FT8132
数据手册
ry
三相内置 PreDriver
im
in
a
直流无刷马达控制器
Pr
el
FT8132
峰岹科技(深圳)股份有限公司
www.fortiortech.com
FT8132
目
录
目
录 ..................................................................... 2
1
系统介绍 ............................................................... 4
1.1
概述 .................................................................4
1.2
应用场景 .............................................................4
1.3
特性 .................................................................4
1.4
应用电路 .............................................................5
1.5
功能框图 .............................................................6
1.6
封装 .................................................................8
FT8132Q QFN24 ....................................................8
1.6.2
FT8132S SSOP24 ...................................................9
1.7
引脚定义 ............................................................10
1.7.1
FT8132Q QFN24 ...................................................10
1.7.2
FT8132S SSOP24 ..................................................12
封装信息 .............................................................. 14
im
in
a
2
ry
1.6.1
2.1
QFN24 ...............................................................14
2.2
SSOP24 ..............................................................15
3
定购信息 .............................................................. 16
4
电气特性 .............................................................. 17
绝对最大值 ..........................................................17
4.2
电气特性 ............................................................18
4.3
封装热阻 ............................................................19
el
功能描述 .............................................................. 20
5.1
VDD5 ................................................................20
5.2
DIR .................................................................20
5.3
ICP .................................................................20
5.4
ASPEED ..............................................................20
5.5
SPEED ...............................................................20
5.6
FG ..................................................................20
5.7
HBIAS ...............................................................20
