RK808-D
RK808-D
    ROCKCHIP(瑞芯微)
    QFN68_7X7MM
    RK808-D
RK808-D 数据手册
RK808 Power Management System Power Management System Technical Specifications PRELIMINARY V1.0.1 2015-1-5 Fuzhou Rockchip Electronics Co.Ltd Version 1.0.1 www.rock-chips.com 1 RK808 Power Management System REVISION HISTORY Date Revision Description 2013-03-02 0.1 Initial preliminary version 2013-03-25 0.2 Initial complete version 2013-08-31 0.3 Updated register map 2013-12-4 Changed package information 0.4 2014-02-22 0.5 Changed some details information 2014-03-14 0.6 Adding some information 2014-06-16 0.7 1.adding ordering information 2.deleted some RDSON information 2014-09-13 0.8 1.revised the packaging information 2.adding the BOOT11 timing sequence 3.Revised the BUCK1/2 output voltage range from 0.7v~1.5v to 0.7125v~1.5V 2014-12-30 1.0 1. adding ordering RK808-B/RK808-C 2.adding BOOT11 start RK808-B/RK808-C 3. adding 2014-01-05 1.0.1 Version 1.0.1 information up sequence for of 1.changing the BUCK1/BUCK2 Output voltage transition rate www.rock-chips.com 2 RK808 Power Management System TABLE OF CONTENTS 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 OVERVIEW.................................................................................................... 8 FEATURES .................................................................................................... 8 BLOCK DIAGRAM ........................................................................................... 9 TYPICAL APPLICATION DIAGRAMS .................................................................. 10 ORDERING INFORMATION ............................................................................. 12 ABSOLUTE MAXIMUM RATINGS ...................................................................... 12 RECOMMENDED OPERATING CONDITIONS....................................................... 12 ELECTRICAL CHARACTERISTICS ..................................................................... 13 STATE MACHINE DESCRIPTION ...................................................................... 23 9.1 STATE MACHINE DESCRIPTION ............................................................ 23 9.2 DEVICE POWER-ON ENABLE CONDITIONS............................................. 23 9.3 DEVICE POWER-ON DISABLE CONDITIONS ........................................... 24 9.4 DEVICE SLEEP ENABLE CONDITIONS.................................................... 24 POWER SEQUENCE .................................................................................. 25 10.1 BOOT1=0, BOOT0 = 0 ........................................................................ 26 10.2 BOOT1=0, BOOT0 = 1 ........................................................................ 26 10.3 BOOT1=1, BOOT0 = 0 ........................................................................ 27 10.4 BOOT1=1, BOOT0 = 1(RK808-B/RK808-C) ........................................... 27 10.5 BOOT TIMING CHARACTERISTIC .......................................................... 28 POWER CONTROL TIMING ........................................................................ 