74HC4316DB,118
74HC4316DB,118
    NEXPERIA(安世)
    SSOP16_6.2X5.3MM
    四极单极单掷模拟开关
74HC4316DB,118 数据手册
74HC4316; 74HCT4316 Quad single-pole single-throw analog switch Rev. 4 — 15 October 2018 Product data sheet 1. General description The 74HC4316; 74HCT4316 is a quad single pole, single throw analog switch (SPST). Each switch features two input/output terminals (nY and nZ) and an active HIGH enable input (nS). When nS is LOW, the analog switch is turned off. When E is HIGH all four analog switches are turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • Input levels E and nS inputs: • For 74HC4316: CMOS level • For 74HCT4316: TTL level Low ON resistance: • 160 Ω (typical) at VCC - VEE = 4.5 V • 120 Ω (typical) at VCC - VEE = 6.0 V • 80 Ω (typical) at VCC - VEE = 9.0 V Logic level translation: • To enable 5 V logic to communicate with ±5 V analog signals Typical break-before-make built in Specified in compliance with JEDEC standard no. 7A ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Applications • • • • Signal gating Modulation Demodulation Chopper 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 4. Ordering information Table 1. Ordering information Type number Package 74HC4316D Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm 74HCT4316D 74HC4316DB 74HCT4316DB 74HC4316PW 74HCT4316PW SOT338-1 SOT403-1 5. Functional diagram 7 7 G1 2 15 5 6 14 1Y 1Z 1S 2Y 2S 2Z 3Y 3S 3Z 4S 4Y 4Z E 2 15 # 1 1 1 3 3 5# 4 4 6# 10 12 12 13 14 # 2 4 1 10 11 10 6# 1 13 12 13 14 # 1 (b) aaa-024847 aaa-024846 Fig. 1. Logic symbol 74HC_HCT4316 Product data sheet 1 1X2 3 (a) 7 2 5# 11 11 2 15 # G1 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 2 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch VCC 16 1 1Z 1S 15 2 1Y 4 2Z 2S 5 3 2Y 3S 6 LOGIC LEVEL CONVERSION AND CONTROL 10 3Z 11 3Y 13 4Z 4S 14 12 4Y E 7 Fig. 3. 8 9 GND VEE aaa-024848 Functional diagram nY VCC E LOGIC LEVEL CONVERSION nS LOGIC LEVEL CONVERSION VEE VEE VCC VCC VEE nZ Fig. 4. aaa-024850 Schematic diagram (one switch) 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 3 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 6. Pinning information 6.1. Pinning 74HC4316 74HCT4316 1Z 1 16 VCC 1Y 2 15 1S 2Y 3 14 4S 2Z 4 13 4Z 2S 5 74HC4316 74HCT4316 1Z 1 1Y 2 16 VCC 15 1S 2Y 3 14 4S 2Z 4 13 4Z 12 4Y 2S 5 12 4Y 6 11 3Y 10 3Z 3S 6 11 3Y 3S 7 E 7 10 3Z E GND 8 GND 8 9 VEE VEE aaa-024852 aaa-024851 Fig. 5. 9 Fig. 6. Pin configuration SOT109-1 (SO16) Pin configuration SOT338-1 (SSOP16) and SOT403-1 (TSSOP16) 6.2. Pin description Table 2. Pin description Symbol Pin Description 1Z, 2Z, 3Z, 4Z 1, 4, 10, 13 independent input or output 1Y, 2Y, 3Y, 4Y 2, 3, 11, 12 independent input or output E 7 enable input (active LOW) GND 8 ground (0 V) VEE 9 negative supply voltage 1S, 2S, 3S, 4S 15, 5, 6, 14 select input (active HIGH) VCC 14 positive supply voltage 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Input Switch E nS L L OFF L H ON H X OFF 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 4 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max Unit VCC supply voltage -0.5 +11.0 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA ISK switch clamping current VSW < -0.5 V or VSW > VCC + 0.5 V ISW switch current VSW = -0.5 V to VCC + 0.5 V - ±20 mA - ±25 mA IEE supply current - 20 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation Tamb = -40 °C to +125 °C - 500 mW P power dissipation per switch - 100 mW [1] [2] Conditions [1] [2] To avoid drawing VCC current out of terminal nZ, when switch current flows in terminals nY, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no VCC current will flow out of terminals nY. In this case