A
B
D
C
E
A
0.95 [0.037]
1.54 [0.060]
2.54 [0.100]
Terminal
Contact
0.60[0.024]
Actuator
2
3
4
5
6
7
8
9
10
11
12
6.15 [0.242]
1
Movadle
Base
Terminal
3.40 [0.134]
0.25 [0.010]
0.80 [0.031]
0.795[0.031]
9.40 [0.370]
3
2.54x(N-1)±0.20
1.44 [0.057]
2.20 [0.087]
6.60 [0.260]
11.00 [0.433]
1.10 [0.043]
4
1
2
0.60 [0.024]
3.20 [0.126]
2
G
Switching:25mA at 24VDC
Non-Switching:100mA at 50VDC
Initial:50m Ω Max
After life:100mΩ Max
Insulation Resistance:100mΩ Min,60 sec at 500VDC
Dielectyic Strength:500VAC for 60seconds
Swith Capacitance:5pF Max at 1MHZ
Operation Temperature:-30℃to﹢85℃
Storage Temperature:-40℃to﹢85℃
Operation Force:500gf Max
Mechanicai Life:3000 cycles opertions
Resistance to Soldering:260±5℃ for 3-5 seconds
Cover
NO
F
Poles(N)
A Dimension(mm)
01
2.54
02
5.08
03
7.62
04
10.16
05
12.70
06
15.24
07
17.78
08
20.32
09
22.86
10
25.40
12
30.48
3
Part Name
Material
Finished
Base
PPS UL94 VO
Black
Cover
PPS UL94 VO
Black
1 2 3 4 5 6 7 8 9 10 11 12
Actuator
Nylon UL94 VO
White
SCHEMATIC
Movadle
Copper Alloy
Gold
Terminal Contact
Brass
Gold
Terminal
Brass
Gold/Tin
4
2.54 [0.100]
UNIT
A4
COMMON
DRAWN BY FUYUAN
台普
A2
A1
REV
ROCPU
DATE
REVISION DESCRIPTION
A
ISSUE
B
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
C
PROJCTED
PRODUCT NAME:
TOLERANCE
A3
5
MM
DATE
2019
CHECKED BY
APPROVAL B
COCO
ALEN
MODEL NO: TSD106EZ
Https:
www.rocpu.tw
ROCPU TECHNOLONGY CO.,LTD
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
D
E
F
G
5
很抱歉,暂时无法提供与“TSD106EZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.98960
- 10+4.01760
- 33+3.53160
