74HCT4053PW,118
74HCT4053PW,118
    NEXPERIA(安世)
    TSSOP-16
    三路2通道模拟多路复用器/解复用器
74HCT4053PW,118 数据手册
74HC4053; 74HCT4053 Triple 2-channel analog multiplexer/demultiplexer Rev. 9 — 10 February 2016 Product data sheet 1. General description The 74HC4053; 74HCT4053 is a triple single-pole double-throw analog switch (3x SPDT) suitable for use in analog or digital 2:1 multiplexer/demultiplexer applications. Each switch features a digital select input (Sn), two independent inputs/outputs (nY0 and nY1) and a common input/output (nZ). A digital enable input (E) is common to all switches. When E is HIGH, the switches are turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Wide analog input voltage range from 5 V to +5 V  Complies with JEDEC standard no. 7A  Low ON resistance:  80  (typical) at VCC  VEE = 4.5 V  70  (typical) at VCC  VEE = 6.0 V  60  (typical) at VCC  VEE = 9.0 V  Logic level translation: to enable 5 V logic to communicate with 5 V analog signals  Typical ‘break before make’ built-in  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating 74HC4053; 74HCT4053 Nexperia Triple 2-channel analog multiplexer/demultiplexer 4. Ordering information Table 1. Ordering information Type number 74HC4053D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm 74HCT4053D 74HC4053DB 74HCT4053DB 74HC4053PW 74HCT4053PW 74HC4053BQ 74HCT4053BQ SOT763-1 5. Functional diagram 9&&  (
74HCT4053PW,118 价格&库存
很抱歉,暂时无法提供与“74HCT4053PW,118”相匹配的价格&库存,您可以联系我们找货
74HCT4053PW,118
  • 1+3.441951+0.43180
  • 10+2.3648810+0.29668
  • 25+2.1054125+0.26413
  • 100+1.81830100+0.22811
  • 250+1.68116250+0.21090
  • 500+1.59872500+0.20056
  • 1000+1.530771000+0.19204
库存:3
74HCT4053PW,118
  • 1+4.78933
  • 10+4.01631
  • 25+3.20969
  • 100+2.86519
  • 250+2.40307
  • 500+2.16780
  • 1000+2.00816
  • 2500+1.91573
库存:2046
74HCT4053PW,118
    74HCT4053PW,118
    • 1+0.99180
    • 100+0.96920
    库存:420
    74HCT4053PW,118
    • 50+1.53188
    • 650+1.48606
    • 1250+1.44128
    库存:400