5.8
调速 ................................................................20
Pr
5
4.1
5.8.1
调速模式 ........................................................20
5.8.2
调速曲线 ........................................................ 21
5.9
提前角曲线 ..........................................................22
5.10
休眠模式 ..........................................................23
5.11
软启动与软关断(SOFT-ON、SOFT-OFF) ...............................23
5.12
堵转保护 ..........................................................24
5.13
缺相保护 ..........................................................24
5.14
过流保护 ..........................................................24
REV_Preliminary_0.2
2
www.fortiortech.com
FT8132
5.15
修改记录(DOCUMENT CHANGE LIST) ....................................... 26
Pr
el
im
in
a
ry
6
FG 的倍频和分频 ......................................................24
REV_Preliminary_0.2
3
www.fortiortech.com
FT8132
FT8132 三相内置 PreDriver 直流无刷马达控制器
1
系统介绍
1.1 概述
1.3 特性
FT8132 是一款三相内置 PreDriver 直
支持无传感器磁场定向控制(FOC)
流无刷马达驱动 IC。芯片高度集成电机控
支持有感(HALL IC 或 HALL Sensor)
SVPWM 或 FOC 模式
制所需部件,
所需外围元器件少,
噪声低,
电机转矩脉动小。GUI 可配置客户电机参
可以减小电机噪声和振动
Predriver 输出(PMOS+NMOS),死
数、启动和调速方式,并储存在内置的
EEPROM。
调速接口可选择 PWM、
CLOCK,
模拟输入、I2C 调节电机转速,集成转速
ry
区时间可选择
恒转速、恒电流、恒功率或电压环控
制模式
模拟/PWM/I2C/CLOCK 调速
I2C 接口用于电机控制和状态回读
静止状态支持初始位置检测启动
支持顺逆风启动
Soft-On Soft-Off (SOSO)
内置 EEPROM,可配置电机参数、启
im
in
a
指示功能,可通过 FG 引脚或 I2C 接口实
时读取电机转速。速度控制方式可选择恒
转速、恒电流、恒功率和电压环控制,具
有电机转速指示功能,集成过流、硬件欠
压、软件欠压、过压、外部过温检测、内
动和调速方式
部过温(TSD)
、堵转、缺相、HALL 异常
el
等多种保护模式,睡眠电流约 60uA。
1.2 应用场景
可配置多段速度曲线
集成过流、硬件欠压、软件欠压、软
件过压、过温检测、堵转、HALL 异
落地扇、散热风扇、吊扇、扫地宝、
吸尘器等
Pr
常等多种保护模式
QFN24(4mm*4mm*0.75mm)
REV_Preliminary_0.2
正、反转自由切换
可配置电机转速指示或堵转
SSOP24(e=0.635mm)
4
www.fortiortech.com
FT8132
1.4 应用电路
VSS
VCC
VCC
C1
VSS
VDD5
C2
H_PW
HBIAS
H_PV
DIR
SPEED
Interface
VCC
MP1
MP2
MP3
H_PU
SPEED
FG
Motor
L_W
IU
IBUS
IV
IBUS
IBUS
1kΩ 1%
1kΩ 1%
1kΩ 1%
1kΩ 1%
1kΩ 1%
A0P
FT8132
A0M
IU
A1P
IBUS
EV
A2M
ASPEED
R5
R7
R6
R8
R9
R2
R10
R4
EU
A2P
MN3
IV
R1
A1M
ICP
MN2
MN1
L_U
ry
1kΩ 1%
L_V
EW
im
in
a
IBUS
1kΩ 1%
图 1-1 无感 FOC 双电阻示意图(PGA 运放输入匹配电阻固定 1kΩ)
VSS
SPEED
Interface
H_PW
el
HBIAS
VCC
HCC
C1
VSS
VDD5
C2
VCC
A2M/FAULTN
H_PV
DIR
H_PU
VCC
MP1
MP2
MP3
SPEED
FG
A0P
Pr
IBUS
1kΩ 1%
1kΩ 1%
IBUS
A0M
ICP
ASPEED
FT8132
