TP10221618
TP10221618
    ROCPU(台普)
    SMD,4.65x3.6mm
    轻触开关 4.65*3.6*1.84mm 卧贴
TP10221618 数据手册
B D C 1.84±0.05 [0.072] 3.60[0.142] 2.45[0.096]±0.20 B 0.90[0.035] B 2.40[0.094] 1 4.35[0.171]±0.10 E F 0.75 [0.030]±0.03 G 耐压:250V,AC,1Min Insulation resistance:≥100MΩ 绝缘电阻:≥100MΩ Operating force:160±50g 操作力:160±50g Travel:0.20±0.05mm 行程:0.20±0.05mm Life:50,000 times 寿命:50,000 times Main Specifications 主要技术指标 Climate grade:-30℃~70℃ 气候等级:-30℃~70℃ Rated values:0.5A/12V 额定值:0.5A/12V Contact resistance:≤500mΩ 接触电阻:≤500mΩ Dielectric strength:250V,AC,1Min 0.03 [0.001]±0.04 A 1 0.85 [0.034]±0.10 2 2.00 [0.079]±0.10 2 R0 .10 3 3.40 [0.134] 0.40 [0.016] 5.10 [0.201] 0.20[0.008] 1.80[0.071] 1.05 [0.041] Circuit Diagram A 5] 0.03 90[ Ø0. 1 3 4.65[0.183]±0.20 2.55 [0.100] 4.35 [0.171] 4 7 Plastic upper cover 塑胶上盖 6 Yellow membrane 黄膜 Pin 引脚 base 塑胶底座 Shrapnel 弹片 Plastic key 塑胶按钮 Cover plate 盖板 5 1.85 [0.073] 3.45[0.136]±0.10 1.05 [0.041] 1.90 [0.075] B 1.40 [0.055] 1.50 [0.059] A B 4 3 2 1 UNIT COMMON DRAWN BY FUYUAN X.XX A2 ± 0.10 C:\ProgramData\cadconverter\output\121212211.pdf-2021-09-29-10-11-50-040-1-1.jpg A1 REV DATE REVISION DESCRIPTION A ISSUE B X.X ± 0.15 X ± 0.25 ANGULAR C SUS 不锈钢 PA6T 尼龙6T Brass 黄铜 Materials PROJCTED DATE 2019 1 1 Yellow 黄色 1 Silver 镀银 1 Black 黑色 Silver 单面镀银 Natural color 本色 Silver 镀银 2 1 1 NUM COLOR CHECKED BY COCO APPROVAL B ALEN MODEL NO: TP10221618 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 4 PRODUCT NAME: TOLERANCE A3 5 MM Teflon 铁氟龙 Phosphor copper 磷铜 PA6T 尼龙6T Name ITEM A4 PA6T Natural color 本色 F G 5
TP10221618 价格&库存
很抱歉,暂时无法提供与“TP10221618”相匹配的价格&库存,您可以联系我们找货
TP10221618
    • 5+0.70514
    • 50+0.62198
    • 150+0.58040
    • 500+0.54918
    库存:2854