there is no limit for the voltage drop across the switch, but the voltages at nY and nZ may not exceed VCC or VEE. For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C. For (T)SSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 °C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage 74HC4316 74HCT4316 Unit Min Typ Max Min Typ Max VCC - GND 2.0 5.0 10.0 4.5 5.0 5.5 V VEE - GND 2.0 5.0 10.0 2.0 5.0 10.0 V see Fig. 7 and Fig. 8 VI input voltage GND - VCC GND - VCC V VSW switch voltage VEE - VCC VEE - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate 74HC_HCT4316 Product data sheet VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V VCC = 10.0 V - - 35 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 5 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 001aad545 10 001aad546 10 VCC - GND (V) VCC - GND (V) 8 8 6 6 operating area operating area 4 4 2 2 0 Fig. 7. 0 2 4 6 0 8 10 VCC - VEE (V) Guaranteed operating area as a function of the supply voltages for 74HC4316 Fig. 8. 0 2 4 6 8 10 VCC - VEE (V) Guaranteed operating area as a function of the supply voltages for 74HCT4316 10. Static characteristics Table 6. RON resistance per switch for types 74HC4316 and 74HCT4316 VI = VIH or VIL; for test circuit see Fig. 9. Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. For 74HC4316: VCC - GND or VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. For 74HCT4316: VCC - GND = 4.5 V and 5.5 V; VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. Symbol Parameter Conditions 25 °C Product data sheet -40 °C to +125 °C Unit Typ Max Min Max Min Max - - - - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA 160 320 - 400 - 480 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA 120 240 - 300 - 360 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA 85 170 - 215 - 255 Ω RON(peak) ON resistance Vis = VCC to VEE (peak) VCC = 2.0 V; VEE = 0 V; ISW = 100 μA 74HC_HCT4316 -40 °C to +85 °C [1] All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 6 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch Symbol RON(rail) Parameter Conditions 25 °C Max Min Max Min Max 160 - - - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA 80 160 - 200 - 240 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA 70 140 - 175 - 210 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA 60 120 - 150 - 180 Ω VCC = 2.0 V; VEE = 0 V; ISW = 100 μA 170 - - - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA 90 180 - 225 - 270 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA 80 160 - 200 - 240 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA 65 135 - 170 - 205 Ω - - - - - - Ω 16 - - - - - Ω 9 - - - - - Ω 6 - - - - - Ω ON resistance Vis = VEE (rail) VCC = 2.0 V; VEE = 0 V; ISW = 100 μA [1] [1] ON resistance Vis = VCC to VEE mismatch VCC = 2.0 V; VEE = 0 V between VCC = 4.5 V; VEE = 0 V channels VCC = 6.0 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V [1] -40 °C to +125 °C Unit Typ Vis = VCC ΔRON -40 °C to +85 °C [1] When supply voltages (VCC - VEE) near 2.0 V the analog switch ON resistance becomes extremely non-linear. When using a supply of 2 V, it is recommended to use these devices only for transmitting digital signals. aaa-024854 200 RON (Ω) Vsw VCC = 4.5 V V VCC nS VIH E VIL VCC = 9.0 V nY Vis VCC = 6.0 V 100 nZ GND VEE Isw aaa-024853 Vis = 0 V to (VCC - VEE) 0 0 5 Vis (V) 10 Vis = 0 V to (VCC - VEE) Fig. 9. Test circuit for measuring RON 74HC_HCT4316 Product data sheet Fig. 10. Typical RON as a function of input voltage Vis All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 7 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch Table 7. Static characteristics 74HC4316 