74LVCH16374ADGG,11
74LVCH16374ADGG,11
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    16位边缘触发D型触发器;5 V耐受电压;三态
74LVCH16374ADGG,11 数据手册
74LVC16374A; 74LVCH16374A 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state Rev. 12 — 20 November 2018 Product data sheet 1. General description The 74LVC16374A and 74LVCH16374A are 16-bit edge-triggered flip-flops featuring separate D-type inputs with bus hold (74LVCH16374A only) for each flip-flop and 3-state outputs for busoriented applications. It consists of two sections of eight positive edge-triggered flip-flops. A clock input (nCP) and an output enable (nOE) are provided for each octal. The flip-flops store the state of their individual D-inputs that meet the set-up and hold time requirements on the LOW-to-HIGH clock (CP) transition. When pin nOE is LOW, the contents of the flip-flops are available at the outputs. When pin nOE is HIGH, the outputs go to the high-impedance OFF-state. Operation of input nOE does not affect the state of the flip-flops. Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs. These features allow the use of these devices in mixed 3.3 V and 5 V applications. Bus hold on data inputs eliminates the need for external pull-up resistors to hold unused inputs. 2. Features and benefits • • • • • • • • • • • 5 V tolerant inputs/outputs for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption Multibyte flow-through standard pinout architecture Low inductance multiple supply pins for minimum noise and ground bounce Direct interface with TTL levels All data inputs have bus hold (74LVCH16374A only) High-impedance outputs when VCC = 0 V Complies with JEDEC standard: • JESD8-7A (1.65 V to 1.95 V) • JESD8-5A (2.3 V to 2.7 V) • JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-B exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC16374ADL -40 °C to +125 °C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 74LVC16374ADGG -40 °C to +125 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74LVCH16374ADGG 4. Functional diagram Fig. 1. 1 24 1OE 2OE 1 1OE 48 1CP 24 2OE 25 2CP 47 1D0 1Q0 2 46 1D1 1Q1 3 1D0 44 1D2 1Q2 5 1D1 43 1D3 1Q3 6 1D2 41 1D4 1Q4 8 1D3 40 1D5 1Q5 9 1D4 38 1D6 1Q6 11 1D5 37 1D7 1Q7 12 36 2D0 2Q0 13 1D6 35 2D1 2Q1 14 33 2D2 2Q2 16 32 2D3 2Q3 17 30 2D4 2Q4 19 29 2D5 2Q5 20 27 2D6 2Q6 22 26 2D7 2Q7 23 1CP 2CP 48 25 1D7 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 C3 EN2 C4 47 3D 46 3 44 5 43 6 41 8 40 9 38 11 37 12 36 13 4D 35 2 14 33 16 32 17 30 19 29 20 27 22 26 23 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 001aaa254 Fig. 2. D 2 1 001aaa253 Logic symbol 1D0 EN1 Q 1Q0 IEC logic symbol 2D0 CP D Q 2Q0 CP FF1 FF2 1CP 2CP 1OE 2OE to 7 other channels to 7 other channels 001aaa255 Fig. 3. Logic diagram 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 2 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state VCC data input to internal circuit mna705 Fig. 4. Bus hold circuit 5. Pinning information 5.1. Pinning 74LVC16374A 74LVCH16374A 1OE 1 48 1CP 1Q0 2 47 1D0 1Q1 3 46 1D1 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 42 VCC 1Q4 8 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 VCC 18 31 VCC 2Q4 19 30 2D4 2Q5 20 29 2D5 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2CP 001aaa231 Fig. 5. Pin configuration SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 3 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 24 output enable input (active LOW) GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 1Q0 to 1Q7 2, 3, 5, 6, 8, 9, 11, 12 data output 2Q0 to 2Q7 13, 14, 16, 17, 19, 20, 22, 23 data output 1D0 to 1D7 47, 46, 44, 43, 41, 40, 38, 37 data input 2D0 to 2D7 36, 35, 33, 32, 30, 29, 27, 26 data input 1CP, 2CP 48, 25 clock input 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state; ↑ = LOW-to-HIGH transition; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW CP transition; l = LOW voltage level one set-up time prior to the HIGH-to-LOW CP transition. Operating mode Load and read register Load register and disable outputs Input Internal flip-flop Output nQ0 to nQ7 l L L ↑ h H H H ↑ l L Z H ↑ h H Z nOE nCP nDn L ↑ L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage output HIGH-or LOW-state [2] -0.5 output 3-state [2] -0.5 +6.5 V IO output current - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] Conditions VI < 0 V [1] VO = 0 V to VCC Tamb = -40 °C to +125 °C [3] Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA mA VCC + 0.5 V The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. For (T)SSOP48 packages: above 60 °C, the value of Ptot derates linearly with 5.5 mW/K. 