TP3302111530
TP3302111530
    ROCPU(台普)
    插件,14.7x6.8mm
    检测开关 插件,14.7x6.8mm 单刀双掷 操作寿命10万次 DC12V
TP3302111530 数据手册
A B D C E F G 3.40[0.130]±0.10 ±0.20 [0.600] 0.60[0.020] 6.80[0.270]±0.15 7.50[0.300]±0.15 9.60[0.380] 2 PT 1 OP FP 15.30 2 3 NC 1 COM NO 3-0.50[0.020]±0.02 3.50[0.140]±0.10 3-0.60[0.020] 3 2.30[0.090] 5.05[0.200] Circuit diagram 5.05[0.200] NO C NG 5.40[0.213]±0.15 14.70[0.580]±0.15 4 1 Rubber shell PA66 2 Seal ring Silica gel 3 Base Brass+PA66 4 According to sincerity Pom 5 Contact moving plate Phosphor bronze 6 Strut SUS UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED DATE 2019 CHECKED BY COCO APPROVAL B ALEN MODEL NO: TP3302111530 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 1 2 3 4 PRODUCT NAME: TOLERANCE A3 5 MM Technical Parameters 技术参数 1.Electrical Rating: 3A/12VDC;0.1A/48vdc 1.电气额定值:3A/12VDC;0.1A/48vdc 2.Electrical lifetime:100,000 cycles 2.电气寿命:100,000 cycles 3.Mechanical lifetime:100,000 cycles 3.机械寿命:100,00 cycles 4.Contact Resistance:≤50mΩ 4.接触电阻:≤50兆欧 5.Operating force:1.95N MAX 5.操作力:1.95N MAX 6.Free Position:7.0mm 6.自由位置:7.0mm 7.Operation Position:3.7±0.6mm 7.动作位置:3.7±0.6mm 8.Pretravel:3.5mm 8.动作行程:3.5mm 9.Withstand Voltage:Feet and Feet 500V/5S/5mA Feet and Shell 1500/5S/5mA 9.耐压:脚与脚 500/5s/5mA 脚与壳 1500/5S/5mA 10.Insulation Resistance:≥100MΩ 10.绝缘电阻:≥100MΩ 11.Proof Tracking Index(PTI):175V 11.漏电起痕指数(PTI):175V 12.Ambient temperature:125° 12.环境温度:125° 13.Waterproof grade: IP67 13.防水等级:IP67 14.working temperature:-25~﹢105℃ 14.工作温度:-25~﹢105℃ F G 5
TP3302111530 价格&库存
很抱歉,暂时无法提供与“TP3302111530”相匹配的价格&库存,您可以联系我们找货
TP3302111530
    • 1+10.31400
    • 10+8.53200
    • 30+7.54920
    库存:27
