74AVC16374DGG-Q10J
74AVC16374DGG-Q10J
    NEXPERIA(安世)
    TSSOP-48
    16位边缘触发D型触发器;3.6 V耐受电压;三态
74AVC16374DGG-Q10J 数据手册
74AVC16374-Q100 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state Rev. 2 — 16 March 2015 Product data sheet 1. General description The 74AVC16374-Q100 is a 16-bit edge triggered flip-flop featuring separate D-type inputs for each flip-flop and 3-state outputs for bus-oriented applications. The 74AVC16374-Q100 consist of 2 sections of 8 edge-triggered flip-flops. A clock input (CP) and an output enable (OE) are provided per 8-bit section. The 74AVC16374-Q100 is designed to have an extremely fast propagation delay and a minimum amount of power consumption. To ensure the high-impedance output state during power-up or power-down, nOE should be tied to VCC through a pull-up resistor (Live Insertion). A Dynamic Controlled Output (DCO) circuitry is implemented to support termination line drive during transient (see Figure 5 and Figure 6). This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 3)  Specified from 40 C to +85 C  Wide supply voltage range from 1.2 V to 3.6 V  Complies with JEDEC standards:  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-1A (2.7 V to 3.6 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 1000 V  HBM JESD22-A114F exceeds 1000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  CMOS low power consumption  Input/output tolerant up to 3.6 V  Dynamic Controlled Output (DCO) circuit dynamically changes output impedance, resulting in noise reduction without speed degradation  Low inductance multiple VCC and GND pins to minimize noise and ground bounce  Supports Live Insertion 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74AVC16374DGG-Q100 Temperature range Name Description Version 40 C to +85 C plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 TSSOP48 4. Functional diagram 2( &3 2( &3 ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' '      (1 (1 '                '                 IEC logic symbol 74AVC16374_Q100 Product data sheet 2( 2( ' 4   ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4  4  ' 4   ' 4   ' 4  4 4 4 &3 &3   4 PQD Fig 1.   &    & Fig 2. PQD Logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 2 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state ' ' 4 4 &3 )) &3 2( WRRWKHUFKDQQHOV ' ' 4 4 &3 &3 )) 2( WRRWKHUFKDQQHOV Fig 3. PQD Logic diagram 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 3 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 5. Pinning information 5.1 Pinning $9&4 2(   &3 4   ' 4   ' *1'   *1' 4   ' 4   ' 9&&   9&& 4   ' 4   ' *1'   *1' 4   ' 4   ' 4   ' 4   ' *1'   *1' 4   ' 4   ' 9&&   9&& 4   ' 4   ' *1'   *1' 4   ' 4   ' 2(   &3 DDD Fig 4. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE 1 output enable input (active LOW) 1Q0 to 1Q7 2, 3, 5, 6, 8, 9, 11, 12 3-state flip-flop outputs GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 2Q0 to 2Q7 13, 14, 16, 17, 19, 20, 22, 23 3-state flip-flop outputs 2OE 24 output enable input (active LOW) 2CP 25 clock input 2D0 to 2D7 36, 35, 33, 32, 30, 29, 27, 26 data input/output 1D0 to 1D7 47, 46, 44, 43, 41, 40, 38, 37 data input/output 1CP 48 clock input 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 4 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 6. Functional description Table 3. Function table[1] Operating modes Inputs Internal flip-flops Outputs nOE nCp nDn Load and read register L  I L  h H H Load register and disable outputs H  I L Z H  h H Z [1] nQn L L H = HIGH voltage level h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition L = LOW voltage level l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition Z = high-impedance OFF-state  = LOW-to-HIGH CP transition 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO Conditions VI < 0 V [1] Min Max Unit 0.5 +4.6 V - 50 mA 0.5 +4.6 V mA 50 - output HIGH or LOW [1] 0.5 VCC + 0.5 V output 3-state [1] 0.5 +4.6 V - 50 mA VO < 0 V IO output current ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot VO = 0 V to VCC Tamb = 40 C to +85 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 60 C, the value of Ptot derates linearly with 5.5 mW/K. 