IP101GRI
IP101GRI
    ICPLUS(九阳电子)
    QFN-32-EP(4x4)
    单端口10/100 Mbps快速以太网收发器
IP101GRI 数据手册
IP101G Data Sheet Single Port 10/100 MII/RMII/TP/Fiber Fast Ethernet Transceiver (85nm/Extreme Low PW, PWMT® and EMIMT®) Features General Description z 10/100Mbps IEEE 802.3/802.3u compliant Fast Ethernet transceiver z Supports 100Base-TX/FX Media Interface z Supports MII/ RMII Interface z Supports Auto MDI/MDIX function z Power Management Tool - APS, auto power saving while Link-off - 802.3az, protocol based power saving - WOL+, light traffic power saving - PWD, force-off power saving - Supports MII with LPI for RX and TX - Supports RMII with LPI for RX z Supports Base Line Wander compensation z Supports Interrupt function z Built in synchronization FIFO to support jumbo frame size up to 12KB in MII mode (10KB in RMII 100Mbps mode) z Supports MDC and MDIO to communicate with the MAC z EMI Management Tool - F/W based control - 4 levels for mapping the difference layout length on the PCB z Single 3.3V power supply z Built-in Vcore regulator z DSP-based PHY Transceiver technology z System Debug Assistant Tool - 16 bit RX counter - 9 bit RXError/CRC counter - Isolate MII/RMII - RX to TX Loopback - Loopback MII/RMII z Using either 25MHz crystal/oscillator or 50MHz oscillator REF_CLK as clock source z Built-in 49.9ohm resistors for simplifying BOM z Flexible LED display z Process: 85nm z Package and operation temperature IP101G: dice, 0~70℃ IP101GA: 48LQFP, 0~70℃ IP101GR: 32QFN, 0~70℃ IP101GRI: 32QFN, -40~85℃ IP101G is an IEEE 802.3/802.3u compliant single-port Fast Ethernet Transceiver for both 100Mbps and 10Mbps operations. It supports Auto MDI/MDIX function to simplify the network installation and reduce the system maintenance cost. To improve the system performance, IP101G provides a hardware interrupt pin to indicate the link, speed and duplex status change. IP101G provides Media Independent Interface (MII) or Reduced Media Independent Interface (RMII) to connect with different types of 10/100Mbps Media Access Controller (MAC). IP101G is designed to use category 5 unshielded twisted-pair cable or Fiber-Optic cables connecting to other LAN devices. A PECL interface is supported to connect with an external 100Base-FX fiber optical transceiver. Except good performance, reliability, rich power saving method and extreme low operating current, IP101G provides a serial tool for system designers to complete their projects easily. They are System Debug Assistant Tool and EMI Management Tool. IP101G is fabricated with advanced CMOS (85nm) technology and design is based on IC Plus’s 5th Ethernet-PHY architecture, this feature makes IP101G consumes very low power. Such as in the full load operation (100Mbps_FDX), it only takes below 0.15W. IP101GA / IP101GR&IP101GRI are available in 48LQFP/32QFN, lead-free package. * EMIMT: Patent under apply. Application ■ ■ ■ ■ NAS Network Printers and Servers IP Set-Top Box IP/Smart TV ■ ■ ■ ■ 1/66 Copyright © 2011, IC Plus Corp. Game console IP and Video Phone PoE Telecom Fiber device May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Table Of Contents Table Of Contents.................................................................................................................................... 2 List of Figures .......................................................................................................................................... 4 List of Tables............................................................................................................................................ 5 Revision History....................................................................................................................................... 6 Features comparison between IP101G and IP101A/IP101AH ............................................................... 7 Transmit and Receive Data Path Block Diagram .................................................................................... 8 1 Pin diagram ...................................................................................................................................... 9 2 Dice pad information .......................................................................................................................11 3 Pin description................................................................................................................................ 12 IP101GA pin description .................................................................................................... 12 3.1 IP101GR/GRI pin description............................................................................................. 16 3.2 4 Register Descriptions ..................................................................................................................... 19 Register Page mode Control Register ............................................................................... 20 4.1 MII Registers ...................................................................................................................... 20 4.2 MMD Control Register ....................................................................................................... 30 4.3 MMD Data Register ........................................................................................................... 31 4.4 RX Counter Register.......................................................................................................... 34 4.5 LED Pin Control Register................................................................................................... 35 4.6 WOL+ Control Register...................................................................................................... 35 4.7 UTP PHY Specific Control Register ................................................................................... 38 4.8 Digital IO Pin Control Register ........................................................................................... 39 4.9 5 Function Description....................................................................................................................... 41 Major Functional Block Description ................................................................................... 41 5.1 Transmission Description...................................................................................... 41 5.1.1 MII and Management Control Interface ................................................................ 42 5.1.2 RMII Interface ....................................................................................................... 43 5.1.3 Flexible Clock Source ........................................................................................... 45 5.1.4 Auto-Negotiation and Related Information............................................................ 45 5.1.5 Auto-MDIX function............................................................................................... 46 5.1.6 PHY Address Configuration ............................................................................................... 46 5.2 Power Management Tool ................................................................................................... 48 5.3 Auto Power Saving Mode ..................................................................................... 48 5.3.1 IEEE802.3az EEE (Energy Efficient Ethernet) ..................................................... 49 5.3.2 Force power down ................................................................................................ 49 5.3.3 WOL+ operation mode.......................................................................................... 49 5.3.4 LED Mode Configuration.................................................................................................... 53 5.4 LED Blink Timing................................................................................................................ 53 5.5 Repeater Mode .................................................................................................................. 53 5.6 Interrupt.............................................................................................................................. 53 5.7 Miscellaneous .................................................................................................................... 53 5.8 Serial Management Interface............................................................................................. 54 5.9 5.10 Fiber Mode Setting............................................................................................................. 55 Jumbo Frame ..................................................................................................................... 55 5.11 6 Layout Guideline ............................................................................................................................ 56 General Layout Guideline .................................................................................................. 56 6.1 Twisted Pair recommendation............................................................................................ 56 6.2 7 Electrical Characteristics ................................................................................................................ 57 Absolute Maximum Rating ................................................................................................. 57 7.1 DC Characteristics ............................................................................................................. 57 7.2 Crystal Specifications......................................................................................................... 58 7.3 2/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 7.4 8 9 AC Timing........................................................................................................................... 59 Reset, Pin Latched-in, Clock and Power Source.................................................. 59 7.4.1 MII Timing ............................................................................................................. 60 7.4.2 RMII Timing........................................................................................................... 61 7.4.3 SMI Timing ............................................................................................................ 62 7.4.4 MDI to MII latency delay time ............................................................................... 62 7.4.5 7.5 Thermal Data ..................................................................................................................... 63 Order Information ........................................................................................................................... 63 Physical Dimensions ...................................................................................................................... 64 48-PIN LQFP...................................................................................................................... 64 9.1 32-PIN QFN ....................................................................................................................... 65 9.2 3/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet List of Figures Figure 1 Figure 2 Figure 3 Figure 4 Figure 5 Figure 6 Figure 7 Figure 8 Figure 9 Figure 10 Figure 11 Figure 12 Figure 13 Figure 14 Figure 15 Figure 16 Figure 17 Figure 18 Figure 19 Figure 20 Figure 21 Figure 22 Figure 23 Figure 24 Figure 25 Flow chart of IP101G ..................................................................................................................8 IP101GA 48 Pin Top view Diagram .............................................................................................9 IP101GR/GRI 32 Pin Top view Diagram ...................................................................................10 IP101G dice pad information Top view...................................................................................... 11 LPI transition .............................................................................................................................43 IP101G/GA/GR/GRI MII Mode with LPI transition Block Diagram............................................43 IP101G/GA/GR/GRI MII Mode without LPI transition Block Diagram.......................................43 IP101G RMII Mode with internal clock Block Diagram .............................................................44 IP101G RMII Mode with external clock Block Diagram ............................................................44 IP101GR need add a buffer if RXCLK/50M_CLK push over two device ................................45 IP101G link speed and EEE ability programming guide .........................................................46 PHY Address Configuration ....................................................................................................47 Magic Packet Format ..............................................................................................................50 Sleep or wake up automatically programming guide ..............................................................51 MAC control