74AHC1G66; 74AHCT1G66
Single-pole single-throw analog switch
Rev. 04 — 18 December 2008
Product data sheet
1. General description
74AHC1G66 and 74AHCT1G66 are high-speed Si-gate CMOS devices. They are
single-pole single-throw analog switches. The switch has two input/output pins (Y and Z)
and an active HIGH enable input pin (E). When pin E is LOW, the analog switch is turned
off.
2. Features
n Very low ON resistance:
u 26 Ω (typ.) at VCC = 3.0 V
u 16 Ω (typ.) at VCC = 4.5 V
u 14 Ω (typ.) at VCC = 5.5 V
n High noise immunity
n Low power dissipation
n Balanced propagation delays
n Multiple package options
n ESD protection:
u HMB JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
u CDM JESD22-C101C exceeds 1000 V
n Specified from −40 °C to +85 °C and −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
74AHC1G66GW
Package
Temperature range
Name
Description
Version
−40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
−40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74AHCT1G66GW
74AHC1G66GV
74AHCT1G66GV
Nexperia
4. Marking
Table 2.
Marking codes
Type number
Marking
74AHC1G66GW
AL
74AHCT1G66GW
CL
74AHC1G66GV
A66
74AHCT1G66GV
C66
5. Functional diagram
Z
E
Y
E
Z
Y
VCC
001aag487
Fig 1. Logic symbol
mna628
Fig 2. Logic diagram
6. Pinning information
6.1 Pinning
74AHC1G66
74AHCT1G66
Y
1
Z
2
GND
3
5
VCC
4
E
001aai834
Fig 3.
Pin configuration SOT353-1 and SOT753
74AHC_AHCT1G66_4
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 17
Nexperia
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
Y
1
independent input or output
Z
2
GND
3
ground (0 V)
E
4
enable input (active HIGH)
VCC
5
supply voltage
7. Functional description
Table 4.
Function table[1]
Input E
Switch
L
OFF
H
ON
[1]
H = HIGH voltage level; L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
input clamping current
VI < −0.5 V
[1]
ISK
switch clamping current
VI < −0.5 V or VI > VCC + 0.5 V
[1]
ISW
switch current
−0.5 V < VO < VCC + 0.5 V
ICC
IIK
Min
Max
Unit
−0.5
+7.0
V
−20
mA
±20
mA
±25
mA
supply current
75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
250
mW
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output voltage ratings are observed.
[2]
For TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 6.
Voltages are referenced to GND (ground = 0 V).[1]
Symbol Parameter
Conditions
74AHC1G66
74AHCT1G66
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
V
VSW
switch voltage
VCC
VCC
V
74AHC_AHCT1G66_4
Product data sheet
3 of 17
Nexperia
Table 6.
Recommended operating conditions …continued
Symbol Parameter
Conditions
74AHC1G66
Tamb
ambient temperature
∆t/∆V
input transition rise and VCC = 3.3 ± 0.3 V
fall rate
VCC = 5.0 ± 0.5 V
74AHCT1G66
Unit
Min
Typ
Max
Min
Typ
Max
−40
+25
+125
−40
+25
+125
[2]
°C
100
ns/V
[2]
ns/V
[1]
To avoid drawing VCC current out of pin Z, when switch current flows in pin Y, the voltage drop across the bidirectional switch must not
exceed 0.4 V. If the switch current flows into pin Z, no VCC current will flow out of terminal Y. In this case there is no limit for the voltage
drop across the switch, but the voltage at pins Y and Z may not exceed VCC or GND.
[2]
Applies to control signal levels.
10. Static characteristics
Table 7.
