74LVC1G80GF,132
74LVC1G80GF,132
    NEXPERIA(安世)
    XSON6_1.05X1.05MM
    单D型触发器;正边缘触发器
74LVC1G80GF,132 数据手册
74LVC1G80 Single D-type flip-flop; positive-edge trigger Rev. 13 — 5 December 2016 Product data sheet 1. General description The 74LVC1G80 provides a single positive-edge triggered D-type flip-flop. Information on the data input is transferred to the Q output on the LOW-to-HIGH transition of the clock pulse. The input pin D must be stable one set-up time prior to the LOW-to-HIGH clock transition for predictable operation. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 1.65 V to 5.5 V  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8B/JESD36 (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance exceeds 250 mA  Direct interface with TTL levels  Inputs accept voltages up to 5 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C. 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G80GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G80GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G80GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1.45  0.5 mm SOT886 74LVC1G80GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1  0.5 mm SOT891 74LVC1G80GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74LVC1G80GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74LVC1G80GX 40 C to +125 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking codes Type number Marking[1] 74LVC1G80GW VT 74LVC1G80GV V80 74LVC1G80GM VT 74LVC1G80GF VT 74LVC1G80GN VT 74LVC1G80GS VT 74LVC1G80GX VT [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  ' 4     &3 ' DDF PQD Fig 1. Logic symbol 74LVC1G80 Product data sheet  &3 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger &3 & & ' & & 7* 7* & & Fig 3. 4 & & 7* 7* & & PQD Logic diagram 6. Pinning information 6.1 Pinning /9&* /9&* '  &3  *1'    '   9&& &3   QF *1'   4 9&& 4 DDE 7UDQVSDUHQWWRSYLHZ DDE Fig 4. Pin configuration SOT353-1 and SOT753 Fig 5. Pin configuration SOT886 /9&* /9&* ' '   9&& &3   QF *1'   4 &3   4 DDD Pin configuration SOT891, SOT1115 and SOT1202 Product data sheet 9&& 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ 74LVC1G80   *1' DDI Fig 6.  Fig 7. Pin configuration SOT1226 (X2SON5) All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 6.2 Pin description Table 3. Pin description Symbol Pin D Description TSSOP5 and X2SON5 XSON6 1 1 data input CP 2 2 clock pulse input GND 3 3 ground (0 V) Q 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description Table 4. Function table[1] Input Output CP D Q  L H  H L L X q [1] H = HIGH voltage level; L = LOW voltage level.  = LOW-to-HIGH CP transition; X = don’t care; q = lower case letter indicates the state of referenced input, one set-up time prior to the LOW-to-HIGH CP transition. 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Max Unit 0.5 +6.5 V 50 - 0.5 +6.5 V mA VI < 0 V [1] - 50 Active mode 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA - 100 mA 100 - mA - 250 mW 65 +150 C VO = 0 V to VCC Tamb = 40 C to +125 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] mA [1][2] VO > VCC or VO < 0 V output voltage VO Min For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate 74LVC1G80 Product data sheet Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V VCC = 0 V; Power-down mode 0 - 5.5 V 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 - - V IO = 8 mA; VCC = 2.3 V 1.9 - - V IO = 12 mA; VCC = 2.7 V 2.2 - - V IO = 24 mA; VCC = 3.0 V 2.3 - - V IO = 32 mA; VCC = 4.5 V 3.8 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage 0.35  VCC V VCC = 1.65 V to 1.95 V VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - 0.1 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - 5 500 A CI input capacitance VCC = 3.3 V; VI = GND to VCC - 5 - pF 0.65  VCC - - V 1.7 - - V Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V VIL LOW-level input voltage 74LVC1G80 Product data sheet VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 0.35  VCC V 0.7 © V Nexperia B.V. 2017. All rights reserved 6 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger Table 7. