A
B
D
C
E
5.60 [0.220]±0.3
1
2
3
4
5
6
7
8
9
2.30 [0.091]
0.90 [0.035]
0.15 [0.006]
1
10
0.60 [0.024]
1.27 [0.050]
0.51 [0.020]
10.00 [0.394]
4
2.60 [0.102]
6.00 [0.236]
3
0.76 [0.030]
PCB LAYOUT
SCHEMATIC
UNIT
A4
COMMON
MM
DRAWN BY FUYUAN
台普
A2
A1
ROCPU
DATE
01
2.98
02
4.12
04
6.66
06
9.20
08
11.74
10
14.28
REVISION DESCRIPTION
A
ISSUE
B
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
C
Material
Finished
Base
PPS UL94 V0
Black
Cover
PPS UL94 V0
Black
Actuator
Nylon UL94 V0
White
Movadle
Terminal
Contact
Terminal
Berylium
3U"Gold
Brass
3U"Gold
Brass
3U"Gold
Tapa
Polyimide
Amber
PROJCTED
DATE
2019
CHECKED BY
APPROVAL B
COCO
ALEN
MODEL NO: THS101J
Https:
www.rocpu.tw
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
E
2
4
PRODUCT NAME:
ROCPU TECHNOLONGY CO.,LTD
D
1
3
Part Name
TOLERANCE
A3
REV
A Dimension(mm)
A
11.43 [0.450]±0.2
1.27 [0.050]
5
Poles(N)
1.70 [0.067]
2.30 [0.091]
0.05 [0.002]
0.80 [0.031]
2
G
Switching:25mA at 24VDC
Non-Switching:100mA at 50VDC
Initial:50m Ω Max
After life:100mΩ Max
Insulation Resistance:100mΩ Min,60 sec at 500VDC
Dielectyic Strength:300VAC for 60seconds
Swith Capacitance:5pF Max at 1MHZ
Operation Temperature:-30℃to﹢85℃
Storage Temperature:-40℃to﹢85℃
Operation Force:500gf Max
Mechanicai Life:3000 cycles opertions
Resistance to Soldering:260±5℃ for 3-5 seconds
0.40[0.016]
NO
F
F
G
5
很抱歉,暂时无法提供与“THS101J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.88160
- 10+3.90960
- 30+3.41280
- 100+2.92680
- 500+2.63520
- 1000+2.48400
