TP301111300
TP301111300
    ROCPU(台普)
    插件,12.8x5.7mm
    检测开关 插件,12.8x5.7mm 单刀双掷 操作寿命1万次
TP301111300 数据手册
A B D C E Ø4.80 [0.189] 16.00[0.630]±0.10 1.50[0.059] 2.00 [0.079]±0.10 2 G 技术参数值(Technical Parameters) 1.电气额定值(Electrical Rating):1A 250VAC 2.电气寿命(Electrical lifetime):Min 10,000 cycles 3.接触电阻(Contact Resistance):≤50mΩ 4.操作力(Operating force):35±20gf 5.自有位置(Free position):10.4±1mm 6.动作位置(Operating position):8.7±0.5mm 7.环境温度(Ambient temperature):T85° 8.耐压(Withstand Voltage): Between terminal and terminal 500V/5S/5mA; Between terminals and case 1500/5S/5mA 9.绝缘电阻(Insulation Resistance): ≥100MΩ(Test Voltage 500VDC) 10.漏电起痕指数Proof Tracking Index(PTI):175V 1 0.30 ± ] 2 1 [0.5 13.00 F 1 2 Ø2.20[0.087]±0.10 6.50 [0.256] Ø2.00[0.079]±0.10 3X0.90 [0.035] 6.50 [0.256]±0.10 5.10[0.201]±0.10 POM 5 压柄 Pressing handle 1 不锈钢 SUS 4 塑盖 Plastic cover 1 PBT 3 动触片组件 Contact parts 1 铍青铜+银丝 Beryllium bronze + silver wire 2 推动子 Push parts 1 尼龙66 PA66 1 底座组件 Bottom assembly 1 PBT+黄铜+银丝 PBT + brass + silver wire 序号 Serial number 零件名称 Part name 数量 quantity 材质 Texture of material 5.10 [0.201]±0.10 12.80 [0.504]±0.20 0.50 [0.020] 电路简图 Z1 滚轮 Roller 1 3.40 [0.134] 3 6 黑色 black 3 黑色 black 5.80 [0.229]±0.20 灰色 grey Z2 4 4 S L N UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED PRODUCT NAME: TOLERANCE A3 5 MM DATE 2019 CHECKED BY APPROVAL B 备注 REMARK COCO ALEN MODEL NO: TP301111300 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E F G 5
TP301111300 价格&库存
很抱歉,暂时无法提供与“TP301111300”相匹配的价格&库存,您可以联系我们找货