29 11.1 DEVICE TURN-ON WITH PLUG_IN ........................................................ 29 11.2 DEVICE TURN OFF WITH FALLING INPUT VOLTAGE ................................. 30 11.3 TIMING CHARACTERISTICS(Vin rising/falling and Plug-in) ....................... 30 11.4 DEVICE STATE CONTROL THROUGH PWRON SIGNAL .............................. 31 11.5 TIMING CHARACTERISTICS (PWRON, DEV_OFF) .................................... 32 11.6 DEVICE SLEEP STATE CONTROL ........................................................... 32 11.7 TIMING CHARACTERISTICS (SLEEP) ..................................................... 33 PIN ASSIGNMENT .................................................................................... 33 PINOUT DEFINITION ................................................................................ 34 APPLICATION NOTE ................................................................................. 38 REGISTER DEFINITION ............................................................................ 38 15.1 REGISTER SUMMARY .......................................................................... 38 15.2 REGISTER DESCRIPTION .................................................................... 40 15.2.1 RTC REGISTERS ...................................................................... 40 Version 1.0.1 www.rock-chips.com 3 RK808 Power Management System 15.2.1.1 SECONDS_REG : RTC SECOND Register ................................ 40 15.2.1.2 MINUTES_REG : RTC MINUTE Register .................................. 40 15.2.1.3 HOURS_REG : RTC HOUR Register ....................................... 41 15.2.1.4 DAYS_REG : RTC DAY Register ............................................. 41 15.2.1.5 MONTHS_REG : RTC MONTH Register ................................... 41 15.2.1.6 YEARS_REG : RTC YEAR Register ......................................... 42 15.2.1.7 WEEKS_REG : RTC WEEK Register ....................................... 42 15.2.1.8 ALARM_SECONDS_REG : RTC ALARM SECOND Register .......... 42 15.2.1.9 ALARM_MINUTES_REG : RTC ALARM MINUTE Register ............ 43 15.2.1.10 ALARM_HOURS_REG : RTC ALARM HOUR Register ............ 43 15.2.1.11 ALARM_DAYS_REG : RTC ALARM DAY Register ................. 43 15.2.1.12 ALARM_MONTHS_REG : RTC ALARM MONTH Register ........ 44 15.2.1.13 ALARM_YEARS_REG : RTC ALARM YEAR Register .............. 44 15.2.1.14 RTC_CTRL_REG : RTC Control Register ............................ 44 15.2.1.15 RTC_STATUS_REG : RTC Status Register ......................... 45 15.2.1.16 RTC_INT_REG : RTC Interrupt Register ............................ 46 15.2.1.17 RTC_COMP_LSB_REG : RTC Comensation LSB Register ..... 46 15.2.1.18 RTC_COMP_MSB_REG : RTC Compensation MSB Register .. 46 15.2.2 MISC REGISTERS .................................................................... 47 15.2.2.1 CLK32KOUT_REG : RTC Compensation MSB Register .............. 47 15.2.2.2 VB_MON_REG : Battery Voltage Monitor Register ................... 47 15.2.2.3 THERMAL_REG : Thermal Control Register ............................ 