Motor
L_W
L_V
MN1
MN2
MN3
L_U
HCC
IBUS
EU/HUP
A1M/HUM
R4
HALL
HUP
HUM
A1P/HVP
HVP
EV/HVM
HVM
A2P/HWP
HWP
EW/HWM
HWM
图 1-2 HALL Sensor
REV_Preliminary_0.2
5
www.fortiortech.com
FT8132
VCC
VDD5
HBIAS
1.5 功能框图
LDO5
VScaler
PGAx3
ADC
ry
A2P/HWP
A2M
A1P/HVP
A1M/HUM
A0P
A0M
ASPEED
OCP
I2C
FG
DIR
VSS
3P3N
Predriver
Logic
Control
im
in
a
ICP
EU/HUP
EV/HVM
EW/HWM
SPEED
HUP
HUM
HVP
HVM
HWP
HWM
HALL/
BEMF
EEPROM
UVLO
Thermal
OSC
H_PU
H_PV
H_PW
L_U
L_V
L_W
Pr
el
图 1-3 FT8132 无感功能框图
REV_Preliminary_0.2
6
www.fortiortech.com
HBIAS
VCC
VDD5
FT8132
LDO5
VScaler
PGA
A0P
A0M
HUP
HUM
HVP
HVM
HWP
HWM
HALL/
BEMF
ADC
ASPEED
OCP
EU/HUP
EV/HVM
EW/HWM
A2P/HWP
FAULTN
HVP
HUM
SPEED
im
in
a
DIR
VSS
3P3N
Predriver
Logic
Control
I2C
FG
H_PU
H_PV
H_PW
L_U
L_V
L_W
ry
ICP
EEPROM
UVLO
Thermal
OSC
Pr
el
图 1-4 FT8132 有感功能框图
REV_Preliminary_0.2
7
www.fortiortech.com
FT8132
1.6 封装
H_PU
6
20 A1M/HUM
21 EU/HUP
22 A0M
19 A1P/HVP
ry
A2P/HWP
15 A2M/FAULTN
14 HBIAS
13 VDD5
VSS 12
5
SPEED 11
L_W
FG/RD 10
4
9
L_V
16
FT8132Q
Top View
With downbond VSS
VCC
3
im
in
a
L_U
17 EW/HWM
8
2
H_PW
DIR
18 EV/HVM
7
1
H_PV
ASPEED
23 A0P
24 ICP
1.6.1 FT8132Q QFN24
Pr
el
图 1-5 FT8132 QFN24 顶视图封装尺寸:(4mm*4mm*0.75mm, e=0.5mm)
REV_Preliminary_0.2
8
www.fortiortech.com
FT8132
1.6.2 FT8132S SSOP24
L_V
1
24
L_U
L_W
2
23
DIR
H_PU
3
22
ASPEED
4
21
ICP
5
A0P
19
A0M
18
EU/HUP
17
A1M/HUM
VCC
6
FG/RD
7
SPEED
8
FT8132S
H_PV
H_PW
9
16
A1P/HVP
10
15
EV/HVM
HBIAS
11
14
A2M/FAULTN
12
13
ry
VSS
VDD5
EW/HWM
im
in
a
A2P/HWP
Pr
el
图 1-6 FT8132 SSOP24 顶视图封装尺寸:(e=0.635mm)
REV_Preliminary_0.2
9
www.fortiortech.com
FT8132
1.7 引脚定义
1.7.1 FT8132Q QFN24
表 1-1 FT8132 QFN24 引脚定义
PAD 名称
ASPEED
FT8132
QFN24
1
IO 类型
AI
功能描述
模拟调速输入
电机转动方向控制,内置上拉电阻
DIR
2
DI
1:正转。输出相序为 U-->V-->W
0:反转。输出相序为 U-->W-->V
3
DO
3P3N 模式 Predriver 下桥 U 相电压输出
L_V
4
DO
3P3N 模式 Predriver 下桥 V 相电压输出
L_W
5
DO
3P3N 模式 Predriver 下桥 W 相电压输出
H_PU
6
DO
3P3N 模式 Predriver 上桥 U 相电压输出
H_PV
7
H_PW
8
VCC
9
FG/RD
10
SPEED
11
VSS
12
VDD5
13
HBIAS
14
3P3N 模式 Predriver 上桥 V 相电压输出
DO
3P3N 模式 Predriver 上桥 W 相电压输出
P
HWP
17
Pr
HWM
16
EV/
HVM
A1P/
HVP
A1M/
HUM
EU/
HUP
18
19
输入电源,6~28V DC,接≥10uF 电容到地
DO
转速输出信号或者堵转指示,集电极开漏输出
DI
电机调速输入,PWM 调速
P
地
P
5V LDO 输出,接 1~4.7uF 电容到地
DO
HALL 偏置电源,内部通过开关连接 VDD5
AI/
运放 A2 负输入端
DO
故障输出指示,集电极开漏输出
AI/
运放 A2 正输入端
AI
