THS110
THS110
    ROCPU(台普)
    SMD,P=1.27mm
    拨码开关 间距:1.27mm 10位 凹槽式 安装方式:贴片 额定电流:25mA 额定电压:24V 电路结构:单刀单掷 样式:鸥翼型 安装方式:贴片 工作温度:-30℃~+85℃ 使用寿命:3000 ...
THS110 数据手册
A B A 3 A 4 5 6 7 8 9 0.15[0.006] 2.30 [0.091] 0.9[0.035] Terminal Contact Actuator Cover 0.60 [0.024] Tape 0.40 [0.016] 0.40[0.016] 2x0.81[0.032] A-A 8.35[0.836] 0.05 [0.002] Terminal Base 2 A 11.43 [0.450]±0.2 1.27 [0.050] 8.89 [0.350] 6.35 [0.250] 3 4 10.00 [0.394] 0.51 [0.020] SCHEMATIC 0.76 [0.030] PCB LAYOUT UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV MM ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED DATE 2019 Poles(N) A Dimension(mm) 1 2 3 4 5 6 8 10 2.87 4.12 5.41 6.66 7.93 9.2 11.74 14.28 CHECKED BY APPROVAL B 3 Part Name Material Finished Base PPS UL94 V0 Black Cover PPS UL94 V0 Black Actuator nYlon UL94 V0 White Movadle Berylium 3U"Gold Terminal Contact Brass 3U"Gold Terminal Brass 3U"Gold Tapa Polyimide Amber COCO ALEN MODEL NO: THS110 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 4 PRODUCT NAME: TOLERANCE A3 5 G Switching:25mA at 24VDC 1 Non-Switching:100mA at 50VDC Initial:50m Ω Max After life:100mΩ Max Insulation Resistance:100mΩ Min,60 sec at 500VDC Dielectyic Strength:300VAC for 60seconds Swith Capacitance:5pF Max at 1MHZ Operation Temperature:-30℃to﹢85℃ Storage Temperature:-40℃to﹢85℃ Operation Force:500gf Max Mechanicai Life:3000 cycles opertions Resistance to Soldering:260±5℃ for 3-5 seconds 10 2 2.30 [0.091] F 1.27 [0.050] 5.40 [0.213] NO 2 E 1.27 [0.050] 1 1 D C F G 5
THS110 价格&库存
很抱歉,暂时无法提供与“THS110”相匹配的价格&库存,您可以联系我们找货
THS110
  • 1+8.42400
  • 10+6.96600
  • 30+6.16680
库存:44