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 5 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions Min Typ Max Unit according to JEDEC Low Voltage Standards 1.4 - 1.6 V 1.65 - 1.95 V 2.3 - 2.7 V 3.0 - 3.6 V 1.2 - 3.6 V 0 - 3.6 V for low-voltage applications VI input voltage VO output voltage output HIGH or LOW 0 - VCC V output 3-state 0 - 3.6 V Tamb ambient temperature in free air 40 - +85 C t/V input transition rise and fall rate VCC = 1.4 V to 1.6 V 0 - 40 ns/V VCC = 1.65 V to 2.3 V 0 - 30 ns/V VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max VCC = 1.2 V VCC - - V VCC = 1.4 V to 1.6 V 0.65  VCC 0.9 - V VCC = 1.65 V to 1.95 V 0.65  VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 3.0 V to 3.6 V 2.0 1.5 - V VCC = 1.2 V - - GND V VCC = 1.4 V to 1.6 V - 0.9 0.35  VCC V VCC = 1.65 V to 1.95 V - 0.9 0.35  VCC V VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 3.0 V to 3.6 V - 1.5 0.8 V Unit Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74AVC16374_Q100 Product data sheet VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 3.6 V VCC  0.20 VCC - V IO = 3 mA; VCC = 1.4 V VCC  0.35 VCC  0.23 - V IO = 4 mA; VCC = 1.65 V VCC  0.45 VCC  0.25 - V IO = 8 mA; VCC = 2.3 V VCC  0.55 VCC  0.38 - V IO = 12 mA; VCC = 3.0 V VCC  0.70 VCC  0.48 - V All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 6 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Min Typ[1] Max Unit IO = 100 A; VCC = 1.65 V to 3.6 V - GND 0.20 V IO = 3 mA; VCC = 1.4 V - 0.10 0.35 V IO = 4 mA; VCC = 1.65 V - 0.10 0.45 V IO = 8 mA; VCC = 2.3 V - 0.26 0.55 V IO = 12 mA; VCC = 3.0 V - 0.36 0.70 V Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage II input leakage current per pin; VI = VCC or GND; VCC = 1.4 V to 3.6 V - 0.1 2.5 A IOFF power-off leakage current VI or VO = 3.6 V; VCC = 0.0 V - 0.1 10 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND VCC = 1.4 V to 2.7 V - 0.1 5 A VCC = 3.0 V to 3.6 V - 0.1 10 A - 0.1 20 A - 0.2 40 A - 5 - supply current ICC VI = VCC or GND; IO = 0 A VCC = 1.4 V to 2.7 V VCC = 3.0 V to 3.6 V input capacitance CI [1] pF All typical values are measured at Tamb = 25 C. 9.1 Graphs PQD  ,2+ P$ PQD  ,2/ P$ 9 9   9 9   9 9            92+ 9 Fig 5. Output voltage as a function of the HIGH-level output current. 74AVC16374_Q100 Product data sheet  92/ 9 Fig 6. Output voltage as a function of the LOW-level output current. All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 7 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). tr = tf  2 ns. For test circuit, see Figure 10. Symbol tpd Parameter propagation delay 40 C to +85 C Conditions Min Max - 3.1 - ns VCC = 1.4 V to 1.6 V 1.2 2.4 8.4 ns VCC = 1.65 V to 1.95 V 1.0 2.0 6.7 ns VCC = 2.3 V to 2.7 V 0.8 1.5 4.1 ns VCC = 3.0 V to 3.6 V 0.7 1.3 3.3 ns - 5.4 - ns nCP to nQn; see Figure 7 [1] VCC = 1.2 V ten enable time nOE to nQn, nBn; see Figure 8 [1] VCC = 1.2 V VCC = 1.4 V to 1.6 V 1.6 3.9 8.5 ns VCC = 1.65 V to 1.95 V 2.3 3.3 6.7 ns VCC = 2.3 V to 2.7 V 0.9 2.3 4.3 ns 0.7 2.0 3.4 ns - 5.6 - ns VCC = 1.4 V to 1.6 V 2.5 4.5 9.4 ns VCC = 1.65 V to 1.95 V 1.8 3.3 7.8 ns VCC = 2.3 V to 2.7 V 1.0 1.8 4.2 ns VCC = 3.0 V to 3.6 V 1.2 2.0 3.9 ns - 0.8 - ns VCC = 3.0 V to 3.6 V tdis disable time nOE to nQn; see Figure 8 VCC = 1.2 V tW pulse width VCC = 1.4 V to 1.6 V set-up time - 0.5 - ns VCC = 1.65 V to 1.95 V 3.1 0.3 - ns VCC = 2.3 V to 2.7 V 2.5 0.2 - ns VCC = 3.0 V to 3.6 V 2.5 0.2 - ns - 0.6 - ns VCC = 1.4 V to 1.6 V 2.7 0.3 - ns VCC = 1.65 V to 1.95 V 1.9 0.3 - ns VCC = 2.3 V to 2.7 V 1.4 0.2 - ns VCC = 3.0 V to 3.6 V 1.4 0.1 - ns - 0.8 - ns VCC = 1.4 V to 1.6 V 1.3 0.7 - ns VCC = 1.65 V to 1.95 V 1.2 0.6 - ns VCC = 2.3 V to 2.7 V 1.1 0.5 - ns VCC = 3.0 V to 3.6 V 1.1 0.4 - ns nDn to nCP; see Figure 8 VCC = 1.2 V th hold time nDn to nCP; see Figure 8 VCC = 1.2 V 74AVC16374_Q100 Product data