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 9.0 V 6.3 4.3 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V VCC = 9.0 V - 4.3 2.7 V VCC = 6.0 V; VEE = 0 V - - ±0.1 μA VCC = 10.0 V; VEE = 0 V - - ±0.2 μA Tamb = 25 °C VIH VIL II HIGH-level input voltage LOW-level input voltage input leakage current VI = VCC or GND IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 11 - - ±0.1 μA IS(ON) ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 12 - - ±0.1 μA ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE VCC = 6.0 V; VEE = 0 V - - 8.0 μA VCC = 10.0 V; VEE = 0 V - - 16.0 μA CI input capacitance - 3.5 - pF Csw switch capacitance - 5 - pF VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V VCC = 9.0 V - - 2.7 V VCC = 6.0 V; VEE = 0 V - - ±1.0 μA VCC = 10.0 V; VEE = 0 V - - ±2.0 μA Tamb = -40 °C to +85 °C VIH VIL II HIGH-level input voltage LOW-level input voltage input leakage current VI = VCC or GND IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 11 - - ±1.0 μA IS(ON) ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 12 - - ±1.0 μA ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE VCC = 6.0 V; VEE = 0 V - - 80.0 μA VCC = 10.0 V; VEE = 0 V - - 160.0 μA © Nexperia B.V. 2018. All rights reserved 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 8 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V VCC = 9.0 V - - 2.7 V VCC = 6.0 V; VEE = 0 V - - ±1.0 μA VCC = 10.0 V; VEE = 0 V - - ±2.0 μA Tamb = -40 °C to +125 °C VIH VIL II HIGH-level input voltage LOW-level input voltage input leakage current VI = VCC or GND IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 11 - - ±1.0 μA IS(ON) ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 12 - - ±1.0 μA ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE VCC = 6.0 V; VEE = 0 V - - 160 μA VCC = 10.0 V; VEE = 0 V - - 320 μA Table 8. Static characteristics 74HCT4316 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit - V Tamb = 25 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - ±0.1 μA IS(OFF) OFF-state leakage current VCC = 10 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 11 - - ±0.1 μA IS(ON) ON-state leakage current VCC = 10 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 12 - - ±0.1 μA ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE VCC = 5.5 V; VEE = 0 V - - 8.0 μA VCC = 5.0 V; VEE = -5.0 V - - 16.0 μA - 50 180 μA ΔICC additional supply current CI input capacitance - 3.5 - pF Csw switch capacitance - 5 - pF 74HC_HCT4316 Product data sheet nS and E; per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 9 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch Symbol Parameter Conditions Min Typ Max Unit - V Tamb = -40 °C to +85 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 10 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 11 - - ±1.0 μA IS(ON) ON-state leakage current VCC = 10 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 12 - - ±1.0 μA ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE VCC = 5.5 V; VEE = 0 V - - 80 μA VCC = 5.0 V; VEE = -5.0 V - - 160 μA - - 225 μA ΔICC additional supply current nS and E; per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 10 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 11 - - ±1.0 μA IS(ON) ON-state leakage current VCC = 10 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Fig. 12 - - ±1.0 μA ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE VCC = 5.5 V; VEE = 0 V - - 160 μA VCC = 5.0 V; VEE = -5.0 V - - 320 μA - - 245 μA ΔICC additional supply current nS and E; per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V VCC VIL VIH VCC nS VIH E Isw A Vis nS nY nZ GND VEE VIL Isw A E Isw A Vos Vis