48 15.2.3 POWER CHANNEL CONTROL/MONITOR REGISTERS...................... 49 15.2.3.1 DCDC_EN_REG : DC-DC Converter Enable Register ................ 49 15.2.3.2 LDO_EN_REG : LDO Enable Register..................................... 49 15.2.3.3 SLEEP_SET_OFF_REG1 : Sleep set Off Register #1................. 50 15.2.3.4 SLEEP_SET_OFF_REG2 : Sleep set Off Register #2................. 50 15.2.3.5 DCDC_UV_STS_REG : DC-DC Under Voltage Status Register ... 51 15.2.3.6 DCDC_UV_ACT_REG : DC-DC Under Voltage Action Register ... 51 15.2.3.7 LDO_UV_STS_REG : LDO Under Voltage Status Register ......... 52 15.2.3.8 LDO_UV_ACT_REG : LDO Under Voltage Action Register ......... 53 15.2.3.9 DCDC_PG_REG : DC-DC Converter Power Good Status Register 54 15.2.3.10 LDO_PG_REG : LDO Power Good Status Register .............. 54 15.2.3.11 VOUT_MON_TDB_REG : VOUT Debounce Monitor Register . 55 15.2.4 POWER CHANNEL CONFIGURATION REGISTERS .......................... 56 15.2.4.1 BUCK1_CONFIG_REG : BUCK1 Configuration Register ............ 56 15.2.4.2 BUCK1_ON_VSEL : BUCK1 Active Mode Register .................... 56 15.2.4.3 BUCK1_SLP_VSEL : BUCK1 Sleep Mode Register .................... 57 15.2.4.4 BUCK1_DVS_VSEL : BUCK1 DVS Mode Register ..................... 57 15.2.4.5 BUCK2_CONFIG_REG : BUCK2 Configuration Register ............ 58 15.2.4.6 BUCK2_ON_VSEL : BUCK2 Active Mode Register .................... 59 Version 1.0.1 www.rock-chips.com 4 RK808 Power Management System 16 15.2.4.7 BUCK2_SLP_VSEL : BUCK2 Sleep Mode Register .................... 59 15.2.4.8 BUCK2_DVS_VSEL : BUCK2 DVS Mode Register ..................... 60 15.2.4.9 BUCK3_CONFIG_REG : BUCK3 Configuration Register ............ 60 15.2.4.10 BUCK4_CONFIG_REG : BUCK4 Configuration Register ....... 61 15.2.4.11 BUCK4_ON_VSEL : BUCK4 Active Mode Register ............... 61 15.2.4.12 BUCK4_SLP_VSEL : BUCK4 Sleep Mode Register............... 62 15.2.4.13 LDO1_ON_VSEL_REG : LDO1 Active Mode Voltage Select .. 62 15.2.4.14 LDO1_SLP_VSEL_REG : LDO1 Sleep Mode Voltage Select .. 63 15.2.4.15 LDO2_ON_VSEL_REG : LDO2 Active Mode Voltage Select .. 63 15.2.4.16 LDO2_SLP_VSEL_REG : LDO2 Sleep Mode Voltage Select .. 64 15.2.4.17 LDO3_ON_VSEL_REG : LDO3 Active Mode Voltage Sel ....... 64 15.2.4.18 LDO3_SLP_VSEL_REG : LDO3 Sleep Mode Voltage Select .. 65 15.2.4.19 LDO4_ON_VSEL_REG : LDO4 Active Mode Voltage Select .. 65 15.2.4.20 LDO4_SLP_VSEL_REG : LDO4 Sleep Mode Voltage Select .. 66 15.2.4.21 LDO5_ON_VSEL_REG : LDO5 Active Mode Voltage Select .. 66 15.2.4.22 LDO5_SLP_VSEL_REG : LDO5 Sleep Mode Voltage Select .. 67 15.2.4.23 LDO6_ON_VSEL_REG : LDO6 Active Mode Voltage Select .. 67 15.2.4.24 LDO6_SLP_VSEL_REG : LDO6 Sleep Mode Voltage Select .. 67 15.2.4.25 LDO7_ON_VSEL_REG : LDO7 Active Mode Voltage Select .. 68 15.2.4.26 LDO7_SLP_VSEL_REG : LDO7 Sleep Mode Voltage Select .. 68 15.2.4.27 LDO8_ON_VSEL_REG : LDO8 Active Mode Voltage Select .. 69 15.2.4.28 LDO8_SLP_VSEL_REG : LDO8 Sleep Mode Voltage Select .. 69 15.2.4.29 DEVCTRL_REG : Device Control Register .......................... 