sleep or wake up programming guide................................................................52 MDC/MDIO Format .................................................................................................................54 IP101G Fiber Mode Setting.....................................................................................................55 Reset, Pin Latched-In, Clock and Power Source Timing Requirements.................................59 MII Transmit Timing Requirements .........................................................................................60 MII Receive Timing Specifications ..........................................................................................60 RMII Transmit Timing Requirements.......................................................................................61 RMII Receive Timing Specifications........................................................................................61 SMI Timing Requirements.......................................................................................................62 48-PIN LQFP Dimension.........................................................................................................64 32-PIN QFN Dimension ..........................................................................................................65 4/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet List of Tables Table 1 Table 2 Table 3 Table 4 Table 5 Table 6 Table 7 Table 8 Table 9 Table 10 Table 11 Table 12 Table 13 Table 14 Table 15 Table 16 Table 17 Table 18 Table 19 Table 20 Table 21 Table 22 Table 23 Features comparison between IP101G and IP101A/IP101AH.....................................................7 Register Map...............................................................................................................................19 Flexible Clock Source Setting.....................................................................................................45 PHY Address Configuration ........................................................................................................47 PHY Address Configuration by register ......................................................................................47 WOL+ operation mode................................................................................................................50 LED Mode 1 Function .................................................................................................................53 LED Mode 2 Function .................................................................................................................53 LED Blink Timing ........................................................................................................................53 SMI Format ...............................................................................................................................54 DC Characteristics ....................................................................................................................57 I/O Electrical Characteristics.....................................................................................................57 Pin Latched-in Configuration Resistor ......................................................................................58 Crystal Specifications................................................................................................................58 Reset, Pin Latched-in, Clock and Power Source Timing Requirements ..................................59 MII Transmit Timing Requirements ...........................................................................................60 MII Receive Timing Specifications ............................................................................................60 RMII Transmit Timing Requirements ........................................................................................61 RMII Receive Timing Specifications .........................................................................................61 SMI Timing Requirements ........................................................................................................62 MDI to MII latency delay time ...................................................................................................62 Thermal Data ............................................................................................................................63 Part Number and Package .......................................................................................................63 5/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Revision History Revision # Change Description IP101G-DS-R01 Initial release. IP101G-DS-R01-20120808 1) Correct the I/O type of IP101GA pin description to O(Ouput) for pin24 RXER. 2) Change the pin name from DVDD33_IO to VDDIO. IP101G-DS-R01-20120821 1) Change the default value of register P16R27 from 0x0022 to 0x0012. 2) Remove I/O Slew Rate Control Register. 3) Change the register location RMII_WITH_ER from P16R29[0] to P16R29[7]. IP101G-DS-R01-20120927 1) Add more description of low power idle (LPI) state in MII and RMII modes. 2) Correct the typo of Physical Dimensions. IP101G-DS-R01-20121101 Change the LED blink timing from “On 80ms -> Off (20~40)ms” to “On 26ms -> Off 78ms”. IP101G-DS-R01-20121113 Add more function description to support Jumbo Frame. IP101G-DS-R01-20121127 Change the LED mode function as same as IP101A. IP101G-DS-R01-20121224 Add the notice that does not let these PHY address pins floating for the latched-in settings after the power is ready. IP101G-DS-R01-20130206 Change the AC timing Tclk_MII_rdy in Table 14 from 10ms Min. to 10ms Max. IP101G-DS-R01-20130312 1) Add more Min. and Max value on the AC Timing table. 2) Add thermal data on the Table 20. IP101G-DS-R01-20130507 Add LED Pin Driving Control Register. IP101G-DS-R01-20130621 Add IP101GRI 2.5V I/O power supply. IP101G-DS-R01-20130712 Modify WOL+ programming guide. IP101G-DS-R01-20130830 Modify Magic packet MAC_Address description. IP101G-DS-R01-20130905 Modify LED Control Register. IP101G-DS-R01-20130927 Modify MDC clock period can be to 300ns. IP101G-DS-R01-20131110 Add the symbol "Bottom view" and "Top view" in Physical Dimensions. IP101G-DS-R01-20131115 Add Equivalent Series Resistance and Drive Level in Crystal Specifications. IP101G-DS-R01-20140114 1) Make more clear between 100Mbps (25M nibbles/s) and 25M code-groups/s in Figure 1 Flow chart of IP101G. 2) Change all symbols from “VQFN” to “QFN”. 3) Add the key word “Fiber” in Table 11 I/O Electrical Characteristics. 4) Add register PHY_ADDRESS in Page16 Reg29 bit[12:8]. 5) Add Table 20 MDI to MII latency delay time. 6) Add table 5 PHY Address Configuration by register description IP101G-DS-R01-20140224 Modify Register4 Next Page bit symbol “RO” to “RW”. IP101G-DS-R01-20140328 Delete termination resistors description of Layout Guideline 6.2. IP101G-DS-R01-20140520 1) Modify UTP PHY Interrupt control/status Register description. 2) Add special Reset request description. Disclaimer This document probably contains the inaccurate data or typographic error. In order to keep this document correct, IC Plus reserves the right to change or improve the content of this document. 6/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Features comparison between IP101G and IP101A/IP101AH Table 1 Features comparison between IP101G and IP101A/IP101AH Product Name Package Type REGOUT(1) Output Voltage and location REGIN Input Voltage and location RMII mode setting Fiber mode setting: Fiber FXSD signal: Number of LED LED mode LED Blink Timing PHY address number(3) IP101GR 32pin QFN 1.0V, pin28 IP101G IP101GA IP101A IP101AH Dice 48pin LQFP 48pin LQFP 1.0V, pad5 1.0V, pin8 2.5V, pin32 and pad11 NA(2) 1.0V, pad23 NA 2.5V, pin8 and pad26 Pin4 Pad18 Pin1 Pin1 and pin44 Pin19 Pad39 Pin22 NA Pin24 and pin48 Pin1 Pad13 Pin43 Pin37 2 4 4 5 1 and 2 1 and 2 On 26ms -> Off 78ms On 26ms -> Off 78ms Single: 0 ~ 1 Single: 0 ~ 7 Single: 0 ~ 31 Multi: 2 ~ 31 Multi: 8 ~ 31 Center-tap of transformer Do not connect to any power 2.5V input power Built-in 49.9ohm resistors Yes No Power consumption ~150mW ~480mW Process 85nm 0.25μm IEEE 802.3az Yes No 10Base TX amplitude ~1.75V (10Base-Te) ~2.5V (10Base-T) WOL+ (Wake On LAN Plus) Yes No Analog OFF Yes No 16 bit RX counter Yes No 9 bit RXER/CRC counter Yes No RX to TX Loopback Yes No Loopback MII/RMII Yes Yes SNI mode No Yes Note 1: Regulator voltage output is for internal use only. Do not supply to any other device. Note 2: Not available for this function. The 1.0V is supplied by the regulator that built-in the chip. Note 3: Do not let these PHY address pins floating for the latched-in settings after the power is ready. 7/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Transmit and Receive Data Path Block Diagram Figure 1 Flow chart of IP101G 8/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 1 Pin diagram 24 RXER 23 CRS/LEDMOD 22 RXDV/CRS_DV/FX_HEN 40 21 RXD0 NC 41 20 RXD1 RESET_N 42 19 RXD2 TXER/FXSD 43 18 RXD3 NC 44 17 DGND DGND 45 16 RXCLK/50M_CLKO X1 46 15 NC X2 47 14 VDDIO INTR 48 13 LED3/PHY_AD3 NC 37 NC 38 NC 39 NC Note: Those pins in "blue" are different from IP101A. IP101GA (LQFP-48) Figure 2 IP101GA 48 Pin Top view Diagram 9/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet ISET 25 16 RXD2 MDI_RN 26 15 RXD3 MDI_RP 27 14 RXCLK/50M_CLKO REGOUT 28 13 VDD_IO MDI_TN 29 12 LED3/PHY_AD3 MDI_TP 30 11 LED0/PHY_AD0 AVDD33 31 10 TXCLK/50M_CLKI RESET_N 32 9 IP101GR/GRI (QFN-32) (GND on bottom of chip) TXD0 Figure 3 IP101GR/GRI 32 Pin Top view Diagram 10/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 2 Dice pad information Pad 31 Pad 22 Pad 24 Pad 23 Pad 12 Pad 44 Pad 45 Pad 11 Pad 1 IC Logo Pad No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Text Name ISET AGND_1V MDI_RN MDI_RP REGOUT MDI_TN MDI_TP AGND_33 AGND33 AVDD33 REGOUT RESET_N TXER_FXSD VSSIO X1 X2 INTR COL_RMII TX_EN TXD[3] TXD[2] TXD[1] REGIN Pad No. 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 Text Name TXD[0] TX_CLK REGIN PHYAD_LED0 PHYAD_LED1 VSS PHYAD_LED2 PHYAD_LED3 VDDIO RX_CLK VSSIO RXD[3] RXD[2] RXD[1] RXD[0] RXDV_FIBMOD CRS RXER_INTR MDC MDIO TEST_ON AVDD33 Figure 4 IP101G dice pad information Top view 11/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 3 Pin description Type LI I/O Description Latched Input in power up or reset Type PD Description Internal Pull-Down 104KΩ Bi-directional input and output PU Internal Pull-Up 222KΩ I Input Hi-Z High impedance O Output P Power OD Open Drain 3.1 IP101GA pin description IP101GA Pin no. Label Type Reset State Description Serial Management Interface Pins 25 MDC I Hi-Z Management Data Interface Clock: This pin provides a clock reference to MDIO. The clock period can be to 300ns. 26 MDIO I/O I Management Data interface Input/Output: The (PU) (PU) function of this pin is to transfer management information between PHY and MAC. MII/RMII Pins 2 TXEN I I Transmit Enable or Signal Detect. (PD) (PD) 43 TXER/FXSD I I Transmit Error or FXSD: (PD) (PD) This is a dual-function pin which is determined by the media type selection. If RXDV/CRS_DV/FX_HEN is latched as “0 (default)” upon reset, the TP interface is selected and its function as TXER. If the fiber interface is selected, this pin’s function as FXSD. FXSD: 0: Fiber link down; 1: Fiber link up Transmit Enable: TXEN TXER 1 1 7 TXCLK/50M_CLKI 3,4,5,6 TXD[3:0] I/O I 0 1 1 0 0 0 This pin TXER must be either floating or connecting to GND in RMII mode. Hi-Z Transmit Clock output or 50M clock input: In MII mode, this pin provides a continuous 25MHz clock at 100Base-TX and 2.5MHz at 10Base-T. In RMII mode, a 50Mhz clock should input to this pin for the timing reference of the internal circuit. Hi-Z Transmit Data Input: 12/66 Copyright © 2011, IC Plus Corp. Description Transmission error propagation. Combine TXD[3:0] that equal to 0001 for request PHY to enter LPI mode. Normal operation May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IP101GA Pin no. Label 22 RXDV/CRS_DV/ FX_HEN 16 RXCLK/ 50M_CLKO 18,19, RXD[3:0] 20,21 24 RXER Type Reset State O/LI (PD) I (PD) O Hi-Z O Hi-Z O Hi-Z Description In MII mode, TXD[3:0] is synchronous to TXCLK. In RMII mode, TXD[1:0] is synchronous to 50M_CLKI. Receive Data Valid or Media Type Selection: FX_HEN The input state is latched upon reset to determine whether TP or fiber interface is selected. If it is at logic “0” (default) state upon reset, the TP interface is selected; otherwise the fiber interface is selected. RXDV/CRS_DV In MII mode, this pin indicates the Receive Data Valid function. In RMII mode, this pin indicates the Carrier Sense and Receive Data Valid function. Receive Clock: In MII mode, this pin provides 25MHz for 100BT or 2.5MHz for 10BT. In RMII mode, this pin output a 50 MHz clock for the timing reference of MAC side. Receive Data: In MII mode, RXD[3:0] is synchronous to RXCLK. In RMII mode, RXD[1:0] is synchronous to 50M_CLKI. Receive error: RXDV RXER Description 1 1 Decoding error of the received signal 0 1 Combine RXD[3:0] equal to 0001 indicates PHY is receiving LPI. Normal operation 1 0 0 1 COL/RMII O/LI (PD) 23 CRS/LEDMOD O/LI (PD) Cable Transmission Interface 34,33 MDI_TP I/O MDI_TN I/O This pin RXER is an optional input for MAC/CPU device. I Collision Detected: During the normal operation, this (PD) pin outputs a high status signal it means collision is detected. RMII Mode Selection: During the power on reset, this pin status is latched to determine what kind MAC interface will be used. Logic “1” is for RMII mode and logic “0” is for MII mode. I Carrier Sense: When signal output from this pin is high (PD) indicates the transmission or reception is in process and at low status means the line is in idle state. LEDMOD: During power on reset, this pin status is latched to determine which either LED mode 1 or 2 is selected, please refer to the LED pins description. Hi-Z Transmit Output Pair: Differential pair shared by 100Base-TX and 10Base-T modes. When configured as 100Base-TX, output is an MLT-3 encoded waveform. When configured as 10Base-T, the output is Manchester 13/66 Copyright © 2011, IC Plus Corp. 