SLFL18-2R450G-01TF
SLFL18-2R450G-01TF
    SUNLORD(顺络)
    特性:体积小,重量轻。 低插损。 良好的内部屏蔽。 低温共烧陶瓷技术表面焊接。 可定制中心频率、抑制等特性。应用:LTE、5G移动通信系统。 基站应用
SLFL18-2R450G-01TF 数据手册
Multilayer Chip LC Filter (Low pass) – SLFL Series Operating Temp. : -40℃~+85℃ FEATURES z z z z z Small size, light weight Low insertion loss Inside shielding SMD chip based on LTCC technology Centre frequencies and responses are ready for customization APPLICATIONS Cellular telephones Cordless telephones transceivers, CATV Bluetooth, Wireless LAN, GPS, etc ● ● ● PRODUCT IDENTIFICATION SLFL 15 -2R450G -01 T F ① ② ③ ④ ⑤ ⑥ ① Type SLFL ③ ② Low Pass LC Filter External Dimensions (L×W) (mm) 15 [0402] 1.0×0.5 18 [0603] 1.6×0.8 21 [0805] 2.0×1.2 31 [1206] 3.2×1.6 Center Frequency Example Nominal Value 0R902G 902.5MHz 2R450G 2450.0MHz ⑥ Hazardous Substance Free Products F ⑤ ④ Packing Series Code 01, E1, G9, etc. T Tape Carrier Package SHAPE AND DIMENSIONS Type: SLFL15 Series Dimensions and Land Patterns Type: SLFL18 Series Dimensions and Land Patterns Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2016/04/01 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SHAPE AND DIMENSIONS Type: SLFL21-G9 Series Dimensions and Land Patterns Type: SLFL21-01TF Series Dimensions and Land Patterns Type: SLFL21-2R450G-02TF Dimensions and Land Patterns Type: SLFL31 Series Dimensions and Land Patterns Dimensions and Land Patterns 0.30±0.15 M (2) (3) (1)(3):GND (2):OUT (4):IN M:MARK Unit:mm Sunlord 3.0 1.0 1.50±0.10 2.50±0.20 (4) (1) 3.20±0.20 0.60±0.20 0.40±0.20 Type: SLFL32 Series 1.6 2.2 3.2 3.4 4.3 5.2 Specifications subject to change without notice. Please check our website for latest information. Land Solder resist No Pattern solder resist Unit:mm Revised 2016/04/01 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SLFL15 TYPE Part Number Center Frequency Bandwidth Max. IL in BW (at 25°C) Units Symbol MHz f0 MHz BW dB IL SLFL15-0R870G-01TF 869.5 f0±45.0 0.60 SLFL15-1R810G-01TF 1810.0 f0±100.0 0.50 SLFL15-2R450G-01TF 2450.0 f0±50.0 0.45 Attenuation Thickness dB 25.0dB Min. at 2×(f0±50)MHz 25.0dB Min. at 3×(f0±50)MHz 25.0dB Min. at 4×(f0±50)MHz 25.0dB Min. at 3420~3570MHz 25.0dB Min. at 3700~3820MHz 25.0dB Min. at 5130~5730MHz 21.0dB Min. at 2×(f0±50)MHz 21.0dB Min. at 3×(f0±50)MHz mm T 0.38±0.05 SLFL18 TYPE Part Number Center Frequency Bandwidth Max. IL in BW (at 25°C) Units Symbol MHz f0 MHz BW dB IL SLFL18-1R810G-01TF 1810.0 f0±100.0 0.60 SLFL18-2R450G-01TF 2450.0 f0±50.0 0.60 SLFL18-2R450G-02TF 2450.0 f0±200.0 0.40 Attenuation Thickness dB 25.0dB Min. at 3420~3820MHz 25.0dB Min. at 5130~5730MHz 27.0dB Min. at 2×(f0±50)MHz 30.0dB Min. at 3×(f0±50)MHz 30.0dB Min. at 4×(f0±50)MHz 21.0dB Min. at 4600~5400MHz 22.0dB Min. at 6900~8100MHz mm T 0.80±0.10 SLFL21 TYPE Part Number Center Frequency Bandwidth Max. IL in BW (at 25°C) Units Symbol MHz f0 MHz BW dB IL SLFL21-0R902G-01TF 902.5 f0±12.5 0.60 SLFL21-2R450G-01TF 2450.0 f0±50.0 0.50 SLFL21-2R450G-02TF 2450.0 f0±50.0 0.45 SLFL21-2R450G-G9TF 2450.0 f0±50.0 0.50 SLFL21-5R500G-G9TF 5515.0 f0±365.0 0.60 SLFL21-5R500G-01TF 5515.0 f0±365.0 0.60 Sunlord Attenuation Thickness dB 30.0dB Min. at 2×(f0±50)MHz 30.0dB Min. at 3×(f0±50)MHz 27.0dB Min. at 2×(f0±50)MHz 30.0dB Min. at 3×(f0±50)MHz 30.0dB Min. at 4×(f0±50)MHz 30.0dB Min. at 2×(f0±50)MHz 20.0dB Min. at 3×(f0±50)MHz 27.0dB Min. at 2×f0MHz 25.0dB Min. at 3×f0MHz 25.0dB Min. at 4×f0MHz 25.0dB Min. at 2×(f0±365)MHz 25.0dB Min. at 3×(f0±365)MHz 25.0dB Min. at 2×(f0±365)MHz 25.0dB Min. at 3×(f0±365)MHz mm T Specifications subject to change without notice. Please check our website for latest information. 