 V 20 5 - ns All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 5 / 11 HEF4027B Nexperia Dual JK flip-flop Symbol Parameter Conditions VDD th J, K → CP; see Fig. 5 hold time tW pulse width trec recovery time fmax [1] [2] maximum frequency Extrapolation formula [1] Min Typ Max Unit 5V 25 0 - ns 10 V 20 0 - ns 15 V 15 5 - ns CP LOW; minimum width; see Fig. 5 5V 80 40 - ns 10 V 30 15 - ns 15 V 24 12 - ns SD, CD HIGH; minimum width; see Fig. 6 5V 90 45 - ns 10 V 40 20 - ns 15 V 30 15 - ns SD, CD inputs; see Fig. 6 5V +20 -15 - ns 10 V +15 -10 - ns 15 V +10 -5 - ns CP input; J = K = HIGH; see Fig. 5 5V 4 8 - MHz 10 V 12 25 - MHz 15 V 15 30 - MHz The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). tt is the same as tTLH and tTHL. Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol PD Parameter dynamic power dissipation VDD Typical formula for PD (μW) 5V PD = 900 × fi + Σ(fo × CL) × VDD Where: 2 fi = input frequency in MHz fo = output frequency in MHz CL = output load capacitance in pF VDD = supply voltage in V Σ(fo × CL) = sum of the outputs 2 10 V PD = 4500 × fi + Σ(fo × CL) × VDD 15 V PD = 13200 × fi + Σ(fo × CL) × VDD 2 11.1. Waveforms and test circuit tr VI SD, CD or CP INPUT 0V tf 90 % 10 % VM tPLH VOH Q or Q OUTPUT VOL tPHL 90 % VM 10 % tTLH tTHL 001aah863 VOH and VOL are typical output voltages levels that occur with the output load. Measurement points are given in Table 9. Fig. 4. Waveforms showing rise, fall, and transition times, and propagation delays HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 6 / 11 HEF4027B Nexperia Dual JK flip-flop 1/fmax CP INPUT tW VM th J,K INPUT VM tsu 001aae596 Measurement points are given in Table 9. Fig. 5. Waveforms showing set-up times, hold times, and minimum clock pulse width VI SD INPUT VM 0V tW VI VM CD INPUT 0V tW trec trec VI CP INPUT VM 0V VOH Q OUTPUT VOL 001aae597 VOH and VOL are typical output voltages levels that occur with the output load. Measurement points are given in Table 9. Fig. 6. Waveforms showing pulse widths and recovery times Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD VDD G VI VO DUT CL RT 001aag182 Test data is given in Table 10. Definitions for test circuit: CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig. 7. Test circuit Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD ≤ 20 ns 50 pF HEF4027B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 7 / 11 HEF4027B Nexperia Dual JK flip-flop 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 8 / 11 HEF4027B Nexperia Dual JK flip-flop 13. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4027B v.11 20211207 Product data sheet - HEF4027B v.10 Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 and Section 2 updated. Section 13 added. HEF4027B v.10 20160321 Modifications: • HEF4027B v.9 20111118 Modifications: • • HEF4027B v.8 20111010 HEF4027B v.7 20091125 HEF4027B v.6 Product data sheet - HEF4027B v.9 Type number HEF4027BP (SOT38-4) removed. - HEF4027B v.8 Product data sheet - HEF4027B v.7 Product data sheet - HEF4027B v.6 20090624 Product data sheet - HEF4027B v.5 HEF4027B v.5 20081110 Product data sheet - HEF4027B v.4 HEF4027B v.4 20080703 Product specification - HEF4027B_CNV v.3 HEF4027B_CNV v.3 19950101 Product specification - HEF4027B_CNV v.2 HEF4027B_CNV v.2 19950101 Product specification - - HEF4027B Product data sheet Product data sheet Legal pages updated. Changes in Section 1 and Section 2 All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 9 / 11 HEF4027B Nexperia Dual JK flip-flop 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal HEF4027B Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 10 / 11 HEF4027B Nexperia Dual JK flip-flop Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................5 11.1. Waveforms and test circuit........................................ 6 12. Package outline.......................................................... 8 13. Abbreviations.............................................................. 9 14. Revision history..........................................................9 15. Legal information......................................................10 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 7 December 2021 HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 7 December 2021 © Nexperia B.V. 2021. All rights reserved 11 / 11
HEF4027BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4027BT,653”相匹配的价格&库存,您可以联系我们找货
HEF4027BT,653
    • 1+0.96920
    库存:3940
    HEF4027BT,653
    • 2500+1.224652500+0.15343
    • 5000+1.187215000+0.14874
    • 7500+1.168467500+0.14639
    • 12500+1.1476912500+0.14378
    • 17500+1.1355617500+0.14227
    • 25000+1.1238825000+0.14080
    • 62500+1.0987462500+0.13765
    库存:277
    HEF4027BT,653
      • 1+3.16501
      • 100+2.95401
      • 300+2.74301
      • 500+2.53200
      • 2000+2.42650
      • 5000+2.36320
      HEF4027BT,653
      • 2500+1.60178
      • 7500+1.57805
