TP10122634
TP10122634
    ROCPU(台普)
    SMD,4.1x3.4mm
    轻触开关 4.1*3.4*3.23mm 卧贴
TP10122634 数据手册
A B D C E 0.70±0.03 [0.027] 2.10±0.10[0.082] 3 A 0.55 [0.022] 0.55 [0.022] 0.55 [0.022] E C F B 3.80 [0.150] 2 1.10 [0.043] 1.60[0.062] B D 0.20±0.02 [0.008] A 0.03±0.01 [0.001] 1.90[0.075] 4.30 [0.169] 0.60 [0.024] 1.20±0.10[0.047] 1.20[0.046] 2 耐压:250V,AC,1Min Insulation resistance:≥100MΩ 绝缘电阻:≥100MΩ 1 Operating force:260±50g 操作力:260±50g Travel:0.20±0.05 行程:0.20±0.05 Life:200,000 times 寿命:200,000 times Main Specifications 主要技术指标 Climate grade:-30℃~70℃ 气候等级:-30℃~70℃ Rated values:0.5A/12V 额定值:0.5A/12V Contact resistance:≤50mΩ 接触电阻:≤50mΩ Dielectric strength:250V,AC,1Min 1.80[0.069] 0.20 [0.008] 1.60 [0.063] 4.10 [0.161] 2.20 [0.087] 3.23 [0.127] 0.20 [0.008] G 3.40 [0.134] 4.10 [0.161] 1 F 2-Ø0.9 [Ø0.035] 0.90[0.037] 0.80[0.033] 0.80[0.033] 3 3.20 [0.126] 1.25 [0.049] 2.5 [0.098] 6 5 Circuit Diagram 4 3 4 A B 2 1 Yellow membrane 黄膜 Cover plate 盖板 Plastic button 按钮 Shrapnel 弹片 Plastic base 塑胶底座 Pin 引脚 ITEM UNIT A4 COMMON DRAWN BY FUYUAN X.XX A2 ± 0.10 C:\ProgramData\cadconverter\output\121212211.pdf-2021-09-29-10-11-50-040-1-1.jpg A1 REV DATE REVISION DESCRIPTION A ISSUE B X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED DATE 2019 1 Phosphor copper 磷铜 1 PA 1 SUS 不锈钢 1 LCP 1 Phosphor copper 磷铜 1 Materials NUM yellow 黄色 silver 镀银 white 白色 silver 单面镀银 BLACK 黑色 silver 镀银 COLOR CHECKED BY COCO APPROVAL B ALEN MODEL NO: TP10122634 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 4 PRODUCT NAME: TOLERANCE A3 5 MM Name PI F G 5
TP10122634 价格&库存
很抱歉,暂时无法提供与“TP10122634”相匹配的价格&库存,您可以联系我们找货
TP10122634
    • 5+0.92006
    • 50+0.73181
    • 150+0.63774
    • 500+0.56722
    库存:1954