W 相差分 HALL 正输入端
AI/
W 相反电动势分压输入
AI
W 相差分 HALL 负输入端或者开关 HALL 输入
AI/
V 相反电动势分压输入
AI
V 相差分 HALL 负输入端或者开关 HALL 输入
AI/
运放 A1 正输入端
AI
V 相差分 HALL 正输入端
AI/
运放 A1 负输入端
AI
U 相差分 HALL 负输入端
AI/
U 相反电动势分压输入
AI
U 相差分 HALL 正输入端或者开关 HALL 输入
el
A2P/
EW/
15
DO
im
in
a
A2M/
FAULTN
ry
L_U
A0M
22
AI
运放 A0 负输入端
A0P
23
AI
运放 A0 正输入端
ICP
24
AI
过流保护输入
REV_Preliminary_0.2
10
www.fortiortech.com
FT8132
备注:
IO 类型说明:
DI = 数字输入,
DO = 数字输出,
AI = 模拟输入,
AO = 模拟输出,
Pr
el
im
in
a
ry
P = 电源
REV_Preliminary_0.2
11
www.fortiortech.com
FT8132
1.7.2 FT8132S SSOP24
表 1-2 FT8132 SSOP24 引脚定义
FT8132S
IO 类
SSOP24
型
L_V
1
DO
L_W
2
DO
H_PU
3
DO
H_PV
4
DO
H_PW
5
DO
VCC
6
P
FG/RD
7
DO
SPEED
8
DI
电机调速输入,PWM 调速
VSS
9
P
地
VDD5
10
P
HBIAS
11
DO
A2M/
FAULTN
A2P/
HWP
EW/
HWM
EV/
HVM
A1P/
A1M/
HUM
EU/
13
14
15
16
ry
AI/
运放 A2 负输入端
DO
故障输出指示,集电极开漏输出
AI/
运放 A2 正输入端
AI
W 相差分 HALL 正输入端
AI/
W 相反电动势分压输入
AI
AI/
V 相反电动势分压输入
AI
AI/
运放 A1 正输入端
AI
V 相差分 HALL 正输入端
el
HVP
12
功能描述
im
in
a
PAD 名称
18
Pr
HUP
17
AI/
运放 A1 负输入端
AI
U 相差分 HALL 负输入端
AI/
U 相反电动势分压输入
AI
A0M
19
AI
运放 A0 负输入端
A0P
AI
运放 A0 正输入端
ICP
21
AI
过流保护输入
ASPEED
22
AI
模拟调速输入
电机转动方向控制,内置上拉电阻
DIR
23
DI
L_U
REV_Preliminary_0.2
24
DO
12
www.fortiortech.com
FT8132
备注:
IO 类型说明:
DI = 数字输入,
DO = 数字输出,
AI = 模拟输入,
AO = 模拟输出,
Pr
el
im
in
a
ry
P = 电源
REV_Preliminary_0.2
13
www.fortiortech.com
FT8132
2
封装信息
im
in
a
ry
2.1 QFN24
Millimeter
Symbol
A
b
c
D
D2
Pr
e
Nom
Max
0.70
0.75
0.80
0.02
0.05
0.18
0.25
0.30
0.18
0.20
0.25
3.90
4.00
4.10
2.40
2.50
2.60
el
A1
Min
0.50BSC
Ne
2.50BSC
Nd
2.50BSC
E
3.90
4.00
4.10
E2
2.35
2.50
2.65
L
0.35
0.40
0.45
h
0.30
0.35
0.40
N
Pin Number = 24
图 2-1 QFN24 封装尺寸图(4.0mm*4.0mm*0.75mm, e=0.5mm)
REV_Preliminary_0.2
14
www.fortiortech.com
FT8132
Pr
el
im
in
a
ry
2.2 SSOP24
图 2-2 SSOP24_8.65X3.9 封装尺寸图
REV_Preliminary_0.2
15
www.fortiortech.com
FT8132
3
定购信息
控制功能
保护
初
电源
封装
电压
驱动接口
(V)
驱动类型
反
I2C
FT8132Q
QFN24
(4x4 mm)
6~28
SSOP24
FT8132S
(8.65x3.9
有感&
Predriver
无感正弦
3P3N
有感&
Predriver
无感正弦
模
CLOCK
拟
转
硬
件
件
A
过
过
件
欠
过
堵
L
缺
工作温
位
流
温
欠
压
压
转
L
相
度
置
保
保
压
保
保
保
异
保
Tj(℃)
侦
护
护
保
护
护
护
常
护
测
护
无
铅
保
护
-40~
150
-40~
150
Pr
el
mm)
6~28
3P3N
PWM/
H
始
im
in
a
型号
正
软
ry
调速方式
软
REV_Preliminary_0.2
16
www.fortiortech.com
FT8132
4
电气特性
4.1 绝对最大值
表 4-1 绝对最大值
条件
最小值
典型值
最大值
单位
工作时结温 Tj
-40
150
存储温度 Tstg
-55
150
