TPH110EZ
TPH110EZ
    ROCPU(台普)
    插件,P=2.54mm
    琴键拨码开关 间距:2.54mm 10位 安装方式:插件 额定电流:25mA 额定电压:24V 电路结构:单刀单掷 工作温度:-30℃~+85℃ 使用寿命:3000 颜色:黑色
TPH110EZ 数据手册
A B D C E Piano Cover Piano Pad Actuator Cover 1 Terminal Contact Movadle Base 1.10[0.043] Terminal A 2 3 2 3 4 5 6 0.60 [0.024] 7 8 9 10 11 Switching:25mA at 24VDC 1 Non-Switching:100mA at 50VDC Initial:50m Ω Max After life:100mΩ Max Insulation Resistance:100mΩ Min,60 sec at 500VDC Dielectyic Strength:500VAC for 60seconds Swith Capacitance:5pF Max at 1MHZ Operation Temperature:-30℃to﹢85℃ Storage Temperature:-40℃to﹢85℃ Operation Force:500gf Max Mechanicai Life:3000 cycles opertions 2 Resistance to Soldering:260±5℃ for 3-5 seconds 12 2.54 [0.100] 6.60 [0.260] 10.45 [0.411] N 1 G 9.00 [0.354] 6.15 [0.242] 7.05 [0.278] 1.10 [0.043] F Poles(N) A Dimension(mm) 02 03 04 05 06 07 08 09 10 12 6.48 9.02 11.56 14.10 16.64 19.18 21.72 24.26 26.80 31.88 0.25 [0.010] 1.54 [0.061] 7.62 [0.300]±0.5 3 2.54X(N-1)±0.20 4 Ø0 [0 0 .8 7.62 [0.300] 2.54 [0.100] ] 1 .03 1 2 3 4 5 6 7 8 9 10 11 12 SCHEMATIC UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED DATE 2019 CHECKED BY APPROVAL B Material Nylon UL94 VO PPS UL94 VO PPS UL94 VO PPS UL94 VO Nylon UL94 VO Copper Alloy Finished White Black Black Black White Gold Brass Gold Brass Gold/Tin COCO ALEN MODEL NO: TPH110EZ Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 4 PRODUCT NAME: TOLERANCE A3 5 MM Part Name Piano Pad Piano Cover Base Cover Actuator Movadle Terminal Contact Terminal F G 5
TPH110EZ 价格&库存
很抱歉,暂时无法提供与“TPH110EZ”相匹配的价格&库存,您可以联系我们找货
TPH110EZ
    • 1+10.31400
    • 10+8.53200
    • 38+7.54920
    库存:14
