TP10322620
TP10322620
    ROCPU(台普)
    SMD,5.2x5.2mm
    轻触开关 5.2*5.2*2mm 立贴
TP10322620 数据手册
A B D C E F G Circuit Diagram 2.00[0.079] 1 1 PCB.layout T3 T1 4.80 [0.189] T6 0.03[0.001] T5 0.03[0.001] 4.40 [0.174] 2 1.00 [0.040] 2 4.40 [0.174] 8.00 [0.315] T2 0.50[0.019] T4 2.60 [0.103] 5.60 [0.221] 3 Main Specifications: 主要技术指标: Climate grade: -30℃~﹢80℃ 气候等级:-30℃~﹢80 Rated values:Max50 Ma12V,DC Min10 uA1V DC 额定值:Max50 Ma12V,DC Min10 uA1V DC Contact resistance:≤100m Ω 接触电阻:≤100m Ω Dielectric strength:250V AC 1Min 5.20[0.204] T3 T1 0.90[0.035] 耐压:250V AC 1Min Insulation resistance:≥100MΩ 绝缘电阻:≥100MΩ Travel:0.20±0.10mm 行程:0.20±0.10mm Operating force:260±50gf 操作力:260±50gf Life:200,000 寿命:200,000 3 10.80 [0.426] 7] Ø3. .13 50[0 Upper cover 上盖 Push Button 按钮 Terminal 端子 Yellow Membrane 黄膜 Shrapnel 弹片 Plastic base 塑胶底座 6 5 4 4 3 2 T4 6.30[0.248] T2 1 Name NO UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C SUS 不锈钢 1 LCP 1 Phosphor bronze 磷青铜 1 PI 1 SUS 不锈钢 1 LCP PCS Materials PROJCTED DATE 2019 CHECKED BY APPROVAL B Black 黑色 Silver plating 镀银 Yellow 黄色 Silver plating 镀银 Black 黑色 Notes 4 PRODUCT NAME: TOLERANCE A3 5 MM 1 COCO ALEN MODEL NO: TP10322620 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E F G 5
TP10322620 价格&库存
很抱歉,暂时无法提供与“TP10322620”相匹配的价格&库存,您可以联系我们找货
TP10322620
    • 5+0.66917
    • 50+0.53223
    • 150+0.46386
    • 500+0.41256
    • 2500+0.37142
    库存:3274