0.95±0.10 0.45±0.05 0.95±0.10 0.95±0.10 Revised 2016/04/01 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SLFL31 TYPE Part Number Pass Band Max. IL (at 25°C) Units Symbol MHz PB dB IL SLFL31-0R080G-01TF 1~80 1.0dB Max. at 1~80MHz 3.0dB Max. at 145MHz SLFL31-0R120G-01TF 1~120 1.2dB Max. at 1~120MHz SLFL31-0R180G-01TF 1~180 1.2dB Max. at 1~180MHz SLFL31-0R320G-01TF 1~320 1.0dB Max. at 1~320MHz SLFL31-0R400G-01TF 1~400 1.0dB Max. at 1~400MHz 3.0dB Max. at 560MHz SLFL31-0R530G-01TF 1~530 1.0dB Max. at 1~530MHz SLFL31-0R560G-01TF 1~560 1.0dB Max. at 1~400MHz 3.0dB Max. at 560MHz SLFL31-0R630G-01TF 1~630 1.2dB Max. at 1~630MHz SLFL31-0R850G-01TF 1~850 1.3dB Max. at 1~850MHz SLFL31-1R325G-01TF 1~1325 1.3dB Max. at 1~1325MHz SLFL31-1R450G-01TF 1~1450 1.0dB Max. at 1~1450MHz SLFL31-1R500G-01TF 1~1500 1.0dB Max. at 1~1500MHz 4.0dB Max. at 1825MHz SLFL31-1R800G-01TF 1~1800 1.2dB Max. at 1~1800MHz SLFL31-5R500G-01TF 1~5500 2.0dB Max. at 1~ 5500MHz 4.0dB Max. at 6200MHz SLFL31-6R000G-01TF 1~6000 1.2dB Max. at 1~6000MHz 4.0dB Max. at 6800MHz SLFL31-6R700G-01TF 1~6700 1.2dB Max. at 1~6700MHz 4.0dB Max. at 7600MHz Sunlord Attenuation Thickness dB 20.0dB Min. at 200MHz 40.0dB Min. at 225~1550MHz 20.0dB Min. at 4500MHz 20.0dB Min. at 280MHz 30.0dB Min. at 300~1850MHz 15.0dB Min. at 4750MHz 20.0dB Min. at 370~525MHz 30.0dB Min. at 525~2350MHz 15.0dB Min. at 2350~6400MHz 20.0dB Min. at 560MHz 40.0dB Min. at 640~2500MHz 20.0dB Min. at 5300MHz mm T 20.0dB Min. at 660MHz 35.0dB Min. at 680~3000MHz 20.0dB Min. at 5500MHz 20.0dB Min. at 820MHz 40.0dB Min. at 945~3000MHz 20.0dB Min. at 6000MHz 20.0dB Min. at 660MHz 40.0dB Min. at 680~3000MHz 20.0dB Min. at 660~5500MHz 20.0dB Min. at 1000MHz 30.0dB Min. at 1050~3500MHz 15.0dB Min. at 6000MHz 20.0dB Min. at 1275MHz 25.0dB Min. at 1350~4850MHz 15.0dB Min. at 5100MHz 20.0dB Min. at 2100MHz 25.0dB Min. at 2200MHz 15.0dB Min. at 4250MHz 20.0dB Min. at 2025MHz 25.0dB Min. at 2050~6600MHz 15.0dB Min. at 6700MHz 20.0dB Min. at 2100MHz 30.0dB Min. at 2150~6600MHz 20.0dB Min. at 6800MHz 0.95±0.20 20.0dB Min. at 2425MHz 25.0dB Min. at 2500~7200MHz 15.0dB Min. at 8600MHz 20.0dB Min. at 7200MHz 20.0dB Min. at 9500~12100MHz 20.0dB Min. at 8500MHz 30.0dB Min. at 8700~10500MHz 20.0dB Min. at 18000MHz 20.0dB Min. at 9300MHz 30.0dB Min. at 9500~11000MHz 20.0dB Min. at 18000MHz Specifications subject to change without notice. Please check our website for latest information. Revised 2016/04/01 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SLFL32 TYPE Part Number Pass Band Units Symbol MHz PB dB IL SLFL32-0R045G-01TF 1~45 1.2dB Max. at 1~45MHz SLFL32-0R093G-01TF 1~52 1.2dB Max. at 1~52MHz SLFL32-1R002G-01TF 5~1002 1.5dB Max. at 5~1002MHZ Sunlord Max. IL( at 25°C) Attenuation Thickness dB 20.0dB Min. at 120MHz 30.0dB Min. at 150~910MHz 20.0dB Min. at 1000MHz 20.0dB Min. at 140MHz 25.0dB Min. at 170~1100MHz 20.0dB Min. at 1200MHz 28.0dB Min. at 1125~1525MHZ mm T Specifications subject to change without notice. Please check our website for latest information. 1.50±0.30 Revised 2016/04/01 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SLFL18-2R450G-01TF 价格&库存
很抱歉,暂时无法提供与“SLFL18-2R450G-01TF”相匹配的价格&库存,您可以联系我们找货