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IP101GA Pin no. Label Type 31,30 MDI_RP I/O MDI_RN I/O Clock and Miscellaneous Pins 47 X2 O Reset State Description code. Hi-Z Receive Input Pair: Differential 100Base-TX and 10Base-T modes. O 46 X1 I I 42 RESET_N I I (PU) 28 ISET I I 48 INTR OD Hi-Z 9 LED0/PHY_AD0 O/LI Hi-Z 10 LED1/PHY_AD1 O/LI Hi-Z 12 LED2/PHY_AD2 O/LI Hi-Z 13 LED3/PHY_AD3 O/LI (PD) Hi-Z 27 TEST_ON I I shared by 25MHz Crystal Output: Connects to crystal to provide the 25MHz output. It must be left open when X1 is driven with an external 25MHz oscillator. 25MHz Crystal Input: Connects to crystal to provide the 25MHz crystal input. If a 25MHz oscillator is used, connect X1 to the oscillator’s output. If a 50MHz clock is applied to pin7 TXCLK/50M_CLKI, X1 must be connected to GND or AGND33. RESET_N: Enable a low status signal will reset the chip. For a complete reset function. 25MHz clock (x1) must be active for a minimum of 10 clock cycles before the rising edge of RESET_N. Chip will be able to operate after 2.5ms delay of the rising edge of RESET_N. The 2.5ms extension is to ensure the stability of system power. Bandgap Circuit Resistor: This pin should be connected to GND via a 6.19KΩ (1%) resistor to define the standard current of the internal circuit. Interrupt: Programmable Interrupt Output, this is an open drain output, and an external pulled-up resistor is needed for normal mode operation. Another operation mode is Rx to Tx loopback debugging test (reflect on Register P1R23[13] RX2TX_LPBK) when connect INTR pin to GND. LED 0 and PHY Address [0] LED 0 LED mode 1 2 LED0 Link Link /ACT(blinking) LED 1 and PHY Address [1] LED1 LED mode 1 2 LED1 Duplex Duplex /COL (blinking) LED 2 and PHY Address [2] LED2 LED mode 1 2 LED2 10M Link /ACT 10M Link LED 3 and PHY Address [3] LED3 LED mode 1 2 LED3 100M Link /ACT 100M Link Test Enable: Set this pin to high to enable Test mode. 14/66 Copyright © 2011, IC Plus Corp. pair May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IP101GA Pin no. Label Type (PD) Power and Ground 32 NC 8 REGOUT Reset Description State (PD) For normal operation, this pin doesn’t need to be connected. -P -P 14 VDDIO P P 36 AVDD33 P P 35 AGND33 29 AGND1V 45,11,17 DGND P P P P P P It’s a NC pin. Regulator Power Output: This is a regulator power output. A 10uF and 0.1uF should be connected to this pin to filter the power noise. Digital Power input: Either 3.3V or 2.5V for I/O power supply. 3.3V Analog power input: This is a 3.3V power supply for analog circuitry, and it should be decoupled carefully. Ground. Ground Ground. 15/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 3.2 IP101GR/GRI pin description IP101GR/GRI Pin no. Label Type Reset State Description Serial Management Interface Pins 22 MDC I Hi-Z Management Data Interface Clock: This pin provides a clock reference to MDIO. The clock period can be to 300ns. 23 MDIO I/O I Management Data interface Input/Output: The (PU) (PU) function of this pin is to transfer management information between PHY and MAC. MII/RMII Pins 5 TXEN I I Transmit Enable or Signal Detect. (PD) (PD) 1 TXER/FXSD I I Transmit Error or FXSD: (PD) (PD) This is a dual-function pin which is determined by the media type selection. If RXDV/CRS_DV/FX_HEN is latched as “0 (default)” upon reset, the TP interface is selected and its function as TXER. If the fiber interface is selected, this pin’s function as FXSD. FXSD: 0: Fiber link down; 1: Fiber link up Transmit Enable: TXEN TXER 1 1 10 TXCLK/50M_CLKI 6,7,8,9 TXD[3:0] 19 RXDV/CRS_DV/ FX_HEN I/O I O/LI (PD) 0 1 1 0 0 0 This pin TXER must be either floating or connecting to GND in RMII mode. Hi-Z Transmit Clock output or 50M clock input: In MII mode, this pin provides a continuous 25MHz clock at 100Base-TX and 2.5MHz at 10Base-T. In RMII mode, a 50Mhz clock should input to this pin for the timing reference of the internal circuit. Hi-Z Transmit Data Input: In MII mode, TXD[3:0] is synchronous to TXCLK. In RMII mode, TXD[1:0] is synchronous to 50M_CLKI. I Receive Data Valid or Media Type Selection: (PD) FX_HEN The input state is latched upon reset to determine whether TP or fiber interface is selected. If it is at logic “0” (default) state upon reset, the TP interface is selected; otherwise the fiber interface is selected. RXDV/CRS_DV In MII mode, this pin indicates the Receive Data Valid 16/66 Copyright © 2011, IC Plus Corp. Description Transmission error propagation. Combine TXD[3:0] that equal to 0001 for request PHY to enter LPI mode. Normal operation May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IP101GR/GRI Pin no. 14 Label RXCLK/ 50M_CLKO 15,16, RXD[3:0] 17,18 21 RXER/INTR_32 Type O O O/OD Reset State Description function. In RMII mode, this pin indicates the Carrier Sense and Receive Data Valid function. Hi-Z Receive Clock: In MII mode, this pin provides 25MHz for 100BT or 2.5MHz for 10BT. In RMII mode, this pin output a 50 MHz clock for the timing reference of MAC side. Hi-Z Receive Data: In MII mode, RXD[3:0] is synchronous to RXCLK. In RMII mode, RXD[1:0] is synchronous to 50M_CLKI. Hi-Z The multiplex function of this pin is set by the register SEL_INTR32, page 16, 29[2]. The default function is RXER. Receive error: RXDV RXER Description 1 1 Decoding error of the received signal 0 1 Combine RXD[3:0] equal to 0001 indicates PHY is receiving LPI. Normal operation 1 0 0 4 COL/RMII O/LI (PD) 20 CRS/LEDMOD O/LI (PD) Cable Transmission Interface 30,29 MDI_TP I/O MDI_TN I/O 27,26 MDI_RP I/O MDI_RN I/O Clock and Miscellaneous Pins This pin RXER is an optional input for MAC/CPU device. Interrupt: Programmable Interrupt Output, this is an open drain output, and an external pulled-up resistor is needed. I Collision Detected: During the normal operation, this (PD) pin outputs a high status signal it means collision is detected. RMII Mode Selection: During the power on reset, this pin status is latched to determine what kind MAC interface will be used. Logic “1” is for RMII mode and logic “0” is for MII mode. I Carrier Sense: When signal output from this pin is high (PD) indicates the transmission or reception is in process and at low status means the line is in idle state. LEDMOD: During power on reset, this pin status is latched to determine which either LED mode 1 or 2 is selected, please refer to the LED pins description. Hi-Z Transmit Output Pair: Differential pair shared by 100Base-TX and 10Base-T modes. When configured as 100Base-TX, output is an MLT-3 encoded waveform. When configured as 10Base-T, the output is Manchester code. Hi-Z Receive Input Pair: Differential pair shared by 100Base-TX and 10Base-T modes. 17/66 Copyright © 2011, IC Plus Corp. 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IP101GR/GRI Pin no. Label Type 3 X2 O 2 X1 I 32 RESET_N I 25 ISET I 11 LED0/PHY_AD0 O/LI 12 LED3/PHY_AD3 O/LI (PD) 24 TEST_ON I (PD) Power and Ground 28 REGOUT Reset Description State O 25MHz Crystal Output: Connects to crystal to provide the 25MHz output. It must be left open when X1 is driven with an external 25MHz oscillator. I 25MHz Crystal Input: Connects to crystal to provide the 25MHz crystal input. If a 25MHz oscillator is used, connect X1 to the oscillator’s output. If a 50MHz clock is applied to pin10 TXCLK/50M_CLKI, X1 must be connected to GND. I RESET_N: Enable a low status signal will reset the chip. (PU) For a complete reset function. 25MHz clock (x1) must be active for a minimum of 10 clock cycles before the rising edge of RESET_N. Chip will be able to operate after 2.5ms delay of the rising edge of RESET_N. The 2.5ms extension is to ensure the stability of system power. I Bandgap Circuit Resistor: This pin should be connected to GND via a 6.19KΩ (1%) resistor to define the standard current of the internal circuit. Hi-Z LED 0 and PHY Address [0] LED 0 LED mode 1 2 LED0 Link Link /ACT(blinking) Hi-Z LED 3 and PHY Address [3] LED3 LED mode 1 2 LED3 100M Link /ACT 100M Link I Test Enable: Set this pin to high to enable Test mode. (PD) For normal operation, this pin doesn’t need to be connected. P P 13 VDDIO P P 31 AVDD33 P P P P Bottom GND PAD Regulator Power Output: This is a regulator power output. A 10uF and 0.1uF should be connected to this pin to filter the power noise. Digital Power input: IP101GR/GRI: Either 3.3V or 2.5V for I/O power supply. 3.3V Analog power input: This is a 3.3V power supply for analog circuitry, and it should be decoupled carefully. Ground. 18/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 4 Register Descriptions Table 2 Register Map Page X Register 20 Description Page Control Register Default 0x0010 -- 0 Control Register 0x3100 -- 1 Status Register 0x7849 -- 2 PHY Identifier 1 Register 0x0243 --- 3 4 PHY Identifier 2 Register Auto-Negotiation Advertisement Register 0x0C54 0x01E1 -- 5 Auto-Negotiation Link Partner Ability Register 0x0000 -- 6 Auto-Negotiation Expansion Register 0x0004 -- 7 Auto-Negotiation Next Page Transmit Register 0x2001 --- 8 13 Auto-Negotiation Link Partner Next Page Register MMD Access Control Register 0x0000 0x0000 -- 14 MMD Access Address Data Register 0x0000 16 16 PHY Specific Control Register 0x0002 16 17 PHY Interrupt Ctrl/Status Register 0x0F00 16 18 PHY Status Monitoring Register 0x0208 16 16 26 27 Digital IO Pin Driving Control Register Digital IO Pin Driving Control Register 0x1249 0x0012 16 28 LED Pin Driving Control Register 0x0001 16 29 Digital I/O Specific Control Register 0x0082 16 30 PHY MDI/MDIX Control and Specific Status Register 0x0000 --- MMD 3.0 MMD 3.1 PCS Control 1 Register PCS Status 1 Register 0x0000 0x0000 -- MMD 3.20 EEE Capability Register 0x0002 -- MMD 3.22 EEE Wake Error Count Register 0x0000 -- MMD 7.60 EEE Advertisement Register 0x0002 -1 MMD 7.61 17 EEE Link Partner Ability Register PHY Specific Control Register 0x0000 0x0000 1 18 RX CRC Error Counter Register 0x0000 1 22 Linear Regulator Output Control Register 0x2020 1 23 UTP PHY Specific Control Register 0x8000 2 18 RX Packet Counter Register 0x0000 4 4 16 22 WOL+ Control Register Digital IO Pin Driving Control Register 0x5F40 0x4000 5 16 PHY WOL+ MAC Address Register 0x0000 8 17 RX Counter Control Register 0x7000 11 18 UTP PHY Interrupt Control/Status Register 0x0000 19/66 Copyright © 2011, IC Plus Corp. Note May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Page 17 Register 17 18 17 Description PHY WOL+ Status Register Default 0x0000 RX Counter Interrupt Control/Status Register 0x0000 Note Register descriptions R/W = Read/Write, SC = Self-Clearing, RO = Read Only, LL = Latching Low, LH = Latching High (TP): for twisted pair operation. (FX): for fiber operation. (e-fuse): only available for IP101G (dice). 4.1 Register Page mode Control Register MII register 20 PHY MII ROM R/W Description Default Page Control Register -20[4:0] -R/W Reg16~31_Page_Sel[4:0] 0x10 Register Page Select The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 4.2 MII Registers Bit Name Description/Usage Default value (h): 3100 Register 0 : Control Register 15 Reset 14 Loopback 13 Speed Selection 12 AutoNegotiation Enable 11 Power Down 10 Isolate When set, this action will bring both status and control registers 0, RW/SC of the PHY to default state. This bit is self-clearing. 1 = Software reset 0 = Normal operation This bit enables loopback of transmit data to the receive data 0, RW path, i.e., TXD to RXD. 1 = enable loopback 0 = normal operation This bit sets the speed of transmission. 1, RW 1 = 100Mbps 0 = 10Mbps After completing auto-negotiation, this bit will reflect the speed status.(1: 100Mbps, 0: 10Mbps) This bit determines the auto-negotiation function. 1, RW (TP) 1 = enable auto-negotiation; bits 13 and 8 will be ignored. 0, RO (FX) 0 = disable auto-negotiation; bits 13 and 8 will determine the link speed and the data transfer mode, under this condition. This bit will turn down the power of the PHY chip and the internal 0, RW crystal oscillator circuit if this bit is enabled. The MDC and MDIO are still activated for accessing to the MAC. 1 = power down 0 = normal operation 1=electrically Isolate PHY from MII but not isolate MDC and 0,RW MDIO 20/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Bit Name Description/Usage Default value (h): 3100 Register 0 : Control Register 9 Restart AutoNegotiation 8 Duplex Mode 7 Collision Test 6:0 Bit 0=normal operation This bit allows the auto-negotiation function to be reset. 