BTSA-N-P-17
BTSA-N-P-17
    ROCPU(台普)
    插件
    按动开关 1万次 直插 100mA 2.6N 12V -20℃~+70℃
BTSA-N-P-17 数据手册
A B D C E F G 8.00 [0.315]±0.20 0.30 [0.012] 0.60 [0.024] ② ① ② ③ ④ ③ ④ 5.00[0.197] Normal: 1-2 on, 3-4 on 常态:1-2导通 3-4导通 Press: all off 按下:全断开 2 3.80 [0.150] 3.80 [0.150] ③ ⑤ ⑥ ① 5.00 [0.197]±0.30 A4 5 COMMON A3 台普 A2 A1 REV 3.50 [0.138]±0.20 6.00[0.236]±0.30 DATE REVISION DESCRIPTION A ISSUE B TOLERANCE X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C 2 7 ② 4 1 3 ④ 8.00[0.315]±0.10 13.50[0.531]±0.20 3 ① Technical parameter 技术参数 1. Rated current: 100mA 30V DC 1.额定电流:100mA 30V DC 2. Contact resistance: ≤ 10 Ω 2.接触电阻:≤10 Ω 3.Electric strength: AC250V 50Hz 1min 3.抗电强度:AC250v 50Hz 1Min 4. Operating force: 260gf ± 50gf 4.操作力:260gf±50gf 5. Maximum stroke: 3.0 ± 0.2mm 5.最大行程:3.0±0.2mm 6. Insulation resistance: ≥ 100m Ω 6.绝缘电阻:≥100MΩ 7. Service life: 10000 times 7.寿命:10000次 8. Switch similar: No lock 8.开关类似:无锁 5.50[0.217]±0.10 1 6.00[0.236] 8.00 [0.315]±0.20 UNIT MM DRAWN BY FUYUAN DATE 2019 6 Spring 弹簧 SUS 不锈钢丝 1 Natural color 本色 5 reed 簧片 Phosphor bronze 磷青铜 1 Natural color/nickel 本色/镀镍 PA66 1 PPA 1 black 黑色 black 黑色 3 Upper cover 上盖 handle 按柄 2 terminal 端子 Brass 黄铜 1 Natural color/nickel 本色/镀镍 1 Pedestal 基座 PPT 1 white 白色 ITEM Name Materials NUM COLOR 4 PROJCTED PRODUCT NAME: CHECKED BY COCO MODEL NO: BTSA-N-P-17 APPROVAL B ALEN Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 4 F G 5
BTSA-N-P-17 价格&库存
很抱歉,暂时无法提供与“BTSA-N-P-17”相匹配的价格&库存,您可以联系我们找货
