A
B
D
C
E
F
G
5.80 [0.228]±0.10
②
④
4.00 [0.157]
5.80 [0.228]±0.10
1
③
①
4.50 [0.177]
5.00[0.197]±0.10
4.00 [0.157]±0.20
4
3.50[0.138]±0.20
3
6.80[0.268]±0.20(OFF)
3.00[0.118]
8.00[0.315]±0.20(ON)
3.60 [0.142]
3.00[0.118]±0.10
2
4.50[0.177]±0.20
A4
A3
台普
A2
A1
REV
DATE
REVISION DESCRIPTION
ISSUE
①
③
②
④
①
③
②
④
Circuit diagram
电路简图
Normal: 1-2 on, 3-4 on
常态:1-2导通,3-4导通
Press: all disconnected
按下:全部断开
COMMON
TOLERANCE
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
UNIT
MM
DRAWN BY FUYUAN
DATE
行程状态(mm)
④
⑤
①
2019
0-0.5
⑥
通电状态
3
1
4
2
1与2导通,3与4导通
0.5-2.0
②
向视图
5
行程与通电状态对照
③
3
1
4
2
全断开
Technical parameter
技术参数
1. Rated current: 100mA 30V DC
1.额定电流:100mA 30V DC
2. Contact resistance: ≤ 200m Ω
2.接触电阻:≤200m Ω
3. Operating force: 260gf ± 50gf
3.操作力:260gf±50gf
4. Maximum stroke: 2.0 ± 0.2mm
4.最大行程:2.0±0.2mm
5. Insulation resistance: ≥ 100M Ω
5.绝缘电阻:≥100MΩ
6.Electric strength: AC250v 50Hz 1Min
6.抗电强度:AC250v 50Hz 1Min
7. Service life: 10000 times
7.寿命:10000次
8. Switch similar: No lock
8.开关类似:无锁
6
Spring
弹簧
SUS
不锈钢丝
1
Natural color
本色
5
reed
簧片
Composite silver
复合银
1
Natural color
本色
PA66
1
PA66
1
black
黑色
pale
灰白
1
Natural color/silver
本色/镀银
3
Upper cover
上盖
handle
按柄
2
terminal
端子
Brass
黄铜
1
Pedestal
基座
PA66
ITEM
Name
Materials
4
PROJCTED
1
black
黑色
NUM
COLOR
PRODUCT NAME:
CHECKED BY
COCO
APPROVAL B
ALEN
MODEL NO: TP55821280
Https:
www.rocpu.tw
ROCPU TECHNOLONGY CO.,LTD
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
F
很抱歉,暂时无法提供与“TP55821280”相匹配的价格&库存,您可以联系我们找货