VCC 相对 VSS 电压
-0.3
30
V
VDD5 相对 VSS 电压
-0.3
5
6.5
V
FG 相对 VSS 电压
-0.3
VCC+0.3
V
H_PU/H_PV/H_PW 相对 VSS 电压
-0.3
VCC+0.3
V
L_U/L_V/L_W 相对 VSS 电压
-0.3
VCC+0.3
V
-0.3
VDD5+0.3
V
ry
参数
EU/A1M/A1P/EV/EW/A2P/
im
in
a
DIR/ASPEED/ICP/A0P/A0M/
A2M/HBIAS/SPEED 相对 VSS 电压
注意:超过表 4-1 “绝对最大值”中所列的应力值可能会永久损坏器件。这仅为应力额定值,
Pr
el
我们不建议器件运行在该规范范围以外。长期在绝对最大值条件下工作可能会影响器件的可靠性。
REV_Preliminary_0.2
17
www.fortiortech.com
FT8132
4.2 电气特性
表 4-2 电气特性
参数
条件
VCC 工作电压
最小值
典型值
最大值
单位
6
28
V
VDD5 工作电压
TA=-40~85℃
4.8
5
5.2
V
VCC 工作电流 IVCC
TA=-40~85℃
15
25
mA
VDD5 带负载电流
TA=-40~85℃
10
mA
VCC 休眠电流 IVCC-sleep
TA=-40~85℃
50
100
uA
4.8
5.4
6
V
保护特性
ry
VCC 硬件欠压保护 VUVLO
VCC 硬件欠压保护恢复迟滞 VUVLO-HYS
TTSD 保护温度
Tj 配置为 135℃档
IO 电气特性(DIR/SPEED/FG)
输入高电平 VIH
输入低电平 VIL
SPEED/DIR/A1P 上拉电阻
SPEED 下拉电阻
EW/EV/EU/A2P/A2M 上拉电阻
PWM/CLOCK 调速频率范围
PWM 调速频率范围
CLOCK 调速频率范围
0.4
V
129
135
141
10
im
in
a
TTSD_HYS 温度迟滞
0.6*VDD5
V
0.2*VDD5
V
33
kΩ
30
kΩ
5.6
kΩ
100
100k
Hz
Hz
150
mA
90
mA
150
mA
180
mA
25
ns
90
ns
115
ns
60
ns
VDD5
V
上桥输出拉电流
上桥输出灌电流
下桥输出拉电流
Pr
下桥输出灌电流
el
PreDriver 电气特性(VCC=15V,TA=25℃)
上桥输出上升时间
上桥输出下降时间
下桥输出上升时间
下桥输出下降时间
1nF Load,
从 10%上升至 90%
1nF Load,
从 90%下降至 10%
1nF Load,
从 10%上升至 90%
1nF Load,
从 90%下降至 10%
模拟调速
ASPEED 调速输入电压范围
REV_Preliminary_0.2
18
www.fortiortech.com
FT8132
4.3 封装热阻
表 4-3 QFN24 封装热阻
参数
条件
值
单位
ƟJA 芯片节温相对环境温度
(1), (2)
50
℃/W
ƟJC 芯片节温相对封装表面温度
(1), (2)
25
℃/W
值
单位
(1) JEDEC 标准,2S2P PCB
(2) 实际应用条件不同,会与测试结果有所出入
表 4-4 SSOP24 封装热阻
条件
ƟJA 芯片节温相对环境温度
ry
参数
(1), (2)
85
Pr
el
im
in
a
℃/W
REV_Preliminary_0.2
19
www.fortiortech.com
FT8132
5
功能描述
5.1
VDD5
电压基准,只为内部数字逻辑和模拟电路供电,VDD5 不可用于外部电路供电。在引脚
上需要一个 1uF 或更大的电容来稳定电源。
5.2
DIR
正反转引脚,根据不同电平来控制电机转向,可通过改变 DIR 电平来改变电机的转向。
5.3
ry
内部上拉,默认为高电平。
ICP
5.4
ASPEED
im
in
a
采集电流,当 EEPROM 的设置为过流保护模式为 ICP 时,用于电流采样。
模拟电压调速引脚,当 EEPROM 的设置为 Analog 调速时起作用,输入电压进行调速。
5.5
SPEED
调速引脚,根据 EEPROM 的设置不同,可输入占空比或者频率进行调速。此外,SPEED
引脚作为时钟线(SCL)用于 I2C 通信。
FG
el
5.6
速度反馈及故障状态指示引脚,开漏输出。根据 EEPROM 的设置不同,FG/RD 设置为
FG 时输出速度反馈信号指示电机运行转速;FG/RD 设置为 RD 时输出故障状态信号,用于
显示电机运行状态,进入故障状态输出高电平。此外 FG 引脚作为数据线(SDA)用于 I2C 通
Pr
信。
5.7
HBIAS
HALL 偏置电源,内部通过开关连接 VDD5,最大的带负载能力为 10mA。
5.8 调速
5.8.1 调速模式
FT8132 支持数字 PWM,模拟电压、I2C 、CLOCK 四种调速输入接口,同一时间只
能选择一种调速方式。模拟电压调速时信号输入 ASPEED 脚,数字 PWM 和 CLOCK 调速时
信号输入 SPEED 脚。当控制模式选择电压环时,也可选择调电源电压来调速。
REV_Preliminary_0.2
