PEMD14,115
PEMD14,115
    NEXPERIA(安世)
    SOT666
    TRANS PREBIAS NPN/PNP SOT666
PEMD14,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PEMD14; PUMD14 NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open Rev. 02 — 2 September 2009 Product data sheet 1. Product profile 1.1 General description NPN/PNP resistor-equipped transistors Table 1. Product overview Type number Package PNP/PNP complement NPN/NPN complement NXP JEITA PEMD14 SOT666 - PEMB14 PEMH14 PUMD14 SOT363 SC-88 PUMB14 PUMH14 1.2 Features n n n n Built-in bias resistors Simplifies circuit design Reduces component count Reduces pick and place cost 1.3 Applications n Low current peripheral driver n Control of IC inputs n Replacement of general-purpose transistors in digital applications 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 50 V IO output current (DC) - - 100 mA R1 bias resistor 1 (input) 33 47 61 kΩ PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 2. Pinning information Table 3. Pinning Pin Description Simplified outline 1 GND (emitter) TR1 2 input (base) TR1 3 output (collector) TR2 4 GND (emitter) TR2 5 input (base) TR2 6 output (collector) TR1 6 5 4 Symbol 6 5 4 R1 TR2 TR1 1 2 3 R1 001aab555 1 2 3 006aaa269 3. Ordering information Table 4. Ordering information Type number Package Name Description Version PEMD14 - plastic surface mounted package; 6 leads SOT666 PUMD14 SC-88 plastic surface mounted package; 6 leads SOT363 4. Marking Table 5. Marking codes Type number Marking code[1] PEMD14 5B PUMD14 T2* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China PEMD14_PUMD14_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 2 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor; for the PNP transistor with negative polarity VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 5 V IO output current (DC) - 100 mA ICM peak collector current - 100 mA Ptot total power dissipation Tamb ≤ 25 °C SOT363 [1] - 200 mW SOT666 [1] [2] - 200 mW Tstg storage temperature −65 +150 °C Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Per device total power dissipation Ptot Tamb ≤ 25 °C SOT363 [1] - 300 mW SOT666 [1] [2] - 300 mW [1] Device mounted on a FR4 printed-circuit board, single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. 6. Thermal characteristics Table 7. Symbol Thermal characteristics Parameter Conditions Min Typ Max Unit Per transistor Rth(j-a) thermal resistance from junction to ambient Tamb ≤ 25 °C SOT363 [1] - - 625 K/W SOT666 [1] [2] - - 625 K/W SOT363 [1] - - 416 K/W SOT666 [1] [2] - - 416 K/W Per device Rth(j-a) thermal resistance from junction to ambient Tamb ≤ 25 °C [1] Device mounted on a FR4 printed-circuit board, single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. PEMD14_PUMD14_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 3 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified Symbol Parameter Conditions Min Typ Max Unit Per transistor; for the PNP transistor with negative polarity ICBO collector-base cut-off current VCB = 50 V; IE = 0 A - - 100 nA ICEO collector-emitter cut-off current VCE = 30 V; IB = 0 A - - 1 µA VCE = 30 V; IB = 0 A; Tj = 150 °C - - 50 µA nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 hFE DC current gain VCE = 5 V; IC = 1 mA 100 - - VCEsat collector-emitter saturation voltage IC = 10 mA; IB = 0.5 mA - - 150 mV R1 bias resistor 1 (input) 33 47 61 kΩ Cc collector capacitance TR1 (NPN) - - 2.5 pF TR2 (PNP) - - 3 pF VCB = −10 V; IE = ie = 0 A; f = 1 MHz PEMD14_PUMD14_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 4 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 006aaa182 103 006aaa183 103 VCEsat (mV) hFE (1) (2) 102 (2) (1) (3) (3) 102 10−1 1 10 102 10 1 I C (mA) VCE = 5 V IC/IB = 20 (1) Tamb = 100 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 1. 102 10 I C (mA) TR1 (NPN): DC current gain as a function of collector current; typical values Fig 2. 