LM4007
LM4007
    MDD(辰达半导体)
    DO213AA
LM4007 数据手册
LM4001 THRU LM4007 SURFACE MOUNT RECTIFIERS REVERSE VOLTAGE: 50 - 1000 V CURRENT: 1.0 A FEATURES MiniMELF (DO-213AA) ◇ The plastic package carries Underwrites Laboratory ◇ Flammability classification 94V-0 ◇ For surface mounted application MECHANICAL DATA ◇ Case: MiniMELF(DO-213AA), molded plastic body ◇ Terminals: Lead solderable per MIL-STD-750, method 2026 ◇ Polarity: Color band denotes cathode end ◇ Mounting Position: Any Dimensions in millimeters MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase,half wave,60Hz,resistive or inductive load.For capactive load,derate current by 20%. MDD Catalog Number Maximum recurrent peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forword rectified current T A=75℃ VRRM VRMS VDC LM LM LM 4001 4002 4003 LM 4004 LM 4005 LM 4006 50 100 200 400 600 800 1000 35 70 140 280 420 560 700 50 100 200 400 600 800 1000 LM UNITS 4007 V V V I(AV) 1.0 A IFSM 25 A VF 1.1 V Peak forward surge current 8.3ms single half-sine-wave superimposed on rated load (JEDEC method) Maximum forward voltage at 1.0A Maximum DC reverse current @TA=25℃ at rated DC blockjing voltage @T A=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Typical thermal resistance (NOTE 3) Operating temperature range Storage temperature range 5.0 IR Cj RjθL RjθA Tj TSTG 50 15 75 30 - 65 --- + 175 - 65 --- + 175 NOTES:1. Measured at 1.0MHz and applied average voltage of 4.0V DC. 2. Thermal resistance junction to lead, 6.0 mm 2 coppeer pads to each terminal. 3. Thermal resistance junction to ambient, 6.0 mm 2 coppeer pads to each terminal. μA pF ℃/W ℃/W ℃ ℃ RATINGS AND CHARACTERISTIC CURVES LM4001 THRU LM4007 The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
LM4007 价格&库存
很抱歉,暂时无法提供与“LM4007”相匹配的价格&库存,您可以联系我们找货