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
74AHC1G66
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 2.0 V
VCC = 5.5 V
1.65
1.65
1.65
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 5.5 V
0.1
1.0
2.0
µA
IS(OFF)
OFF-state
leakage
current
Y or Z; VCC = 5.5 V;
see Figure 4
0.1
1.0
4.0
µA
IS(ON)
ON-state
leakage
current
see Figure 5
0.1
1.0
4.0
µA
ICC
supply current E, Y or Z = VCC or GND;
VCC = 5.5 V
1.0
10
40
µA
CI
input
capacitance
E input
2.0
10
10
10
pF
CS(ON)
ON-state
capacitance
Y or Z input or output
4.0
10
10
10
pF
74AHCT1G66
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 5.5 V
0.1
1.0
2.0
µA
74AHC_AHCT1G66_4
Product data sheet
4 of 17
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
IS(OFF)
OFF-state
leakage
current
see Figure 4
0.1
1.0
4.0
µA
IS(ON)
ON-state
leakage
current
see Figure 5
0.1
1.0
4.0
µA
ICC
VCC = 5.5 V
1.0
10
40
µA
∆ICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
E input
2.0
10
10
10
pF
CS(ON)
ON-state
capacitance
4.0
10
10
10
pF
10.1 Test circuits
VCC
VCC
E
VIL
IS
VI
E
VIH
Y
Z
IS
IS
GND
VI
VO
Y
Z
GND
VO
001aai835
VI = VCC or GND and VO = GND or VCC.
Fig 4. Test circuit for measuring OFF-state
leakage current
001aai836
VI = VCC or GND and VO = open circuit.
Fig 5. Test circuit for measuring ON-state
leakage current
74AHC_AHCT1G66_4
Product data sheet
5 of 17
Nexperia
10.2 ON resistance
Table 8.
ON resistance
At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graph see Figure 7 [1].
Symbol
Parameter
25 °C
Conditions
Typ
max
Max
Max
148[1]
Ω
ISW = 10 mA; VCC = 3.0 V to 3.6 V
28
50
70
110
Ω
ISW = 10 mA; VCC = 4.5 V to 5.5 V
15
30
40
60
Ω
ISW = 1.0 mA; VCC = 2.0 V
30
Ω
65
90
Ω
15
22
26
40
Ω
28
Ω
18
50
65
90
Ω
13
22
26
40
Ω
RON(peak) ON resistance
(peak)
RON(rail)
ON resistance
(rail)
VI = VCC to GND; see Figure 6
VI = GND; see Figure 6
VI = VCC; see Figure 6
[1]
At supply voltages approaching 2 V, the analog switch ON resistance becomes extremely non-linear. Therefore it is recommended that
these devices be used to transmit digital signals only, when using this supply voltage.
10.3 ON resistance test circuit and graphs
mna630
40
RON
(Ω)
30
VCC = 3.0 V
VSW
VCC
4.5 V
E
VIH
5.5 V
Y
VI
10
Z
GND
ISW
4
VI (V)
001aag490
Tamb = 25 °C.
RON = VSW / ISW.
Fig 6.
Test circuit for measuring ON resistance
Fig 7.
Typical ON resistance as a function of
input voltage
74AHC_AHCT1G66_4
Product data sheet
6
6 of 17
Nexperia
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); CL = 50 pF; unless otherwise specified; For test circuit see Figure 10.
Symbol Parameter
25 °C
Conditions
Typ[1]
max
Max
Max
VCC = 2.0 V
2.2
5.0
6.0
7.0
ns
1.0
2.0
3.0
4.0
ns
0.6
1.0
2.0
3.0
ns
VCC = 2.0 V; CL = 15 pF
7.0
25.0
33.0
40.0
ns
VCC = 2.0 V
11.0
35.0
46.0
57.0
ns
VCC = 3.0 V to 3.6 V;
CL = 15 pF
4.0
11.0
14.0
18.0
ns
5.8
15.0
20.0
25.0
ns
VCC = 4.5 V to 5.5 V;
CL = 15 pF
3.0
8.0
10.0
13.0
ns
4.0
11.0
13.0
17.0
ns
9.0
25.0
33.0
40.0
ns
VCC = 2.0 V
13.0
35.0
46.0
57.0
ns
CL = 15 pF
6.0
11.0
14.0
18.0
ns
8.4
15.0
20.0
25.0
ns
CL = 15 pF
5.0
8.0
10.0
13.0
ns
6.1
11.0
13.0
17.0
ns
13
pF
0.7
1.0
2.0
3.0
ns
3.0
7.0
10.0
13.0
ns
4.7
10.0
13.0
17.0
ns
CL = 15 pF
5.0
8.0
10.0
13.0
ns
6.5
11.0
13.0
17.0
ns
74AHC1G66
tpd
propagation
delay
Y to Z or Z to Y; see Figure 8
[2]
ten
enable time
E to Y or Z; see Figure 9
[2]
tdis
disable time
[2]
CPD
power
dissipation
capacitance
VI = GND to VCC
[3]
[2]
74AHCT1G66
tpd
propagation
delay
ten
enable time
[2]
CL = 15 pF
tdis
disable time
[2]
74AHC_AHCT1G66_4
Product data sheet
7 of 17
Nexperia
Table 9.