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Min Typ[1] Max VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V IO = 32 mA; VCC = 4.5 V 3.4 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V Symbol Parameter Conditions VOH VI = VIH or VIL HIGH-level output voltage IO = 100 A; VCC = 1.65 V to 5.5 V LOW-level output voltage VOL Unit VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 1 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - - 500 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10. Symbol Parameter tpd tsu 40 C to +85 C Conditions Min Max Min Max VCC = 1.65 V to 1.95 V 1.0 3.4 9.9 1.0 13.0 ns VCC = 2.3 V to 2.7 V 0.5 2.3 7.0 0.5 9.0 ns VCC = 2.7 V 0.5 2.5 6.0 0.5 8.0 ns VCC = 3.0 V to 3.6 V 0.9 2.4 5.0 0.9 6.5 ns VCC = 4.5 V to 5.5 V 0.5 1.8 4.5 0.5 6.0 ns propagation delay CP to Q; see Figure 8 set-up time 74LVC1G80 Product data sheet 40 C to +125 C Unit Typ[1] HIGH or LOW; D to CP; see Figure 9 [2] [3] VCC = 1.65 V to 1.95 V 2.3 0.8 - 2.3 - ns VCC = 2.3 V to 2.7 V 1.5 0.6 - 1.5 - ns VCC = 2.7 V 1.5 0.5 - 1.5 - ns VCC = 3.0 V to 3.6 V 1.3 0.4 - 1.3 - ns VCC = 4.5 V to 5.5 V 1.1 0.5 - 1.1 - ns All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 7 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10. Symbol Parameter th hold time pulse width tW 40 C to +85 C Conditions Min Max Min Max VCC = 1.65 V to 1.95 V 0 0.6 - 0 - ns VCC = 2.3 V to 2.7 V 0 0.4 - 0 - ns VCC = 2.7 V +0.5 0.2 - 0.5 - ns VCC = 3.0 V to 3.6 V 0.9 0.2 - 0.9 - ns VCC = 4.5 V to 5.5 V +0.5 0.1 - 0.5 - ns 3.0 1.1 - 3.0 - ns D to CP; see Figure 9 CP HIGH or LOW; see Figure 9 VCC = 1.65 V to 1.95 V maximum frequency fmax power dissipation capacitance CPD 40 C to +125 C Unit Typ[1] VCC = 2.3 V to 2.7 V 2.5 0.7 - 2.5 - ns VCC = 2.7 V 2.5 0.6 - 2.5 - ns VCC = 3.0 V to 3.6 V 2.5 0.6 - 2.5 - ns VCC = 4.5 V to 5.5 V 2.0 0.5 - 2.0 - ns VCC = 1.65 V to 1.95 V 160 300 - 160 - MHz VCC = 2.3 V to 2.7 V 160 350 - 160 - MHz VCC = 2.7 V 160 350 - 160 - MHz VCC = 3.0 V to 3.6 V 160 350 - 160 - MHz VCC = 4.5 V to 5.5 V 200 400 - 200 - MHz - 17 - - - pF CP; see Figure 9 [4] VI = GND to VCC; VCC = 3.3 V [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] tsu is the same as tsu(H) and tsu(L). [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 8 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 12. Waveforms 9, 'LQSXW *1' 9, &3LQSXW  90 90 *1' W 3/+ W 3+/ 92+ 90 4RXWSXW 90 92/ PQD Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output. Fig 8. Clock (CP) to output (Q) propagation delay times 9, 90 'LQSXW *1' WK WK W VX / W VX + IPD[ 9, &3LQSXW 90 *1' W: W 3/+ W 3+/ 92+ 90 4RXWSXW 92/ PQD Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 9. Clock (CP) to output (Q) propagation delay times, clock pulse width, D to set-up times, the CP to D hold times and maximum clock pulse frequency 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 9 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger Table 9. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5  VCC 0.5  VCC 2.3 V to 2.7 V 0.5  VCC 0.5  VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5  VCC 0.5  VCC 9(;7 9&& * 9, 5/ 92 '87 57 &/ 5/ PQD Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 10. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC  2.0 ns 30 pF 1 k open 2.3 V to 2.7 V VCC  2.0 ns 30 pF 500  open 2.7 V 2.7 V  2.5 ns 50 pF 500  open 3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  open 4.5 V to 5.5 V VCC  2.5 ns 50 pF 500  open 74LVC1G80 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 VEXT © Nexperia B.V. 2017. All rights reserved 10 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 13. Package outline 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ( ' 627 $ ; F \ +( Y 0 $ =   $ $ $  $ ș  /S  H / Z 0 ES GHWDLO; H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H H +( PP                      / /S Y Z \ =   ș      ƒ ƒ 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ 02  6&$ (8523($1 352-(&7,21 ,668('$7(   Fig 11. Package outline SOT353-1 (TSSOP5) 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 11 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV 627 ' % $ ( \ ; +(  Y 0 $  4 $ $ F    /S GHWDLO; ES H Z 0 %   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV 81,7 $ $ ES F ' ( H +( /S 4 Y Z \ PP                       287/,1( 9(56,21 5()(5(1&(6 ,(& -('(& -(,7$  6&$ 627 (8523($1 352-(&7,21 ,668('$7(   Fig 12. Package outline SOT753 (SC-74A) 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 12 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 627 ;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP E    [  / / H   H  H [ $  $ ' ( WHUPLQDO LQGH[DUHD   PP VFDOH 'LPHQVLRQV PPDUHWKHRULJLQDOGLPHQVLRQV 8QLW PP PD[ QRP PLQ $   $ E ' (           H H   / /       1RWHV ,QFOXGLQJSODWLQJWKLFNQHVV &DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV 2XWOLQH YHUVLRQ 627 VRWBSR 5HIHUHQFHV ,(& -('(& -(,7$ (XURSHDQ SURMHFWLRQ ,VVXHGDWH   02 Fig 13. Package outline