sheet [1] HIGH; nCP; see Figure 7 VCC = 1.2 V tsu Unit Typ[2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 8 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). tr = tf  2 ns. For test circuit, see Figure 10. Symbol Parameter fmax 40 C to +85 C Conditions maximum frequency Min Max VCC = 1.2 V - 250 - MHz VCC = 1.4 V to 1.6 V - 300 - MHz VCC = 1.65 V to 1.95 V 160 320 - MHz VCC = 2.3 V to 2.7 V 200 350 - MHz 200 350 - MHz outputs enabled - 66 - pF outputs disabled - 1 - pF see Figure 8 VCC = 3.0 V to 3.6 V power dissipation capacitance CPD [1] Unit Typ[2] [3] per input; VI = GND to VCC tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [2] Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 11. Waveforms IPD[ 9, Q&3LQSXW 90 90 *1' W: W3+/ W3/+ 92+ Q4QRXWSXW 90 92/ PQD Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. Clock input (nCP) to output (nQn) propagation delays 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 9 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 9, Q2(LQSXW 90 *1' W 3=/ W 3/= 9&& RXWSXW /2:WR2)) 2))WR/2: 90 9; 92/ W 3=+ W 3+= 92+ 9< RXWSXW +,*+WR2)) 2))WR+,*+ 90 *1' RXWSXWV HQDEOHG RXWSXWV GLVDEOHG RXWSXWV HQDEOHG PQD Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. 3-state enable and disable times 9, 90 Q&3LQSXW *1' WVX WVX WK WK 9, 90 Q'QLQSXW *1' 92+ 90 Q4QRXWSXW 92/ PQD Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 9. Data set-up and hold times for nDn input to nCP input 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 10 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state Table 8. Measurement points Supply voltage VM Input VCC VI tr = tf VX VY 1.2 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 1.4 V to 1.6 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 1.65 V to 1.95 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 2.3 V to 2.7 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 3.0 V to 3.6 V 0.5  VCC VCC  2 ns VOL + 0.3 V VOH  0.3 V W: 9,  QHJDWLYH SXOVH 90 90  9 WI WU WU WI 9,  SRVLWLYH SXOVH 90 90  9 W: 9(;7 9&& * 9, 5/ 92 '87 57 5/ &/ DDH Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC  2 ns 15 pF 2 k open 2  VCC GND 1.4 V to 1.6 V VCC  2 ns 15 pF 2 k open 2  VCC GND 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k open 2  VCC GND 2.3 V to 2.7 V VCC  2 ns 30 pF 500  open 2  VCC GND 3.0 V to 3.6 V VCC  2 ns 30 pF 500  open 2  VCC GND 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 11 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 12. Package outline 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F Y +( \ $ =   4 $ $ $ $ SLQLQGH[ ș /S /   GHWDLO; Z ES H  PP  VFDOH 'LPHQVLRQV PPDUHWKHRULJLQDOGLPHQVLRQV 8QLW PP PD[ QRP PLQ $ $ $ $    ES F '  (         H +(      /  /S 4     Y Z     \ = ș  ƒ  ƒ  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 2XWOLQH YHUVLRQ 627 5HIHUHQFHV ,(& -('(& -(,7$ VRWBSR (XURSHDQ SURMHFWLRQ ,VVXHGDWH   02 Fig 11. Package outline SOT362-1 (TSSOP48) 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 12 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test MIL Military TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVC16374_Q100 v.2 20150316 Product data sheet - 74AVC16374_Q100 v.1 Modifications: 74AVC16374_Q100 v.1 74AVC16374_Q100 Product data sheet • Section 2: ESD protection; for MIL-STD-883 (method 3015) and HBM JESD22-A114F the value is changed from 2000 V to 1000 V. 20130916 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 - © Nexperia B.V. 2017. All rights reserved 13 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AVC16374_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 14 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AVC16374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2015 © Nexperia B.V. 2017. All rights reserved 15 of 16 74AVC16374-Q100 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 9.1 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 March 2015
74AVC16374DGG-Q10J 价格&库存
很抱歉,暂时无法提供与“74AVC16374DGG-Q10J”相匹配的价格&库存,您可以联系我们找货
