TP3306141365
TP3306141365
    ROCPU(台普)
    插件,14.7x6.8mm
    检测开关 插件,14.7x6.8mm 单刀双掷 操作寿命10万次 DC12V
TP3306141365 数据手册
A B D C E 3.40[0.130] 5 9.50[0.370]±0.15 2 NC 3 FP:9.4 MAX 2-2.00[0.080] 2-Ø2.20[0.090]±0.05 2-2.60[0.100]±0.05 2 6.80[0.270] 7.50[0.300]±0.15 OP 0.60[0.020] 1 PT 40]±0.1 13.65[0.5 1 3-0.50[0.020] COM 6-0.80[0.030] NO 1.70[0.070] 3-2.50[0.100] 4.10[0.160] 4.10[0.160] 2-3.25[0.130] Circuit diagram 3 14.70[0.580]±0.15 5.40[0.210]±0.15 C 4 Rubber shell PA66 2 Seal ring Silica gel 3 Base Brass+PA66 4 According to sincerity Pom 5 Contact moving plate Phosphor bronze 6 Strut SUS UNIT COMMON MM DRAWN BY FUYUAN 台普 A2 A1 ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C DATE 2019 G Technical Parameters 技术参数 1.Electrical Rating:0.1A 125/250VAC 3A/12VDC;0.1A/48VDC 1.电气额定值:0.1A 125/250VAC 3A/12VDC;0.1A/48VDC 2.Electrical lifetime:100,000 cycles 2.电气寿命:100,000 cycles 3.Mechanical lifetime:100,000 cycles 3.机械寿命:100,00 cycles 4.Contact Resistance:≤50mΩ 4.接触电阻:≤50兆欧 5.Operating force:2.2N MAX 5.操作力:2.2N MAX 6.Operation Position:7.1±0.5mm 6.动作位置:7.1±0.5mm 7.Pretravel:3.0mm 7.动作行程:3.0mm 8.Withstand Voltage:Feet and Feet 500V/5S/5mA Feet and Shell 1500/5S/5mA 8.耐压:脚与脚 500/5s/5mA 脚与壳 1500/5S/5mA 9.Insulation Resistance:≥100MΩ 9.绝缘电阻:≥100MΩ 10.Proof Tracking Index(PTI):175V 10.漏电起痕指数(PTI):175V 11.Ambient temperature:125° 11.环境温度:125° 12.Waterproof grade: IP67 12.防水等级:IP67 13.working temperature:-25℃~﹢105℃ 13.工作温度:-25℃~﹢105℃ PROJCTED CHECKED BY COCO APPROVAL B ALEN MODEL NO:TP3306141365 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 1 2 3 4 PRODUCT NAME: TOLERANCE A3 REV NC 1 A4 5 NO F F G 5
TP3306141365 价格&库存
很抱歉,暂时无法提供与“TP3306141365”相匹配的价格&库存,您可以联系我们找货
TP3306141365
  • 1+10.63800
  • 10+8.84520
  • 30+7.86240
库存:19