Dynamic characteristics …continued
Symbol Parameter
CPD
power
dissipation
capacitance
25 °C
Conditions
max
Max
Max
15
[3]
VI = GND to VCC
Typ[1]
[1]
All typical values are measured at VCC = 2.0 V, VCC = 3.3 V, VCC = 5.0 V and Tamb = 25 °C.
[2]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[3]
CPD is used to determine the dynamic power dissipation PD (µW).
PD = CPD × VCC2 × fi + Σ ((CL × CSW) × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
CSW = maximum switch capacitance in pF (see Table 7);
VCC = supply voltage in Volt;
Σ ((CL × CSW) × VCC2 × fo) = sum of outputs.
pF
11.1 Waveforms and test circuit
VI
VM
Y or Z input
GND
t PLH
t PHL
VOH
VM
Z or Y output
VOL
mna667
Measurement points are given in Table 10.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig 8.
Input (Y or Z) to output (Z or Y) propagation delays
74AHC_AHCT1G66_4
Product data sheet
8 of 17
Nexperia
VI
E
VM
GND
t PZL
t PLZ
VCC
Y or Z
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
Y or Z
output
HIGH-to-OFF
OFF-to-HIGH
VOH
VY
VM
GND
switch
enabled
switch
disabled
switch
enabled
mna668
Fig 9.
Table 10.
Enable and disable times
Measurement points
Type
Input
Output
VM
VM
VX
VY
74AHC1G66
0.5VCC
0.5VCC
VOL + 0.3 V
VOH − 0.3 V
74AHCT1G66
1.5 V
1.5 V
VOL + 0.3 V
VOH − 0.3 V
74AHC_AHCT1G66_4
Product data sheet
9 of 17
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
CL
RT
001aad983
Test data is given in Table 11.
Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig 10. Test circuit for measuring switching times
Table 11.
Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74AHC1G66
GND to VCC
3 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHCT1G66
GND to 3 V
3 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
11.2 Additional dynamic characteristics
Table 12. Additional dynamic characteristics for 74AHC1G66 and 74AHCT1G66
GND = 0 V; tr = tf = 3.0 ns; CL = 50 pF; unless otherwise specified. All typical values are measured at Tamb = 25 °C.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
THD
total harmonic
distortion
fi = 1 kHz; RL = 10 kΩ; see Figure 11
0.025
0.015
VCC = 3.0 V to 3.6 V; VI = 2.5 V
0.025
VCC = 4.5 V to 5.5 V; VI = 4.0 V
0.015
fi = 10 kHz; RL = 10 kΩ; see Figure 11
74AHC_AHCT1G66_4
Product data sheet
10 of 17
Nexperia
Table 12. Additional dynamic characteristics for 74AHC1G66 and 74AHCT1G66 …continued
Symbol
Parameter
Conditions
f(−3dB)
−3 dB frequency
response
RL = 50 Ω; CL = 10 pF;
see Figure 12 and 13
αiso
[1]
isolation (OFF-state)
Min
Typ
Max
Unit
230
MHz
280
MHz
−50
dB
−50
dB
RL = 600 Ω; fi = 1 MHz; see Figure 14
[1]
Adjust input voltage VI to 0 dBm level (0 dBm =1 mW into 50 Ω).