1 = restart auto-negotiation 0 = normal operation This bit sets the duplex mode if auto-negotiation is disabled (bit 12=0) 1 = full duplex 0 = half duplex After completing auto-negotiation, this bit will reflect the duplex status.(1: Full duplex, 0: Half duplex) 1=enable COL signal test 0=disable COL signal test Reserved Name 1, RW 0,RW 0, RO Description/Usage Register 1 : Status Register 15 100Base-T4 1 = enable 100Base-T4 support 0 = suppress 100Base-T4 support 14 100Base-TX Full 1 = enable 100Base-TX full duplex support Duplex 0 = suppress 100Base-TX full duplex support 13 100BASE-TX Half 1 = enable 100Base-TX half duplex support Duplex 0 = suppress 100Base-TX half duplex support 12 10Base-T Full 1 = enable 10Base-T full duplex support Duplex 0 = suppress 10Base-T full duplex support 11 10_Base-T Half 1 = enable 10Base-T half duplex support Duplex 0 = suppress 10Base-T half duplex support 10:7 Reserved 6 MF Preamble The IP101G will accept management frames with preamble Suppression suppressed. The IP101G accepts management frames without preamble. A Minimum of 32 preamble bits is required for the first SMI read/write transaction after reset. One idle bit is required between any two management transactions as per IEEE802.3u specifications 5 Auto- Negotiation 1 = auto-negotiation process completed Complete 0 = auto-negotiation process not completed 4 Remote Fault 1 = remote fault condition detected (cleared on read) 0 = no remote fault condition detected 3 Auto- Negotiation 1 = able to perform auto-negotiation 0 = unable to perform auto-negotiation 2 Link Status 1 = valid link established 0 = no valid link established 1 Jabber Detect 1 = jabber condition detected 0 = no jabber condition detected 0 Extended 1 = extended register capability Capability 0 = basic register capability only 21/66 Copyright © 2011, IC Plus Corp. 0, RW/SC Default value (h): 7849 0, RO 1, RO 1, RO 1, RO 1, RO 0, RO 1, RO 0, RO 0, RO/LH 1, RO 0, RO/LL 0, RO/LH 1, RO May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Bit Name Default value (h): 0243 Description/Usage Register 2 : PHY Identifier 1 Register 15:0 PHYID1 PHY identifier ID for software recognize IP101G Bit Name Description/Usage 0X0243, RO Default value (h): 0C54 Register 3 : PHY Identifier 2 Register 15:0 PHYID2 PHY identifier ID for software recognize 0X0C54, RO Note: Register 2 and register 3 identifier registers altogether consist of Vender model, model revision number and Organizationally Unique identifier (OUI) information. Total of 32 bits allocate in these 2 registers and they can return all zeroes in all bits if desired. Register 2 contains OUI’s most significant bits and OUI’s least significant bits, Vender model, Model revision number are allocated in register 3. Register 4 lists the advertised abilities during auto-negotiation for what will be transmitted to IP101G’s Link Partner. Bit Description/Usage Default value (h): 01E1 Name Register 4 : Auto-Negotiation Advertisement Register 15 NP Next Page bit. 0, RW 0 = transmitting the primary capability data page 1 = transmitting the protocol specific data page 14 Reserved 0, RO 13 RF 1 = advertise remote fault detection capability 0, RW 0 = do not advertise remote fault detection capability 12 Reserved 0, RO 11 Asymmetric. 1 = asymmetric flow control is supported by local node 0, RW Pause 0 = asymmetric flow control is NOT supported by local node 10 Pause 1 = flow control is supported by local node 0, RW 0 = flow control is NOT supported by local node 9 T4 1 = 100Base-T4 is supported by local node 0, RO 0 = 100Base-T4 not supported by local node 8 TX Full Duplex 1 = 100Base-TX full duplex is supported by local node 1, RW 0 = 100Base-TX full duplex not supported by local node 7 TX 1 = 100Base-TX is supported by local node 1, RW 0 = 100Base-TX not supported by local node 6 10 Full Duplex 1 = 10Base-T full duplex supported by local node 1, RW 0 = 10Base-T full duplex not supported by local node 5 10 1 = 10Base-T is supported by local node 1, RW 0 = 10Base-T not supported by local node 4:0 Selector Binary encoded selector supported by this node. Currently only , RO CSMA/CD is specified. No other protocols are supported. 22/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet This register contains the advertised abilities of the Link Partner as received during Auto-negotiation. The content changes after the successful Auto-negotiation if Next-pages are supported. Bit Name Description/Usage Default value (h): 0000 Register 5 : Auto-Negotiation Link Partner Ability Register (ANLPAR) 15 Next Page Next Page bit. 0, RO 0 = transmitting the primary capability data page 1 = transmitting the protocol specific data page 14 Acknowledge 1 = link partner acknowledges reception of local node’s 0, RO capability data word 0 = no acknowledgement 13 Remote Fault 1 = link partner is indicating a remote fault 0, RO 0 = link partner does not indicate a remote fault 12 Reserved 0, RO 11 Asymmetric. 1 = asymmetric flow control is supported link partner 0, RO Pause 0 = asymmetric flow control is NOT supported by link partner 10 Pause 1 = flow control is supported by Link partner 0, RO 0 = flow control is NOT supported by Link partner 9 T4 1 = 100Base-T4 is supported by link partner 0, RO 0 = 100Base-T4 not supported by link partner 8 TXFD 1 = 100Base-TX full duplex is supported by link partner 0, RO 0 = 100Base-TX full duplex not supported by link partner 7 100BASE-TX 1 = 100Base-TX is supported by link partner 0, RO 0 = 100Base-TX not supported by link partner This bit will also be set after the link in 100Base-TX is established by parallel detection. 6 10FD 1 = 10Base-T full duplex is supported by link partner 0, RO 0 = 10Base-T full duplex not supported by link partner 5 10Base-T 1 = 10Base-T is supported by link partner 0, RO 0 = 10Base-T not supported by link partner This bit will also be set after the link in 10Base-T is established by parallel detection. 4:0 Selector Link Partner’s binary encoded node selector Currently only , RO CSMA/CD is specified 23/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Register 6 defines more auto-negotiation registers to meet the requirement. Bit Name Description/Usage Register 6 : Auto-Negotiation Expansion Register 15:5 Reserved This bit is always set to 0. 4 MLF This status indicates if a multiple link fault has occurred. 1 = fault occurred 0 = no fault occurred 3 LP_NP_ABLE This status indicates if the link partner supports Next Page negotiation. 1 = supported 0 = not supported 2 NP_ABLE This bit indicates if the device is able to send additional Next Pages. 1 PAGE_RX This bit will be set if a new link code word page has been received. It is cleared automatically after the auto-negotiation link partner’s ability register (register 5) is read by the management. 0 LP_NW_ABLE 1 = link partner supports auto-negotiation. Default value (h): 0004 0, RO 0, RO 0, RO 1, RO 0, RO 0, RO Register 7 defines more auto-negotiation registers to meet the requirement. Bit Name Description/Usage Register 7 : Auto-Negotiation Next Page Transmit Register 15 Next Page Next Page Transmit Code Word Bit 15 14 Reserved Reserved Transmit Code Word Bit 14 13 Message Page Message Page Transmit Code Word Bit 13 12 Acknowledge 2 Acknowledge 2 Transmit Code Word Bit 12 11 Toggle Toggle Transmit Code Word Bit 11 [10:0] Message/Unformatt Message/Unformatted Field ed Field Transmit Code Word Bit 10:0 24/66 Copyright © 2011, IC Plus Corp. Default value (h): 2001 0, RW 0, RW 1, RW 0, RW 0, RW 1, RW May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Register 8 defines more auto-negotiation registers to meet the requirement. Bit Name Default value (h): 0000 Description/Usage Register 8 : Auto-Negotiation Link Partner Next Page Register 15 Next Page Next Page 0, RO Received Code Word Bit 15 14 Reserved Acknowledge 0, RO Received Code Word Bit 14 13 Message Page Message Page 0, RO Received Code Word Bit 13 12 Acknowledge 2 Acknowledge 2 0, RO Received Code Word Bit 12 11 Toggle Toggle 0, RO Received Code Word Bit 11 [10:0] Message/Unformatt Message/Unformatted Field 0, RO ed Field Received Code Word Bit 10:0 The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. MII page16 register16 page MII ROM R/W Description Default UTP PHY Specific Control Register 16 16[15:14] RO Reserved 2’b00 16[13] R/W RMII_V10 This bit combines with RMII_V12 bit for RMII mode settings. 0 16[12] R/W RMII_V12 0 RMII_V10 RMII_V12 REPEATER _MODE (P16R16[2]) 0 X 16[11] 0 1 Mode X 1 RMII back to back mode RMII v1.2 CRS_DV will toggle at the end 1 0 1 RMII v1.0 CRS_DV will not toggle at the end Note 1: “X” indicate don’t care (either 1 or 0). Note 2: When RMII_v10 or RMII_v12 is selected, page16 reg16 bit2 should be also set to 1 to enable repeater mode. Then CRS_DV will be asserted only when receive medium is nonidle. R/W AUTO_MDIX_DIS Set high to disable the automatic switch of MDI and MDI-X modes. For details, please refer to section 4 Auto-MDIX function description. 0 16[10] R/W Reserved 0 16[9] R/W JABBER_ENABLE Jabber function enable at 10Base-T 0 25/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page16 register16 page MII 16[8] ROM R/W Description R/W FEF_DISABLE To enable or disable the functionality of Far-End Fault Mode Enable Disable 100Base-TX 1 0 16[7] 16[6] 16[5] 16[4:3] Default 0 R/W NWAY_PSAVE_DIS Set high to disable the power saving during auto-negotiation RO Reserved 0 R/W BYPASS_DSP_RESET Set high to bypass the reset DSP mechanism in PCS sub-layer 0 RO Reserved 0 2’b00 16[2] R/W REPEATER_MODE Set high to put IP101G into repeater mode 16[1] R/W Reserved 0 1 16[0] R/W ANALOG_OFF Set high to power down analog transceiver The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 0 MII page16 register17 page MII ROM R/W Description Default Interrupt Status Register 16 17[15] R/W INTR pin used Interrupt pin used. Set high to enable INTR or INTR_32 as an interrupt pin. Pin INTR or INTR_32 will be high impedance if this bit is set low. 17[14:12] RO Reserved 0 3’b000 17[11] R/W All Mask When this bit is set high, flags to be raised on bit 6, 2, 1 and 0 will not cause an interrupt. 1 17[10] R/W Speed Mask When this bit is set high, changes in speed mode will not cause an interrupt. R/W Duplex Mask When this bit is set high, changes in duplex mode will not cause an interrupt. R/W Link Mask When this bit is set high, changes in link status will not cause an interrupt. 1 17[9] 17[8] 17[7:4] 17[3] 17[2] RO Reserved RO INTR Status (SC) Flag to indicate interrupt status RO Speed Change (SC) Flag to indicate speed change interrupt 26/66 Copyright © 2011, IC Plus Corp. 1 1 0x0 0 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page16 register17 page MII 17[1] ROM R/W Description RO Duplex Change (SC) Flag to indicate duplex change interrupt Default 0 17[0] RO Link Change (SC) Flag to indicate link status change interrupt The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 0 MII page16 register18 page MII ROM R/W Description Default UTP PHY Interrupt Control/Status Register 16 18[15] RO Reserved 0 18[14] RO Resolved Speed The resolved speed selection after auto negotiation or forced mode, 1: Auto negotiation mode 0: Forced mode 0 18[13] RO Resolved Duplex The resolved duplex selection after auto negotiation or forced mode 1: Auto negotiation mode 0: Forced mode 0 18[12] RO Reserved 0 18[11] RO Resolved Auto negotiation completed To indicate if auto negotiation is finished 1: Auto negotiation is finished 0: Auto negotiation is not finished 0 18[10] RO LINK_UP To indicate the link status is OK or FAIL 1: Link status is OK. 0: Link status is FAIL RO MDI/MDIX To indicate which channel is selected by auto-MDIX. 1: MDIX is selected 0: MDI is selected 0 18[8] RO POLARITY To indicate the polarity of twist pair N/P is reversed 1: The polarity of twist pair N/P is reversed 0: The polarity of twist pair N/P is not reversed 0 18[7] RO JABBER To indicate if jabber packet is received or not, when bit 16: is set high 1: Jabber packet is received 0: Jabber packet is not received 0 RO Reserved 0 18[9] 18[6:4] 27/66 Copyright © 2011, IC Plus Corp. 1 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page16 register18 page MII 18[3:0] ROM R/W Description Default RO AN_ARBIT_STATE 0x8 To monitor the current value of N-WAY arbiter state machine 8: AUTO NEGOTIATION ENABLE 0: TRANSMIT DISABLE 1: ABILITY DETECT 5: ACKNOWLEDGE DETECT 4: COMPLETE ACKNOWLEDGE 12: NEXT PAGE WAIT 3: LINK STATUS CHECK 9: PARALLEL DETECTION FAULT 2: FLP LINK GOOD CHECK 10: FLP LINK GOOD The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. MII page16 register29 page MII ROM R/W Description Default Digital I/O Specific Control Register 16 29[15:13] RO Reserved 29[12:8] 3’b000 R/W PHY_ADDRESS Pin The initial PHY address [4:0] is determined via pin setting in setting Table 4 PHY Address Configuration. User can changes the PHY_ADDRESS by register, determined via register setting in Table 5, If user changes the register of PHY_ADDRESS, the SMI(MDC/MDIO) read/write command should change “PHY address” value at the same time. 29[7] R/W RMII_WITH_ER 1: enable TXER/RXER function in RMII mode. 0: disable TXER/RXER function in RMII mode. 29[6:3] 1 R/W Reserved 29[2] 4’b0000 R/W SEL_INTR32 The multiplex function is for 32pin package at pin21 RXER/INTR_32. 