70 15.2.5 INTERRUPT REGISTERS............................................................ 71 15.2.5.1 INT_STS_REG1 : Interrupt Status Register #1 ....................... 71 15.2.5.2 INT_MSK_REG1 : Interrupt Mask Register #1 ........................ 71 15.2.5.3 INT_STS_REG2 : Interrupt Status Register #2 ....................... 72 15.2.5.4 INT_STS_MSK_REG2 : Interrupt Status Register #2 ............... 72 15.2.5.5 IO_POL_REG : IO Polarity Register ....................................... 73 15.2.5.6 DCDC_ILMAX_REG : DCDC max inductor current Register ....... 73 PACKAGE INFORMATION .......................................................................... 74 Version 1.0.1 www.rock-chips.com 5 RK808 Power Management System LIST OF FIGURES Figure 3-1 Functional Block Diagram ...................................................... 9 Figure 4-1 One Battery Cell Application ............................................... 10 Figure 4-2 Two Battery Cells Application ............................................... 11 Figure 8-1 State Machine .................................................................. 23 Figure 8-2 Power On Enable Control ................................................... 24 Figure 8-3 SLEEP Enable Control ........................................................ 25 Figure 9-1 Power On/Off Timing, BOOT1=0, BOOT0=0 ........................... 26 Figure 9-2 Power On/Off Timing, BOOT1=0, BOOT0=1 ........................... 26 Figure 9-3 Power On/Off Timing, BOOT1=1, BOOT0=0 ........................... 27 Figure 10-1Power ON Timing with VDC Plug in (PLUP_IN_INT Trigger a Power on Enable) ................................................................................... 29 Figure 10-2 Power Control Timing with VIN Falling ................................. 30 Figure 10-3 Vin and PLUG_IN Timing Characteristics .............................. 30 Figure 10-4 PWRON Turn-On/DEV_OFF Turn Off ..................................... 31 Figure 10-5 PWRON Long Press Turn Off ............................................... 31 Figure 10-6 SLEEP/ACTIVE Transition Timing ......................................... 32 Figure 11-1 Pin Assignment ................................................................. 33 Version 1.0.1 www.rock-chips.com 6 RK808 Power Management System LIST OF TABLES Table 9-1 Power Start Up Sequence ...................................................... 25 Table 10-1 PWRON/DEV_OFF Timing Characteristics ............................... 32 Table 10-2 SLEEP Timing Characteristics ............................................... 33 Version 1.0.1 www.rock-chips.com 7 RK808 Power Management System 1 OVERVIEW The RK808 is a complete power supply solution for Portable systems. The highly integrated device includes four buck DC-DC converters, eight high performance ldos, two low Rds switches, I2C interface, programmable power sequencing and an RTC. The RK808 improves performance, reduces component count and size, and therefore provides lower cost solution compared to conventional portable designs. The