11.3 Test circuits and graphs
VCC
VCC
E
VIH
2RL
10 µF
Y/Z
Z/Y
fi
VO
2RL
CL
D
001aai678
Test conditions:
VCC = 3.0 V to 3.6 V; VI = 2.5 V (p-p).
VCC = 4.5 V to 5.5 V; VI = 4.0 V (p-p).
Fig 11. Test circuit for measuring total harmonic distortion
VCC
VCC
E
VIH
2RL
0.1 µF
fi
Y/Z
Z/Y
VO
2RL
CL
dB
001aai680
With fi = 1 MHz adjust the switch input voltage for a 0 dBm level at the switch output, (0 dBm = 1 mW into 50 Ω). Then increase
the input fi frequency until the dB meter reads −3 dB.
Fig 12. Test circuit for measuring the −3 dB frequency response
74AHC_AHCT1G66_4
Product data sheet
11 of 17
Nexperia
001aai837
4
(dB)
2
−2
−4
104
105
106
107
108
109
fi (Hz)
Test conditions: VCC = 4.5 V; GND = 0 V; RL = 50 Ω; RSOURCE = 1 kΩ.
Fig 13. Typical −3 dB frequency response
VCC
VCC
E
VIL
2RL
0.1 µF
Y/Z
fi
Z/Y
VO
CL
2RL
dB
001aai679
Adjust the switch input voltage for a 0 dBm level (0 dBm = 1 mW into 600 Ω).
Fig 14. Test circuit for measuring isolation (OFF-state)
74AHC_AHCT1G66_4
Product data sheet
12 of 17
Nexperia
12. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 15. Package outline SOT353-1 (TSSOP5)
74AHC_AHCT1G66_4
Product data sheet
13 of 17
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
E
B
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Fig 16. Package outline SOT753 (SC-74A)
74AHC_AHCT1G66_4
Product data sheet
14 of 17
Nexperia
13. Abbreviations
Table 13.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
14. Revision history
Table 14.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT1G66_4
20081218
Product data sheet
74AHC_AHCT1G66_3
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Package SOT353 changed to SOT353-1 in Table 1 and Figure 15.
Quick Reference Data and Soldering sections removed.
Section 2 “Features” updated.
74AHC_AHCT1G66_3
20020606
Product specification
74AHC_AHCT1G66_2
74AHC_AHCT1G66_2
20020215
74AHC_AHCT1G66_1
74AHC_AHCT1G66_1
20010129
74AHC_AHCT1G66_4
Product data sheet
15 of 17
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT1G66_4
Product data sheet
16 of 17
Nexperia
17. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
10.1
10.2
10.3
11
11.1
11.2
11.3
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 3
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
ON resistance . . . . . . . . . . . . . . . . . . . . . . . . . . 6
ON resistance test circuit and graphs. . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms and test circuit . . . . . . . . . . . . . . . . 8
Additional dynamic characteristics . . . . . . . . . 10
Test circuits and graphs . . . . . . . . . . . . . . . . . 11
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15
Legal information. . . . . . . . . . . . . . . . . . . . . . . 16
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Contact information. . . . . . . . . . . . . . . . . . . . . 16
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Date of release: 18 December 2008
很抱歉,暂时无法提供与“74AHCT1G66GV,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.777151+0.21345
- 10+1.2014010+0.14430
- 25+1.0592325+0.12722
- 100+0.90344100+0.10851
- 250+0.82905250+0.09958
- 500+0.78438500+0.09421
- 1000+0.747501000+0.08978
- 国内价格 香港价格
- 3000+0.555913000+0.06677
- 6000+0.537526000+0.06456
- 9000+0.528329000+0.06346
- 15000+0.5181115000+0.06223
- 21000+0.5121521000+0.06152
- 30000+0.5064230000+0.06083
- 75000+0.4940675000+0.05934
- 150000+0.48662150000+0.05845