1: INTR function 0: RXER function 0 29[1:0] R/W Reserved The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 2’b10 MII page16 register30 page MII ROM R/W Description PHY MDI/MDIX Control and Specific Status Register 16 30[15:9] RO Reserved 28/66 Copyright © 2011, IC Plus Corp. Default 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page16 register30 page MII 30[8] ROM R/W Description RO LINK_UP To indicate the link status is OK or FAIL 30[7:4] 30[3] Default 0 RO Reserved R/W FORCE_MDIX Set high to force the MDIX channel to be selected. 1: Force the MDIX channel to be selected. 0: MDI channel is selected when auto-MDIX is turned off. When IP101G operates in Force 10Mbps mode or APS mode, this bit is not able to write. 0 0 30[2:0] RO OP_MODE_IND 3’b000 Operation Mode Idicator 000= Link off 001= 10M Half 010= 100M Half 011= Reserved 100= Reserved 101= 10M Full 110= 100M Full 111= Reserved The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. MII page1 register17 page MII ROM R/W Description Default PHY Spec. Control Register 1 17[15:9] R/W Reserved 0 17[8] R/W FORCE_LINK_10 0 17[7] R/W FORCE_LINK_100 0 17[6:0] R/W Reserved The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 29/66 Copyright © 2011, IC Plus Corp. 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 4.3 MMD Control Register MII register 13 page MII ROM R/W Description Default MMD Access Control Register -13[15:14] -R/W Function 00 = address 01 = data, no post increment 10 = data, post increment on reads and writes 11 = data, post increment on writes only -- 13[13:5] -- -- 13[4:0] -- 0 R/W Reserved Write as 0, ignore on read R/W DEVAD Device Address 0 0 MII register 14 page MII ROM R/W Description Default MMD Access Address Data Register -14[15:0] -R/W Address Data If 13.15:14 = 00, MMD DEVAD’s address register. Otherwise, MMD DEVAD’s data register as indicated by the contents of its address register 0 Example 1, Read 0.3.20 (Read Data from MMD register 3.20 of PHY address 0): 1. Write 0.13 = 0x0003 //MMD DEVAD 3 2. Write 0.14 = 0x0014 //MMD Address 20 3. Write 0.13 = 0x4003 //MMD Data command for MMD DEVAD 3 4. Read 0.14 //Read MMD Data from 0.3.20 Example 2, Write 1.7.60 = 0x3210 (Write 0x3210 Data to MMD register 7.60 of PHY address 1): 1. Write 1.13 = 0x0007 //MMD DEVAD 7 2. Write 1.14 = 0x003C //MMD Address 60 3. Write 1.13 = 0x4007 //MMD Data command for MMD DEVAD 7 4. Write 1.14 = 0x3210 //Write MMD Data 0x3210 to 1.7.60 30/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 4.4 MMD Data Register MMD register 3.0 Page MII ROM R/W Description Default PCS Control 1 Register -3.0[15:11] RO Reserved Ignore when read 0 -- 3.0.10 R/W Clock stop enable 1 = IP101G may stop xMII Rx clock during LPI 0 = Clock not stoppable 0 -- 3.0[9:0] RO Reserved Ignore when read 0 MMD register 3.1 page MII ROM R/W PCS Status 1 Register -3.1[15:12] RO Description Reserved Ignore when read Default 0 -- 3.1.11 RO/LH Tx LPI received 1 = Tx PCS has received LPI 0 = LPI not received 0 -- 3.1.10 RO/LH Rx LPI received 1 = Rx PCS has received LPI 0 = LPI not received 0 -- 3.1.9 RO Tx LPI indication 1 = Tx PCS is currently receiving LPI 0 = PCS is not currently receiving LPI 0 -- 3.1.8 RO 0 -- 3.1.7 RO Rx LPI indication 1 = Rx PCS is currently receiving LPI 0 = PCS is not currently receiving LPI Reserved Ignore on read -- 3.1.6 RO Clock stop capable 1 = The MAC may stop the clock during LPI 0 = Clock not stoppable 0 -- 3.1[5:0] RO Reserved Ignore when read 0 0 MMD register 3.20 page MII ROM EEE Capability Register -3.20[15:7] R/W Description RO Reserved Ignore when read 31/66 Copyright © 2011, IC Plus Corp. Default 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MMD register 3.20 page -- MII 3.20.6 ROM R/W Description RO 10GBASE-KR EEE 1 = EEE is supported for 10GBASE-KR 0 = EEE is not supported for 10GBASE-KR RO 10GBASE-KX4 EEE 1 = EEE is supported for 10GBASE-KX4 0 = EEE is not supported for 10GBASE-KX4 RO 1000BASE-KX EEE 1 = EEE is supported for 1000BASE-KX 0 = EEE is not supported for 1000BASE-KX Default 0 -- 3.20.5 -- 3.20.4 -- 3.20.3 RO 10GBASE-T EEE 1 = EEE is supported for 10GBASE-T 0 = EEE is not supported for 10GBASE-T 0 -- 3.20.2 RO 1000BASE-T EEE 1 = EEE is supported for 1000BASE-T 0 = EEE is not supported for 1000BASE-T 0 -- 3.20.1 RO 100BASE-TX EEE 1 = EEE is supported for 100BASE-TX 0 = EEE is not supported for 100BASE-TX 1 -- 3.20.0 RO Reserved Ignore when read 0 0 0 MMD register 3.22 page MII ROM R/W Description Default EEE Wake Error Count Register -3.22[15:0] RO EEE wake error count 0x0000 (SC) Count wake time faults where IP101G fails to complete its normal wake sequence within the time required for the specific PHY type. MMD register 7.60 page MII ROM R/W Description Default EEE Advertisement Register -7.60[15:7] RO Reserved Ignore when read -7.60.6 RO 10GBASE-KR EEE 1 = Advertise that the 10GBASE-KR has EEE capability 0 = Do not advertise that the 10GBASE-KR has EEE capability 0 0 -- 7.60.5 RO 10GBASE-KX4 EEE 1 = Advertise that the 10GBASE-KX4 has EEE capability 0 = Do not advertise that the 10GBASE-KX4 has EEE capability 0 -- 7.60.4 RO 1000BASE-KX EEE 1 = Advertise that the 1000BASE-KX has EEE capability 0 = Do not advertise that the 1000BASE-KX has EEE capability 0 32/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MMD register 7.60 page -- MII 7.60.3 -- 7.60.2 -- 7.60.1 -- 7.60.0 ROM R/W Description RO 10GBASE-T EEE 1 = Advertise that the 10GBASE-T has EEE capability 0 = Do not advertise that the 10GBASE-T has EEE capability RO 1000BASE-T EEE 1 = Advertise that the 1000BASE-T has EEE capability 0 = Do not advertise that the 1000BASE-T has EEE capability R/W 100BASE-TX EEE 1 = Advertise that the 100BASE-TX has EEE capability 0 = Do not advertise that the 100BASE-TX has EEE capability RO Reserved Ignore when read Default 0 0 1 0 MMD register 7.61 page MII ROM R/W Description Default EEE Link Partner Ability Register -7.61[15:7] RO Reserved Ignore when read -7.61.6 RO 10GBASE-KR EEE 1 = Link partner is advertising EEE capability for 10GBASE-KR 0 = Link partner is not advertising EEE capability for 10GBASE-KR 0 -- 7.61.5 RO 10GBASE-KX4 EEE 1 = Link partner is advertising EEE capability for 10GBASE-KX4 0 = Link partner is not advertising EEE capability for 10GBASE-KX4 0 -- 7.61.4 RO 1000BASE-KX EEE 1 = Link partner is advertising EEE capability for 1000BASE-KX 0 = Link partner is not advertising EEE capability for 1000BASE-KX 0 -- 7.61.3 0 -- 7.61.2 RO 10GBASE-T EEE 1 = Link partner is advertising EEE capability for 10GBASE-T 0 = Link partner is not advertising EEE capability for 10GBASE-T RO 1000BASE-T EEE 1 = Link partner is advertising EEE capability for 1000BASE-T 0 = Link partner is not advertising EEE capability for 1000BASE-T -- 7.61.1 RO 100BASE-TX EEE 1 = Link partner is advertising EEE capability for 100BASE-TX 0 = Link partner is not advertising EEE capability for 100BASE-TX 0 -- 7.61.0 RO Reserved Ignore when read The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 0 33/66 Copyright © 2011, IC Plus Corp. 0 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 4.5 RX Counter Register MII page1 register17 page MII ROM R/W Description Default RX Counter Control Register 1 17[13] R/W RX Counter Enable 0= RX Counter Disable 1= RX Counter Enable for CRC_ERR_CNT(P1R18[15:0]), PKT_STS_CNT(P2R18[15:0]) and SYMB_ERR_CNT(P11R18[15:0]). The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 0 MII page1 register18 page MII ROM R/W RX CRC Error Counter Register 1 18[15:0] RO CRC_ERR_CNT RX CRC error counter Description Default 0x0000 MII page2 register18 page MII ROM R/W Description Default RX Packet Counter Register 2 18[15:0] RO PKT_STS_CNT 0x0000 RX packet status counter (include CRC good and error packet) MII page8 register17 page MII ROM R/W Description RX Counter Control Register 8 17[15] R/W RXERR_CNT_RDCLR_EN Set 1 to clear RX error counter after reading 17[14] R/W RXERR_CNT_REPEAT This bit is set to 0 when RXERR_INTR_EN = 1 17[13:12] 17[11:0] Default 0 1 R/W RXERR_CNTDOWN_SEL Select the RX error countdown value 2’b00: 1 2’b01: 255 2’b10: 1023 2’b11: 65535 2’b11 RO Reserved 0x000 MII page11 register18 page MII ROM R/W Description Default UTP PHY Interrupt Control/Status Register 34/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page11 register18 page 11 MII ROM R/W Description Default 18[15:0] RO SYMB_ERR_CNT 0x0000 RX symbol error counter Each symbol error of idle will add the counter by 1. Several symbol errors of one data frame will add the counter by 1. MII page18 register17 page MII ROM R/W Description Default RX Counter Interrupt Control/Status Register 18 17[15] R/W RXERR_INTR_EN Set 1 to enable RXERR interrupt function 17[14] R/W RXERR_INTR_SEL Select RXERR interrupt type 0= RX CRC error 1= RX Symbol error 17[13:1] 0 0 RO Reserved 0x000 17[0] RO/ INTR_RXERR_CNTDOWN LH Flag to indicate RX error countdown interrupt The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 0 4.6 LED Pin Control Register MII page16 Register28 page MII ROM R/W Description Default LED Pin Driving Control Register 16 28[11:9] R/W LED_DRIVE 3’b000 LED PAD Driving Current 3’b000: 1.62mA 3’b001: 3.24mA 3’b010: 4.86mA 3’b011: 6.48mA 3’b100: 8.10mA 3’b101: 12.96mA 3’b110: 17.82mA 3’b111: 22.68mA Note: Simulation IC bias to the fixed 0.4V. The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 4.7 WOL+ Control Register MII page4 register16 page MII ROM R/W Description Default PHY WOL+ Control Register 35/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page4 register16 page 4 MII ROM R/W Description Default 16[15] R/W WOL_PLUS_EN WOL+ enable function. Set high to enable WOL+ function. 1=Enable 0=Disable 0 16[14] R/W WOL_PLUS_MASTER WOL+ master mode setting. This bit is used to select WOL+ either master mode or slave mode. 1=WOL+ Master mode 0=WOL+ Slave mode 1 16[13] R/W INTR_ACT_HIGH Interrupt active high. This bit is used to select the active level either high or low of interrupt pin. 1=Pin "INTR" is set to output type and active high. 0=Pin "INTR" is set to open drain type and active low. 0 16[12] R/W Reserved 1 16[11] R/W SENSE_MAGIC_PKT Sense Magic Packet. Set high to enable WOL+ interrupt when magic packet is receiving. 1=Enable 0=Disable 1 16[10] R/W SENSE_ANY_PKT Sense Any Packet. Set high to enable WOL+ interrupt when any good CRC packet is receiving. 1=Enable 0=Disable 1 16[9] R/W SENSE_DUT Sense DUT. Set high to enable wake up event detection (magic packet, any packet) of corresponding port. 1=Enable 0=Disable 1 16[8] R/W WOL_PLUS_DNSPD_EN WOL+ Down Speed Enable. Set high to enable WOL+ down speed function 1=Enable 0=Disable 1 16[7:6] R/W WOL_PLUS_TIMER_SEL WOL+ Timer Select, 2’b00 = 30 seconds. 2’b01 = 3 minutes. 2’b10 = Reserved for internal test used. 2’b11 = 10 minutes. 36/66 Copyright © 2011, IC Plus Corp. 2’b01 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page4 register16 page MII ROM R/W Description R/W WOL_PLUS_MANUAL_SET WOL+ Manual Set. (SC) CPU/MAC can set high to sleep mode or wake up in slave mode. 1=Manual set sleep/wake in WOL+ slave mode. 0=Disable. 16[5] 16[4:0] RO Reserved Default 0 0x00 MII page5 register16 page MII ROM R/W Description Default PHY WOL+ MAC Address Register 5 16[15:0] R/W WOL_PLUS_MAC_ADDR 0x0000 WOL+ MAC address table. Continuously write/read this register 3 times to set/obtain WOL+ Magic packet MAC address. The sequence of MAC address is [31~16], [47~32] then [15~0]. MII page17 register17 page MII ROM R/W Description Default PHY WOL+ Status Register 17 17[15] R/W WOL_PLUS_INTR_PIN_DIS WOL+ interrupt pin disable. Interrupt pin INTR is served to WOL+ event only, when this bit set to 0 and not only enable WOL_PLUS_EN (Page4 Reg16[15]=1) but also INTR pin used (Page16 Reg17[15]=1). INTR pin WOL_PL WOL_PLUS_ INTR pin function used US_EN INT_PIN_DI (P16R17 (P4R16[ S [15]) 15]) (P17R17[15]) 0 X X Disable 1 0 0 Not including WOL+ interrupt status 1 X 1 1 1 0 Only for WOL+ interrupt status 17 17[14:4] RO 17 17[3] RO 17 17[2] RO Reserved 0x000 WOL_PLUS_INTR_STATUS WOL+ interrupt status. (SC) 1=Interrupt event. 