S22-ZZ-0019
S22-ZZ-0019
    UDE
    RJ45_21.5X16.55MM_TM
    RJ45连接器 插件 10/100 Base-T
S22-ZZ-0019 数据手册
To: Customer P/N: UDE P/N: S22-ZZ-0019 Description: RJ45 1X1 Tab Up Through Hole 10/100 Base-T Contact Area : Gold Flash LED:L-Green; R-Yellow Spec No. S2218018-00 Approved Checked Update Date 2018/3/27 Revision A Prepared Revision History Issue Date 2018/3/27 Revision A Initial Release . Comments Operator Bluce UD-P09-R03E S2218018-00 S22-ZZ-0019 1. MECHANICAL DIMENSION Product Dimension U. D. Electronic Corp. Unit:mm 1/9 General Tolerance : X.X : ± 0.38 X.XX : ± 0.20 UD-P09-R60A S2218018-00 S22-ZZ-0019 Recommended PCB Layout. Component side of board All dimension units are "mm". All dimension tolerances are ±0.05mm unless otherwise specified. Table1 Layout Trace component Grounding Test Point Component side X X O X X X O Inner layer O NA O NA O X O Bottom side O O O O O X O Layer Via Hole PTH NPTH X--Forbid; O--OK; NA--Not Applicable. U. D. Electronic Corp. 2/9 UD-P09-R60A S2218018-00 S22-ZZ-0019 Recommended Panel cutout 2. Packing Information 60 pcs finished goods per tray 7 trays(420 pcs finished goods) per inner box 4 Inner boxes(1680 pcs finished goods) per master carton U. D. Electronic Corp. 3/9 UD-P09-R60A S2218018-00 S22-ZZ-0019 3. Standard RJ45 Plug Specification - All dimensions follow : FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i) IEC 60603-7 - All plugs must be meeting the requirements of plug Go & No-Go gauge. Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i) - There must be no damage to Housing and Locking Latch. - There must be no nicks and cuts in cable. - Durability : 750 cycles generally U. D. Electronic Corp. 4/9 UD-P09-R60A S2218018-00 S22-ZZ-0019 4. REQUIREMENTS Design and Construction Product shall be of design, construction and physical dimensions specified on applicable. Material Terminal Parts (Underplating : 50μ"min Nickel overall) RJ Terminal :Phosphor Bronze , Thickness=0.30mm Finish : Contact Area : Gold Flash Input Terminal : Brass, Thickness=0.35mm Finish : 100μ" min. Matte Tin Plastic Parts Housing : PA6T, Black Case : PA6T, Black LED Cover : PA6T, Black Shield Parts Shield Parts : Stainless steel, Thickness=0.20mm, Pre-soldering U. D. Electronic Corp. 5/9 UD-P09-R60A S2218018-00 S22-ZZ-0019 5. Operating and Storage Temperature Operating Temperature : -40°C to +85°C Storage Temperature : -40°C to +85°C 6. RJ45 specifications Insulation Resistance : 500MΩ min. Insertion force with the latch depressed : 20N max. Removal force with the latch depressed : 20N max. Locking Force of Plug Latch : Durability : 50N min. @ 60+/-5 sec. 750 cycles 7. Performance and Test Description Product is designed to meet electrical, mechanical and environmental performance requirements specified in below table. All tests are performed at ambient environmental conditions per MIL-STD-1344A and EIA-364 unless otherwise specified. 8. Packaging and Packing All parts shall be packaged and packed to protect against physical damage, corrosion and deterioration during shipment and storage. U. D. Electronic Corp. 6/9 UD-P09-R60A S2218018-00 S22-ZZ-0019 9. ELECTRICAL CHARACTERISTCS @ 25℃ PHY Side (INPUT) Cable Side (RJ45 OUTPUT) 1:1 TD+ R1 C1 TX+ TD- R2 C2 TX75Ω 75Ω TCT R4 C4 RCT R5 C5 1:1 RD+ R3 C3 RX+ C6 RX- RD- R6 75Ω 75Ω C7 NC R7 2KV 1000pF GND R8 C8 Emitting Color λp (nm) Vf @If=20mA Ir @Vr=5V Green 570 1.7 ~2.6 V 10μA max. Yellow 588 1.7 ~2.6 V 10μA max. U. D. Electronic Corp. 7/9 UD-P09-R60A S2218018-00 S22-ZZ-0019 Transmitter filter & Receiver filter Type : Balance low pass 100Ω impedance Insertion loss : 1 MHz Return loss : -1.0dB max. 100 MHz -1.4dB max. 1~30MHz -16dB min. load 100Ω 30~60MHz -14dB min. load 100Ω 60~80MHz -10dB min. load 100Ω Common Mode Rejection @1~100 MHz -30dB min. Cross Talk @ 1~100MHz -30dB min. Inductance @ 100KHz, 0.1V Input(TD+,TD-); (RD+,RD-) : 350 μH Typ. HiPot Test PHY Side(input) U. D. Electronic Corp. To Cable Side(output) : 8/9 1500Vac 60s or 2250Vdc 60s UD-P09-R60A S2218018-00 S22-ZZ-0019 10. WAVE SOLDERING TEMPERATURE PROFILE Note: The measuring point for the specified temperature shall be on the soldered part of the lead. U. D. Electronic Corp. 9/9 UD-P09-R60A
S22-ZZ-0019 价格&库存
很抱歉,暂时无法提供与“S22-ZZ-0019”相匹配的价格&库存,您可以联系我们找货