ultra fast 2MHz current mode DC/DC architecture optimizes the transient performance and is compatible with tiny low cost ceramic inductors and capacitors. All DC/DC channels include integrated MOSFETS. Internal soft-start and compensation circuits minimize external components count. Most outputs can be programmed through the I2C interface 2 FEATURES           Input voltage range: 2.7V to 5.5V 2MHz Switching Frequency for bucks Current mode architecture for best transient performance Internal compensation and soft start I2C Programmable output levels and power sequencing High efficiency architecture Integrated Vout Discharge Circuit for BUCK and LDO Power: • CH1: Synchronous Buck regulator, 5A max • CH2: Synchronous Buck regulator, 5A max • CH3: Synchronous Buck regulator, 3A max • CH4: Synchronous Buck regulator, 2.5A max • CH6,CH7,CH9,CH11: Linear regulators, 150mA max • CH8: Low noise and high PSRR linear regulator,100mA max • CH10,CH12,CH13: Linear regulators, 300mA max • CH14: Low Rds switch, 0.2ohm@Vgs=3v • CH15: Low Rds switch, 0.2ohm@Vgs=3v Auxiliary: Flexible Power Sequence control Package: 7mmx7mm QFN68 Version 1.0.1 www.rock-chips.com 8 RK808 Power Management System 3 BLOCK DIAGRAM VCC6 Vcc_tp VCCA LDO1 150mA VLDOA CH6 VCC1 VCC1 LDO2 Vcca_33 CH1 150mA SW1 BUCK1 Step-Down 5A 0.7125~1.5V CH7 VCC7 Vdd_11 LDO3 (low noise) DAC Vdd_arm SW1 GND1 GND1 VFB1 100mA LDO3 VCC2 VCC2 CH8 CH2 SW2 VCC9 Vcc_25 BUCK1 Step-Down 5A 0.7125~1.5V LDO4 150mA CH9 DAC Vdd_logic SW2 GND2 GND2 VFB2 LDO5 Vcc28_cif 300mA VCC3 CH3 CH10 VCC10 Vcc_12 BUCK3 Step-Down 3A 1.0~1.8V LDO6 150mA SW3 Vcc_ddr GND3 VFB3 VCC4 CH11 2MHz Clock VCC7 Vcc18_cif LDO7 300mA CH12 VCC11 Vcc33_wifi CH4 BUCK4 Step-Down 2.5A 1.8~3.3V DAC Vcc_io SW4 GND4 VFB4 LDO8 300mA CH13 VCC8 Vcc_sd Switch 1 300mA CH14 VCC12 Vcc_lcd I2C Switch 2 300mA CH15 Power Sequence VCCRTC SDA SCK INT SLEEP PWRON Ext_EN NRESPWRON BOOT0 BOOT1 DVS1 DVS2 DVSOK VDDIO OSC32KIN 32K OSC RTC Reference OSC32KOUT CLK32OUT1 VREF REFGND CLK32OUT2 Figure 3-1 Functional Block Diagram Version 1.0.1 www.rock-chips.com 9 RK808 Power Management System 4 TYPICAL APPLICATION DIAGRAMS Vsys VCC1 VCC1 Vsys 4.7uF VCC6 2.2uF Vcc_tp 2.2uFVcca_33 VLDO1 SW1 SW1 GND1 GND1 VFB1 VLDO2 VCC_IO 4.7uF VCC7 2.2uF Vdd_11 Vcc18_cif 4.7uF VLDO3 VLDO7 SW2 SW2 GND2 GND2 VFB1 VCC8 2.2uF Vcc_sd VSWOUT1 VCC_IO 4.7uF VCC9 2.2uF Vcc_25 Vcc28_cif 2.2uF 33uF Vsys 4.7uF VDD_LOGIC 2.2uH/5A 33uF Vsys 4.7uF VCC3 VLDO4 VDD_ARM 2.2uH/5A VCC2 VCC2 VCC_IO 4.7uF 4.7uF VCC_DDR 2.2uH/3A SW3 VLDO5 VCC_IO 4.7uF VCC10 33uF VFB3 2.2uF Vcc_12 VCC_IO 4.7uF VLDO6 GND3 VCC11 Vcc33_wifi 2.2uF Vsys 4.7uF VLDO8 VCC4 VCC_IO 4.7uF VCC12 2.2uFVcc_lcd 4.7uF VCC_IO 4.7uF Vsys 2.2uF Vsys 0.1uF BAT USB/Adapter Power Path 25pF 25pF VFB4 VCCA VDDIO VCCRTC VLDOA VREF REFGND AGND DGND EXT_EN OSC32KIN Vsys 33uF GND4 VSWOUT2 4.7uF Vsys VCC_IO 2.2uH/3A SW4 DVS1 DVS2 SLEEP DVS1 DVS2 SLEEP VCC_IO 32.768K 100K 100K 100K 100K OSC32KOUT 10K RESET VCCRTC VPPOTP 200K VDC 33K 22nF DVSOK INT NRESPWON AP (VCC_IO) CLK32KOUT2 VCCRTC VCC_IO 10K PWRON 4.7K PWRON 4.7K SCL SCL VCCRTC SDA