0=Normal (no any interrupt event). WOL_PLUS_SLEEPING WOL+ sleeping status. This bit is a real-time status in WOL+ sleep mode. 1=IP101G is in WOL+ sleeping mode. 37/66 Copyright © 2011, IC Plus Corp. 0 0 0 May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page17 register17 page 17 MII ROM R/W 17[1] RO/ LH 17 Description Default WOL_PLUS_SLEEP WOL+ sleep status. This bit is a latched high signal that provide a previous status for WOL+ sleep mode. Master mode: 1=IP101G has entered WOL+ sleep mode. Slave mode: 1=IP101G is ready for entering WOL+ sleep mode. WOL_PLUS_WAKE WOL+ wake status. LH This bit is a latched high signal that provide a previous status for WOL+ wake up. Master mode: 1=IP101G has left WOL+ sleep mode. Slave mode: 1=IP101G is ready for wake up. The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 17[0] RO/ 0 0 Example 1, Read page3 register16 (Read Data from page3 register16 of PHY address 0): 1. Write 0.20 = 0x0003 //page3 2. Read 0.16 //Read Data from page3 register16 3. Write 0.20 = 0x0000 //restore to page0 Example 2, Write page3 register16 = 0x3400 (Write Data 0x3400 to page3 register16 of PHY address 0): 1. Write 0.20 = 0x0003 //page3 2. Write 0.16 = 0x3400 //Write Data 0x3400 to page3 register16 3. Write 0.20 = 0x0000 //restore to page0 4.8 UTP PHY Specific Control Register MII page1 register22 page MII ROM R/W Description Linear Regulator Output Control Register 1 22[15] R/W LDO Output Disable 1: LDO Output Disable 0: LDO Output Enable Default 0 (e-fuse) 22[14:0] R/W Reserved 0x2020 The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. MII page1 register23 page MII ROM R/W Description UTP PHY Specific Control Register 1 23[15:14] R/W Reserved 2’b10 38/66 Copyright © 2011, IC Plus Corp. Default May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page1 register23 page MII 23[13] ROM R/W Description Default R/W RX2TX_LPBK 0 1= Rx to Tx loopback mode for debugging 0= Normal mode (INTR pin of IP101G/IP101GA should pull 5.1K resistor to DVDD33_IO for normal mode operation. We can connect INTR pin to GND for Rx to Tx loopback test.) 23[12] R/W Reserved 0 23[11] R/W FIX_TXD_EN 1= Fix TXD pattern 0= Normal mode 0 23[10] R/W FIX_TXD_SEL 1= Long pulse 0= Short pulse 23[9] R/W FORCE_TX_LPI 1= Force TX LPI 0= TX respond to MII 23[8:0] R/W Reserved The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 0 0 0 4.9 Digital IO Pin Control Register MII page4 Register22 page MII ROM R/W Description Digital IO Pin Driving Control Register 4 22[15:13] R/W RXC_DRIVE RXC PAD Driving Current 3’b000: 1.62mA 3’b001: 3.24mA 3’b010: 4.86mA 3’b011: 6.48mA 3’b100: 8.10mA 3’b101: 12.96mA 3’b110: 17.82mA 3’b111: 22.68mA Default 3’b010 (e-fuse) 22[12:11] RO Reserved 2’b00 22[10:0] R/W Reserved 0x000 The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. MII page16 Register26~27 page MII ROM R/W Description Digital IO Pin Driving Control Register 16 26[15] RO Reserved 0 39/66 Copyright © 2011, IC Plus Corp. Default May 20, 2014 IP101G-DS-R01 IP101G Data Sheet MII page16 Register26~27 page MII ROM R/W Description 26[14:12] R/W RXDV_DRIVE RXDV PAD Driving Current is defined as same as RXC. Default 3’b001 26[11:9] R/W RXD3_DRIVE RXD3 PAD Driving Current is defined as same as RXC. 3’b001 26[8:6] R/W RXD2_DRIVE RXD2 PAD Driving Current is defined as same as RXC. 3’b001 26[5:3] R/W RXD1_DRIVE RXD1 PAD Driving Current is defined as same as RXC. 3’b001 26[2:0] R/W RXD0_DRIVE RXD0 PAD Driving Current is defined as same as RXC. 3’b001 27[15] 27[14:12] RO Reserved R/W MDIO_DRIVE MDIO PAD Driving Current is defined as same as RXC. 0 3’b000 27[11:9] R/W COL_DRIVE COL PAD Driving Current is defined as same as RXC. 3’b000 27[8:6] R/W CRS_DRIVE CRS PAD Driving Current is defined as same as RXC. 3’b000 27[5:3] R/W Reserved 3’b010 27[2:0] R/W TXC_DRIVE 3’b010 TXC PAD Driving Current is defined as same as RXC. The other Registers are reserved registers. User is inhibited to access to these registers. It may introduce abnormal function to write these registers. 40/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 5 Function Description IP101G 10/100Mbps Ethernet PHY Transceiver integrates 100 Base-TX and 10 Base-T modules into a single chip. IP101G acts as an interface between physical signaling and Media Access Controller (MAC). IP101G has several major functions: 1. PCS layer (Physical Coding Sub-Layer): This function contains transmit, receive and carrier sense functional circuitries. 2. Management interface: Media Independent Interface (MII) or Reduced Management Interface (RMII) registers contains information for communication with other MAC. 3. Auto-Negotiation: Communication conditions between 2 PHY transceivers. IP101G advertise its own ability and also detects corresponding operational mode from the other party, eventually both sides will come to an agreement for their optimized transmission mode. 5.1 Major Functional Block Description The functional blocks diagram is referred to Figure 1: a. 4B/5B encoder: 100 Base-X transmissions require converting 4-bit nibble data into 5-bit wide data code-word format. Transmitting data is packaged by J/K codes at the start of packet and by T/R codes at the end of packet in the 4B/5B block. When transmit error has occurred during a transmitting process, the H error code will be sent. The idle code is sent between two packets. b. 4B/5B Decoder: The decoder performs the 5B/4B decoding from the received code-groups. The 5 bits (5B) data is decoded into four bits nibble data. The decoded 4 bit (4B) data is then forwarded through MII to the repeater, switch or MAC device. The SSD is then converted into 4B 5 nibbles and the ESD and IDLE Codes are replaced by 4B 0 nibbles data. The decoded data is driven onto the corresponding MII port or shared MII port. Receiving an invalid code group will cause PHY to assert the MII RXER signal. c. Scrambler/Descrambler: Repetitive patterns exist in 4B/5B encoded data which result in large RF spectrum peaks and keep the system from being approved by regulatory agencies. The peak in the radiated signal is reduced significantly by scrambling the transmitted signal. Scrambler adds a random generator to the data signal output. The resulting signal is with fewer repetitive data patterns. The scrambled data stream is descrambled at the receiver by adding another random generator to the output. The receiver’s random generator has the same function as the transmitter’s random generator. Scrambler operation is dictated by the 100Base-TX and TP_FDDI standards. d. NRZI/MLT-3(Manchester) Encoder and Decoder: 100Base-TX Transmission requires encoding the data into NRZ format and again converted into MLT-3 signal, while 10 Base-T will convert into Manchester form after NRZ coding. This helps to remove the high frequency noise generated by the twisted pair cables. At receiving end, the coding is reversed from MLT-3 (Manchester) signal back to NRZ format. e. Clock Recovery: The receiver circuit recovers data from the input stream by regenerating clocking information embedded in the serial stream. The clock recovery block extracts the RXCLK from the transition of received f. DSP Engine: This block includes Adaptive equalizer and Base Line Wander correction function. 5.1.1 Transmission Description 10Mbps Transmit flow path: TXD J Parallel to Serial J NRZI/Manchester Encoder J D/A & line driver J TXO 41/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet After MAC passes data to PHY via 4 bits nibbles, the data are serialized in the parallel to serial converter. The converter outputs NRZI coded data which the data are then mapped to Manchester code within the Manchester Encoder. Before transmitting to the physical medium, the Manchester coded data are shaped by D/A converter to fit the physical medium. 10Mbps Receive: RXI J Squelch J Clock Recovery J Manchester/NRZ Decoder J Serial to Parallel J RXD The squelch block determines valid data from both AC timing and DC amplitude measurement. When a valid data is present in the medium, squelch block will generate a signal to indicate the data has received. The data receive are coded in Manchester form, and are decoded in the Manchester to NRZ Decoder. Then the data are mapped to 4 bits nibbles and transmitted onto MAC interface. 100Mbps TX Transmit: TXD J 4B/5B Encoder J Scrambler J Mux J Parallel to Serial J NRZI/MLT-3 Encoder J D/A & line driver J TXO The major differences between 10Mbps transmission and 100Mbps transmission are that 100Mbps transmission requires to be coded from 4-bit wide nibbles to 5 bits wide data coding, and after that the data are scrambled through scrambler to reduce the radiated energy generated by the 4B/5B conversion. Then the data is converted into NRZI form and again from NRZI coded form into MLT-3 form. The MLT-3 data form is fed into D/A converter and shaped to fit the physical medium transmission. 100Mbps RX Receive: RXI J DSP J MLT-3/NRZI Decoder J Clock Recovery J Serial to Parallel J Descrambler J 4B/5B Decoder J RXD The received data first go through DSP engines which includes adaptive equalizer and base-line wander correction mechanism. The adaptive equalizer will compensate the loss of signals during the transmission, while base-line wander monitors and corrects the equalization process. If a valid data is detected then the data are parallelized in Serial to Parallel block, which it converts NRZI coded data form back to scrambled data. The scrambled data are descrambled and converted back to 4 bits–wide format data and then feed into MAC. 5.1.2 MII and Management Control Interface Media Independent Interface (MII) is described in clause 22 in the IEEE 802.3u standard. The main function of this interface is to provide a communication path between PHY and MAC/Repeater. It can operate either in 10Mbps or 100Mbps environment, and operate at 2.5MHz frequency for 10Mbps clock data rate or 25MHz frequency for 100Mbps data rate transmission. MII consists of 4 bit wide data path for both transmit and receive. The transmission pins consists of TXD[3:0], TX_EN and TXC, and at receiving MII pins have RXD[3:0], RXER, RX_DV and RXC. The Management control pins include MDC and MDIO. MDC, Management Data Clock, provides management data clock period can be to 300ns as a reference for MDIO, Management Data Input/Output. CRS, Carrier Sense, is used for signaling data transmission is in process while COL, Collision, is used for signaling the occurrence of collision during transmission. Transmitting a packet, MAC will first assert TX_EN and convert the information into 4 bits wide data and then pass the data to IP101G. IP101G will sample the data according to TX_CLK until TX_EN is low. While receiving a packet, IP101G asserts RX_DV high when data present in the medium through RXD[3:0] bus lines. IP101G samples received data according to RX_CLK until the medium is back to idle state. The MDI transmitter of IP101G can enter low power idle (LPI) state via TX_ER, TXD[3:0] and TX_EN as the following behavior. 42/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Figure 5 LPI transition Figure 6 IP101G/GA/GR/GRI MII Mode with LPI transition Block Diagram Figure 7 IP101G/GA/GR/GRI MII Mode without LPI transition Block Diagram 5.1.3 RMII Interface 43/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Reduced Media Independent Interface (RMII) is defined to provide a fewer pins data transmission condition. The management interface, MDC and MDIO, are identical to the MII defined in IEEE 802.3. RMII supports 10/100Mb data rates and the clock source are provided by a single 50MHz clock from either external or within IP101G. This clock is used as reference for transmit, receive and control. RMII provides independent 2 bit wide transmit and receive data path, i.e., TXD[1:0] and RXD[1:0]. CRS_DV is asserted when the receive medium is not idle and de-asserted when the medium is idle. Before any transmission occurs, CRS_DV should be de-asserted and value “00” should be present in both TXD[1:0] and RXD[1:0]. When transmission begins, IP101G will send “01” (TXD[1:0] = 01) for preamble to indicate SFD, and also assert TX_EN synchronous with first nibble of the preamble. TX_EN should be de-asserted until the end of the data transmission. At receiving mechanism, by receiving “01” means a valid data is available. If the False carrier is detected, RXD[1:0] shall be “10” until the end of the transmission. The MDI transmitter of IP101G can not enter low power idle (LPI) state, but can receive the LPI signal from MDI path. At 10Mbps mode, every 10th cycle of REF_CLK will be sampled in RXD[1:0] and TXD[1:0], because the REF_CLK frequency is 10 times faster than the data rate of the 10Mbps. Figure 8 IP101G RMII Mode with internal clock Block Diagram Figure 9 IP101G RMII Mode with external clock Block Diagram 44/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 5.1.4 Flexible Clock Source While set COL/RMII pin to logic 1, 50MHz reference clock will be provided by IP101G in RMII mode. For this configuration, RMII reference clock output for IP101G is from RXCLK/50M_CLKO. Clock skew could be eliminated by adding an external buffer and placing equal trace lengths between buffer outputs and each chip. The flexible clock source is list as the following table. Table 3 Flexible Clock Source Setting Pin name COL/RMII Mode 1 RMII 0 MII Clock Source Function Crystal 25MHz Provides a crystal 25MHz into pin X1 and X2. Clock 25MHz Provides a clock source 25MHz into pin X1. Clock 50MHz Provides a clock source 50MHz into pin TXCLK/50M_CLKI and connect pin X1 to GND or AGND33. Crystal 25MHz Provides a crystal 25MHz into pin X1 and X2. Clock 25MHz Provides a clock source 25MHz into pin X1. Figure 10 IP101GR need add a buffer if RXCLK/50M_CLK push over two device 5.1.5 Auto-Negotiation and Related Information IP101G supports clause 28 in the IEEE 802.3u standard. IP101G can be operated either in 10Mbps/100Mbps or half/full duplex transmission mode. IP101G also supports flow control mechanism to prevent any collision in the network. If the other end does not support Auto-Negotiation function, IP101G will link at half duplex mode and enter parallel detection. At beginning of auto-negotiation, IP101G will advertise its own ability by sending FLP waveform out to the other end and also listening signals from the other end. IP101G will place itself into correct connection speed depends on the received signals. If NLP signal is replied from the other end, IP101G will enter 10Mbps, while active idle pulses (unique 100Mbps pattern) IP101G will go to 100Mbps mode instead. 