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 4 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC 1.65 - 3.6 V 1.2 - - V 0 - 5.5 V active mode 0 - VCC V power-down mode; VCC = 0 V 0 - 5.5 V -40 - +125 °C VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V supply voltage functional VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage Conditions -40 °C to +85 °C VCC = 1.2 V LOW-level output voltage Min Typ[1] Max Min Max Unit 1.08 - - 1.08 - V 0.65xVCC - - 0.65xVCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V LOW-level input VCC = 1.2 V voltage VCC = 1.65 V to 1.95 V HIGH-level output voltage -40 °C to +125 °C - - 0.35xVCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.35xVCC V 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC - 0.2 VCC - VCC - 0.3 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = -8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = -18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = -24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 μA; VCC = 1.65 V to 3.6 V - 0 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 3.6 V VI = VIH or VIL II input leakage current VCC = 3.6 V; VI = 5.5 V or GND[2] - ±0.1 ±5 - ±20 μA IOZ OFF-state output current VI = VIH or VIL; VCC = 3.6 V; VO = 5.5 V or GND[2] - ±0.1 ±5 - ±20 μA 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 5 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Min Typ[1] Max Min Max Unit IOFF power-off VCC = 0 V; VI or VO = 5.5 V leakage current - ±0.1 ±10 - ±20 μA ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 20 - 80 μA ΔICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 - 5000 μA CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 5.0 - - - pF IBHL bus hold LOW current VCC = 1.65; VI = 0.58 V[3][4] 10 - - 10 - μA VCC = 2.3; VI = 0.7 V 30 - - 25 - μA VCC = 3.0; VI = 0.8 V 75 - - 60 - μA VCC = 1.65; VI = 1.07 V[3][4] -10 - - -10 - μA VCC = 2.3; VI = 1.7 V -30 - - -25 - μA IBHH IBHLO IBHHO [1] [2] [3] [4] [5] bus hold HIGH current VCC = 3.0; VI = 2.0 V -75 - - -60 - μA bus hold LOW overdrive current VCC = 1.95 V[3][5] 200 - - 200 - μA VCC = 2.7 V 300 - - 300 - μA VCC = 3.6 V 500 - - 500 - μA bus hold HIGH overdrive current VCC = 1.95 V[3][5] -200 - - -200 - μA VCC = 2.7 V -300 - - -300 - μA VCC = 3.6 V -500 - - -500 - μA All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. The bus hold circuit is switched off when VI > VCC allowing 5.5 V on the input pin. Valid for data inputs (74LVCH16374A) only; control inputs do not have a bus hold circuit. The specified sustaining current at the data inputs holds the input below the specified VI level. The specified overdrive current at the data input forces the data input to the opposite logic input state. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 9. Symbol Parameter tpd propagation delay Conditions -40 °C to +85 °C Min Typ[1] Max Min Max - 14 - - - ns VCC = 1.65 V to 1.95 V 2.1 6.9 13.5 2.1 15.6 ns VCC = 2.3 V to 2.7 V 1.5 3.7 6.7 1.5 7.7 ns VCC = 2.7 V 1.5 3.4 6.0 1.5 7.5 ns 1.5 3.1 5.4 1.5 7.0 ns - 20 - - - ns VCC = 1.65 V to 1.95 V 1.5 5.9 13.1 1.5 15.1 ns VCC = 2.3 V to 2.7 V 1.5 3.4 6.9 1.5 8.0 ns VCC = 2.7 V 1.5 3.6 6.0 1.5 7.5 ns VCC = 3.0 V to 3.6 V 1.0 2.7 5.2 1.0 6.5 ns nCP to nQn; see Fig. 6 [2] VCC = 1.2 V VCC = 3.0 V to 3.6 V ten enable time nOE to nQn; see Fig. 7 VCC = 1.2 V 74LVC_LVCH16374A Product data sheet -40 °C to +125 °C Unit [2] All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 6 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state Symbol Parameter Conditions -40 °C to +85 °C Min tdis disable time nOE to nQn; see Fig. 7 pulse width tsu set-up time th hold time fmax maximum frequency Min Max - 12 - - - ns VCC = 1.65 V to 1.95 V 2.8 4.6 9.1 2.8 10.5 ns VCC = 2.3 V to 2.7 V 1.0 2.5 4.9 1.0 5.7 ns VCC = 2.7 V 1.5 3.4 5.1 1.5 6.5 ns VCC = 3.0 V to 3.6 V 1.5 3.1 4.9 1.5 6.5 ns VCC = 1.65 V to 1.95 V 5.0 - - 5.0 - ns VCC = 2.3 V to 2.7 V 4.0 - - 4.0 - ns VCC = 2.7 V 3.0 - - 3.0 - ns VCC = 3.0 V to 3.6 V 3.0 1.5 - 3.0 - ns VCC = 1.65 V to 1.95 V 4.0 - - 4.0 - ns VCC = 2.3 V to 2.7 V 3.0 - - 3.0 - ns VCC = 2.7 V 1.9 - - 1.9 - ns VCC = 3.0 V to 3.6 V 1.9 0.3 - 1.9 - ns VCC = 1.65 V to 1.95 V 3.0 - - 3.0 - ns VCC = 2.3 V to 2.7 V 2.5 - - 2.5 - ns VCC = 2.7 V 1.1 - - 1.1 - ns VCC = 3.0 V to 3.6 V +1.5 -0.3 - 1.5 - ns VCC = 1.65 V to 1.95 V 100 - - 80 - ns VCC = 2.3 V to 2.7 V 125 - - 100 - ns VCC = 2.7 V 150 - - 120 - MHz VCC = 3.0 V to 3.6 V 150 300 - 120 - MHz - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 14.1 - - - pF VCC = 2.3 V to 2.7 V - 16.4 - - - pF VCC = 3.0 V to 3.6 V - 18.5 - - - pF nCP HIGH; see Fig. 6 nDn to nCP; see Fig. 8 nDn to nCP; see Fig. 8 see Fig. 6 tsk(o) output skew time VCC = 3.0 V to 3.6 V [3] CPD power dissipation capacitance per input; VI = GND to VCC [4] [1] [2] [3] [4] Max [2] VCC = 1.2 V tW Typ[1] -40 °C to +125 °C Unit Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively. tpd is the same as tPLH and tPHL; ten is the same as tPZL and tPZH; tdis is the same as tPLZ and tPHZ. Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL x VCC x fo) = sum of the outputs 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 7 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state 10.1. Waveforms and test circuit 1/fmax VI nCP input VM VM GND tW t PHL t PLH VOH VM nQn output VOL 001aaa256 Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig. 6. Clock (nCP) to output (nQn) propagation delays, clock pulse width, and the maximum frequency VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs disabled outputs enabled mna362 Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig. 7. 3-state enable and disable times 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 8 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state VI VM nCP input GND t su t su th th VI VM nDn input GND VOH VM nQn output VOL 001aaa257 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable performance. VOL and VOH are the typical output voltage levels that occur with the output load. Fig. 8. Data set-up and hold times for the nDn input to the nCP input Table 8. Measurement points Supply voltage Input Output VCC VI VM VM VX VY 1.2 V VCC 0.5xVCC 0.5xVCC VOL + 0.15 V VOH - 0.15 V 1.65 V to 1.95 V VCC 0.5xVCC 0.5xVCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V VCC 0.5xVCC 0.5xVCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 9 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC VI G RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 9. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ open 2xVCC GND 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ open 2xVCC GND 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω open 2xVCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2xVCC GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2xVCC GND 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 10 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state 11. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3 ) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Fig. 10. Package outline SOT370-1 (SSOP48) 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 11 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Fig. 11. Package outline SOT362-1 (TSSOP48) 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 12 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC_LVCH16374A v.12 20181120 Product data sheet - 74LVC_LVCH16374A v.11 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVCH16374ADL (SOT370-1/SSOP48), 74LVC16374ABX and 74LVCH16374ABX (SOT1134-1/HXQFN60U) removed. 74LVC_LVCH16374A v.11 20130116 Modifications: • • 74LVC_LVCH16374A v.10 20120301 Product data sheet - 74LVC_LVCH16374A v.9 74LVC_LVCH16374A v.9 20111219 Product data sheet - 74LVC_LVCH16374A v.8 74LVC_LVCH16374A v.8 20110621 Product data sheet - 74LVC_LVCH16374A v.7 74LVC_LVCH16374A v.7 20100323 Product data sheet - 74LVC_LVCH16374A v.6 74LVC_LVCH16374A v.6 20090212 Product data sheet - 74LVC_LVCH16374A v.5 74LVC_LVCH16374A v.5 20031212 Product specification - 74LVC_H16374A v.4 74LVC_H16374A v.4 19980317 Product specification - 74LVC16374A_ 74LVCH16374A v.3 74LVC16374A_ 74LVCH16374A v.3 19980317 Product specification - 74LVC16374A v.2 74LVC16374A v.2 19970822 Product specification - 74LVC16374A v.1 74LVC16374A v.1 - - - - 74LVC_LVCH16374A Product data sheet Product data sheet - 74LVC_LVCH16374A v.10 Minor non-technical text changes and corrections Document revision history correction All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 13 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC_LVCH16374A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 14 / 15 74LVC16374A; 74LVCH16374A Nexperia 16-bit edge-triggered D-type flip-flop; 5 V tolerant; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 4 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................5 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 8 11. Package outline........................................................ 11 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 November 2018 74LVC_LVCH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 20 November 2018 © Nexperia B.V. 2018. All rights reserved 15 / 15
74LVCH16374ADGG,11 价格&库存
很抱歉,暂时无法提供与“74LVCH16374ADGG,11”相匹配的价格&库存,您可以联系我们找货