SDA VCCRTC 10K 10K VCCRTC BOOT0 BOOT1 BOOT0 BOOT1 100K CLK32KOUT1 GPS Figure 4-1 RK808 One Battery Cell Application Version 1.0.1 www.rock-chips.com 10 RK808 Power Management System Vsys VCC1 VCC1 Vsys 4.7uF VCC6 2.2uF Vcc_tp VLDO1 2.2uFVcca_33 SW1 SW1 GND1 GND2 VFB1 VLDO2 VCC_IO 4.7uF VCC7 2.2uF Vdd_11 VLDO3 Vcc18_cif 4.7uF VLDO7 VSWOUT1 VCC_IO 4.7uF VCC9 VLDO4 VCC3 VLDO5 SW3 VCC_IO 4.7uF VCC10 VFB3 4.7uF 4.7uF VCC_IO Vhvldo 4.7uF 2.2uF Vsys 0.1uF VSWOUT2 GND4 VCCA VFB4 33uF VDDIO VCCRTC VLDOA DVS1 DVS2 SLEEP DVS1 DVS2 SLEEP VCC_IO 25pF 25pF 100K Ext_en 100K VPPOTP VDC 100K 100K DVSOK INT NRESPWON RESET VCCRTC AP (VCC_IO) CLK32KOUT2 VCCRTC 33K VAP_pwr1 OSC32KIN 32.768K OSC32KOUT 10K VCC_IO 2.2uH/3A SW4 VREF REFGND AGND DGND Vsys 33uF 4.7uF VCC4 VCC12 4.7uFVhvldo 400K VCC_DDR Vsys VLDO8 2.2uFVcc_lcd BUCK 33uF GND3 VCC_IO 4.7uF 9V/12V Adapter VDD_LOGIC VLDO6 VCC11 Vcc33_wifi 2.2uF Power Path 2.2uH/5A 2.2uH/3A 2.2uF Vcc_12 2*BAT 4.7uF VCC_IO 4.7uF LDO Vsys Vsys 2.2uF Vcc_25 Vcc28_cif 2.2uF 33uF SW2 SW2 GND2 GND2 VFB2 VCC8 2.2uF Vcc_sd VDD_ARM 2.2uH/5A VCC2 VCC2 VCC_IO 4.7uF 4.7uF VCC_IO VAP_pwr2 22nF 10K PWRON 4.7K PWRON 4.7K SCL SCL VCCRTC SDA SDA VCCRTC 10K 10K VCCRTC BOOT0 BOOT1 BOOT0 CLK32KOUT1 BOOT1 100K GPS Vsys must less than (Vhvldo+0.5V) Figure 4-2 RK808 Two Battery Cells Application Version 1.0.1 www.rock-chips.com 11 RK808 Power Management System 5 ORDERING INFORMATION Orderable Device RoHS status Package Package Qty Device special feature RK808-B RoHS pass QFN68(7X7) 2600ea/inner box* 6 For RK3288 inner boxes/outer box B-application RK808-C RoHS pass QFN68(7X7) 2600ea/inner box* 6 For RK3288 inner boxes/outer box C-application 6 ABSOLUTE MAXIMUM RATINGS Parameter Min Voltage range on pins VCCx, VDDIO, VCCRTC, VFBx, VLDOx, VSWOUTx, VREF Voltage range on pin CLK32KOUT1, CLK32KOUT2, VDC, SLEEP Voltage range on pins OSC32KIN, OSC32KOUT, BOOT0, BOOT1, EXT_EN, PWRON Voltage range on pins NRESPWRON, INT, SDA, SCL, DVS1, DVS2, DVSOK Storage temperature range, TS Operating temperature range, TJ Maximum Soldering Temperature, TSOLDER Max Uni ts -0.3 7 V -0.3 7 V -0.3 VCCRTCMAX+0.3 -0.3 VDDIO+0.3 V -40 -40 150 125 300 ℃ ℃ ℃ Note 1. Exposure to the conditions exceeded absolute maximum ratings may cause the permanent damages and affect the reliability and safety of both device and systems using the device. The functional operations cannot be guaranteed beyond specified values in the recommended conditions. 7 RECOMMENDED OPERATING CONDITIONS Parameter Voltage range on pins VCCx, VDDIO Voltage range on pin VCCRTC Voltage range on other pins Power Dissipation Version 1.0.1 Min 3 2.5 www.rock-chips.com TYP Max 5.5 5.5 5.5 2.5 Units V V V W 12 RK808 Power Management System 8 ELECTRICAL CHARACTERISTICS TJ=25C; VBAT=VCCx=3.8V, VDDIO=3V unless otherwise specified. Parameter Symbol Min. VINPUT 2.7 VBLO 3.25 Typ. Max. Unit 5.5 V 3.35 V General Input supply voltage range ( VBAT ) Battery low alarm voltage (2.8V~3.5V programmable, step=100mV) Battery under voltage threshold (vin falling) VBUVL Battery under voltage threshold (vin