nY nZ GND aaa-024855 aaa-024856 Vis = VCC and Vos = VEE Vis = VEE and Vos = VCC Vis = VCC and Vos = open Vis = VEE and Vos = open Fig. 11. Test circuit for measuring OFF-state leakage current 74HC_HCT4316 Product data sheet Vos VEE Fig. 12. Test circuit for measuring ON-state leakage current All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 10 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 11. Dynamic characteristics Table 9. Dynamic characteristics GND = 0 V; tr = tf = 6 ns; CL = 50 pF unless specified otherwise; for test circuit see Fig. 15. Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Typ Max Min Max Min Max VCC = 2.0 V; VEE = 0 V 17 60 - 75 - 90 ns VCC = 4.5 V; VEE = 0 V 6 12 - 15 - 18 ns VCC = 6.0 V; VEE = 0 V 5 10 - 13 - 15 ns VCC = 4.5 V; VEE = -4.5 V 4 8 - 10 - 12 ns VCC = 2.0 V; VEE = 0 V 63 220 - 275 - 330 ns VCC = 4.5 V; VEE = 0 V 23 44 - 55 - 66 ns VCC = 5.0 V; VEE = 0 V;CL = 15 pF 20 - - - - - ns VCC = 6.0 V; VEE = 0 V 18 37 - 47 - 56 ns 21 39 - 49 - 59 ns VCC = 2.0 V; VEE = 0 V 55 175 - 220 - 265 ns VCC = 4.5 V; VEE = 0 V 20 35 - 44 - 53 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF 16 - - - - - ns VCC = 6.0 V; VEE = 0 V 16 30 - 37 - 45 ns VCC = 4.5 V; VEE = -4.5 V 18 36 - 45 - 54 ns VCC = 2.0 V; VEE = 0 V 61 205 - 255 - 310 ns VCC = 4.5 V; VEE = 0 V 22 41 - 51 - 62 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF 19 - - - - - ns VCC = 6.0 V; VEE = 0 V 18 35 - 43 - 53 ns VCC = 4.5 V; VEE = -4.5 V 19 37 - 47 - 56 ns VCC = 2.0 V; VEE = 0 V 52 175 - 220 - 265 ns VCC = 4.5 V; VEE = 0 V 19 35 - 44 - 53 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF 16 - - - - - ns VCC = 6.0 V; VEE = 0 V 15 30 - 37 - 45 ns VCC = 4.5 V; VEE = -4.5 V 17 34 - 43 - 51 ns - - - - - pF 74HC4316 tpd toff propagation nY to nZ or nZ to nY; RL = ∞ Ω; see Fig. 13 delay turn-off time E to nY or nZ; see Fig. 14 [1] [2] VCC = 4.5 V; VEE = -4.5 V nS to nY or nZ; see Fig. 14 ton turn-on time E to nY or nZ; see Fig. 14 [3] nS to nY or nZ; see Fig. 14 CPD power per switch; VI = GND to VCC dissipation capacitance 74HC_HCT4316 Product data sheet [2] [3] [4] 13 All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 11 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Typ Max Min Max Min Max VCC = 4.5 V; VEE = 0 V 6 12 - 15 - 18 ns VCC = 4.5 V; VEE = -4.5 V 4 8 - 10 - 12 ns 22 44 - 55 - 66 ns 19 - - - - - ns 21 42 - 53 - 63 ns VCC = 4.5 V; VEE = 0 V 20 40 - 53 - 60 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF 17 - - - - - ns VCC = 4.5 V; VEE = -4.5 V 17 34 - 43 - 51 ns 28 56 - 70 - 84 ns 24 - - - - - ns 21 42 - 53 - 63 ns VCC = 4.5 V; VEE = 0 V 25 50 - 63 - 75 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF 21 - - - - - ns VCC = 4.5 V; VEE = -4.5 V 17 34 - 43 - 51 ns VCC = 4.5 V; VEE = 0 V 25 50 - 63 - 75 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF 21 - - - - - ns VCC = 4.5 V; VEE = -4.5 V 23 46 - 58 - 69 ns VCC = 4.5 V; VEE = 0 V 22 44 - 55 - 66 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF 19 - - - - - ns VCC = 4.5 V; VEE = -4.5 V 20 40 - 50 - 60 ns - - - - - pF 74HCT4316 propagation nY to nZ or nZ to nY; RL = ∞ Ω; see Fig. 13 delay tpd tPZH [1] E to nY or nZ; see Fig. 14 OFF-state to HIGH VCC = 4.5 V; VEE = 0 V propagation VCC = 5.0 V; VEE = 0 V; CL = 15 pF delay VCC = 4.5 V; VEE = -4.5 V nS to nY or nZ; see Fig. 14 E to nY or nZ; see Fig. 14 OFF-state to LOW VCC = 4.5 V; VEE = 0 V propagation VCC = 5.0 V; VEE = 0 V; CL = 15 pF delay VCC = 4.5 V; VEE = -4.5 V tPZL nS to nY or nZ; see Fig. 14 turn-off time E to nY or nZ; see Fig. 14 toff [2] nS to nY or nZ; see Fig. 14 CPD [1] [2] [3] [4] power per switch; VI = GND to (VCC - 1.5 V) dissipation capacitance [2] [4] 14 tpd is the same as tPHL and tPLH. toff is the same as tPHZ and tPLZ. ton is the same as tPZH and tPZL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + ∑((CL + Csw) x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; 2 ∑((CL + Csw) x VCC x fo) = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 12 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 11.1. Waveforms and test circuit 50 % Vis input tPLH tPHL 50 % Vos output 001aad555 Fig. 13. Input (Vis) to output (Vos) propagation delays VI VM nS, E input 0V tPLZ tPZL 50 % Vos output 10 % tPHZ tPZH 90 % 50 % Vos output switch ON switch OFF switch ON aaa-024857 Measurement points are shown in Table 10. Fig. 14. Turn-on and turn-off times Table 10. Measurement points Type VI VM 74HC4316 VCC 0.5VCC 74HCT4316 3.0 V 1.3 V 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 13 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % VM positive pulse VM 10 % 0V tW VCC Vis PULSE GENERATOR VI DUT VCC Vos RT RL S1 open CL GND VEE aaa-024858 Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 15. Test circuit for measuring switching times Table 11. Test data Test Input E Output nS Switch nY (nZ) tr, tf S1 position Switch nZ (nY) Vis at fmax other [1] CL RL tPHL, tPLH [2] GND to VCC < 2 ns 6 ns 50 pF - open tPHZ, tPZH [2] VCC < 2 ns 6 ns 50 pF, 15 pF 1 kΩ VEE tPLZ, tPZL [2] VEE < 2 ns 6 ns 50 pF, 15 pF 1 kΩ VCC VI [1] [2] tr = tf = 6 ns; when measuring fmax, there is no constraint to tr and tf with 50 % duty factor. VI values: For 74HC4316: VI = VCC For 74HCT4316: VI = 3 V 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 14 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 11.2. Additional dynamic characteristics Table 12. Additional dynamic characteristics Recommended conditions and typical values; GND = 0 V; Tamb = 25 °C; CL = 50 pF. Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. Symbol Parameter Conditions THD fi = 1 kHz; RL = 10 kΩ; see Fig. 16 total harmonic distortion Min Typ Max Unit Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = -2.25 V - 0.80 - % Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = -4.5 V - 0.40 - % - 2.40 - % - 1.20 - % VCC = 2.25 V; VEE = -2.25 V - 150 - MHz VCC = 4.5 V; VEE = -4.5 V - 160 - MHz VCC = 2.25 V; VEE = -2.25 V - -50 - dB VCC = 4.5 V; VEE = -4.5 V - -50 - dB VCC = 4.5 V; VEE = 0 V - 110 - mV VCC = 4.5 V; VEE = -4.5 V - 220 - mV VCC = 2.25 V; VEE = -2.25 V - -60 - dB VCC = 4.5 V; VEE = -4.5 V - -60 - dB fi = 10 kHz; RL = 10 kΩ; see Fig. 16 Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = -2.25 V Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = -4.5 V f(-3dB) RL = 50 Ω; CL = 10 pF; see Fig. 17 [1] isolation (OFF-state) RL = 600 Ω; fi = 1 MHz; see Fig. 18 αiso Vct crosstalk voltage Xtalk [1] [2] -3 dB frequency response crosstalk [2] between digital input and switch (peak to peak value); RL = 600 Ω; fi = 1 MHz; E or nS square wave between VCC and GND; tr = tf = 6 ns; see Fig. 19 between switches; RL = 600 Ω; fi = 1 MHz; see Fig. 20 [2] Adjust input voltage Vis to 0 dBm level at Vos for 1 MHz (0 dBm = 1 mW into 50 Ω). Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 Ω). VCC nS VIH E VIL 10 µF Vis nYn/nZ nZ/nYn VEE GND Vos RL CL dB aaa-024860 Fig. 16. Test circuit for measuring total harmonic distortion 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 15 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch VCC nS VIH E VIL Vis 0.1 µF nYn/nZ nZ/nYn VEE GND Vos RL CL dB aaa-024861 VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 50 Ω; RS = 1 kΩ. a. Test circuit aaa-024862 5 (dB) 0 -5 10 102 103 104 105 fi (kHz) 106 b. Typical -3 dB frequency response Fig. 