DIO2543CS8
DIO2543CS8
    DIOO(帝奥)
    SOIC-8
    是低电压三通道视频放大器,集成了重建滤波器和输入钳位。与无源 LC 滤波器和分立驱动器解决方案相比,可提供更高的图像质量,特别适用于标准清晰度视频信号,如电视和机顶盒应用。可由直流耦合 DAC 输出或...
DIO2543CS8 数据手册
Limited Datasheet For full content datatasheet, please go to www.dioo.com/support/doc.html or Email datasheet.requiry@dioo.com Rec 0.2 DIO2543 Three-Channel, Channel, 9.5MHz, 6th-Order Order Standard Definition Video Filter Features Descriptions s th  Triple 6 -order 9.5MHz SD filters DIO2543 is a low voltage, triple video amplifier with  6dB Output Driver Gain integrated reconstruction filter and input clamps. and Drive Dual Video Load DIO2543 provides improved image quality  Transparent Input Clamping  AC or DC Coupled Inputs  AC or DC Coupled Outputs drivers solution, especially suited for standard  Operates from 3.135V to 5.5V definition video signals, such as television and  Single Power Supply set-top box applications.  Low Power 24mA Typical Supply Current  RoHS or Green SOIC-8 8 and MSOP-8 MSOP  compared with passive LC filters and discrete DIO2543 can be directly driven by a DC-coupled DC Package DAC output or an AC-coupled coupled signal. Internal diode 8kV ESD protection clamps and bias circuitry may be used if AC-coupled coupled inputs are required. Applications The output in DIO2543 can n also drive AC or DC coupled single  DVD Players  Video Amplifiers  Cable set-top boxes  Personal Video Recorders  Communications Devices  Video on Demand (150Ω) or dual (75Ω) loads. The DC coupling capacitors can be removed. Block Diagram Ordering Information Order Part Number Top Marking TA Package DIO2543CM8 DIO2543 RoHS/Green -40 to +85°C MSOP-8 Tape & Reel, 3000 DIO2543CS8 DIO2543 RoHS/Green -40 to +85°C SOIC--8 Tape & Reel, 2500 www.dioo.com © 2013 DIOO MICROCIRCUITS CO., LTD DIO DIO2543• Rec. 0.2 DIO2543 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.45 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 0° 8° Θ 9° 12° 15° Θ1 www.dioo.com © 2013 DIOO MICROCIRCUITS CO., LTD DIO IO2543• Rec. 0.2 Three-Channel, 9.5MHz, 6th-Order Standard Definition Video Filter Physical Dimensions: MSOP-8 DIO2543 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 15° 17° 19° Θ1 11° 13° 15° Θ2 15° 17° 19° Θ3 11° 13° 15° Θ4 www.dioo.com © 2013 DIOO MICROCIRCUITS CO., LTD DIO2543• Rec. 0.2 Three-Channel, 9.5MHz, 6th-Order Standard Definition Video Filter Physical Dimensions: SOIC-8 DIO2543 Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipments and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2013 DIOO MICROCIRCUITS CO., LTD DIO2543• Rec. 0.2 Three-Channel, 9.5MHz, 6th-Order Standard Definition Video Filter CONTACT US
DIO2543CS8 价格&库存
很抱歉,暂时无法提供与“DIO2543CS8”相匹配的价格&库存,您可以联系我们找货