45/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Once the negotiation has completed with the other party, IP101G will configure itself to the desired connection mode, i.e., 10/100Mbps or Half/Full duplex modes. If there is no detection of link pulses within 1200~1500ms, IP101G will enter Link Fail State and restart auto-negotiation procedure. The auto-negotiation information is stored in the IP101G’s MII registers. These registers can be modified and monitor the IP101G’s Auto-Negotiation status. The reset auto-negotiation in register 0 of MII registers can be set at any time to restart auto-negotiation. The flow control ability is also included in the IP101G chip. If MAC supports flow control condition, then flow control will be enabled by setting bit 10 (Pause) of the Register 4. We can determine the link speed and EEE ability from IP101G’s MII registers. There is an example as following figure. Figure 11 IP101G link speed and EEE ability programming guide 5.1.6 Auto-MDIX function IP101G will keep sensing incoming signal in MDI RX pair, if no incoming signal is detected, IP101G will switch TX and RX pairs automatically trying to establish connection. IP101G supports this function both in Auto-Negotiation mode and force mode. 5.2 PHY Address Configuration IP101GR/IP101GRI PHY Address can be configured to 5’d0, 5’d1 or response any one PHY address from 5’d2 to 5’d31. IP101G/IP101GA PHY Address can be configured to 5’d0, 5’d1,…, 5’d7 or response any one PHY address from 5’d8 to 5’d31. This PHY Address configuration is the following table. 46/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Table 4 PHY Address Configuration Package Pin name LED3/PHY_AD3 LED2/PHY_AD2 LED1/PHY_AD1 LED0/PHY_AD0 0 X 1 0 X X X X X X X 1 32 pin 48 pin X X X 0 0 0 0 1 1 1 1 0 X X X 0 0 1 1 0 0 1 1 0 0 1 0 0 1 0 1 0 1 0 1 0 PHY Address setting 5’d0 5’d1 5’d2 ~ 5’d31 5’d0 5’d1 5’d2 5’d3 5’d4 5’d5 5’d6 5’d7 5’d8 ~ 5’d31 Note: “X” indicate don’t care (either 1 or 0). Do not let these PHY address pins floating for the latched-in settings after the power is ready. LED pins also include the information of PHY address. The PHY address can be modified by changing the LED circuitry. The modification can be arranged as follows. Figure 12 PHY Address Configuration The left diagram will enable the specific PHY address to 1, if it is connected to VDD33. The diagram on the right shows the configuration for setting PHY address to 0, when the circuit is connected to ground. By setting either one of the bits according to the diagram will allow one to modify PHY addresses from PHY_AD0 to PHY_AD3. Table 5 PHY Address Configuration by register Package 32 pin and 48 pin Page16 Reg29.12 Reg29.11 Reg29.10 Reg29.9 Reg29.8 PHY Address setting 0 0 0 0 ~ 1 0 0 0 0 ~ 1 0 0 0 0 ~ 1 0 0 1 1 ~ 1 0 1 0 1 ~ 1 5’d0 5’d1 5’d2 5’d3 ~ 5’d31 Note: If system initial have two device at the same PHY address will be conflicting, User can use Register setting IP101G to another PHY address, but two device both will be setting, so must to write 47/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet another device P16Reg29 to default setting, and IP101G read/write command should change “PHY address” value at the same time. 5.3 Power Management Tool IP101G provides rich power management tool to save the power consumption. They are z APS, auto power saving while Link-off z 802.3az, protocol based power saving z PWD, force power down z WOL+, light traffic power saving 5.3.1 Auto Power Saving Mode APS mode while link is down, MDC and MDIO are kept activated. IP101G will send NLP every 256ms or (256*N)ms during APS sleeping mode, and the symbol N is an integer such as 2,3,4… random seed for power saving. 48/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 5.3.2 IEEE802.3az EEE (Energy Efficient Ethernet) In order to enter this mode, the PHY part should declare the EEE capability during the auto-negotiation phase, and then send a LLDP to the link partner to indicate the wakeup time. If both ends of the cable support EEE, IP101G can enter Low Power Idle mode per the request from the higher layer (such as the command from CPU or MAC layer). There are 2 methods to activate Low Power Idle Mode: the MII/RMII bus coming from MAC layer and the MII register control coming from MDC/MDIO serial bus. For legacy Ethernet MAC, the MII/RMII does not provide any command regarding EEE. When used in conjunction with these MACs, IP101G provides a MII register that allows the designer to activate the Low Power Idle mode. It’s the higher layer’s responsibility to memorize the link partner’s wakeup time and wakeup the link partner before sending data. The higher layer means a mechanism that can evaluate the packet buffer utilization and wake the link partner before sending the data. In general speaking, this mechanism probably consists of at least one of the following items: the packet buffer manager, the application program and OS. The EEE module works well at LPI (Low Power Idle) mode when 1. Link at full-duplex and 2. Auto-negotiation is enabled in both local and remote PHYs and 3. 100Mbps and 4. EEE ability is supported in both local & remote PHYs and 5. EEE_EN (MMD register 7.60[1]) is enabled for EEE function via default value. In general applications, the energy-saving mechanism is activated by the real-time OS or the higher layer hardware. When the OS or higher layer hardware knows that it’s the time to force the unused function to enter standby mode or sleeping mode, it can force the MAC to send IEEE 802.3az compliant command to set IP101G to “low power idle” mode. Once entering the “low power idle” mode, IP101G will stay at a low power consumption level without losing the link capability. After awaken, it can generate a INTR signal, hardware pin from IP101G, to notify the CPU or external circuitry. IP101G supports not only EEE ability at 100Mbps but also smaller transmit amplitude requirement at 10Mbps. That complies with 10Base-T PHY interoperability over 100 meters of Category 5 or better cable types. 5.3.3 Force power down IP101G can be power-down by 2 methods. These 2 methods are as follows. Power Down in bit 11 of Register 0: Enable this bit will disconnect the power to IP101G and also internal clock, but MDC and MDIO are still activated. Analog off in bit 0 of Register 16: Enable this bit will put IP101G in analog off state. This will power down all analog functions but internal 25MHz operating clock is active, and MDC and MDIO are also activated. 5.3.4 WOL+ operation mode The huge amount of legacy Ethernet devices will make an Ethernet device which supports 802.3az lost his energy saving capability, because they can not talk to each other for settling down the idle schedule. IP101G to be a full-range-green Ethernet PHY, not only consumes very low power and with 802.3az capability, but also supports a WOL+ function for solving this issue. IP101G supports WOL+ either master mode or slave mode. In master mode, the WOL+ function will be active if all ports are in idle state has been continuously held for a period time. This period time can be configured by WOL+ timer register (Page4 Reg16[7:6]). 49/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet In slave mode, a WOL+ interrupt will take place if no any frame for a period time and the WOL+ function only be asserted by CPU through SMI interface to write WOL+ control register (Page4 Reg16[5]). Table 6 WOL+ operation mode Register Page17 Sleeping Sleep Wake (Reg17.2) (Reg17.1) (Reg17.0) 0 0 0 0 x 1 0 1 0 1 1 x 0 0 1 1 1 1 Description IP101G is in normal mode. IP101G has been changed to normal mode. IP101G is in normal mode and it’s ready for sleeping in WOL+ slave mode. CPU may set Page4 Reg16[5] as 1 to force sleep. IP101G is in WOL+ sleep mode. IP101G is in WOL+ sleep mode and it’s ready for wake up in WOL+ slave mode. CPU may set Page4 Reg16[5] as 1 to force wake up. IP101G is in WOL+ sleep mode. Once IP101G enters to power-saving mode (speed down to 10Mbps when sleep), it shall wake up if a) Disable WOL+ function (Page4 Reg16.15); b) Sense magic packet; c) Sense link change; d) Sense any packet; The packet format of Magic packet is showing as follows, source address=0x112233445566 for example, repeat this source address 16 times at least. Received Packet 0xFFFFFFFFFFFF 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 0x112233445566 Figure 13 Magic Packet Format 50/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IP101G can sleep or wake up automatically in WOL+ master mode. There is an example as the following figure. Setting to wake up by any packets or the link status changed, and use an active-high INTR (interrupt) to notify the MAC when sense any WOL+ events. Power on Enable INTR pin (Write)P16R17[15]=1 Disable Mask (Write)P16R17[11:8]=4'b0000 SEL_INTR32 (Write)P16R29[2]=1 Select Master mode & Active High INTR (Write)P4R16[14:13]=2'b11 Wake up by receiving any packets (Write)P4R16[11:10]=2'b01 Stay the idle state how long to be treat as a WOL+ event (Write)P4R16[7:6]=2'b11 WOL+ Enable (Write)P4R16[15]=1 1 Normal mode 2 No INTR goes high Yes WOL+ status (Read)P17R17[2:0] Case: 0X0 Case: 1XX 1 Sleep Wake up 2 Wait 5sec for PHY linkup Case: 0X1 1 Figure 14 Sleep or wake up automatically programming guide 51/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IP101G can sleep or wake up by MAC manual set in WOL+ slave mode. There is an example as the following figure. Setting to wake up by magic packets or the link status changed, and use an active-low INTR (interrupt) to notify the MAC when sense any WOL+ events. Power on Enable INTR pin (Write)P16R17[15]=1 Disable Mask (Write)P16R17[11:8]=4'b0000 SEL_INTR32 (Write)P16R29[2]=1 Select Slave mode & Active Low INTR (Write)P4R16[14:13]=2'b00 Wake up by receiving magic packets (Write)P4R16[11:10]=2'b10 Magic packet MAC_ADDR (Write)P5R16[15:0]=0x1122 (Write)P5R16[15:0]=0x3344 (Write)P5R16[15:0]=0x5566 WOL+ Enable (Write)P4R16[15]=1 1 Normal mode 2 INTR goes low No Yes WOL+ status (Read)P17R17[2:0] Case: others 1 Case: 0X1 Case: 101 Case: 010 (Write) P4R16[5]=1 (Write) P4R16[5]=1 Wake up Sleep Wait 5sec for PHY linkup 2 1 Figure 15 MAC control sleep or wake up programming guide 52/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 5.4 LED Mode Configuration IP101G provides 2 LED operation modes, LED Mode 1 (default): Table 7 LED Mode 1 Function LED LED0 LED1 LED2 LED3 Function Link status: Active indicates the link has established Duplex operation: Active indicates full duplex 10BT/ACT: Active indicates 10Mbps connection has established, and blinking while TX/RX events occur. 100BT/ACT: Active indicates 100Mbps connection has established, and blinking while TX/RX events occur. LED Mode 2 (could be set by pulling up pin CRS/LEDMOD with a 4.7K resistor): Table 8 LED Mode 2 Function LED LED0 LED1 LED2 LED3 Function Link/ACT: Active indicates the link has established, and blinking while TX/RX events occur. Duplex/COL: Active indicates full duplex, and blinking while collision events occur. 10BT: Active indicates 10Mbps connection has established 100BT: Active indicates 100Mbps connection has established 5.5 LED Blink Timing Table 9 LED Blink Timing LED mode Active LED blink Blinking speed On 26ms -> Off 78ms -> On 26ms -> Off 78ms … Collision LED blink On 26ms -> Off 78ms -> On 26ms -> Off 78ms … 5.6 Repeater Mode To enter Repeater mode, one can set 1 to bit 2 of Register 16 will allow IP101G to enter Repeater mode. If IP101G is used in repeater, CRS will be high if IP101G is in a process of receiving packets. While IP101G is used in a network interface card, CRS will be generated in both transmitting and receiving packets. 5.7 Interrupt IP101G provides 4 kinds of interrupt function: speed change, duplex change, link change and arbiter state change. Interrupt masks could be selected by Reg 17, and an active low interrupt will be sent from INTR or INTR_32 pin when event occurs. 5.8 Miscellaneous ISET pin should be connected to GND via a 6.19K ohm resistor with 1% accuracy to ensure a correct driving current for transmit DAC. 53/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Set low to RESET_N pin, for at least 10ms will reset all functions available in IP101G. The bit 15 of Register 0 will put PHY into its default status. 