www.fortiortech.com
FT8132
5.8.2 调速曲线
输入输出的调速曲线如下图,横坐标为输入数字 PWM 占空比(I2C 调速和模拟调速
可换算成对应数字 PWM 占空比)
;纵坐标为输出,在不同的控制模式下代表不同的物理量。
当控制模式选择电压环时,Y 轴代表输出 Duty,通过设置 5 个点位输出不同占空比,
实现多段式曲线调速。启动占空比 X_ON 可设置,最高占空比 PWM_X98 可设置为 98%或
100%。速度曲线拐点固定为 25%,50%,75%。各拐点对应的输出值 Y_ON,Y_25,Y_50,
im
in
a
ry
Y_75,Y_Max 可设置。
Pr
el
图 5-1 电压环模式下的曲线(PwmOffMode 设置为 Stop)
图 5-2 电压环模式下的曲线(PwmOffMode 设置为 MinSpeed)
当控制模式选择速度环时,Y 轴代表速度;选择电流环时,Y 轴代表电流。选择功率环
时,Y 轴代表功率;只能设置最高点与最低点的输出,中间各点的输出值随输入值的变化线
性增加。
REV_Preliminary_0.2
21
www.fortiortech.com
FT8132
im
in
a
ry
图 5-3 速度环或电流环或功率环模式下的曲线(PwmOffMode 设置为 Stop)
图 5-4 速度环或电流环或功率环模式下的曲线(PwmOffMode 设置为 MinSpeed)
el
5.9 提前角曲线
当控制模式选择有感 SVPWM 时,输出 duty 的对应提前角的曲线如下图,横坐标为输
入 PWM 占空比;纵坐标为提前角, 提前角曲线对应 9 个输入 duty ,分别为 0%,12.5%,
25%,37.5%,50%,62.5%,75%,87.5%,100% ,每相邻的两个 duty 之间最大的角度差
Pr
为 10.547°,将 10.547°分成 15 份设置对应 Duty 的角度,比如 0%可以通过 GUI 设置为
7,则 0%对应的角度为(7/15)*10.547°=4.922°,12.5%设置 GUI 的值为 6,则 12.5%的角度为
(6/15)*10.547°=4.218°,则 12.5%的实际角度为 0%的设置的角度加上 12.5%设置的角度等
于 9.1°,依照此规律可以计算其他点的角度。
REV_Preliminary_0.2
22
www.fortiortech.com
5.10 休眠模式
im
in
a
图 5-5 提前角曲线
ry
FT8132
当芯片一直处于停机状态,6s 后进入休眠模式。
唤醒条件:I2C 调速时,芯片收到匹配的 I2C ID 后唤醒。数字 PWM 和 CLOCK 调速,
反向输入不使能时,SPEED 脚输入高电平时唤醒;反向输入使能时,SPEED 脚输入低电平
时唤醒。模拟电压调速时,ASPEED 脚电压大于 1.5V 或者 SPEED 脚输入高电平时唤醒。
5.11 软启动与软关断(Soft-On、Soft-Off)
el
软启动(Soft-On)功能在“开”指令时逐渐增加电机的电流,软关断(Soft-Off)在“关”指
Pr
令时逐渐减少电机的电流,进一步降低噪音,使电机平稳运行。
图 5-6 软启动(Soft-On)相电流波形
REV_Preliminary_0.2
23
www.fortiortech.com
FT8132
图 5-7 软关断(Soft-Off)相电流波形
ry
5.12 堵转保护
出现堵转情况时,当满足软件设置的堵转判断条件时,芯片关闭输出,等待 6s 后根据
5.13 缺相保护
im
in
a
软件设置来决定是否重启。
出现缺相情况时,当满足软件设置的缺相判断条件时,芯片关闭输出,等待 6s 后根据
软件设置来决定是否重启。
5.14 过流保护
如果电流过大,当电流超过过流保护门限时,芯片关闭输出,等待 6s 后根据软件设置
el
来决定是否重启。
5.15 FG 的倍频和分频
设置 FG/RD 为 FG,即选择 FG/RD 管脚输出 FG 信号。FG 的输出频率由
Pr
FGDIV&FGMUL 决定,默认的 FG 每个电周期翻转一次。FG 输出倍频系数 FGMUL 可以
设置为 1、2、3、4,FG 输出分频系数 FGDIV 可以设置为 1、1/3、1/4、1/5。
表 5-1 FG 配置系数表
一个机械周期显示的 FG 个数=pp*FGMUL/FGDIV。
(pp 为电机的极对数)
例:四对极电机,一个机械周期显示 3 个 FG 信号,则设置倍频系数为 3,设置分频
系数为 4,即 k=3/4,设置 FGDIV/FGMUL 为 1010。
REV_Preliminary_0.2
24
www.fortiortech.com
FT8132
ry
图 5-8 k=1 和 k=3/4 的 FG 输出图
当在无感模式,选择 CLOCK 调速模式时,FGMUL 与 FGDIV 用于设置转速与 CLOCK
im
in
a
频率之间的关系,公式为:转速=(输入 PWM 频率*60/极对数)/FGMUL/FGDIV。
如电机为 5 对极,FGMUL 设置 1/3,FGDIV 设置 2,输入 PWM 频率为 100Hz,转速=
(100Hz*60/5)/2/(1/3)