17. -3 dB frequency response 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 16 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch VCC nS VIH E VIL 0.1 µF Vis nYn/nZ nZ/nYn VEE GND Vos RL CL dB aaa-024861 VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 600 Ω; RS = 1 kΩ. a. Test circuit 001aae332 0 α iso (dB) - 20 - 40 - 60 - 80 - 100 102 10 103 104 105 fi (kHz) 106 b. Isolation (OFF-state) as a function of frequency Fig. 18. Isolation (OFF-state) as a function of frequency 2RL 2RL VCC Vct nS, E nY G 2RL nZ VEE GND 2RL oscilloscope aaa-024863 Fig. 19. Test circuit for measuring crosstalk voltage (between the digital input and the switch) 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 17 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch VCC nS VIH E VIL Vis 0.1 µF RL nY/nZ nZ/nY VEE GND RL CL VCC nS VIL E VIH nY/nZ RL nZ/nY VEE GND Vos RL CL dB aaa-024864 Fig. 20. Test circuit for measuring crosstalk (between the switches) 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 18 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 21. Package outline SOT109-1 (SO16) 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 19 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 22. Package outline SOT338-1 (SSOP16) 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 20 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 23. Package outline SOT403-1 (TSSOP16) 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 21 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 13. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4316 v.4 20181016 Product data sheet - 74HC_HCT4316 v.3 Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74HC_HCT4316 v.3 20170102 Modifications: • • • Product data sheet - 74HC_HCT4316_CNV v.2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC4316N and 74HCT4316N removed. 74HC_HCT4316_CNV v.2 19930901 74HC_HCT4316 Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 - © Nexperia B.V. 2018. All rights reserved 22 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT4316 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 23 / 24 74HC4316; 74HCT4316 Nexperia Quad single-pole single-throw analog switch Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Functional diagram.......................................................2 6. Pinning information......................................................4 6.1. Pinning.........................................................................4 6.2. Pin description............................................................. 4 7. Functional description................................................. 4 8. Limiting values............................................................. 5 9. Recommended operating conditions..........................5 10. Static characteristics..................................................6 11. Dynamic characteristics...........................................11 11.1. Waveforms and test circuit.......................................13 11.2. Additional dynamic characteristics........................... 15 12. Package outline........................................................ 19 13. Abbreviations............................................................ 22 14. Revision history........................................................22 15. Legal information......................................................23 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 October 2018 74HC_HCT4316 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 15 October 2018 © Nexperia B.V. 2018. All rights reserved 24 / 24
74HC4316DB,118 价格&库存
很抱歉,暂时无法提供与“74HC4316DB,118”相匹配的价格&库存,您可以联系我们找货