rising) VBUVH Battery OK voltage threshold VBOK 3.3 2.5 2.6 2.7 V 2.8 3.0 V V (3.0V/3.4V/3.5V/3.6V OTP programmable) Power on Reset Threshold (Rising) VPORH Power on Reset Threshold (Falling) VPORL 1.2 VTH(OVLO) 5.7 Over Voltage Lock Out Threshold (Vin Rising) Over Voltage Lock Out Hysteresis 2.2 V V 6.0 6.3 V VHYS (OVLO) 0.2 V VDC pin threshold(rising edge) VDCH 0.6 V VDC pin threshold(falling edge) VDCL 0.54 V IQ(STNBY) 60 uA Stand-by current, VDD=3.6V, device OFF state 32KHz clock running Hot-die temperature rising threshold (85℃~115℃ programmable, step=10℃) Thermal shut down THD 85 115 ℃ TTSD 140 170 ℃ fSW 1.8 2.2 MHz 0.3xVDDIO V (140℃~170℃ programmable, step=30℃) Oscillator circuit Switching Frequency CH1,2,3,4( Tj=25℃ ) 2 Logic inputs Input LOW-Level Voltage (VDDIO) VIL Input HIGH-Level Voltage (VDDIO) VIH 0.7xVDDIO V Logic outputs LOW-Level Output Voltage, 3.0 mA sink VOL HIGH-Level Output Voltage, 3.0 mA source VOH 0.4 V current VDDIO-0.4 V current NRESPWON pin LOW-Level Output Voltage, VOL(NRES) 0.4 V VOL(CLKO1) 0.4 V 3.0mA sink current CLK32KOUT1 pin LOW-Level Output Voltage, Version 1.0.1 www.rock-chips.com 13 RK808 Power Management System Parameter Symbol Min. Typ. Max. Unit 3.0mA sink current CLK32KOUT2 pin LOW-Level Output Voltage, VOL(CLKO2) 0.4 3.0mA sink current CLK32KOUT2 pin HIGH-Level Output VOH(CLKO2) VDDIO-0.4 V VINPUT1 2.7 5.5 V VFB1 0.7125 1.500 V Voltage, 3.0mA source current CH1 Buck1 Regulator (VDD_ARM) Input supply voltage range Voltage Adjustable Range, 6bit DC output voltage programmable step(DVS) 12.5 mV Output voltage transition rate BUCK1_RATE=00 2 BUCK1_RATE=01 3.6 BUCK1_RATE=10 5 BUCK1_RATE=11 6.5 DVS OK threshold (Vout rising) VDVSOKR1 mV/us 93 % VDVSOKF1 107 % Power Good threshold (Vout rising) VPG1 93 % Output under voltage lockout(Vout falling) VUV1 85 % Output over voltage lockout (Vout rising) VOV1 117 % DVS OK threshold (Vout falling) Preset Voltage, Default( Tj=25℃ ) VFB1(Default) 1.078 1.100 1.122 V Preset Voltage, Default(-10℃≦Tj≦+85℃) VFB1(Default) 1.067 1.100 1.133 V Load Regulation, IOUT1 = 100mA to 5A Line Regulation, VCC1 = 3 to 5V, IOUT1 = 1A 1 %/A 0.1 %/V Rated output current(If ICL1=6A) IMAX1 5 A Switch Current Limit ICL1 6 A IQ1 70 uA ICLMIN1 100 mA tSS1 400 us RDIS1 250 ohm (4.5A~6A programmable, step=0.5A) Operating Quiescent Current, No load, VDD=3.8V Minimun Switch Current Limit (50mA~400mA programmable, step=50mA) Soft-start Time COUT Discharge Switch ON Resistance Conversion Effeciency (Vin=3.8V,Vout=1.1V) 68 Iout=5A 73 Iout=4A 78 Iout=3A 84 Iout=2A 89 Iout=1 A Version 1.0.1 % www.rock-chips.com 14 RK808 Power Management System Parameter Symbol Min. Typ. Iout=500mA 90 Iout=100 mA 81 Iout=10 mA 79 Max. Unit CH2 Buck2 Regulator (VDD_LOG) Input supply voltage range Voltage Adjustable Range, 6bit VINPUT2 2.7 5.5 VINPUT2 VFB2 0.7125 1.500 VFB2 DC output voltage programmable step(DVS) 12.5 Output voltage transition rate BUCK2_RATE=00 2 BUCK2_RATE=01 3.6 BUCK2_RATE=10 5 BUCK2_RATE=11 6.5 DVS OK threshold (Vout rising) VDVSOKR2 93 % VDVSOKF2 107 % Power Good threshold (Vout rising) VPG2 93 % Output under voltage lockout (Vout falling) VUV2 85 % Output over voltage lockout (Vout rising) VOV2 117 % DVS OK threshold (Vout falling) Preset Voltage, Default( Tj=25℃ ) VFB2(Default) 1.078 1.100 V Preset Voltage, Default(-10℃≦Tj≦+85℃) VFB2(Default) 1.067 1.100 V 1 %/A 0.1 %/V Load Regulation, IOUT2 = 100 mA to 5A Line Regulation, VCC2 = 3 to 5V, IOUT2 = 1A Rated output current(If ICL2=6A) IMAX2 5 A Switch Current Limit ICL2 6 A IQ2 70 uA ICLMIN2 100 mA tSS2 400 us RDIS2 250 ohm (4.5A~6A programmable, step=0.5A) Operating Quiescent Current, No load, VDD=3.8V Minimun Switch Current Limit (50mA~400mA programmable, step=50mA) Soft-start Time COUT Discharge Switch ON Resistance Conversion Effeciency (Vin=3.8V,Vout=1.1V) Iout=5A 68 Iout=4A 73 Iout=3A 78 Iout=2A 84 Iout=1 A 89 Version 1.0.1 www.rock-chips.com % 15 RK808 Power Management System Parameter Symbol Min. Typ. Iout=500mA 90 Iout=100 mA 81 Iout=10 mA 79 Max. Unit CH3 Buck3 Regulator (VDD_DDR) Input supply voltage range VINPUT3 2.7 V Feedback Voltage, Default( Tj=25℃ ) VFB3(Default) 0.98 1.00 V Feedback Voltage, Default(-10℃≦Tj≦+85℃) VFB3(Default) 0.97 1.00 V Power Good threshold (Vout rising) VPG3 93 % Output under voltage lockout (Vout falling) VUV3 85 % Output over voltage lockout (Vout rising) VOV3 117 % 1 %/A 0.1 %/V Load Regulation, IOUT3 = 100mA to 3A Line Regulation, VCC3 = 3 to 5V, IOUT3 = 0.5A Rated output current(If ICL3=3.5A) IMAX3 3 A Switch Current Limit ICL3 3.5 A IQ3 70 uA ICLMIN3 100 mA tSS3 400 us RDIS3 250 ohm (2A~3.5A programmable, step=0.5A) Operating Quiescent Current, No load, VDD=3.8V Minimun Switch Current Limit (50mA~400mA programmable, step=50mA) Soft-start Time COUT Discharge Switch ON Resistance Conversion Effeciency (Vin=3.8V,Vout=1.4V) Iout=3A 71 Iout=2A 79 Iout=1.5A 83 Iout=1 A 87 Iout=500mA 90 Iout=100 mA 83 Iout=10 mA 76 % CH4 Buck4 Regulator (VDD_IO) Input supply voltage range Voltage Adjustable Range, 4bit VINPUT4 2.7 5.5 V VFB4 1.8 3.3 V DC output voltage programmable step(gain 100 mV select) Feedback Voltage, Default( Tj=25℃ ) Version 1.0.1 VFB4(Default) www.rock-chips.com 2.94 3.00 3.06 V 16 RK808 Power Management System Parameter Symbol Min. Typ. Max. Unit Feedback Voltage, Default(-10℃≦Tj≦+85℃) VFB4(Default) -2.91 3.00 3.09 V Power Good threshold (Vout rising) VPG4 93 % Output under voltage lockout (Vout falling) VUV4 85 % Output over voltage lockout (Vout rising) VOV4 117 % 1 %/A 0.1 %/V Load Regulation, IOUT4 = 100mA to 2.5A Line Regulation, VCC4 = 3 to 5V, IOUT4 = 0.5A Rated output current(If ICL4=3.5A) IMAX4 2.5 A Switch Current Limit ICL4 3.5 A IQ4 70 uA ICLMIN4 100 mA tSS4 400 us RDIS4 250 Ohm (2A~3.5A programmable, step=0.5A) Operating Quiescent Current, No load, VDD=3.8V Minimun Switch Current Limit (50mA~400mA programmable, step=50mA) Soft-start Time COUT Discharge Switch ON Resistance Conversion Effeciency, (DCRVB_LO_SEL 1: VBAT90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout90% of setting voltage 0: Power not good, Vout
RK808-D 价格&库存
很抱歉,暂时无法提供与“RK808-D”相匹配的价格&库存,您可以联系我们找货