SOT886 (XSON6) 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 13 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger ;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP  627 E   î  / / H   H  H î $  $ ' ( WHUPLQDO LQGH[DUHD   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV 81,7 $ PD[ $ PD[ E ' ( H H / / PP               1RWH &DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV 5()(5(1&(6 287/,1( 9(56,21 ,(& 627  -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(    Fig 14. Package outline SOT891 (XSON6) 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 14 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger ;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP  627 E   î  / / H    H H î  $ $ ' ( WHUPLQDO LQGH[DUHD   VFDOH 'LPHQVLRQV 8QLW PP PP $  $ E ' ( H / H PD[      QRP     PLQ    /        1RWH ,QFOXGLQJSODWLQJWKLFNQHVV 9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\ VRWBSR 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627    (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 15. Package outline SOT1115 (XSON6) 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 15 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger ;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP  627 E   î  / / H    H H î  $ $ ' ( WHUPLQDO LQGH[DUHD   VFDOH 'LPHQVLRQV 8QLW PP PP $  $ E ' ( H / H / PD[        QRP        PLQ      1RWH ,QFOXGLQJSODWLQJWKLFNQHVV 9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\ VRWBSR 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627    (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 16. Package outline SOT1202 (XSON6) 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 16 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger ;621SODVWLFWKHUPDOHQKDQFHGH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP ' $ % 627 ; $ ( $ $ GHWDLO; WHUPLQDO LQGH[DUHD H & Y Z E   WHUPLQDO LQGH[DUHD & $ % & \ & \ N ' K  /    PP VFDOH 'LPHQVLRQV 8QLW PP $  $ $ ' 'K ( E H N /  PD[              QRP PLQ        Y  Z \ \    1RWH 'LPHQVLRQ$LVLQFOXGLQJSODWLQJWKLFNQHVV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 2XWOLQH YHUVLRQ 5HIHUHQFHV ,(& -('(& (,$- VRWBSR (XURSHDQ SURMHFWLRQ ,VVXHGDWH   627 Fig 17. Package outline SOT1226 (X2SON5) 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 17 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 14. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G80 v.13 20161205 Product data sheet - 74LVC1G80 v.12 Modifications: 74LVC1G80 v.12 Modifications: 74LVC1G80 v.11 Modifications: 74LVC1G80 v.10 Modifications: 74LVC1G80 v.9 Modifications: • Table 7: The maximum limits for leakage current and supply current have changed. 20120702 • Product data sheet - 74LVC1G80 v.10 Product data sheet - 74LVC1G80 v.9 - 74LVC1G80 v.8 Legal pages updated. 20100928 • • 74LVC1G80 v.11 Errata in table 3 corrected (description CP input). 20111202 • - Added type number 74LVC1G80GX (SOT1226) 20120402 • Product data sheet Product data sheet Added type number 74LVC1G80GN (SOT1115/XSON6 package). Added type number 74LVC1G80GS (SOT1202/XSON6 package). 74LVC1G80 v.8 20070829 Product data sheet - 74LVC1G80 v.7 74LVC1G80 v.7 20061012 Product data sheet - 74LVC1G80 v.6 74LVC1G80 v.6 20040910 Product specification 74LVC1G80 v.5 20040629 Product specification - 74LVC1G80 v.4 74LVC1G80 v.4 20040429 Product specification - 74LVC1G80 v.3 74LVC1G80 v.3 20030526 Product specification - 74LVC1G80 v.2 74LVC1G80 v.2 20030130 Product specification - 74LVC1G80 v.1 74LVC1G80 v.1 20010404 Product specification - - 74LVC1G80 Product data sheet 74LVC1G80 v.5 All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 18 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVC1G80 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 19 of 21 74LVC1G80 Nexperia Single D-type flip-flop; positive-edge trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVC1G80 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 5 December 2016 © Nexperia B.V. 2017. All rights reserved 20 of 21 Nexperia 74LVC1G80 Single D-type flip-flop; positive-edge trigger 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 18 Legal information. . . . . . . . . . . . . . . . . . . . . . . 19 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 19 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Contact information. . . . . . . . . . . . . . . . . . . . . 20 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 05 December 2016
74LVC1G80GF,132 价格&库存
很抱歉,暂时无法提供与“74LVC1G80GF,132”相匹配的价格&库存,您可以联系我们找货