5.9 Serial Management Interface IP101G supports one serial management interface (SMI). User can access IP101G’s MII registers through MDC and MDIO. Its format is shown in the following table. To access MII register in IP101G, MDC should be at least one more cycle than MDIO. That is, a complete command consists of 32 bits MDIO data and at least 33 MDC clocks. When the SMI is idle, MDIO is in high impedance. Table 10 SMI Format Frame format Read Operation Write Operation MDC z z MDIO 1..1 0 1 0 1 0 0 0 0 1 0 0 0 0 0 1 0 0 0 1 1 0 0 1 1 0 0 0 0 0 0 0 0 1..1 idle start op code write A A A A A R R R R R TA b b b b b b b b b b b b b b b b 1 1 1 1 1 1 9 8 7 6 5 4 3 2 1 0 4 3 2 1 0 4 3 2 1 0 PHY address = Reg address = 5 4 3 2 1 0 Register data 01h 00h idle MDC MDIO z z z 1..1 0 1 1 0 0 0 0 0 1 0 0 0 0 0 Z 0 0 0 1 1 0 0 0 1 0 0 0 0 0 0 0 0 1..1 idle start op code read A A A A A R R R R R TA b b b b b b b b b b b b b b b b 1 1 1 1 1 1 9 8 7 6 5 4 3 2 1 0 4 3 2 1 0 4 3 2 1 0 PHY address = Reg address = 5 4 3 2 1 0 Register data 01h 00h idle Figure 16 MDC/MDIO Format 54/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 5.10 Fiber Mode Setting IP101G supports either TP mode or Fiber mode. User should pull high voltage on pin RXDV/CRS_DV/FX_HEN of IP101G when reset signal is completed for Fiber mode operation. Fiber MAU provides high voltage to pin TXER/FXSD of IP101G when Fiber MAU is active to transmit or receive packet frames. Figure 17 IP101G Fiber Mode Setting 5.11 Jumbo Frame IP101G supports jumbo frame size up to 12K Bytes in MII mode. In the other mode RMII, IP101G supports jumbo frame size up to 10K Bytes that is auto-negotiation at 100Mbps full duplex. 55/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 6 Layout Guideline 6.1 General Layout Guideline Best performance depends on a good PCB layout. The following recommendation steps will help customer to gain maximum performance. ‹ ‹ ‹ ‹ ‹ ‹ ‹ ‹ ‹ ‹ ‹ ‹ Create a good power source to minimize noise from switching power source. All components are qualified, especially high noise component, such as clock component. Use bulk capacitors between power plane and ground plane for 4 layers board, signals trace on component and bottom side, power plane on third layer, and ground layer on second layer. Use decoupling capacitors to decouple high frequency noise between chip’s power and ground, must be as close as possible to IP101G. The clock trace length to IP101G must be equal the clock trace length to MAC. Use guard traces to protect clock traces if possible. Avoid signals path parallel to clock signals path, because clock signals will interference with other parallel signals, degrading signal quality, such as MDC and X1 signals. The clock must be low jitter for 25/50/125MHz PLL requirement with less than the 500ps Peak-to-Peak, or 83ps RMS for normal distribution. Avoid highly speed signal across ground gap to prevent large EMI effect. Keep ground region as one continuous and unbroken plane. Place a gap between the system and chassis grounds. No any ground loop exists on the chassis ground. 6.2 Twisted Pair recommendation When routing the MDI_TP/MDI_TN signal traces from IP101G to transformer, the traces should be as short as possible. Center tap of primary winding of these transformers must be connected to decoupling capacitors respectively. It is recommended that MDI_RP/MDI_RN trace pair be route such that the space between it and others is three times space, which can separate individual traces from one another. It is recommended that offers chassis ground in the area between transformer and media connector (RJ-45 port), this isolates the analog signals from external noise sources and reduces EMI effect. Note the usage of the vias, it is best not use via to place anywhere other than in close proximity to device, in order to minimize impedance variations in a given signal trace. 56/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 7 Electrical Characteristics 7.1 Absolute Maximum Rating Stresses exceed those values listed under Absolute Maximum Ratings may cause permanent damage to the device. Functional performance and device reliability are not guaranteed under these conditions. All voltages are specified with respect to GND. Supply Voltage……………………………………..................... Input Voltage…………………………………………………….. . Output Voltage…………………………………………………… Storage Temperature……………………………………………. Ambient Operating Temperature (Ta) for IP101G/GR/GA…… Ambient Operating Temperature (Ta) for IP101GRI………….. IC Junction Temperature (Tj)…………………………………… IEC 61000-4-2 Contact Discharge ESD Reliability……………. IEC 61000-4-2 Air Discharge ESD Reliability………………….. -0.3V to 3.63V -0.3V to 3.63V -0.3V to 3.63V -65°C to 150°C 0°C to 70°C -40°C to 85°C 0°C to 125°C ±12KV ±15KV 7.2 DC Characteristics Table 11 DC Characteristics Symbol REGOUT Specific Name Minimum Linear regulator output 1.07V voltage DVDD_REGIN Digital core supply voltage 1.07V VDDIO I/O pad supply voltage for 3.135V LED, RESETB and MII/RMII 2.375V AVDD33 Analog core supply voltage 3.135V Typical 1.10V Maximum Condition 1.18V 1.10V 3.30V 1.18V 3.465V 2.50V 2.625V 3.30V 3.465V MAC uses 3.3V I/O supply voltage. MAC uses 2.5V I/O supply voltage. Both MAC and IP101G sides use the same I/O supply voltage for MII/RMII. Table 12 I/O Electrical Characteristics Symbol Specific Name Minimum VIH Input High Voltage 0.8*VDDIO VIL Input Low Voltage -0.5V VOH Output High Voltage 0.9* VDDIO VOL Output Low Voltage VIH X1 Input High Voltage 0.8* AVDD33 VIL X1 Input Low Voltage -0.5V VRST RESETB Threshold Voltage 0.4*VDDIO VFRC Fiber Rx common mode Voltage VFRD Fiber Rx differential mode Voltage 0.4V VFXSD Fiber signal detect on when plug 2.0V VFXSD Fiber signal detect on when 1.3V unplug tjitter Fiber Jitter on TXOP, TXOM 57/66 Copyright © 2011, IC Plus Corp. Typical Maximum 3.3V +0.5V 0.2*VDDIO VDDIO 0.1*VDDIO AVDD33 +0.5V 0.2*AVDD33 0.6*VDDIO Condition 1.8V 2.2V 3.3V +0.5V 1.7V 800ps May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Symbol Specific Name Minimum tr / tf Fiber Rise time & Fall time on TXOP, TXOM Typical Maximum 6ns Condition Table 13 Pin Latched-in Configuration Resistor I/O Voltage VDDIO Pull-up/ Pull-down Resistor 5.1KΩ Condition 7.3 Crystal Specifications Table 14 Crystal Specifications Item Parameter Range 1 Nominal Frequency 25.000 MHz 2 Oscillation Mode Fundamental Mode 3 Frequency Tolerance at 25℃ +/- 50 ppm 4 Temperature Characteristics +/- 50 ppm 5 Operating Temperature Range -10℃~ +70℃ or -40℃~ +85℃ 6 7 Equivalent Series Resistance Drive Level 40 ohm Max. 8 Load Capacitance 20 pF, or specify 9 Shunt Capacitance 7 pF Max 10 Insulation Resistance Mega ohm Min./DC 100V 11 Aging Rate A Year +/- 5 ppm/year 100μW typical 58/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 7.4 AC Timing 7.4.1 Reset, Pin Latched-in, Clock and Power Source Table 15 Reset, Pin Latched-in, Clock and Power Source Timing Requirements Symbol Description Tclk_lead Trst Tclk_MII_rdy X1 input clock valid period before reset released 10 Reset period 10 MII/RMII clock output ready after reset released (Pins settings are latched into IP101G this moment.) Time difference between AVDD33 and VDDIO, DVDD_REGIN All power source ready before reset released 11 Latched-in pin signal setup time 10 Latched-in pin signal hold time 2.63 Tdiff Tpwr_lead Tlat_s Tlat_h Min. Typ. Max. Unit - 10 ms ms ms - 30 ms - - ms µs ms Note: In case of special Reset request under Power stable and X1 input clock valid, the Min. Reset period is 1us. Figure 18 Reset, Pin Latched-In, Clock and Power Source Timing Requirements 59/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 7.4.2 MII Timing a. Transmit Timing Requirements Table 16 MII Transmit Timing Requirements Symbol Description Min. Typ. Max. Unit TTclk1 TTclk1 Ts1 Th1 Period of transmit clock output in 100M mode Period of transmit clock output in 10M mode TXEN, TXD to TX_CLK setup time TXEN, TXD to TX_CLK hold time 10 0 40 400 - - ns ns ns ns Figure 19 MII Transmit Timing Requirements b. Receive Timing Table 17 MII Receive Timing Specifications Symbol Description Min. Typ. Max. Unit TRclk1 TRclk1 Td1 1 100Mbps Td1 10Mbps Period of receive clock output in 100M mode Period of receive clock output in 10M mode MII_RXCLK rising edge to RXDV, RXD output delay 20 200 40 400 22 202 26 206 ns ns ns ns Figure 20 MII Receive Timing Specifications 1 Timing was measured for the pin load TXEN and TXD[3:0] of IP101G. The reference 25MHz clock was from output pin RXCLK of IP101G via the default driving current. 60/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 7.4.3 RMII Timing a. Transmit Timing Requirements Table 18 RMII Transmit Timing Requirements Symbol Description Min. Typ. Max. Unit TRMII_CLK_IN Ts Th Period of RMII clock input TXEN, TXD to RMII_CLK_IN setup time TXEN, TXD to RMII_CLK_IN hold time 4 2 20±50ppm - ns ns ns Typ. Unit Figure 21 RMII Transmit Timing Requirements b. Receive Timing Table 19 RMII Receive Timing Specifications Symbol Description TRMII_CLK_IN Td 2 Period of RMII clock input RMII_CLK_IN rising edge to RXDV, RXD output 6 delay when VDDIO is 3.30V. RMII_CLK_IN rising edge to RXDV, RXD output 6 delay when VDDIO is 2.50V. Td Min. Max. 20±50ppm 10 13 ns ns 10 ns 16 TRMII_CLK_IN RMII_CLK_IN Td RXDV, RXD[3:0] Figure 22 RMII Receive Timing Specifications 2 Timing was measured for the pin load TXEN and TXD[1:0] of IP101G. The reference 50MHz clock was from output pin RXCLK/50M_CLKO of IP101G via the default driving current. 61/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 7.4.4 SMI Timing MDC/MDIO Timing Requirements Table 20 SMI Timing Requirements Symbol Description Min. Typ. Max. Unit Tch Tcl Tcm Tmd Tmh Tms MDC High Time input MDC Low Time input MDC period input MDIO output delay (read from PHY) MDIO setup time (write to PHY) MDIO hold time (write to PHY) 150 150 300 5 10 10 - 15 - ns ns ns ns ns ns MDC Tms Tmh MDIO Write Cycle MDC Tcl Tch Tmd Tcm MDIO Read Cycle Figure 23 SMI Timing Requirements 7.4.5 MDI to MII latency delay time Table 21 MDI to MII latency delay time Sub-layer measurement Event points 100BASE-TX TX_EN Sampled to MDI Output MIIÙMDI assert 100BASE-TX MDI input to RX_DV assert Input timing Min. reference TX_CLK rising 1st symbol of SSD 100BASE-TX TX_EN Sampled to MDI Output TX_CLK deassert rising 100BASE-TX MDI input to RX_DV deassert 1st symbol of SSD 62/66 Copyright © 2011, IC Plus Corp. Typ. Max. Unit 80 100 ns 260 300 ns 80 100 ns 260 300 ns May 20, 2014 IP101G-DS-R01 IP101G Data Sheet Sub-layer measurement Event points 100BASE-FX TX_EN Sampled to MDI Output assert 100BASE-FX MDI input to RX_DV assert Input timing Min. reference TX_CLK rising 1st symbol of SSD 100BASE-FX TX_EN Sampled to MDI Output TX_CLK deassert rising 100BASE-FX MDI input to RX_DV deassert 1st symbol of SSD 10BASE-T TX_EN Sampled to MDI Output TX_CLK assert rising 10BASE-T MDI input to RX_DV assert 1st symbol of SSD Typ. Max. Unit 80 100 ns 180 220 ns 80 100 ns 180 220 ns 800 1000 ns 1300 1900 ns 7.5 Thermal Data Table 22 Thermal Data Package 48-PIN LQFP 32-PIN QFN 8 Theta JA 83.2 75.3 49.1 35.2 Theta JC 42.8 42.4 30.6 26.3 Psi JT 10.7 10.5 13.7 5.0 Units o C/W o C/W o C/W o C/W PCB Layers 2 4 2 4 Conditions 1) FR4 PCB size 113mm * 95.8mm, 2) 1oz Cu for each layer, 3) 1.6mm PCB thickness, 4) Air flow @ 0m/sec. Order Information Table 23 Part Number and Package Part No. IP101G IP101GA IP101GR IP101GRI Package IP101G dice 48-PIN LQFP 32-PIN QFN 32-PIN QFN 63/66 Copyright © 2011, IC Plus Corp. Notice May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 9 Physical Dimensions 9.1 48-PIN LQFP 48 37 1 36 D D1 Top view 12 25 13 24 E "E" 12" e E1 A A2 GAUGE PLANE θ A1 F y c F SEATING PLANE D 0.254 12" L b2 L1 DETAIL "E" 13 24 Symbols 12 A A1 A2 b c D1 E1 e D E L L1 y 25 Bottom view 1 36 48 Unit 37 mm inch 1.600MAX. 0.050~0.150 1.400 + 0.05 0.200TYP 0.127TYP 7.000 + 0.100 7.000 + 0.100 0.500TYP 9.000 + 0.250 9.000 + 0.250 0.600 + 0.150 1.000REF 0.100MAX. 0"~7" 0.0630MAX. 0.0020~0.0059 0.0551 + 0.0020 0.0078TYP 0.0050TYP 0.2756 + 0.0039 0.2756 + 0.0039 0.0196TYP 0.3543 + 0.0098 0.3543 + 0.0098 0.0236 + 0.006 0.0393REF 0.0039MAX. 0"~7" - - - - - - Notes: 1. DIMENSION D1 & E1 DO NOT INCLUDE MOLD FLASH OR PROTRUSION. 2. DIMENSION b DOES NOT INCLUDE DAMBAR PROTRUSION. 3. MAX. END FLASH IS 0.15mm. 4. MAX. DAMBAR PROTRUSION IS 0.13mm. GENERAL APPEARANCE SPEC SHOULD BE BASED ON FINAL VISUAL INSPECTION SPEC. Figure 24 48-PIN LQFP Dimension 64/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet 9.2 32-PIN QFN JEDEC OUTLINE SYMBOLS A A1 A3 b D E e L L1 K MIN. 0.80 0.00 0.15 0.35 0.332 0.20 PACKAGE TYPE NOM. MAX. 0.85 0.90 0.02 0.05 0.20 REF. 0.20 0.25 4.00 RSC 4.00 BSC 0.40 BSC 0.40 0.45 0.382 0.432 --- E2 PAD SIZE 114X114 MIL MIN. 2.60 NOM. 2.70 D2 MAX. 2.75 MIN. 2.60 NOM. 2.70 LEAD FINISH MAX. 2.75 Pure Tin V JEDEC CODE PPF X N/A NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. DIMENSION b APPLIES TO MATALLIZED TERMINAL AND IS MEASURED BETWEEN 0.15mm AND 0.30mm FROM THE TERMINAL TIP. IF THE TERMINAL HAS THE OPTIONAL RADIUS ON THE OTHER END OF THE TERMINAL, THE DIMENSION b SHOULD NOT BE MEASURED IN THAT RADIUS AREA. 3. BILATERAL COPLANARITY ZONE APPLIES TO THE EXPOSED HEAT SINK SLUG AS WELL AS THE TERMINALS. Figure 25 32-PIN QFN Dimension 65/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01 IP101G Data Sheet IC Plus Corp. Headquarters 10F, No.47, Lane 2, Kwang-Fu Road, Sec. 2, Hsin-Chu City, Taiwan 30071, R.O.C. TEL : 886-3-575-0275 FAX : 886-3-575-0475 Website: www.icplus.com.tw Sales Office 4F, No. 106, Hsin-Tai-Wu Road, Sec.1, Hsi-Chih, New Taipei City, Taiwan 22102, R.O.C. TEL : 886-2-2696-1669 FAX : 886-2-2696-2220 66/66 Copyright © 2011, IC Plus Corp. May 20, 2014 IP101G-DS-R01
IP101GRI 价格&库存
很抱歉,暂时无法提供与“IP101GRI”相匹配的价格&库存,您可以联系我们找货
IP101GRI
  • 1+6.91200
  • 10+6.06960
  • 30+5.47560
  • 100+4.98960
  • 490+3.47760
  • 980+3.38040
库存:40480
IP101GRI
  • 1+3.98059
  • 10+3.92088
  • 98+3.18226
  • 196+3.13453
  • 490+2.96050
  • 2450+2.91609
库存:3542