。转速为 1800。此时 FG 的输出频率受 FG 分频与倍频控制。
当在有感模式,选择 CLOCK 调速模式时,FGMUL 与 FGDIV 仍用于设置转速,计算
公式同无感模式的计算公式,此时如果 FG 的输出通过 EEPROM 选择 FG 3 倍频跟随或者
FG 1 倍频跟随,此优先极会高于 FG 分频与倍频,FT8132 会按照设置的 FG 跟随频率输出
Pr
el
FG,如果 FG 跟随功能 Disable 则根据 FT8132 会根据设置的 FG 分频与倍频输出 FG。
REV_Preliminary_0.2
25
www.fortiortech.com
FT8132
6
修改记录(Document Change List)
Revision
Changes
2022/01/04
0.1
初始版本
2022/2/23
0.2
增加 FT8132S SSOP24 相关信息
Pr
el
im
in
a
ry
Date
REV_Preliminary_0.2
26
www.fortiortech.com
FT8132
Copyright Notice
Copyright by Fortior Technology (Shenzhen) Co., Ltd. All Rights Reserved.
Right to make changes —Fortior Technology (Shenzhen) Co., Ltd RSVs the right to make changes
in the products - including circuits, standard cells, and/or software - described or contained herein
in order to improve design and/or performance. The information contained in this manual is
provided for the general use by our customers. Our customers should be aware that the personal
computer field is the subject of many patents. Our customers should ensure that they take
appropriate action so that their use of our products does not infringe upon any patents. It is the
policy of Fortior Technology (Shenzhen) Co., Ltd. to respect the valid patent rights of third parties
and not to infringe upon or assist others to infringe upon such rights.
im
in
a
ry
This manual is copyrighted by Fortior Technology (Shenzhen) Co., Ltd. You may not reproduce,
transmit, transcribe, store in a retrieval system, or translate into any language, in any form or by
any means, electronic, mechanical, magnetic, optical, chemical, manual, or otherwise, any part of
this publication without the expressly written permission from Fortior Technology (Shenzhen) Co.,
Ltd.
Room203, 2/F, Building No.11, Keji Central Road2,
SoftwarePark, High-Tech Industrial Park, Shenzhen, P.R. China 518057
Tel: 0755-26867710
Fax: 0755-26867715
URL: http://www.fortiortech.com
Pr
el
Contained herein
Copyright by Fortior Technology (Shenzhen) Co., Ltd all rights Reserved.
REV_Preliminary_0.2
27
www.fortiortech.com
很抱歉,暂时无法提供与“FT8132Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.61930
- 10+5.36790
- 30+4.74120
- 国内价格
- 1+5.96820
- 10+4.85100
- 30+4.29240
- 100+3.74360
- 国内价格
- 1+6.69600
- 10+5.44320
- 30+4.81680
- 100+4.20120
