A
B
D
C
Terminal
Contact
A
Cover
NO
1
2
4
3
5
6
7
8
9
10
11
12
Movadle
Base
0.25 [0.010]
7.00 [0.276]
0.40 [0.016]
5.20 [0.205]
0.60[0.024]
0.45 [0.018]
3.20 [0.126]
3.60 [0.142]
1.80 [0.071]
2.54 [0.100]
2
Terminal
1.54 [0.060]
7.70 [0.303]
3
2.54x(N-1)±0.2
7.70 [0.303]
2.54 [0.100]
4
1
3
0.0
Ø
Ø
COMMON
5
台普
A1
REV
ROCPU
DATE
REVISION DESCRIPTION
A
ISSUE
B
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
C
A Dimension(mm)
01
02
03
04
2.54
5.08
7.62
10.16
05
12.70
06
07
08
09
10
12
15.24
17.78
20.32
22.86
25.40
30.48
Part Name
Material
Finished
Base
PPS UL94 VO
Black
Cover
PPS UL94 VO
Black
White
1 2 3 4 5 6 7 8 9 10 11 12
Movadle
Copper Alloy
Gold
SCHEMATIC
Terminal Contact
Brass
Gold
Terminal
Brass
Gold/Tin
MM
PROJCTED
DATE
2019
CHECKED BY
APPROVAL B
COCO
ALEN
MODEL NO: TAM104EZ
Https:
www.rocpu.tw
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
E
2
4
PRODUCT NAME:
ROCPU TECHNOLONGY CO.,LTD
D
1
3
Nylon UL94 VO
DRAWN BY FUYUAN
A2
Poles(N)
TOLERANCE
A3
G
Actuator
UNIT
A4
F
Switching:25mA at 24VDC
Non-Switching:100mA at 50VDC
Initial:50m Ω Max
After life:100mΩ Max
Insulation Resistance:100mΩ Min,60 sec at 500VDC
Dielectyic Strength:500VAC for 60seconds
Swith Capacitance:5pF Max at 1MHZ
Operation Temperature:-30℃to﹢85℃
Storage Temperature:-40℃to﹢85℃
Operation Force:500gf Max
Mechanicai Life:3000 cycles opertions
Resistance to Soldering:260±5℃ for 3-5 seconds
Actuator
6.00[0.236]
0.95 [0.037]
1
E
F
G
5
很抱歉,暂时无法提供与“TAM104EZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.16880
- 10+3.35880
- 50+2.94840
- 100+2.54880
