74HCT574PW-Q100,11
74HCT574PW-Q100,11
    NEXPERIA(安世)
    TSSOP-20
    八进制D型触发器;正边缘触发;三态
74HCT574PW-Q100,11 数据手册
74HC574-Q100; 74HCT574-Q100 Octal D-type flip-flop; positive edge-trigger; 3-state Rev. 2 — 26 January 2015 Product data sheet 1. General description The 74HC574-Q100; 74HCT574-Q100 is a high-speed Si-gate CMOS device and is pin compatible with Low-power Schottky TTL. It is specified in compliance with JEDEC standard no. 7A. The 74HC574-Q100; 74HCT574-Q100 are octal D-type flip-flops featuring separate D-type inputs for each flip-flop and 3-state outputs for bus-oriented applications. A clock (CP) and an output enable (OE) input are common to all flip-flops. The 8 flip-flops store the state of their individual D-inputs that meet the set-up and hold times requirements on the LOW-to-HIGH CP transition. When OE is LOW the contents of the 8 flip-flops are available at the outputs. When OE is HIGH, the outputs go to the high-impedance OFF-state. Operation of the OE input does not affect the state of the flip-flops. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  3-state non-inverting outputs for bus-oriented applications  8-bit positive, edge-triggered register  Common 3-state output enable input  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74HC574D-Q100 Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74HCT574D-Q100 74HC574PW-Q100 74HCT574PW-Q100 4. Functional diagram  ' 4   ' 4   '  '  '  ' 4   ' 4   ' 4  4  )) WR )) 4  67$7( 2873876 4   &3  2( PQD Fig 1. Functional diagram ' ' ' 4 ' ' &3 4 ' &3 )) ' 4 ' &3 )) ' 4 ' &3 )) ' 4 ' ' &3 )) 4 ' &3 )) ' 4 ' &3 )) 4 &3 )) )) &3 2( 4 4 4 4 4 4 4 4 DDK Fig 2. Logic diagram 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 2 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state   & (1   &3      ' 4 ' 4 ' 4 ' 4 '    4 ' 4 ' 4 ' 4 2(  Fig 3.   '                      PQD PQD Logic symbol Fig 4. IEC logic symbol 5. Pinning information 5.1 Pinning +&4 +&74 2(   9&& '   4 '   4 '   4 '   4 '   4 +&4 +&74 2(   9&& '   4 '   4 '   4 '   4 '   4 '   4 '   4 '   4  4 '   4 '   4 *1'   &3 '  *1'   &3 DDD DDD Fig 5. Pin configuration SO20 74HC_HCT574_Q100 Product data sheet Fig 6. Pin configuration TSSOP20 All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 3 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description OE 1 3-state output enable input (active LOW) D[0:7] 2, 3, 4, 5, 6, 7, 8, 9 data input GND 10 ground (0 V) CP 11 clock input (LOW-to-HIGH, edge triggered) Q[0:7] 19, 18, 17, 16, 15, 14, 13, 12 3-state flip-flop output VCC 20 supply voltage 6. Functional description Table 3. Function table[1] Operating mode Input OE CP Load and read register L  L Load register and disable output [1] Output Dn Internal flip-flop l L L  h H H H  l L Z H  h H Z Qn H = HIGH voltage level; h = HIGH voltage level one setup time prior to the HIGH-to-LOW CP transition; L = LOW voltage level; l = LOW voltage level one setup time prior to the HIGH-to-LOW CP transition; Z = high-impedance OFF-state;  = LOW-to-HIGH clock transition. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current VO = 0.5 V to (VCC + 0.5 V) - 35 mA ICC supply current - +70 mA IGND ground current - 70 mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW [1] Conditions VI < 0.5 V or VI > VCC + 0.5 V [1] Min Max Unit 0.5 +7 V - 20 mA For SO20 packages: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP20 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 4 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC574-Q100 Min Typ 74HCT574-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC574-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 0.5 - 5.0 - 10.0 A 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 5 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter ICC supply current CI input capacitance 25 C Conditions VI = VCC or GND; IO = 0 A; VCC = 6.0 V 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - - 8.0 - 80 - 160 - 3.5 - A pF 74HCT574-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 6 mA 3.98 4.32 - 3.84 - 3.7 - V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND per input pin; other inputs at VCC or GND; IO = 0 A - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; Dn inputs - 50 180 - 225 - 245 A per input pin; OE input - 125 450 - 563 - 613 A per input pin; CP input - 150 540 - 675 - 735 A - 3.5 - - - - - pF CI input capacitance 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 6 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 10. