10/100/1000 BASE-T DUAL PORT
SURFACE MOUNT MAGNETICS
Meets IEEE 802.3 & ANSI X3.263 Standards.
RoHS Compliant.
10/100/1000 Base-T,Surface Mount Type,Open Header .
Operating temperature range: 0℃ to +70℃
350mA Current Capability Per POE Port / Two-pair.
Electrical Specifications @25°C
Part
Number
Return Loss
OCL(uH Min)
Insertion Loss
Cross talk
(dB Min)
@100KHz,0.2V Turns Ratio (dB Max)
(dB Min)
(±5%)
0.5-100MHz 0.5-40MHz 40.1-100MHz 0.5-40MHz 40.1-100MHz
With 8mA DC Bias
G4802CG
1CT:1CT
350
-1.1
-12+20*log(f/80)
-18
-35
-30
CMRR
(dB Min)
0.5-100MHz
HI-POT
(Vrms)
-30
1500
MECHANICAL
27.8
0.64
2.54
48
12.2
25
15.24
G4802CG
YYWWX
16.44
1.02
0.4
1.02
1
24
SUGGESTED PAD LAYOUT
7.5Max
23.46
0.25±0.15
0.6
48 SURFACES
0°-8°
Unless otherwise specified all tolerances are:±0.25 in mm
SCHEMATICS
26 TD8+
25 TD824
TX8-
27 TCT8
23
MCT8 22
TX8+
28 TD721
TX7-
TX6+
1CT:1CT
1CT:1CT
29 TD7+
31 TD630 TCT7
TX6- 18
MCT7 19
TX7+
32 TD6+
17
34 TD533 TCT6
TX5+
1CT:1CT
1CT:1CT
TX5- 15
MCT6 16
36 TCT5
CMT5 13
35 TD5+
37 TD412
TX4-
14
38 TD4+
11
MCT4 10
TX4+
40 TD3-
39 TCT4
9
TX3-
TX2+
1CT:1CT
1CT:1CT
41 TD3+
8
43 TD242 TCT3
TX2- 6
MCT3 7
TX3+
44 TD2+
5
46 TD145 TCT2
TX1- 3
MCT2 4
1CT:1CT
47 TD1+
TX1+
MCT1 1
1CT:1CT
48 TCT1
2
CHIP SIDE
LINE SIDE
Headquarters +86 769 86921000··Shenzhen R&D +86 755 36899993··USA +1 512 3433613··Korea +82 70 46394572··Taiwan +886 2 26984868··Hongkong +852 21211269
www.mnc-tek.com
很抱歉,暂时无法提供与“G4802CG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.77800
- 10+4.66560
- 30+4.10400
- 300+3.67200
- 600+3.33720
- 900+3.16440
