A
B
D
C
E
Piano Cover
Piano Pad
Actuator
Cover
1
Terminal Contact
Movadle
Base
1.10[0.043]
Terminal
A
2
3
2
3
4
5
6
0.60 [0.024]
7
8
9
10
11
Switching:25mA at 24VDC
1
Non-Switching:100mA at 50VDC
Initial:50m Ω Max
After life:100mΩ Max
Insulation Resistance:100mΩ Min,60 sec at 500VDC
Dielectyic Strength:500VAC for 60seconds
Swith Capacitance:5pF Max at 1MHZ
Operation Temperature:-30℃to﹢85℃
Storage Temperature:-40℃to﹢85℃
Operation Force:500gf Max
Mechanicai Life:3000 cycles opertions
2
Resistance to Soldering:260±5℃ for 3-5 seconds
12
2.54 [0.100]
6.60 [0.260]
10.45 [0.411]
N 1
G
9.00 [0.354]
6.15 [0.242]
7.05 [0.278]
1.10 [0.043]
F
Poles(N)
A Dimension(mm)
02
03
04
05
06
07
08
09
10
12
6.48
9.02
11.56
14.10
16.64
19.18
21.72
24.26
26.80
31.88
0.25 [0.010]
1.54 [0.061]
7.62 [0.300]±0.5
3
2.54X(N-1)±0.20
4
Ø0
[0
7.62 [0.300]
2.54 [0.100]
1
.03
1 2 3 4 5 6 7 8 9 10 11 12
SCHEMATIC
UNIT
A4
COMMON
DRAWN BY FUYUAN
台普
A2
A1
REV
ROCPU
DATE
REVISION DESCRIPTION
A
ISSUE
B
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
C
PROJCTED
DATE
2019
CHECKED BY
APPROVAL B
Material
Nylon UL94 VO
PPS UL94 VO
PPS UL94 VO
PPS UL94 VO
Nylon UL94 VO
Copper Alloy
Finished
White
Black
Black
Black
White
Gold
Brass
Gold
Brass
Gold/Tin
COCO
ALEN
MODEL NO: TPH104EZ
Https:
www.rocpu.tw
ROCPU TECHNOLONGY CO.,LTD
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
D
E
4
PRODUCT NAME:
TOLERANCE
A3
5
MM
Part Name
Piano Pad
Piano Cover
Base
Cover
Actuator
Movadle
Terminal
Contact
Terminal
F
G
5
很抱歉,暂时无法提供与“TPH104EZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.00920
- 10+5.83200
- 43+5.18400