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 47 150 - 190 - 225 ns VCC = 4.5 V - 17 30 - 35 - 45 ns VCC = 5 V; CL = 15 pF - 14 - - - - - ns VCC = 6.0 V - 14 26 - 33 - 38 ns VCC = 2.0 V - 44 140 - 175 - 210 ns VCC = 4.5 V - 16 28 - 35 - 42 ns VCC = 6.0 V - 13 24 - 30 - 36 ns VCC = 2.0 V - 39 125 - 155 - 190 ns VCC = 4.5 V - 14 25 - 31 - 38 ns VCC = 6.0 V - 11 21 - 26 - 32 ns VCC = 2.0 V - 14 60 - 75 - 90 ns VCC = 4.5 V - 5 12 - 15 - 18 ns VCC = 6.0 V - 4 10 - 13 - 15 ns 74HC574-Q100 tpd ten tdis tt tW tsu th fmax propagation delay enable time CP to Qn; see Figure 7 OE to Qn; see Figure 9 disable time OE to Qn; see Figure 9 transition time pulse width set-up time hold time maximum frequency Qn; see Figure 7 [3] CP HIGH or LOW; see Figure 8 VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns Dn to CP; see Figure 8 VCC = 2.0 V 60 6 - 75 - 90 - ns VCC = 4.5 V 12 2 - 15 - 18 - ns VCC = 6.0 V 10 2 - 13 - 15 - ns Dn to CP; see Figure 8 VCC = 2.0 V 5 0 - 5 - 5 - ns VCC = 4.5 V 5 0 - 5 - 5 - ns VCC = 6.0 V 5 0 - 5 - 5 - ns CP; see Figure 7 VCC = 2.0 V 6.0 37 - 4.8 - 4.0 - MHz VCC = 4.5 V 30 112 - 24 - 20 - MHz - 123 - - - - - MHz 35 133 - 28 - 24 - MHz VCC = 6.0 V Product data sheet [2] [4] VCC = 5 V; CL = 15 pF 74HC_HCT574_Q100 [1] All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 7 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 10. Symbol Parameter CPD power dissipation capacitance 25 C Conditions CL = 50 pF; f = 1 MHz; VI = GND to VCC [5] CP to Qn; see Figure 7 [1] 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 22 - - - - - pF 74HCT574-Q100 tpd ten propagation delay enable time VCC = 4.5 V - 18 33 - 41 - 50 ns VCC = 5 V; CL = 15 pF - 15 - - - - - ns - 19 33 - 41 - 50 ns - 16 28 - 35 - 42 ns - 5 12 - 15 - 18 ns 16 7 - 20 - 24 - ns 12 3 - 15 - 18 - ns 5 1 - 5 - 5 - ns 30 69 - 24 - 20 - MHz - 76 - - - - - MHz - 25 - - - - - pF [2] OE to Qn; see Figure 9 VCC = 4.5 V tdis [3] disable time OE to Qn; see Figure 9 VCC = 4.5 V tt tW [4] transition time Qn; see Figure 7 pulse width CP HIGH or LOW; see Figure 8 VCC = 4.5 V VCC = 4.5 V tsu set-up time Dn to CP; see Figure 8 th hold time Dn to CP; see Figure 8 VCC = 4.5 V VCC = 4.5 V fmax maximum frequency CP; see Figure 7 VCC = 4.5 V VCC = 5 V; CL = 15 pF CPD [1] power dissipation capacitance [5] CL = 50 pF; f = 1 MHz; VI = GND to VCC  1.5 V tpd is the same as tPLH and tPHL. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPLZ and tPHZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 8 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 11. Waveforms IPD[ 9, &3LQSXW 90 *1' W: W3+/ 92+ W3/+  90 4QRXWSXW  92/ W7+/ W7/+ DDQ Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Propagation delay input (CP) to output (Qn), output transition time, clock input (CP) pulse width and the maximum frequency (CP) 9, 90 &3LQSXW *1' W VX W VX WK WK 9, 90 'QLQSXW *1' 92+ 90 4QRXWSXW 92/ PQD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. The data input (D) to clock input (CP) set-up times and clock input (CP) to data input (D) hold times 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 9 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 9, 2(LQSXW 90 *1' W3/= W3=/ 9&& 4QRXWSXW /2:WR2)) 2))WR/2: 92/ 90 9; W3+= 92+ W3=+ 9< 4QRXWSXW +,*+WR2)) 2))WR+,*+ *1' 90 RXWSXWV HQDEOHG RXWSXWV GLVDEOHG RXWSXWV HQDEOHG DDK Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 9. Table 8. Enable and disable times Measurement points Type Input Output VM VM VX VY 74HC574-Q100 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT574-Q100 1.3 V 1.3 V 0.1VCC 0.9VCC 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 10 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 10. Test circuit for measuring switching times Table 9. Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC574-Q100 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT574-Q100 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT574_Q100 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 11 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' $ ( ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   H ES GHWDLO; Z 0   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ PP                                           LQFKHV         =       ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 11. Package outline SOT163-1 (SO20) 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 12 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F +( \ Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 12. Package outline SOT360-1 (TSSOP20) 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 13 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic MIL Military 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT574_Q100 v.2 20150126 Product data sheet - 74HC_HCT574_Q100 v.1 Modifications: 74HC_HCT574_Q100 v.1 74HC_HCT574_Q100 Product data sheet • Table 7: Power dissipation capacitance condition for 74HCT574-Q100 is corrected. 20120802 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 - © Nexperia B.V. 2017. All rights reserved 14 of 17 74HC574-Q100; 74HCT574-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT574_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 15 of 17 Nexperia 74HC574-Q100; 74HCT574-Q100 Octal D-type flip-flop; positive edge-trigger; 3-state No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT574_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 16 of 17 Nexperia 74HC574-Q100; 74HCT574-Q100 Octal D-type flip-flop; positive edge-trigger; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 January 2015
74HCT574PW-Q100,11 价格&库存
很抱歉,暂时无法提供与“74HCT574PW-Q100,11”相匹配的价格&库存,您可以联系我们找货