006aaa206 1000 (1) hFE TR1 (NPN): Collector-emitter saturation voltage as a function of collector current; typical values 006aaa207 −1 VCEsat (V) (2) (3) −10−1 100 (1) (2) (3) 10 −10−1 −1 −10 −102 −10−2 −10−1 IC (mA) VCE = −5 V −102 IC/IB = 20 (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C TR2 (PNP): DC current gain as a function of collector current; typical values Fig 4. TR2 (PNP): Collector-emitter saturation voltage as a function of collector current; typical values PEMD14_PUMD14_2 Product data sheet −10 IC (mA) (1) Tamb = 100 °C Fig 3. −1 © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 5 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 8. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 Fig 5. JEITA SC-88 EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 Package outline SOT363 (SC-88) PEMD14_PUMD14_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 6 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open Plastic surface-mounted package; 6 leads SOT666 D E A X Y S S HE 6 5 4 pin 1 index A 1 2 e1 c 3 bp w M A Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A bp c D E e e1 HE Lp w y mm 0.6 0.5 0.27 0.17 0.18 0.08 1.7 1.5 1.3 1.1 1.0 0.5 1.7 1.5 0.3 0.1 0.1 0.1 OUTLINE VERSION REFERENCES IEC JEDEC JEITA ISSUE DATE 04-11-08 06-03-16 SOT666 Fig 6. EUROPEAN PROJECTION Package outline SOT666 PEMD14_PUMD14_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 7 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 9. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code. [1] Type number Package Description Packing quantity 3000 4000 10000 PEMD14 SOT666 4 mm pitch, 8 mm tape and reel - -115 - PUMD14 SOT363 4 mm pitch, 8 mm tape and reel; T1 [2] -115 - -135 PUMD14 SOT363 4 mm pitch, 8 mm tape and reel; T2 [3] -125 - -165 [1] For further information and the availability of packing methods, see Section 12. [2] T1: normal taping [3] T2: reverse taping PEMD14_PUMD14_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 8 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 10. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PEMD14_PUMD14_2 20090902 Product data sheet - PEMD14_PUMD14_1 Modifications: PEMD14_PUMD14_1 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • • Figure 5 “Package outline SOT363 (SC-88)”: updated Figure 6 “Package outline SOT666”: updated 20050114 Product data sheet PEMD14_PUMD14_2 Product data sheet - - © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 9 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 11.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 12. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PEMD14_PUMD14_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 2 September 2009 10 of 11 PEMD14; PUMD14 NXP Semiconductors NPN/PNP resistor-equipped transistors; R1 = 47 kΩ, R2 = open 13. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 11.1 11.2 11.3 11.4 12 13 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics. . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information. . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 2 September 2009 Document identifier: PEMD14_PUMD14_2
PEMD14,115 价格&库存
很抱歉,暂时无法提供与“PEMD14,115”相匹配的价格&库存,您可以联系我们找货
PEMD14,115
  • 1+4.405711+0.57287
  • 10+2.7255710+0.35440
  • 100+1.72378100+0.22414
  • 500+1.29112500+0.16788
  • 1000+1.151131000+0.14968
  • 2000+1.033282000+0.13436
库存:3156
PEMD14,115
  • 1+3.80781
  • 10+2.33691
  • 100+1.50803
PEMD14,115
  • 4000+0.841604000+0.10943
  • 8000+0.764888000+0.09946
  • 12000+0.7257712000+0.09437
  • 20000+0.6818220000+0.08866
  • 28000+0.6557828000+0.08527
  • 40000+0.6304840000+0.08198
库存:3156
PEMD14,115
    • 1+0.44302
    • 10+0.35219
    • 30+0.30683
    • 100+0.27281
    • 500+0.24560
    • 1000+0.23199
    PEMD14,115
    • 1+4.093211+0.53223
    • 10+2.5115510+0.32657
    • 100+1.62512100+0.21131
    PEMD14,115
      PEMD14,115
        PEMD14,115
