TAM101EZ
TAM101EZ
    ROCPU(台普)
    插件,P=2.54mm
    拨码开关 间距:2.54mm 1位 凸起式 安装方式:插件 额定电流:25mA 额定电压:24V 电路结构:单刀单掷 工作温度:-30℃~+85℃ 使用寿命:3000 颜色:黑色
TAM101EZ 数据手册
A B D C Terminal Contact A Cover NO 1 2 4 3 5 6 7 8 9 10 11 12 Movadle Base 0.25 [0.010] 7.00 [0.276] 0.40 [0.016] 5.20 [0.205] 0.60[0.024] 0.45 [0.018] 3.20 [0.126] 3.60 [0.142] 1.80 [0.071] 2.54 [0.100] 2 Terminal 1.54 [0.060] 7.70 [0.303] 3 2.54x(N-1)±0.2 7.70 [0.303] 2.54 [0.100] 4 ] 1 3 0.0 Ø [ 0 .8 0 Ø COMMON 5 台普 A1 REV ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C A Dimension(mm) 01 02 03 04 2.54 5.08 7.62 10.16 05 12.70 06 07 08 09 10 12 15.24 17.78 20.32 22.86 25.40 30.48 Part Name Material Finished Base PPS UL94 VO Black Cover PPS UL94 VO Black White 1 2 3 4 5 6 7 8 9 10 11 12 Movadle Copper Alloy Gold SCHEMATIC Terminal Contact Brass Gold Terminal Brass Gold/Tin MM PROJCTED DATE 2019 CHECKED BY APPROVAL B COCO ALEN MODEL NO: TAM101EZ Https: www.rocpu.tw Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission E 2 4 PRODUCT NAME: ROCPU TECHNOLONGY CO.,LTD D 1 3 Nylon UL94 VO DRAWN BY FUYUAN A2 Poles(N) TOLERANCE A3 G Actuator UNIT A4 F Switching:25mA at 24VDC Non-Switching:100mA at 50VDC Initial:50m Ω Max After life:100mΩ Max Insulation Resistance:100mΩ Min,60 sec at 500VDC Dielectyic Strength:500VAC for 60seconds Swith Capacitance:5pF Max at 1MHZ Operation Temperature:-30℃to﹢85℃ Storage Temperature:-40℃to﹢85℃ Operation Force:500gf Max Mechanicai Life:3000 cycles opertions Resistance to Soldering:260±5℃ for 3-5 seconds Actuator 6.00[0.236] 0.95 [0.037] 1 E F G 5
TAM101EZ 价格&库存
很抱歉,暂时无法提供与“TAM101EZ”相匹配的价格&库存,您可以联系我们找货
TAM101EZ
    • 1+4.05000
    • 10+3.26160
    • 30+2.87280
    库存:154
